UEFI Secure Boot remains in Standard Mode and does not enforce signature verification after enabling custom keys
Description:
I have enabled UEFI Secure Boot on my Jetson Xavier platform and successfully provisioned my own PK, KEK, and db keys using the `fflash.sh --uefi-keys option.
The system boots normally, and efivar shows that SecureBoot is enabled (Value: 01) and SetupMode is disabled (`Value:Value: 00).
However, the firmware still reports “Secure Boot Mode: Standard Mode” and “WARNING: Test Key detected” in the UEFI log.
Even when booting unsigned images (not si
Additionally, the UEFI setup menu does not allow switching from Standard Mode to Custom Mode.
The option appears grCustom Mode.
Steps to Reproduce:
  1. Generate PK, KEK, and db keys using OpenSSL.
  2. Create uefi_keys.conf and flash using:
    sudo ./flash.sh --uefi-keys uefi_keys/uefi_keys.conf <target> mmcblk0p1
  3. Boot the device and verify Secure Boot status:
    efivar -n 8be4df61-93ca-11d2-aa0d-00e098032b8c-SecureBoot
    efivar -n 8be4df61-93ca-11d2-aa0d-00e098032b8c-SetupMode
    efi-readvar
  4. Secure Boot is Enabled, Setup Mode is Disabled, and custom PK/KEK/db certificates appear correctly.
  5. Attempt to boot with unsigned boot.img or kernel — system still boots successfully.
  6. UEFI setup menu shows Secure Boot Mode <Standard Mode> and the warning:
    ** WARNING: Test key detected **
Expected Behavior:
After provisioning custom PK/KEK/db keys and switching out of Setup Mode, the firmware should enter Custom Mode and enforce signature verification — booting should fail for unsigned or untrusted images.
Actual Behavior:
  • Secure Boot remains in Standard Mode.
  • Warning “Test key detected” appears even with custom keys.
  • Unsigned images still boot successfully (no verification failure).
  • Cannot manually switch to Custom Mode in the UEFI configuration interface.
Additional Information:
  • Platform: Jetson Xavier
  • JetPack / L4T version: (e.g., JetPack 5.1.3)
  • Flash command used:
  • Verified efivars:
    SecureBoot = 01
    SetupMode = 00
  • PK, KEK, and db entries visible under /sys/firmware/efi/efivars/
This is log debug :
admin@tegra-ubuntu:~$ sudo mokutil --sb-state
SecureBoot enabled
admin@tegra-ubuntu:~$ sudo efi-readvar
Variable PK, length 837
PK: List 0, type X509
Signature 0, size 809, owner 9f8d71f3-106e-4764-93df-dc425301f36b
Subject:
CN=my Platform Key
Issuer:
CN=my Platform Key
Variable KEK, length 845
KEK: List 0, type X509
Signature 0, size 817, owner e122486c-daa3-4f28-8529-6e0ef334eba8
Subject:
CN=my Key Exchange Key
Issuer:
Variable db, length 1730
db: List 0, type X509
Signature 0, size 829, owner b523ef53-bb0a-4856-9302-4f214be45f99
Subject:
CN=my Signature Database key
Issuer:
db: List 1, type X509
Signature 0, size 845, owner 54d5aa02-1184-4cfd-948e-63ae51bf324e
Subject:
CN=my another Signature Database key
Issuer:
Variable dbx has no entries
Variable MokList has no entries
admin@tegra-ubuntu:~$ sudo hexdump -C /sys/firmware/efi/efivars/SetupMode-*
00000000 06 00 00 00 00 |…|
00000005
admin@tegra-ubuntu:~$ sudo hexdump -C /sys/firmware/efi/efivars/SecureBoot-*
00000000 06 00 00 00 01 |…|
00000005
hello tuan100220,
it does not check/verify the signature if OemKeyValid and SecurityMode are not burned.
please see-also Topic 337248 for reference.
I want to test UEFI Secure Boot on Xavier NX. To modify or set the OemKeyValid and SecurityMode flags, do I have to burn the eFuses, or is there a way to adjust them temporarily for testing without permanently writing to fuses?
hello tuan100220,
that’s not possible, fuse burning operations are high-risk because they cannot be reversed.
Thank you, I understand the issue now. I will look into how to burn the eFuses.
hello tuan100220,
please refer to developer guide for the SecureBoot chapter.
BTW, you may see-also Topic 158361 for the steps we’ve fused/flashed Xavier NX developer kit, although it’s tested on JetPack-4.4
yes. thanks
