I’ve encountered the same problem as described in this thread.When I operate at a baud rate of 115200, he can only receive bytes that are multiples of 8, whilst his transmission shows no abnormalities.
https://forums.developer.nvidia.com/t/tx2-nx-uartc-receiving-exception/255198/8
Unfortunately, I haven’t seen how this issue was resolved in this thread.
Just to add, I am currently using a kernel with rt patches applied:Linux mr123-desktop 4.9.337-rt197 #137 SMP PREEMPT RT Tue Dec 30 10:21:21 CST 2025 aarch64 aarch64 aarch64 GNU/Linux
Hi huangliedouble,
Are you using the devkit or custom board for TX2 NX?
Please share the full dmesg and device tree configuration for further check.
My findings so far are as follows:
- I identified this issue on our custom board;
- I used a devkit to reproduce the issue and was successful;
- I ensured that the system version remained at 32.7.6 throughout.
tegra186-p3636-0001-p3509-0000-a01.zip (42.9 KB)
dmesg.txt (97.1 KB)
I have enabled the use of ttyTHS2 in the device tree:
serial@c280000 {
compatible = "nvidia,tegra186-hsuart";
status = "okay";
Thanks ~0603
Do you have custom design for UART on your custom carrier board?
[ 5.961711] c280000.serial: ttyTHS2 at MMIO 0xc280000 (irq = 34, base_baud = 0) is a TEGRA_UART
Are you using the debug UART port for custom use case?
