Hello NVIDIA Community,
I’m working on prototyping GPUDirect RDMA on a Jetson Xavier device and am seeking guidance on testing procedures and hardware requirements. I’ve looked into the NVIDIA jetson-rdma-picoevb repository, but it doesn’t clearly outline the hardware and software dependencies needed.
Current Setup:
- Software: Mellanox OFED is installed.
- Issue: Running
ibv_devinfoor RDMA examples results in “No IB devices found.” Firmware updates also indicate no devices found.
Questions:
- Hardware Requirement: Do I need to purchase and connect a Mellanox ConnectX NIC to the Jetson Xavier to run basic RDMA examples like
rc_pingpong? - PCIe RDMA Testing: Can I test PCIe-based RDMA between two Jetson devices without a ConnectX NIC?
- Resources: Are there any workflow/setup instructions available on the NVIDIA portal or elsewhere that detail the necessary steps for setting up GPUDirect RDMA on Jetson Xavier?
- Does Jetson Xavier supports both RoCE and PCIe based RDMA?
Any guidance or resources you could provide would be greatly appreciated.
Thank you!
