Trying to load a different video for the car detection demo on the TX2 but i get an error
I’m new to Jetson TX2 but im familiar with deep learning and I wanted to know if I am doing things the correct way.
I ran the sample for detecting cars in the video. I assume that training was done and everytime i loaded it, it was using cached data (weights/model etc) and would re run the demo quicker.
I assumed that now i could just swap the video file and see if it could detect cars in a different scene. I downloaded a CCTV footage video off the internet, saved it to 10fps, 1080p and mp4 using the h264 codec usign Adobe Premiere and I tried loading the video. However it gives me an error that it could not find some nal or EOF
Could anyone please help me with what codec etc i have to use? I create my content on a windows PC using adobe premiere. Here is my log, sample.mp4 is my new video i downloaded and saved. Thanks!
./backend 1 …/…/data/Video/sample.mp4 H264 --trt-deployfile …/…/data/Model/GoogleNet_one_class/GoogleNet_modified_oneClass_halfHD.prototxt --trt-modelfile …/…/data/Model/GoogleNet_one_class/GoogleNet_modified_oneClass_halfHD.caffemodel --trt-forcefp32 0 --trt-proc-interval 1 -fps 10
Net has batch_size, channel, net_height, net_width:1 3 540 960
Using cached TRT model
outputDim c 1 w 240 h 132
outputDimsBBOX.c() 4 w 240 h 132
Failed to query video capabilities: Inappropriate ioctl for device
NvMMLiteOpen : Block : BlockType = 261
TVMR: NvMMLiteTVMRDecBlockOpen: 7647: NvMMLiteBlockOpen
NvMMLiteBlockCreate : Block : BlockType = 261
Starting decoder capture loop thread
Could not read nal unit from file. EOF or file corrupted
Input file read complete
TVMR: NvMMLiteTVMRDecDoWork: 6531: NVMMLITE_TVMR: EOS detected
TVMR: TVMRBufferProcessing: 5486: Processing of EOS
TVMR: TVMRBufferProcessing: 5563: Processing of EOS Done
Hi LeMoth,
The input is h264 stream. You can use ffmpeg or Yamb http://yamb.unite-video.com/ to extract raw h264 from mp4.
hi DaneLLL
this worked thank you very much! However if I were to use this from a webcam stream, is there a library to decode the raw h264 in realtime?
thanks!
Hi LeMoth,
For using tegra_multimedia_api, you have to integrate by your self. Not sure but live555 should help your case.
http://www.live555.com/liveMedia/
Other users can share their experience.
You can also consider DeepStream SDK for Jetson
