Hi lads, since the last nvidia update my second external display [via Display Port] connected to my laptop stopped working most of the time. Sometimes after reconnecting it will pop up for a while and then turns black again. The first external display via HDMI works fine. I crosschecked everything [display/cables] but i can’t figure it out.
I tried everything i could find in several forums, here are some outputs of my terminal:
xrandr:
Screen 0: minimum 8 x 8, current 5760 x 1080, maximum 16384 x 16384
VGA-0 disconnected (normal left inverted right x axis y axis)
HDMI-0 connected 1920x1080+1920+0 (normal left inverted right x axis y axis) 521mm x 293mm
1920x1080 60.00*+ 59.94 50.00
1680x1050 59.95
1600x900 60.00
1440x900 59.89
1280x1024 60.02
1280x800 59.81
1280x720 60.00 59.94 50.00
1024x768 70.07 60.00
800x600 72.19 60.32 56.25
720x576 50.00
720x480 59.94
640x480 72.81 59.94
DP-0 connected primary 1920x1080+3840+0 (normal left inverted right x axis y axis) 344mm x 194mm
1920x1080 60.02*+ 47.99
DP-1 disconnected (normal left inverted right x axis y axis)
DP-2 connected 1920x1080+0+0 (normal left inverted right x axis y axis) 521mm x 293mm
1680x1050 59.95
1600x900 60.00
1440x900 59.89
1280x1024 60.02
1280x800 59.81
720x576 50.00
720x480 59.94
640x480 72.81 59.94
DP-3 disconnected (normal left inverted right x axis y axis)
DP-4 disconnected (normal left inverted right x axis y axis)
prime-select nvidia:
Info: the nvidia profile is already set
rm /etc/modprobe.d/blacklist-nvidia.conf /lib/modprobe.d/blacklist-nvidia.conf:
rm: cannot remove ‘/etc/modprobe.d/blacklist-nvidia.conf’ : No such file or directory
rm: cannot remove ‘/lib/modprobe.d/blacklist-nvidia.conf’ : No such file or directory
nvidia-smi:
Thu Feb 18 09:37:47 2021
| NVIDIA-SMI 460.32.03 Driver Version: 460.32.03 CUDA Version: 11.2 |
| | | MIG M. |
| 0 GeForce GTX 970M Off | 00000000:01:00.0 On | N/A |
| N/A 56C P0 20W / N/A | 442MiB / 6082MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 1178 G /usr/lib/xorg/Xorg 80MiB |
| 0 N/A N/A 1880 G /usr/lib/xorg/Xorg 183MiB |
| 0 N/A N/A 2020 G /usr/bin/gnome-shell 165MiB |
lsb_release -a:
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 20.04.2 LTS
Release: 20.04
Codename: focal
And my log file:
nvidia-bug-report.log.compressed (569.1 KB)
Thanks a lot for help, this is driving me nuts.
