I followed this (Installing the NVIDIA Container Toolkit — NVIDIA Container Toolkit 1.14.5 documentation ) to use nvidia-container-runtime toolkit for containerd .
I ended up with this config.toml file:
[plugins]
[plugins."io.containerd.grpc.v1.cri"]
max_container_log_line_size = -1
sandbox_image = "k8s.gcr.io/pause:3.3"
[plugins."io.containerd.grpc.v1.cri".containerd]
default_runtime_name = "runc"
disable_snapshot_annotations = true
discard_unpacked_layers = false
ignore_blockio_not_enabled_errors = false
ignore_rdt_not_enabled_errors = false
no_pivot = false
snapshotter = "native"
[plugins."io.containerd.grpc.v1.cri".containerd.runtimes]
[plugins."io.containerd.grpc.v1.cri".containerd.runtimes.nvidia]
runtime_engine = ""
runtime_root = ""
runtime_type = "io.containerd.runc.v2"
[plugins."io.containerd.grpc.v1.cri".containerd.runtimes.nvidia.options]
BinaryName = "/usr/bin/nvidia-container-runtime"
systemdCgroup = true
[plugins."io.containerd.grpc.v1.cri".containerd.runtimes.runc]
runtime_engine = ""
runtime_root = ""
[plugins."io.containerd.grpc.v1.cri".containerd.runtimes.runc.options]
[plugins."io.containerd.grpc.v1.cri".registry]
[plugins."io.containerd.grpc.v1.cri".registry.mirrors]
[plugins."io.containerd.grpc.v1.cri".registry.mirrors."docker.io"]
endpoint = ["https://registry-1.docker.io"]
As you can see, eventhough it added the nvidia-container-runtime as a plugin, it did not set it as default which stood as runc.
Should I understand that I have to change it manually ?
