I developed a program on tx2 and xavier. The program utilizes gstreamer to decode rtsp stream. When stress testing the program, I found that there seems to be a lot of hw decoder thread leak. Everytime after processing a stream, 4 more threads remain alive after receiving eos signal. The output looks like:
nvidia@nvidia-desktop:~$ ps -Tp 8809
PID SPID TTY TIME CMD
8809 8809 pts/1 00:00:00 rtsp_mem
8809 8821 pts/1 00:00:00 rtsp_mem
8809 8822 pts/1 00:00:00 rtsp_mem
8809 8826 pts/1 00:00:00 dconf worker
8809 8827 pts/1 00:00:00 gmain
8809 8828 pts/1 00:00:00 gdbus
8809 8842 pts/1 00:00:00 NVMDecBufProcT
8809 8843 pts/1 00:00:00 NVMDecDisplayT
8809 8844 pts/1 00:00:00 NVMDecFrmStatsT
8809 8845 pts/1 00:00:00 NVMDecVPRFlrSzT
8809 8894 pts/1 00:00:00 NVMDecBufProcT
8809 8895 pts/1 00:00:00 NVMDecDisplayT
8809 8896 pts/1 00:00:00 NVMDecFrmStatsT
8809 8897 pts/1 00:00:00 NVMDecVPRFlrSzT
And after one or two days testing, my program will occupy a lot of memory. Please help me out.Is this a bug of the hw decoder? or there is bug in my code. My code is attached here:
rtsp_main.cpp:
#include <iostream>
#include <thread>
#include <chrono>
extern "C" {
int extract_rtsp(char* req_id, char* rtsp_url, int need_audio);
using namespace std;
int main(int argc, char** argv)
std::this_thread::sleep_for (std::chrono::seconds(30));
for(int i=0; i<2; i++){
cout << "loop " << i << endl;
extract_rtsp("test1", "rtsp://192.168.3.11/1", 1);
cout << "sleep_for 30s" << endl;
while(1)
// gcc -c rtsp_mem.c `pkg-config --cflags --libs gstreamer-1.0`
// g++ rtsp_main.cpp rtsp_mem.o -o rtsp_mem `pkg-config --cflags --libs gstreamer-1.0` -lgstapp-1.0
rtsp_mem.c
#include <gst/gst.h>
#include <gst/app/gstappsink.h>
#include <stdio.h>
#include <string.h>
#include <pthread.h>
#include <unistd.h>
/* Structure to contain all our information, so we can pass it to callbacks */
typedef struct _CustomData {
GstElement *pipeline;
GstElement *source;
GstElement *video_queue;
GstElement *video_depay;
GstElement *video_parse;
GstElement *video_decode;
GstElement *video_convert;
GstElement *video_filter;
GstCaps *video_filtercaps;
GstElement *video_rate;
GstElement *jpg_encode;
GstElement *video_sink;
GstElement *audio_queue;
GstElement *audio_depay;
GstElement *audio_parse;
GstElement *audio_decode;
GstElement *audio_convert;
GstElement *audio_resample;
GstElement *audio_filter;
GstCaps *audio_filtercaps;
GstElement *audio_sink;
GMainLoop *main_loop; /* GLib's Main Loop */
char* req_id;
int result;
int is_video_end;
int is_audio_end;
} CustomData;
GstFlowReturn video_new_preroll(GstAppSink *appsink, gpointer data)
g_print ("Got video preroll!\n");
return GST_FLOW_OK;
GstFlowReturn new_frame_sample(GstAppSink *appsink, gpointer data)
g_print("enter new_frame_sample.\n");
static int count = 0;
count++;
GstSample *sample = gst_app_sink_pull_sample(appsink);
GstCaps *caps = gst_sample_get_caps(sample);
GstBuffer *buffer = gst_sample_get_buffer(sample);
GstMapInfo map;
gst_buffer_map (buffer, &map, GST_MAP_READ);
CustomData *pData = (CustomData*)data;
if(pData->is_video_end == 0)
if(count%40 == 0)
gst_element_send_event(pData->pipeline, gst_event_new_eos());
if(pData->is_video_end && pData->is_audio_end)
gst_buffer_unmap(buffer, &map);
// g_print ("%s\n", gst_caps_to_string(caps));
gst_sample_unref (sample);
return GST_FLOW_OK;
/* This function will be called by the pad-added signal */
static void pad_added_handler (GstElement *src, GstPad *new_pad, CustomData *data)
GstPad *video_sink_pad = gst_element_get_static_pad (data->video_queue, "sink");
GstPad *audio_sink_pad = gst_element_get_static_pad (data->audio_queue, "sink");
GstPadLinkReturn ret;
GstCaps *new_pad_caps = NULL;
GstStructure *new_pad_struct = NULL;
const gchar *new_pad_type = NULL;
g_print ("Received new pad '%s' from '%s':\n", GST_PAD_NAME (new_pad), GST_ELEMENT_NAME (src));
/* Check the new pad's type */
new_pad_caps = gst_pad_get_current_caps (new_pad);
new_pad_struct = gst_caps_get_structure (new_pad_caps, 0);
new_pad_type = gst_structure_get_name (new_pad_struct);
if (!g_str_has_prefix (new_pad_type, "application/x-rtp"))
g_print ("It has type '%s' which is not raw audio. Ignoring.\n", new_pad_type);
goto exit;
/* If our converter is already linked, we have nothing to do here */
if (gst_pad_is_linked (audio_sink_pad))
g_print ("audio_sink is already linked. Ignoring.\n");
else
/* Attempt the link */
ret = gst_pad_link (new_pad, audio_sink_pad);
if (GST_PAD_LINK_FAILED (ret))
g_print ("Type is '%s' but link audio_sink failed.\n", new_pad_type);
else
g_print ("audio_sink Link succeeded (type '%s').\n", new_pad_type);
goto exit;
if (gst_pad_is_linked (video_sink_pad))
g_print ("video_sink is already linked. Ignoring.\n");
else
ret = gst_pad_link (new_pad, video_sink_pad);
g_print ("Type is '%s' but link video_sink failed.\n", new_pad_type);
else
g_print ("video_sink Link succeeded (type '%s').\n", new_pad_type);
goto exit;
exit:
/* Unreference the new pad's caps, if we got them */
if (new_pad_caps != NULL)
gst_caps_unref (new_pad_caps);
/* Unreference the sink pad */
gst_object_unref (video_sink_pad);
gst_object_unref (audio_sink_pad);
static void eos_cb (GstBus *bus, GstMessage *msg, CustomData *data)
g_print("received eos!!!\n");
g_main_loop_quit (data->main_loop);
static void error_cb (GstBus *bus, GstMessage *msg, CustomData *data)
GError *err;
gchar *debug_info;
/* Print error details on the screen */
gst_message_parse_error (msg, &err, &debug_info);
g_printerr ("Error received from element %s: %s\n", GST_OBJECT_NAME (msg->src), err->message);
g_printerr ("Debugging information: %s\n", debug_info ? debug_info : "none");
g_clear_error (&err);
g_free (debug_info);
//set the flag for false path
data->result = -1;
static gboolean element_cb(GstBus *bus, GstMessage *message, gpointer data)
printf("Got %s message\n", GST_MESSAGE_TYPE_NAME (message));
const GstStructure *s = gst_message_get_structure(message);
const char *filename = gst_structure_get_string(s, "filename");
// printf("filename:%s\n", filename);
if(!filename)return TRUE;
if(pData->is_audio_end == 0)
else
unlink(filename);
return TRUE;
CustomData data;
GstBus *bus;
GstStateChangeReturn ret;
static int temp = 0;
if(temp==0)
gst_init (NULL, NULL);
temp++;
printf("%s %s %d\n", req_id, rtsp_url, need_audio);
data.req_id = req_id;
data.result = 0;
data.is_video_end = 0;
data.is_audio_end = 0;
data.source = gst_element_factory_make ("rtspsrc", "source");
data.video_queue = gst_element_factory_make ("queue", "video_queue");
data.video_depay = gst_element_factory_make ("rtph264depay", "video_depay");
data.video_parse = gst_element_factory_make ("h264parse", "video_parse");
data.video_decode = gst_element_factory_make ("nvv4l2decoder", "video_decode");
data.video_convert = gst_element_factory_make ("nvvidconv", "video_convert");
data.video_filter = gst_element_factory_make ("capsfilter", "video_filter");
data.video_filtercaps = gst_caps_new_simple ("video/x-raw",/*"format", G_TYPE_STRING, "RGBA",*/
"width", G_TYPE_INT, 1920, "height", G_TYPE_INT, 1080, "framerate", GST_TYPE_FRACTION, 1, 1, NULL);
data.video_rate = gst_element_factory_make("videorate", "video_rate");
data.jpg_encode = gst_element_factory_make("nvjpegenc", "jpg_encode");
data.video_sink = gst_element_factory_make ("appsink", "video_sink");
data.audio_queue = gst_element_factory_make ("queue", "audio_queue");
data.audio_depay = gst_element_factory_make ("rtpmp4gdepay", "audio_depay");
data.audio_parse = gst_element_factory_make ("aacparse", "audio_parse");
data.audio_decode = gst_element_factory_make ("avdec_aac", "audio_decode");
data.audio_convert = gst_element_factory_make ("audioconvert", "audio_convert");
data.audio_resample = gst_element_factory_make("audioresample", "audio_resample");
data.audio_filter = gst_element_factory_make ("capsfilter", "audio_filter");
data.audio_filtercaps = gst_caps_new_simple ("audio/x-raw", "format", G_TYPE_STRING, "S16LE",
"rate", G_TYPE_INT, 16000, "channels", G_TYPE_INT, 1, NULL);
data.audio_sink = gst_element_factory_make ("multifilesink", "audio_sink");
/* Create the empty pipeline */
data.pipeline = gst_pipeline_new ("test-pipeline");
if (!data.pipeline || !data.source || !data.video_queue || !data.video_depay||
!data.video_parse||!data.video_decode || !data.video_convert ||
!data.video_filter || !data.video_rate || !data.video_sink || !data.audio_queue ||
!data.audio_depay || !data.audio_parse || !data.audio_decode ||
!data.audio_convert || !data.audio_filter || !data.audio_sink)
g_printerr ("Not all elements could be created.\n");
return -1;
g_object_set (G_OBJECT (data.audio_filter), "caps", data.audio_filtercaps, NULL);
// gst_caps_unref (data.audio_filtercaps);
/* Build the pipeline. Note that we are NOT linking the source at this point. We will do it later. */
gst_bin_add_many (GST_BIN (data.pipeline), data.source,data.video_queue ,data.video_depay,
data.video_parse,data.video_decode ,data.video_convert,data.video_rate,data.jpg_encode,data.video_sink,
data.audio_queue,data.audio_depay,data.audio_parse,data.audio_decode,data.audio_convert,data.audio_resample,data.audio_filter,data.audio_sink,NULL);
/*Link video pipeline*/
if (!gst_element_link_many (data.video_queue,data.video_depay,data.video_parse,data.video_decode,data.video_convert,data.video_rate,NULL))
g_printerr ("Video-elements could not be linked.\n");
gst_object_unref (data.pipeline);
return -1;
gst_element_link_filtered(data.video_rate, data.jpg_encode, data.video_filtercaps);
gst_caps_unref (data.video_filtercaps);
gst_element_link_many(data.jpg_encode, data.video_sink, NULL);
/*Link audio pipeline*/
if (!gst_element_link_many (data.audio_queue,data.audio_depay,data.audio_parse,data.audio_decode,data.audio_convert,data.audio_resample,data.audio_filter,NULL))
g_printerr ("Audio-elements could not be linked.\n");
return -1;
gst_element_link_filtered(data.audio_filter, data.audio_sink, data.audio_filtercaps);
g_object_set(data.source, "location", rtsp_url, NULL);
char segment_name[512] = {0};
strcat(segment_name, req_id);
strcat(segment_name, "_%06d.pcm");
g_object_set(data.audio_sink, "next-file", 5, "max-file-duration", 1000000000,
"location", segment_name, "post-messages", TRUE, "sync", TRUE, NULL);
g_signal_connect (data.source, "pad-added", G_CALLBACK (pad_added_handler), &data); /* Connect to the pad-added signal */
GstElement *sink = gst_bin_get_by_name (GST_BIN (data.pipeline), "video_sink"); /* get sink */
gst_app_sink_set_emit_signals((GstAppSink*)sink, TRUE);
gst_app_sink_set_drop((GstAppSink*)sink, TRUE);
gst_app_sink_set_max_buffers((GstAppSink*)sink, 1);
GstAppSinkCallbacks callbacks = { NULL, video_new_preroll, new_frame_sample };
gst_app_sink_set_callbacks (GST_APP_SINK(sink), &callbacks, &data, NULL);
/* Start playing */
ret = gst_element_set_state (data.pipeline, GST_STATE_PLAYING);
if (ret == GST_STATE_CHANGE_FAILURE)
g_printerr ("Unable to set the pipeline to the playing state.\n");
return -1;
/* Instruct the bus to emit signals for each received message, and connect to the interesting signals */
bus = gst_element_get_bus (data.pipeline);
gst_bus_add_signal_watch (bus);
g_signal_connect (G_OBJECT (bus), "message::error", (GCallback)error_cb, &data);
g_signal_connect (G_OBJECT (bus), "message::eos", (GCallback)eos_cb, &data);
g_signal_connect(G_OBJECT(bus), "message::element", (GCallback)element_cb, &data);
gst_object_unref (bus);
/* Create a GLib Main Loop and set it to run */
data.main_loop = g_main_loop_new (NULL, FALSE);
g_print("ready to run main loop.\n");
g_main_loop_run (data.main_loop);
gst_element_set_state (data.pipeline, GST_STATE_NULL);
g_print("leaving extract_rtsp.\n");
return data.result;
