Two-Spark Cluster: tensor-parallel-size=2 causing Engine Initialization Failure with Qwen3-VL-30B (Ray + vLLM)
I am currently configuring multi-node inference using stacked DGX Spark systems following the official documentation:
https://build.nvidia.com/spark/vllm/stacked-sparks
The distributed cluster setup has been completed successfully and verified using:
docker exec $VLLM_CONTAINER ray status
Cluster Status
The cluster reports:
  • 2 active nodes
  • 0 pending / 0 failed nodes
Available resources:
CPU: 40
GPU: 2
Memory: 218.87 GiB
This indicates that Ray-level node registration and cluster connectivity are functioning correctly.
Environment Configuration
System: DGX Spark (2 stacked nodes)
CUDA Version: 13.0
NVIDIA Driver Version: 580.126.09
NCCL Version: 2.28.8
PyTorch Version: 2.10.0a0+b558c986e8.nv25.11
vLLM Version: 0.11.0+582e4e37.nv25.11
Container Base Image: nvcr.io/nvidia/vllm:25.11-py3
No custom NCCL environment variables (e.g. NCCL_SOCKET_IFNAME, NCCL_IB_DISABLE) have been configured.
Observed Issue
VLM Model – Engine Initialization Failure
Model: Qwen/Qwen3-VL-30B-A3B-Instruct
Test Results
Tensor Parallelism = 1
Model loads and runs inference successfully.
Tensor Parallelism = 2
Engine fails during initialization with the following error:
RuntimeError: Engine core initialization failed. See root cause above.
Failed core proc(s): {}
The failure occurs during engine startup before inference begins.
Question
Given that:
  • Ray cluster reports 2 GPUs across 2 nodes
  • Single-GPU inference works
  • Failure occurs only when tensor_parallel_size=2
Is there any additional configuration required for cross-node tensor parallelism when using stacked DGX Spark systems with vLLM?
Specifically:
  1. Are additional NCCL environment variables required for multi-node tensor parallelism?
  2. Does Qwen3-VL-30B-A3B currently support distributed tensor parallel across nodes in vLLM?
  3. Are there extra Ray or vLLM launch flags needed for multi-node VLM models?
Any guidance would be appreciated.
I highly recommend to use
instead.
The nvcr.io/nvidia/vllm:25.11-py3 image is quite old.
As for the vLLM arguments. I depends on the model. When you have a look on a model card at Hugging Face you will find usually the necessary minimum version of vLLM and/or SGLang and their options.
Qwen/Qwen3.5-35B-A3B · Hugging Face for example:
The following will create API endpoints at http://localhost:8000/v1:
  • Standard Version: The following command can be used to create an API endpoint with maximum context length 262,144 tokens using tensor parallel on 8 GPUs.
vllm serve Qwen/Qwen3.5-35B-A3B --port 8000 --tensor-parallel-size 8 --max-model-len 262144 --reasoning-parser qwen3
  • Tool Call: To support tool use, you can use the following command.
vllm serve Qwen/Qwen3.5-35B-A3B --port 8000 --tensor-parallel-size 8 --max-model-len 262144 --reasoning-parser qwen3 --enable-auto-tool-choice --tool-call-parser qwen3_coder
  • Multi-Token Prediction (MTP): The following command is recommended for MTP:
vllm serve Qwen/Qwen3.5-35B-A3B --port 8000 --tensor-parallel-size 8 --max-model-len 262144 --reasoning-parser qwen3 --speculative-config '{"method":"qwen3_next_mtp","num_speculative_tokens":2}'
  • Text-Only: The following command skips the vision encoder and multimodal profiling to free up memory for additional KV cache:
Also recommended:
There you will find recipes for eugrs toolkit.
And another option:
If you prefer to get the playbook example running.
The full log of vLLM would be nice. As the “root cause” is above this RuntimeError message.
Qwen3-VL-30B-A3B should support parallelism.
We recently released a new VLLM container, 26.02-py3. I recommend trying the new container. If you still run into the same issue. Please share with me the full VLLM log for more debugging.
@saptarshi2 I would also recommend reducing the allowed memory util to 0.5
I will try this and let you know
