TX2 GPU and CPU use shared same memory space, programer also can use cudaMalloc to Global Memory, malloc to memory, cudaMemcpy to transform betewwn, whether there have new API to support for this shared memory architecture
Related topics
| TX2 GPU and CPU shared same memory space | 2 | 1455 | October 18, 2021 | |
| size of shrare memory between CPU and GPU | 7 | 1460 | October 18, 2021 | |
| Is the available global memory in TX2 less than TX1? | 6 | 1461 | October 18, 2021 | |
| The memory sharing between cpu and gpu in Jetson TX2 | 6 | 7436 | October 18, 2021 | |
| Jetson TX2 GPU memory? | 8 | 18702 | October 18, 2021 | |
| How many physical blocks can TX2 concurrently compute? | 3 | 501 | September 13, 2018 | |
| Memory for GPU so small? | 14 | 4785 | October 18, 2021 | |
| Is the memory management method of TX1 and TX2 different? | 0 | 531 | June 9, 2017 | |
| Unified memory | 5 | 1319 | October 18, 2021 | |
| CPU operation is very slow on memory allocated by cudaMallocHost | 13 | 1950 | October 18, 2021 |
