I would like to deploy on a TX2 my freshly trained YoloV3, which I’ve trained using just a single class (the rest is YoloV3 standard ).
I’ve been converting the YoloV3 model to protobuffer as intermediate format to be able to pass it to the UFFParser.
However when I try to perform the conversion I have this error:
Error
File "/home/cesare/Projects/keras_to_tensorflow/test.py", line 16, in <module>
parser.register_output(output_names)
TypeError: in method 'UffParser_register_output', argument 2 of type 'char const *'
Code
# Import TensorRT Modules
import tensorrt as trt
import uff
from tensorrt.parsers import uffparser
output_names = ['output_node0', 'output_node1', 'output_node2']
G_LOGGER = trt.infer.ConsoleLogger(trt.infer.LogSeverity.INFO)
# Load your newly created Tensorflow frozen model and convert it to UFF
uff_model = uff.from_tensorflow_frozen_model("yolov3-detect.pb", output_names)
# Create a UFF parser to parse the UFF file created from your TF Frozen model
parser = uffparser.create_uff_parser()
parser.register_input("input", (640,352,3),0)
Stdout
/usr/bin/python3.5 /home/cesare/Projects/keras_to_tensorflow/test.py
Using output node output_node0
Using output node output_node1
Using output node output_node2
Converting to UFF graph
Warning: No conversion function registered for layer: Identity yet.
Converting as custom op Identity output_node2
op: "Identity"
input: "conv2d_75/BiasAdd"
attr {
key: "T"
value {
type: DT_FLOAT
Warning: No conversion function registered for layer: Pad yet.
Converting as custom op Pad zero_padding2d_3/Pad
op: "Pad"
input: "add_3/add"
input: "zero_padding2d_3/Pad/paddings"
attr {
key: "T"
value {
type: DT_FLOAT
attr {
key: "Tpaddings"
value {
type: DT_INT32
Converting as custom op Pad zero_padding2d_2/Pad
op: "Pad"
input: "add_1/add"
input: "zero_padding2d_2/Pad/paddings"
attr {
key: "T"
value {
type: DT_FLOAT
attr {
key: "Tpaddings"
value {
type: DT_INT32
Converting as custom op Pad zero_padding2d_1/Pad
op: "Pad"
input: "leaky_re_lu_1/LeakyRelu/Maximum"
input: "zero_padding2d_1/Pad/paddings"
attr {
key: "T"
value {
type: DT_FLOAT
attr {
key: "Tpaddings"
value {
type: DT_INT32
Warning: No conversion function registered for layer: ResizeNearestNeighbor yet.
Converting as custom op ResizeNearestNeighbor up_sampling2d_2/ResizeNearestNeighbor
op: "ResizeNearestNeighbor"
input: "leaky_re_lu_66/LeakyRelu/Maximum"
input: "up_sampling2d_2/mul"
attr {
key: "T"
value {
type: DT_FLOAT
attr {
key: "align_corners"
value {
b: false
Converting as custom op Pad zero_padding2d_4/Pad
op: "Pad"
input: "add_11/add"
input: "zero_padding2d_4/Pad/paddings"
attr {
key: "T"
value {
type: DT_FLOAT
attr {
key: "Tpaddings"
value {
type: DT_INT32
Converting as custom op ResizeNearestNeighbor up_sampling2d_1/ResizeNearestNeighbor
input: "leaky_re_lu_59/LeakyRelu/Maximum"
input: "up_sampling2d_1/mul"
attr {
key: "T"
value {
type: DT_FLOAT
attr {
value {
b: false
Converting as custom op Pad zero_padding2d_5/Pad
op: "Pad"
input: "add_19/add"
input: "zero_padding2d_5/Pad/paddings"
attr {
key: "T"
value {
type: DT_FLOAT
attr {
key: "Tpaddings"
value {
type: DT_INT32
Converting as custom op Identity output_node1
op: "Identity"
input: "conv2d_67/BiasAdd"
attr {
key: "T"
value {
type: DT_FLOAT
Converting as custom op Identity output_node0
op: "Identity"
input: "conv2d_59/BiasAdd"
attr {
key: "T"
value {
type: DT_FLOAT
No. nodes: 1294
Process finished with exit code 1
Any clue ? Do you need additional debug ?
