Hi hope all goes well. For the purpose of an essay for the university, I am trying to regenerate the onnx that is provided by NVidia for fcn-resnet18-deepscene-576x320. The objective is to train the model with my own images, but I want first to make sure I can run the onnx I am generating before doing anything else.
(For your curiosity the essay is an evaluation of the Jetson Nano’s capacacity to run inference (semantic segmentation) in realtime with high resolution video. )
I can train and generate the onnx but it gives me the unfamous assertion Assertion failed: axis >= 0 && axis < nbDims. I understand that torch.view needs to be replaced by torch.flatten(). But I am using the code / models provided by NVidia, and checked that the fix is there (torch.view replaced by torch.flatten() ). But I still get the error
ERROR: onnx2trt_utils.hpp:347 In function convert_axis:
[8] Assertion failed: axis >= 0 && axis < nbDims
And I do not understand where I fail.
I already tried many many many many different things, and spent many hours on this … still no success.
I am so close to close the loop of my experience to go from training to onnx.
If someone has a slim idea or suggestion…
Another important thing : I am very limited in my environment. It’s either the Jetson nano, or a server provided by Compute Canada. No DIGITS.
And I am far from being an expert (today) with Pytorch, DeepLearning models and ONNX. I am a student.
Here are all the steps below I am following on a Compute Canada AI/ML server. I do not do that on the Jetson Nano. I tried to export to onnx a simple model on a docker with JetpPack 4.4, but the Jetson nano freezes. (https://pytorch.org/docs/stable/onnx.html; docker pull nvcr.io/nvidia/l4t-ml:r32.4.2-py3)
# These commands are run on a Compute Canada (server) instance
# move to the home directory
cd ~
# retrieve the deepscene freiburg_forest_multispectral_annotated (1.2Gb); really quick from compute canada (>13Mb/sec)
wget http://deepscene.cs.uni-freiburg.de/static/datasets/freiburg_forest_multispectral_annotated.tar.gz
# untar-zip the deepscene freiburg_forest_multispectral_annotated (1.2Gb) directly inside the home folder
tar xvf freiburg_forest_multispectral_annotated.tar.gz
module python/2.7 cuda/10.1 cudnn
# clean the python virtual env
rm -rf $SLURM_TMPDIR/env
# create the virtual env
virtualenv --no-download $SLURM_TMPDIR/env
# activate the python virtual env
source $SLURM_TMPDIR/env/bin/activate
# install requirements
pip install --no-index torch==1.3.0
pip install --no-index scikit-learn
pip install --no-index six
pip install --no-index pillow==6.1.0
pip install --no-index ~/Cython-0.29.17.tar.gz
pip install --no-index ~/pycocotools-2.0.0.tar.gz
# retrieve the fork for vision-0.3.0 from dusty-nv
cd ~
git clone https://github.com/dusty-nv/vision.git
# retrieve the code for training of semantic segmentation networks with PyTorch for jetson nano
cd ~
git clone https://github.com/dusty-nv/pytorch-segmentation.git
cd ~/vision-0.3.0-dusty-ng
rm -rf build/
python setup.py build install
# run torchvision test models
python test/test_models.py
# remap the deepscene images for the model
cd ~/pytorch-segmentation-master
python deepscene_remap.py ~/downloads/freiburg_forest_annotated/train/GT_color ~/downloads/freiburg_forest_annotated/train/GT_index
python deepscene_remap.py ~/downloads/freiburg_forest_annotated/test/GT_color ~/downloads/freiburg_forest_annotated/test/GT_index
# train
python train.py -a fcn_resnet18 --dataset deepscene --model-dir ./model_output --dist-url 'tcp://127.0.0.1:5556' /home/vincelf/downloads/freiburg_forest_annotated
# export to onnx
python onnx_export.py --input model_output/model_best.pth --output resnet18-vlf.onnx
# test the onnx with trtexec
trtexec --onnx=/home/vincelf/pytorch-segmentation-master/resnet18-vlf.onnx --explicitBatch --verbose
&&&& RUNNING TensorRT.trtexec # trtexec --onnx=/home/vincelf/pytorch-segmentation-master/resnet18-vlf.onnx --explicitBatch --verbose
[04/29/2020-23:09:32] [I] === Model Options ===
[04/29/2020-23:09:32] [I] Format: ONNX
[04/29/2020-23:09:32] [I] Model: /home/vincelf/pytorch-segmentation-master/resnet18-vlf.onnx
[04/29/2020-23:09:32] [I] Output:
[04/29/2020-23:09:32] [I] === Build Options ===
[04/29/2020-23:09:32] [I] Max batch: explicit
[04/29/2020-23:09:32] [I] Workspace: 16 MB
[04/29/2020-23:09:32] [I] minTiming: 1
[04/29/2020-23:09:32] [I] avgTiming: 8
[04/29/2020-23:09:32] [I] Precision: FP32
[04/29/2020-23:09:32] [I] Calibration:
[04/29/2020-23:09:32] [I] Safe mode: Disabled
[04/29/2020-23:09:32] [I] Save engine:
[04/29/2020-23:09:32] [I] Load engine:
[04/29/2020-23:09:32] [I] Inputs format: fp32:CHW
[04/29/2020-23:09:32] [I] Outputs format: fp32:CHW
[04/29/2020-23:09:32] [I] Input build shapes: model
[04/29/2020-23:09:32] [I] === System Options ===
[04/29/2020-23:09:32] [I] Device: 0
[04/29/2020-23:09:32] [I] DLACore:
[04/29/2020-23:09:32] [I] Plugins:
[04/29/2020-23:09:32] [I] === Inference Options ===
[04/29/2020-23:09:32] [I] Batch: Explicit
[04/29/2020-23:09:32] [I] Iterations: 10 (200 ms warm up)
[04/29/2020-23:09:32] [I] Duration: 10s
[04/29/2020-23:09:32] [I] Sleep time: 0ms
[04/29/2020-23:09:32] [I] Streams: 1
[04/29/2020-23:09:32] [I] Spin-wait: Disabled
[04/29/2020-23:09:32] [I] Multithreading: Enabled
[04/29/2020-23:09:32] [I] CUDA Graph: Disabled
[04/29/2020-23:09:32] [I] Skip inference: Disabled
[04/29/2020-23:09:32] [I] === Reporting Options ===
[04/29/2020-23:09:32] [I] Verbose: Enabled
[04/29/2020-23:09:32] [I] Averages: 10 inferences
[04/29/2020-23:09:32] [I] Percentile: 99
[04/29/2020-23:09:32] [I] Dump output: Disabled
[04/29/2020-23:09:32] [I] Profile: Disabled
[04/29/2020-23:09:32] [I] Export timing to JSON file:
[04/29/2020-23:09:32] [I] Export profile to JSON file:
[04/29/2020-23:09:32] [V] [TRT] Plugin Creator registration succeeded - GridAnchor_TRT
[04/29/2020-23:09:32] [V] [TRT] Plugin Creator registration succeeded - NMS_TRT
[04/29/2020-23:09:32] [V] [TRT] Plugin Creator registration succeeded - Reorg_TRT
[04/29/2020-23:09:32] [V] [TRT] Plugin Creator registration succeeded - Region_TRT
[04/29/2020-23:09:32] [V] [TRT] Plugin Creator registration succeeded - Clip_TRT
[04/29/2020-23:09:32] [V] [TRT] Plugin Creator registration succeeded - LReLU_TRT
[04/29/2020-23:09:32] [V] [TRT] Plugin Creator registration succeeded - PriorBox_TRT
[04/29/2020-23:09:32] [V] [TRT] Plugin Creator registration succeeded - Normalize_TRT
[04/29/2020-23:09:32] [V] [TRT] Plugin Creator registration succeeded - RPROI_TRT
[04/29/2020-23:09:32] [V] [TRT] Plugin Creator registration succeeded - BatchedNMS_TRT
[04/29/2020-23:09:32] [V] [TRT] Plugin Creator registration succeeded - FlattenConcat_TRT
Input filename: /home/vincelf/pytorch-segmentation-master/resnet18-vlf.onnx
ONNX IR version: 0.0.4
Opset version: 9
Producer name: pytorch
Producer version: 1.3
Domain:
Model version: 0
Doc string:
WARNING: ONNX model has a newer ir_version (0.0.4) than this parser was built against (0.0.3).
[04/29/2020-23:09:33] [V] [TRT] 129:Constant ->
[04/29/2020-23:09:33] [V] [TRT] 130:Shape -> (4)
WARNING: Your ONNX model has been generated with INT64 weights, while TensorRT does not natively support INT64. Attempting to cast down to INT32.
Successfully casted down to INT32.
While parsing node number 2 [Gather -> "131"]:
--- Begin node ---
input: "130"
input: "129"
output: "131"
op_type: "Gather"
attribute {
i: 0
type: INT
--- End node ---
[04/29/2020-23:09:33] [E] Failed to parse onnx file
[04/29/2020-23:09:33] [E] Parsing model failed
[04/29/2020-23:09:33] [E] Engine could not be created
&&&& FAILED TensorRT.trtexec # trtexec --onnx=/home/vincelf/pytorch-segmentation-master/resnet18-vlf.onnx --explicitBatch --verbose
