I used nfs to mount the root file system and had some problems.
steps are as follows:
- sudo apt-get install nfs-kernel-server
set the static IP address of host - Add rootfs path in “/etc/exports”:
/home/…/Linux_for_Tegra/rootfs *(rw,sync,no_subtree_check,no_root_squash) - sudo /etc/init.d/nfs-kernel-server restart
- Flash:
$ sudo ./flash.sh -N [host ip address]:/home/…/Linux_for_Tegra/rootfs jetson-xavier eth0
Target device information is displayed:
IP-Config : Retrying forever (NFS root) …
Then I re-specify the IP address of the target device
$ sudo ./flash.sh -N [host ip address]:/home/…/Linux_for_Tegra/rootfs [ -n target ip:host ip:gateway ip:netmask ] jetson-xavier eth0
But the result is the same as before.
I have a few questions that I’m not clear about
1.Power On the board and hit a key to stop the U-Boot from continuing, setenv commond not found.
Did NV change the Uboot so that only flash can be used to specify the IP address of tegra device?
