Hi,All
We want clone TX1 whole flash for manufacture.
refer this URL http://elinux.org/Jetson/Cloning
I get TK1’s method :sudo ./nvflash --rawdeviceread 0 3849216 all.img --bl ardbeg/fastboot.bin --go
how about TX1 ,same to TK1 ?
thank u.
hello cambridge,
please try -G command to clone the image.
share steps and commands to clone rootfs as below.
Clone:
$ sudo ./flash.sh -r -k APP -G backup.img jetson-tx1 mmcblk0p1 -
Back up backup.img:
$ sudo mv backup.img <back_up_path>/ -
Flash backup.img to new board:
a. Place backup.img to under bootloader directory with name system.img
sudo ln -s <back_up_path>/backup.img bootloader/system.img b. Flash the cloned system image: sudo ./flash.sh -r -k APP jetson-tx1 mmcblk0p1
thanks for your reply,we will try.
Hi,JerryChang
There is one problem: ./flash.sh :illegal option --G
thank u.
hello cambridge,
sorry, you need to apply this patch to add clone(-G) feature.
https://devtalk.nvidia.com/default/topic/1000105/jetson-tx2/tx2-cloning/post/5111893/#5111893
please take a try, thanks
Hi,JerryChang
I got your reply.
but I have a doubt:
This cmd will clone APP partition only ? or whole flash(APP EBT …)
thank u.
hello cambridge,
yes, this command only clone the APP partition only
Hi,JerryChang
At the milestone of manufacture,emmc flash is a new IC(there is nothing in it).
If we flash only APP.img, the new board will boot normally ?
If not ,How we get the clone file of whole flash ?
thank u.
I know on the JTK1 it was possible to clone not only a particular partition, but there was also “all” (an alias?) possible. One of the TK1 options is to clone eMMC based on 4k byte block offsets, e.g., from “0” to whatever the max eMMC size is in 4k blocks. I’m kind of wondering if the JTX1 and 2 have an option to clone by eMMC byte offset as well…this would do the job for you if it is possible.
Hi,linuxdev
thanks for your note,
there is so little infomation about this.
we will try after get new flash IC.
