Reboots a few times, then tries PXE and finally enters a UEFI shell when everything else fails.
If I do not use the –uefi-keys option, it boots “fine”, but appears to not find the extlinux.conf, and picks things from individual partitions (by what it says).
The “Test key is used” is printed in all cases (good and bad boot)… seems suspicious.
What could be wrong? Let m e know if you need more information.
Jetson UEFI firmware (version 6.2-40633251 built on 2025-05-16T01:35:20+00:00)
ESC to enter Setup.
F11 to enter Boot Manager Menu.
Enter to continue boot.
** WARNING: Test Key is used. **
��I/TC: Reserved shared memory is disabled
I/TC: Dynamic shared memory is enabled
I/TC: Normal World virtualization support is disabled
I/TC: Asynchronous notifications are disabled
��L4TLauncher: Attempting Direct Boot
OpenAndReadUntrustedFileToBuffer: Failed to open boot\extlinux\extlinux.conf: No
t Found
ProcessExtLinuxConfig:sds Failed to Authenticate boot\extlinux\extlinux.conf (No
t Found)
L4TLauncher: Unable to process extlinux config: Not Found
L4TLauncher: Attempting Kernel Boot
��E/TA: decrypt_image:99 TEE_InvokeTACommand failed with res = 0xffff0006
E/TA: decrypt_image:99 TEE_InvokeTACommand failed with res = 0xffff0007
��ReadEncryptedImage: Failed to read data from partition
OpteeDecryptImage: Failed to read data
ReadAndroidStyleKernelPartition: OpteeDecryptImage failed
Failed to boot kernel:0 partition
����Shutdown state requested 1
Rebooting system ...
I have read the Topic you linked, but it seems different in many ways… I am not using options -u or -v, or --uefi-enc, and my keys are not generated with -rand option.
I use only –uedfi-keys, with the idea to get all binaries signed, to see if the extlinux.conf is then found by L4TLauncher, as without any –uefi-keys, nothing is signed, and the extlinux.conf is not found… although the jAX boots fine.
Tried using all keys as 0s, and the FV as in the example.sh
It makes no difference for –uefi-keys only… same messages and everything.
Tried adding the –uefi-enc with the sym_t194.key (all 0s) as in the eks_t195.img generated, and I get similar behaviour, but a bit different:
ESC to enter Setup.
t Found
t Found)
Header not seen
Let me know how do you want all those keys set up, and what tests do you want me to do.
please double check you’re updating EKS image correctly.
you’ll need to replace the new created image with $OUT/Linux_for_Tegra/bootloader/eks_t194.img for image flashing.
ESC to enter Setup.
t Found
t Found)
EFI stub: Booting Linux Kernel...
EFI stub: UEFI Secure Boot is enabled.
EFI stub: Using DTB from configuration table
EFI stub: Loaded initrd from LINUX_EFI_INITRD_MEDIA_GUID device path
EFI stub: Exiting boot services and installing virtual address map...
��I/TC: Secondary CPU 1 initializing
I/TC: Secondary CPU 1 switching to normal world boot
I/TC: Secondary CPU 2 initializing
I/TC: Secondary CPU 2 switching to normal world boot
I/TC: Secondary CPU 3 initializing
I/TC: Secondary CPU 3 switching to normal world boot
I/TC: Secondary CPU 4 initializing
I/TC: Secondary CPU 4 switching to normal world boot
I/TC: Secondary CPU 5 initializing
I/TC: Secondary CPU 5 switching to normal world boot
I/TC: Secondary CPU 6 initializing
I/TC: Secondary CPU 6 switching to normal world boot
I/TC: Secondary CPU 7 initializing
I/TC: Secondary CPU 7 switching to normal world boot
��[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x4e0f0040]
[ 0.000000] Linux version 5.10.216-tegra (david.fernandez@df-laptop) (aarch64-linux-gcc.br_real (Buildroot 2020.08) 9.3.0, GNU ld (GNU Binutils) 2.33.1) #1 SMP PREEMPT Thu Aug 28 20:19:36 BST 2025
[ 0.000000] Machine model: Jetson-AGX
[ 0.000000] efi: EFI v2.70 by EDK II
[ 0.000000] efi: RTPROP=0x875e71b98 SMBIOS=0xc7bb0000 SMBIOS 3.0=0x87b730000 MEMATTR=0x8759cd018 ESRT=0x8759cf018 RNG=0x869c30018 MEMRESERVE=0x86a5a8f18
[ 0.000000] random: crng init done
I take, when using proper keys burned into fuses, we should generate them all, including sym_t194.key, and modify optee to have it?
