The version of gcc-linaro-7.3.1 provided is behaving strangely on my host Ubuntu 18.04 workstation. I’ve probably done something very silly, but I can’t see what. The files are extracted, they are in user path, they have mode 755, and they show up in bash completion, but when I try to execute any tool, even with ./somebinhere I get
bash: ./aarch64-linux-gnu-foo: No such file or directory
instead of
foo: fatal error: no input files
[user@hostname] -- [~/Dev/nano/l4t-gcc/gcc-linaro-7.3.1-2018.05-i686_aarch64-linux-gnu/bin]
$ ls
aarch64-linux-gnu-addr2line aarch64-linux-gnu-cpp aarch64-linux-gnu-gcc-7.3.1 aarch64-linux-gnu-gcov-dump aarch64-linux-gnu-ld aarch64-linux-gnu-objdump aarch64-linux-gnu-strip
aarch64-linux-gnu-ar aarch64-linux-gnu-dwp aarch64-linux-gnu-gcc-ar aarch64-linux-gnu-gcov-tool aarch64-linux-gnu-ld.bfd aarch64-linux-gnu-ranlib
aarch64-linux-gnu-as aarch64-linux-gnu-elfedit aarch64-linux-gnu-gcc-nm aarch64-linux-gnu-gdb aarch64-linux-gnu-ld.gold aarch64-linux-gnu-readelf
aarch64-linux-gnu-c++ aarch64-linux-gnu-g++ aarch64-linux-gnu-gcc-ranlib aarch64-linux-gnu-gfortran aarch64-linux-gnu-nm aarch64-linux-gnu-size
aarch64-linux-gnu-c++filt aarch64-linux-gnu-gcc aarch64-linux-gnu-gcov aarch64-linux-gnu-gprof aarch64-linux-gnu-objcopy aarch64-linux-gnu-strings
$ ./aarch64-linux-gnu-gcc
bash: ./aarch64-linux-gnu-gcc: No such file or directory
$ gcc
gcc: fatal error: no input files
compilation terminated.
Any ideas would be very much appreciated.
