My machine has NVIDIA Quadro K2200 graphic card with GPU.
I installed Ubuntu 18.04 and nvidia-390.48 as well as CUDA 9.0 (I use Cuda 9.0 because higher versions are not working with keras and tensor-flow).
Anyhow, cuda, keras, and tensorflow all work fine. However, Ubuntu is not detecting the second monitor which is connected through DisplayPort while the first one is connected through DVI port.
Here is the output of nvidia-smi:
| NVIDIA-SMI 390.48 Driver Version: 390.48 |
| 0 Quadro K2200 Off | 00000000:03:00.0 On | N/A |
| 42% 33C P8 1W / 39W | 185MiB / 4035MiB | 0% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 924 G /usr/lib/xorg/Xorg 99MiB |
| 0 1390 G /usr/bin/gnome-shell 73MiB |
| 0 1918 G /usr/lib/firefox/firefox 1MiB |
| 0 1991 G /usr/lib/firefox/firefox 1MiB |
| 0 2148 G /usr/lib/firefox/firefox 1MiB |
and here is the output of xrandr:
Screen 0: minimum 8 x 8, current 1920 x 1080, maximum 16384 x 16384
DVI-I-0 disconnected (normal left inverted right x axis y axis)
DVI-I-1 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 531mm x 298mm
1920x1080 60.00*+
1280x1024 75.02 60.02
1152x864 75.00
1024x768 75.03 60.00
800x600 75.00 60.32
640x480 75.00 59.94
DP-0 disconnected (normal left inverted right x axis y axis)
DP-1 disconnected (normal left inverted right x axis y axis)
DP-2 disconnected (normal left inverted right x axis y axis)
DP-3 disconnected (normal left inverted right x axis y axis)
and here is the content of my xorg.conf file:
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig: version 390.48 (buildmeister@swio-display-x86-rhel47-07) Thu Mar 22 01:07:32 PDT 2018
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0"
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
EndSection
Section "Files"
EndSection
Section "InputDevice"
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Unknown"
ModelName "Unknown"
HorizSync 28.0 - 33.0
VertRefresh 43.0 - 72.0
Option "DPMS"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
EndSection
Section "Files"
ModulePath "/usr/local/cuda/lib64/"
ModulePath "/usr/lib/xorg/modules"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
SubSection "Display"
Depth 24
EndSubSection
EndSection
