If I remove disk encryption '-i 'and --user_key <key_file> that used to encrypt user images, such as kernel, kernel-dtb and initrd. I can boot but I can see the same issue in LOG eks bad parametter.
If I remove only disk encrytion but keep --user_key valid EKS is mandatory and I cant boot with EKS issue bad parametter too !!!
It is not possible to boot with bad EKS reading and user_key enabled ???
▒▒NOTICE: BL31: v2.6(release):07eea4970
NOTICE: BL31: Built : 07:55:15, Mar 19 2023
I/TC:
I/TC: Non-secure external DT found
I/TC: OP-TEE version: 3.19 (gcc version 9.3.0 (Buildroot 2020.08)) #2 Sun Mar 19 15:02:42 UTC 2023 aarch64
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
I/TC: Primary CPU initializing
E/TC:0 0 ekb_extraction_process:227 Bad parameter: eks image not correct
E/TC:0 0 jetson_user_key_pta_init:801 jetson_user_key_pta_init: Failed (ffff0006).
E/TC:0 0 call_initcalls:43 Initcall __text_start + 0x000c3240 failed
I/TC: Primary CPU switching to normal world boot
[0003.416] I> Welcome to NVDisp-Init
[0003.416] I> NVDisp-Init version: t194-709c0123
[0003.416] I> CPU-BL Params @ 0xca020000
[0003.417] I> 0) Base:0x00000000 Size:0x00000000
[0003.417] I> 1) Base:0xc8100000 Size:0x00100000
[0003.417] I> 2) Base:0xc9800000 Size:0x00200000
[0003.418] I> 3) Base:0xc8600000 Size:0x00200000
[0003.420] I> 4) Base:0xc8000000 Size:0x00100000
[0003.425] I> 5) Base:0xc7f00000 Size:0x00100000
[0003.429] I> 6) Base:0xc9400000 Size:0x00400000
[0003.434] I> 7) Base:0xc9000000 Size:0x00400000
[0003.438] I> 8) Base:0xc7e00000 Size:0x00100000
[0003.443] I> 9) Base:0xc7d00000 Size:0x00100000
[0003.447] I> 10) Base:0xca800000 Size:0x00800000
[0003.452] I> 11) Base:0x40000000 Size:0x00040000
[0003.456] I> 12) Base:0xc7c00000 Size:0x00100000
[0003.460] I> 13) Base:0x40046000 Size:0x00002000
[0003.465] I> 14) Base:0x40048000 Size:0x00002000
[0003.469] I> 15) Base:0xaf000000 Size:0x00004000
[0003.474] I> 16) Base:0x4004a000 Size:0x00002000
[0003.478] I> 17) Base:0xc7a00000 Size:0x00100000
[0003.483] I> 18) Base:0x4004c000 Size:0x00002000
[0003.487] I> 19) Base:0xc9a00000 Size:0x00600000
[0003.492] I> 20) Base:0x4004e000 Size:0x00002000
[0003.496] I> 21) Base:0xc7bc0000 Size:0x0000c000
[0003.501] I> 22) Base:0x00000000 Size:0x00000000
[0003.505] I> 23) Base:0xc7be0000 Size:0x00020000
[0003.510] I> 24) Base:0xcc000000 Size:0x02000000
[0003.514] I> 25) Base:0x40050000 Size:0x00002000
[0003.518] I> 26) Base:0x40040000 Size:0x00006000
[0003.523] I> 27) Base:0xc8c00000 Size:0x00400000
[0003.527] I> 28) Base:0xc8400000 Size:0x00200000
[0003.532] I> 29) Base:0xc8800000 Size:0x00400000
[0003.536] I> 30) Base:0xc7bd0000 Size:0x00010000
[0003.541] I> 31) Base:0x00000000 Size:0x00000000
[0003.545] I> 32) Base:0xf8000000 Size:0x08000000
[0003.550] I> 33) Base:0xce000000 Size:0x2a000000
[0003.554] I> 34) Base:0xcb000000 Size:0x01000000
[0003.559] I> 35) Base:0xae000000 Size:0x01000000
[0003.563] I> 36) Base:0xa0000000 Size:0x0e000000
[0003.568] I> 37) Base:0xca000000 Size:0x00800000
[0003.572] I> 38) Base:0x80000000 Size:0x20000000
[0003.576] I> 39) Base:0xb0000000 Size:0x08000000
[0003.581] I> 40) Base:0x00000000 Size:0x00000000
[0003.585] I> 41) Base:0x00000000 Size:0x00000000
[0003.590] I> 42) Base:0xc8200000 Size:0x00200000
[0003.594] I> 43) Base:0x00000000 Size:0x00000000
[0003.599] I> 44) Base:0x00000000 Size:0x00000000
[0003.603] I> 45) Base:0x00000000 Size:0x00000000
[0003.608] GIC-SPI Target CPU: 0
[0003.611] Interrupts Init done
[0003.614] calling constructors
[0003.616] initializing heap
[0003.619] I> Heap: [0xa0960000 ... 0xadf00000]
[0003.623] initializing threads
[0003.626] initializing timers
[0003.629] creating bootstrap completion thread
[0003.633] top of bootstrap2()
[0003.636] CPU: MIDR: 0x4E0F0040, MPIDR: 0x80000000
[0003.641] initializing platform
[0003.644] E> DEVICE_PROD: Invalid value data = 0, size = 0.
[0003.649] W> device prod register failed
[0003.653] I> Bl_dtb @0xadf00000
[0003.656] I> gpio framework initialized
[0003.669] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio' driver
[0003.674] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio-aon' driver
[0003.678] I> fixed regulator driver initialized
[0003.699] I> register 'maxim' power off handle
[0003.701] I> virtual i2c enabled
[0003.702] I> registered 'maxim,max20024' pmic
[0003.702] I> tegrabl_gpio_driver_register: register 'max20024-gpio' driver
[0003.702] I> Boot-device: QSPI
[0003.703] I> Boot_device: QSPI_FLASH instance: 0
[0003.705] I> configure_qspi_clk: qparams clk_src = 5, clk_div = 0, clk_src_freq = 800000000, interface_freq = 50000000
[0003.715] I> configure_qspi_clk: FORCING INTERFACE_FREQ TO 133000000!!
[0003.722] I> QSPI source rate = 204000 Khz
[0003.726] I> Requested rate for QSPI clock = 34000 Khz
[0003.731] I> BPMP-set rate for QSPI clk = 34000 Khz
[0003.736] I> tx_clk_tap_delay : 0
[0003.738] I> rx_clk_tap_delay : 16
[0003.742] I> QSPI Flash Size = 32 MB
[0003.750] I> Qspi initialized successfully
[0003.750] I> qspi flash-0 params source = boot args
[0003.754] W> No board IDs available
[0003.757] E> Failed to get board id info!
[0003.763] I> sdmmc-3 params source = safe params
[0003.770] I> Found 41 partitions in QSPI_FLASH (instance 0)
[0003.771] W> Cannot find any partition table for 00000003
[0003.776] E> Failed to publish 00000003
[0003.781] I> Found 22 partitions in SDMMC_USER (instance 3)
[0003.801] I> regulator 'vdd-hdmi-5v0' already enabled
[0003.806] I> regulator 'vdd-hdmi-5v0' already enabled
[0003.806] I> hdmi cable connected
[0003.811] W> set volts not configured for 'vdd-1v0'
[0003.816] W> set volts not configured for 'vdd-1v8-hs'
[0003.817] I> retrieved tmds range from prod_list_hdmi_soc
[0003.818] E> cannot find any other nvdisp nodes
[0003.834] I> edid read success
[0003.847] I> edid read success
[0003.847] I> width = 640, height = 480, frequency = 25174825
[0003.848] I> width = 640, height = 480, frequency = 25174825
[0003.848] I> width = 1024, height = 768, frequency = 65000000
[0003.849] I> width = 1024, height = 768, frequency = 65000000
[0003.852] I> width = 1024, height = 768, frequency = 65000000
[0003.858] I> width = 1920, height = 1080, frequency = 148500000
[0003.864] I> width = 1280, height = 720, frequency = 74250000
[0003.869] I> width = 640, height = 480, frequency = 25174825
[0003.875] I> width = 720, height = 480, frequency = 26973026
[0003.880] I> width = 1280, height = 720, frequency = 74175824
[0003.886] I> width = 1280, height = 720, frequency = 74175824
[0003.892] I> width = 1920, height = 1080, frequency = 148351648
[0003.897] I> width = 1920, height = 1080, frequency = 148351648
[0003.903] I> Best mode Width = 1920, Height = 1080, freq = 148351648
[0003.914] I> hdmi_enable, starting HDMI initialisation
[0003.919] I> hdmi_enable, HDMI initialisation complete
[0003.928] initializing target
[0003.929] calling apps_init()
[0003.930] starting app kernel_boot_app
[0003.931] I> Kernel type = Normal
Jetson UEFI firmware (version 3.1-32827747 built on 2023-03-19T14:56:32+00:00)
** WARNING: Test Key is used. **
EnrollFromDefaultKeysApp: Cannot enroll dbt: Not Found
EnrollFromDefaultKeysApp: Cannot enroll dbx: Not Found
L4TLauncher: Attempting Direct Boot
EFI stub: Booting Linux Kernel...
EFI stub: UEFI Secure Boot is enabled.
EFI stub: Using DTB from configuration table
EFI stub: Loaded initrd from LINUX_EFI_INITRD_MEDIA_GUID device path
EFI stub: Exiting boot services and installing virtual address map...
▒▒I/TC: Secondary CPU 1 initializing
I/TC: Secondary CPU 1 switching to normal world boot
I/TC: Secondary CPU 2 initializing
I/TC: Secondary CPU 2 switching to normal world boot
I/TC: Secondary CPU 3 initializing
I/TC: Secondary CPU 3 switching to normal world boot
I/TC: Secondary CPU 4 initializing
I/TC: Secondary CPU 4 switching to normal world boot
I/TC: Secondary CPU 5 initializing
I/TC: Secondary CPU 5 switching to normal world boot
▒▒[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x4e0f0040]
[ 0.000000] Linux version 5.10.104-tegra (root@swdev33) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2020.08) 9.3.0, GNU ld (GNU Binutils) 2.33.1) #1 SMP PREEMPT Tue Mar 28 14:20:22 EDT 2023
[ 0.000000] Machine model: NVIDIA Jetson Xavier NX Developer Kit
[ 0.000000] efi: EFI v2.70 by EDK II
[ 0.000000] efi: RTPROP=0x259d6eb18 SMBIOS=0xc7bb0000 SMBIOS 3.0=0x2589d0000 MEMATTR=0x25914a018 ESRT=0x259181118 RNG=0x27c54f398 MEMRESERVE=0x25914bf18
[ 0.000000] efi: seeding entropy pool
[ 0.000000] esrt: Reserving ESRT space from 0x0000000259181118 to 0x0000000259181150.
[ 0.000000] OF: fdt: Reserved memory: failed to reserve memory for node 'fb1_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt: Reserved memory: failed to reserve memory for node 'fb2_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt: Reserved memory: failed to reserve memory for node 'fb3_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x000000027fffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x00000000a0973fff]
[ 0.000000] node 0: [mem 0x00000000a0974000-0x00000000a0975fff]
[ 0.000000] node 0: [mem 0x00000000a0977000-0x00000000aeffffff]
[ 0.000000] node 0: [mem 0x00000000af010000-0x00000000c79fffff]
[ 0.000000] node 0: [mem 0x00000000c7b00000-0x00000000c7b9ffff]
[ 0.000000] node 0: [mem 0x00000000c7ba0000-0x00000000c7bbffff]
[ 0.000000] node 0: [mem 0x00000000ca000000-0x00000000ca7fffff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x0000000257bdffff]
[ 0.000000] node 0: [mem 0x0000000257be0000-0x000000025844ffff]
[ 0.000000] node 0: [mem 0x0000000258450000-0x000000025852efff]
[ 0.000000] node 0: [mem 0x000000025852f000-0x00000002586b6fff]
[ 0.000000] node 0: [mem 0x00000002586b7000-0x00000002589bffff]
[ 0.000000] node 0: [mem 0x00000002589c0000-0x00000002589dffff]
[ 0.000000] node 0: [mem 0x00000002589e0000-0x0000000258c5ffff]
[ 0.000000] node 0: [mem 0x0000000258c60000-0x0000000258caffff]
[ 0.000000] node 0: [mem 0x0000000258cb0000-0x000000025908ffff]
[ 0.000000] node 0: [mem 0x0000000259090000-0x00000002590dffff]
[ 0.000000] node 0: [mem 0x00000002590e0000-0x00000002590effff]
[ 0.000000] node 0: [mem 0x00000002590f0000-0x000000025911ffff]
[ 0.000000] node 0: [mem 0x0000000259120000-0x000000025915ffff]
[ 0.000000] node 0: [mem 0x0000000259160000-0x000000025917ffff]
[ 0.000000] node 0: [mem 0x0000000259180000-0x000000025925ffff]
[ 0.000000] node 0: [mem 0x0000000259260000-0x00000002592fffff]
[ 0.000000] node 0: [mem 0x0000000259300000-0x00000002593bffff]
[ 0.000000] node 0: [mem 0x00000002593c0000-0x00000002597cffff]
[ 0.000000] node 0: [mem 0x00000002597d0000-0x000000025981ffff]
[ 0.000000] node 0: [mem 0x0000000259820000-0x000000025986ffff]
[ 0.000000] node 0: [mem 0x0000000259870000-0x0000000259d3ffff]
[ 0.000000] node 0: [mem 0x0000000259d40000-0x0000000259d4ffff]
[ 0.000000] node 0: [mem 0x0000000259d50000-0x0000000259ecffff]
[ 0.000000] node 0: [mem 0x0000000259ed0000-0x0000000259f6ffff]
[ 0.000000] node 0: [mem 0x0000000259f70000-0x000000025a06ffff]
[ 0.000000] node 0: [mem 0x000000025a070000-0x000000025a10ffff]
[ 0.000000] node 0: [mem 0x000000025a110000-0x000000025a1bffff]
[ 0.000000] node 0: [mem 0x000000025a1c0000-0x000000025a25ffff]
[ 0.000000] node 0: [mem 0x000000025a260000-0x000000025ab6ffff]
[ 0.000000] node 0: [mem 0x000000025ab70000-0x000000025ad4ffff]
[ 0.000000] node 0: [mem 0x000000025ad50000-0x000000027c4fffff]
[ 0.000000] node 0: [mem 0x000000027c500000-0x000000027c54ffff]
[ 0.000000] node 0: [mem 0x000000027c550000-0x000000027fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x000000027fffffff]
[ 0.000000] On node 0, zone DMA: 1 pages in unavailable ranges
[ 0.000000] cma: Reserved 64 MiB at 0x00000000c3800000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 32 pages/cpu s90200 r8192 d32680 u131072
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: Virtualization Host Extensions
[ 0.000000] CPU features: kernel page table isolation forced ON by KASLR
[ 0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[ 0.000000] CPU features: detected: Spectre-v2
[ 0.000000] CPU features: detected: NVIDIA Carmel CNP erratum
[ 0.000000] alternatives: patching kernel code
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1839268
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 video=efifb:off
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x00000000b3800000-0x00000000c3800000] (256MB)
[ 0.000000] Memory: 6934996K/7473852K available (18112K kernel code, 3170K rwdata, 7140K rodata, 3968K init, 1108K bss, 473320K reserved, 65536K cma-reserved)
[ 0.000000] random: get_random_u64 called from __kmem_cache_create+0x34/0x420 with crng_init=0
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000023] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.000683] Console: colour dummy device 80x25
[ 0.002109] printk: console [tty0] enabled
[ 0.002168] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[ 0.002200] pid_max: default: 32768 minimum: 301
[ 0.002346] LSM: Security Framework initializing
[ 0.002398] Yama: becoming mindful.
[ 0.002437] SELinux: Initializing.
[ 0.002569] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.002604] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.005677] rcu: Hierarchical SRCU implementation.
[ 0.005921] dyndbg: Ignore empty _ddebug table in a CONFIG_DYNAMIC_DEBUG_CORE build
[ 0.006604] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-5.10/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t19x/jakku/kernel-dts/tegra194-p3668-0001-p3509-0000.dts
[ 0.006669] DTB Build time: Mar 19 2023 08:08:44
[ 0.009418] Tegra Revision: A02 SKU: 0xde CPU Process: 0 SoC Process: 0
[ 0.009668] Remapping and enabling EFI services.
[ 0.011431] smp: Bringing up secondary CPUs ...
[ 0.040582] Detected PIPT I-cache on CPU1
[ 0.040680] CPU1: Booted secondary processor 0x0000000001 [0x4e0f0040]
[ 0.071239] Detected PIPT I-cache on CPU2
[ 0.071335] CPU2: Booted secondary processor 0x0000000100 [0x4e0f0040]
[ 0.100776] Detected PIPT I-cache on CPU3
[ 0.100861] CPU3: Booted secondary processor 0x0000000101 [0x4e0f0040]
[ 0.130417] Detected PIPT I-cache on CPU4
[ 0.130558] CPU4: Booted secondary processor 0x0000000200 [0x4e0f0040]
[ 0.160076] Detected PIPT I-cache on CPU5
[ 0.160219] CPU5: Booted secondary processor 0x0000000201 [0x4e0f0040]
[ 0.160500] smp: Brought up 1 node, 6 CPUs
[ 0.160862] SMP: Total of 6 processors activated.
[ 0.160953] CPU features: detected: Privileged Access Never
[ 0.160986] CPU features: detected: LSE atomic instructions
[ 0.161008] CPU features: detected: User Access Override
[ 0.161030] CPU features: detected: 32-bit EL0 Support
[ 0.161050] CPU features: detected: RAS Extension Support
[ 0.161070] CPU features: detected: CRC32 instructions
[ 0.161091] CPU features: detected: 32-bit EL1 Support
[ 0.234862] CPU: All CPU(s) started at EL2
[ 0.240880] devtmpfs: initialized
[ 0.282693] Registered cp15_barrier emulation handler
[ 0.282828] Registered setend emulation handler
[ 0.282861] KASLR enabled
[ 0.283116] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.283157] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[ 0.284515] pinctrl core: initialized pinctrl subsystem
[ 0.285508] SMBIOS 3.0.0 present.
[ 0.285542] DMI: Unknown NVIDIA Jetson Xavier NX Developer Kit/NVIDIA Jetson Xavier NX Developer Kit, BIOS 3.1-32827747 03/19/2023
[ 0.286177] NET: Registered protocol family 16
[ 0.287910] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[ 0.288431] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.289129] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.289192] audit: initializing netlink subsys (disabled)
[ 0.289464] audit: type=2000 audit(0.284:1): state=initialized audit_enabled=0 res=1
[ 0.289862] thermal_sys: Registered thermal governor 'step_wise'
[ 0.289868] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.289937] thermal_sys: Registered thermal governor 'pid_thermal_gov'
[ 0.292037] cpuidle: using governor menu
[ 0.292430] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.292808] ASID allocator initialised with 32768 entries
[ 0.293034] Serial: AMBA PL011 UART driver
[ 0.295858] Tegra reboot handler registered.
[ 0.363025] mc: mapped MMIO address: 0xffff800010580000 -> 0x2c10000
[ 0.363080] mc: mapped MMIO address: 0xffff8000105a0000 -> 0x2c20000
[ 0.363118] mc: mapped MMIO address: 0xffff8000105c0000 -> 0x2c30000
[ 0.363154] mc: mapped MMIO address: 0xffff8000105e0000 -> 0x2c40000
[ 0.363192] mc: mapped MMIO address: 0xffff800010600000 -> 0x2c50000
[ 0.363228] mc: mapped MMIO address: 0xffff800010620000 -> 0x2b80000
[ 0.363267] mc: mapped MMIO address: 0xffff800010640000 -> 0x2b90000
[ 0.363302] mc: mapped MMIO address: 0xffff800010660000 -> 0x2ba0000
[ 0.363336] mc: mapped MMIO address: 0xffff800010680000 -> 0x2bb0000
[ 0.363370] mc: mapped MMIO address: 0xffff8000106a0000 -> 0x1700000
[ 0.363405] mc: mapped MMIO address: 0xffff8000106c0000 -> 0x1710000
[ 0.363439] mc: mapped MMIO address: 0xffff8000106e0000 -> 0x1720000
[ 0.363473] mc: mapped MMIO address: 0xffff800010700000 -> 0x1730000
[ 0.363508] mc: mapped MMIO address: 0xffff800010720000 -> 0x1740000
[ 0.363542] mc: mapped MMIO address: 0xffff800010740000 -> 0x1750000
[ 0.363586] mc: mapped MMIO address: 0xffff800010760000 -> 0x1760000
[ 0.363622] mc: mapped MMIO address: 0xffff800010780000 -> 0x1770000
[ 0.363715] mc-err: mcerr ops are set to t19x
[ 0.377093] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.377132] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.377161] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.377186] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.384009] ACPI: Interpreter disabled.
[ 0.385130] vdd-epb-1v0: supplied by vdd-3v3-cvb
[ 0.386328] iommu: Default domain type: Translated
[ 0.386405] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.386782] SCSI subsystem initialized
[ 0.386947] usbcore: registered new interface driver usbfs
[ 0.386994] usbcore: registered new interface driver hub
[ 0.387039] usbcore: registered new device driver usb
[ 0.387431] mc: Linux media interface: v0.10
[ 0.387475] videodev: Linux video capture interface: v2.00
[ 0.387751] pps_core: LinuxPPS API ver. 1 registered
[ 0.387774] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.387809] PTP clock support registered
[ 0.388010] tegra_wdt_t18x 30c0000.watchdog: Expiry count is deprecated
[ 0.388343] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[ 0.388434] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 0.388992] Registered efivars operations
[ 0.394490] FPGA manager framework
[ 0.394577] Advanced Linux Sound Architecture Driver Initialized.
[ 0.395191] Bluetooth: Core ver 2.22
[ 0.395235] NET: Registered protocol family 31
[ 0.395253] Bluetooth: HCI device and connection manager initialized
[ 0.395279] Bluetooth: HCI socket layer initialized
[ 0.395301] Bluetooth: L2CAP socket layer initialized
[ 0.395330] Bluetooth: SCO socket layer initialized
[ 0.397839] camchar: rtcpu character device driver loaded
[ 0.398949] clocksource: Switched to clocksource arch_sys_counter
[ 0.799234] VFS: Disk quotas dquot_6.6.0
[ 0.799334] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.799817] pnp: PnP ACPI: disabled
[ 0.814128] la/ptsa driver initialized.
[ 0.814280] NET: Registered protocol family 2
[ 0.814504] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.822101] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
[ 0.822323] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.822697] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 0.823422] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.823607] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 0.823784] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 0.824049] NET: Registered protocol family 1
[ 0.824792] RPC: Registered named UNIX socket transport module.
[ 0.824838] RPC: Registered udp transport module.
[ 0.824863] RPC: Registered tcp transport module.
[ 0.824888] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.824927] PCI: CLS 0 bytes, default 64
[ 0.825244] Trying to unpack rootfs image as initramfs...
[ 1.107957] Freeing initrd memory: 9120K
[ 1.113447] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 1.113822] kvm [1]: IPA Size Limit: 40 bits
[ 1.114366] kvm [1]: vgic interrupt IRQ9
[ 1.114868] kvm [1]: VHE mode initialized successfully
[ 1.116650] Initialise system trusted keyrings
[ 1.117009] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[ 1.123309] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.124057] NFS: Registering the id_resolver key type
[ 1.124094] Key type id_resolver registered
[ 1.124107] Key type id_legacy registered
[ 1.124192] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 1.124242] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 1.124282] ntfs: driver 2.1.32 [Flags: R/W].
[ 1.134792] NET: Registered protocol family 38
[ 1.134813] Key type asymmetric registered
[ 1.134828] Asymmetric key parser 'x509' registered
[ 1.134881] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 1.135142] io scheduler mq-deadline registered
[ 1.135159] io scheduler kyber registered
[ 1.141213] tegra186-dpaux-pinctrl 155f0000.dpaux: can not get clock
[ 1.144427] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 1.144537] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 1.144639] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 1.144736] tegra-pwm 32d0000.pwm: PWM clk can sleep in ops
[ 1.144812] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 1.150786] scrncapt: init (heads:4 wins:6 planes:4)
[ 1.151091] tegradccommon 15200000.display-hub: Nvhost Channel map failed
[ 1.151984] EINJ: ACPI disabled.
[ 1.155234] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 1.155258] tegra-pmc: ### PMC reset source: MAINSWRST
[ 1.155272] tegra-pmc: ### PMC reset level: L1
[ 1.155313] tegra-pmc: ### PMC reset status reg: 0x2d
[ 1.155360] tegra-pmc: PMC Prod config success
[ 1.160241] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 1.174568] random: fast init done
[ 1.175679] printk: console [ttyTCU0] enabled
[ 2.654379] arm-smmu 10000000.iommu: probing hardware configuration...
[ 2.658998] arm-smmu 10000000.iommu: SMMUv2 with:
[ 2.663605] arm-smmu 10000000.iommu: stage 1 translation
[ 2.669270] arm-smmu 10000000.iommu: stage 2 translation
[ 2.674514] arm-smmu 10000000.iommu: nested translation
[ 2.680111] arm-smmu 10000000.iommu: stream matching with 128 register groups
[ 2.687285] arm-smmu 10000000.iommu: 64 context banks (0 stage-2 only)
[ 2.697664] arm-smmu 10000000.iommu: Supported page sizes: 0x00001000
[ 2.700147] arm-smmu 10000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 2.706965] arm-smmu 10000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 2.714451] arm-smmu 12000000.iommu: probing hardware configuration...
[ 2.719751] arm-smmu 12000000.iommu: SMMUv2 with:
[ 2.724471] arm-smmu 12000000.iommu: stage 1 translation
[ 2.730249] arm-smmu 12000000.iommu: stage 2 translation
[ 2.735671] arm-smmu 12000000.iommu: nested translation
[ 2.740835] arm-smmu 12000000.iommu: stream matching with 128 register groups
[ 2.748017] arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 2.758297] arm-smmu 12000000.iommu: Supported page sizes: 0x00001000
[ 2.761392] arm-smmu 12000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 2.767696] arm-smmu 12000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 2.775589] arm-smmu-suspend 12000000.smmu_suspend: arm_smmu_suspend probe successful
[ 2.785221] tegra_profiler: version: 1.150, samples/io: 50/29
[ 2.788125] tegra_profiler: auth: init
[ 2.792483] THERMAL EST: found 3 subdevs
[ 2.796049] THERMAL EST num_resources: 0
[ 2.799661] [THERMAL EST subdev 0]
[ 2.803215] [THERMAL EST subdev 1]
[ 2.806353] [THERMAL EST subdev 2]
[ 2.809871] THERMAL EST: Found 2 profiles, default profile is quiet
[ 2.816290] THERMAL EST: thz register success.
[ 2.820311] THERMAL EST: end of probe, return err: 0
[ 2.825877] nvsciipc: loaded module
[ 2.832865] tun: Universal TUN/TAP device driver, 1.6
[ 2.835219] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[ 2.841369] hns3: Copyright (c) 2017 Huawei Corporation.
[ 2.846962] e1000e: Intel(R) PRO/1000 Network Driver
[ 2.852130] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 2.857945] igb: Intel(R) Gigabit Ethernet Network Driver
[ 2.863502] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 2.869634] PPP generic driver version 2.4.2
[ 2.873915] PPP BSD Compression module registered
[ 2.878483] PPP Deflate Compression module registered
[ 2.883759] PPP MPPE Compression module registered
[ 2.888484] usbcore: registered new interface driver r8152
[ 2.894252] usbcore: registered new interface driver asix
[ 2.899320] usbcore: registered new interface driver ax88179_178a
[ 2.905446] usbcore: registered new interface driver cdc_ether
[ 2.911691] usbcore: registered new interface driver net1080
[ 2.916997] usbcore: registered new interface driver cdc_subset
[ 2.923290] usbcore: registered new interface driver zaurus
[ 2.929019] usbcore: registered new interface driver cdc_ncm
[ 2.934665] usbcore: registered new interface driver aqc111
[ 2.940102] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 2.946128] ohci-pci: OHCI PCI platform driver
[ 2.950704] ohci-platform: OHCI generic platform driver
[ 2.956360] tegra-xusb 3610000.xhci: Adding to iommu group 0
[ 2.962855] usbcore: registered new interface driver uas
[ 2.967069] usbcore: registered new interface driver usb-storage
[ 2.972875] tegra-xudc 3550000.xudc: Adding to iommu group 1
[ 2.979086] mousedev: PS/2 mouse device common for all mice
[ 2.984126] usbcore: registered new interface driver xpad
[ 2.991888] tegra_rtc c2a0000.rtc: registered as rtc1
[ 2.994848] tegra_rtc c2a0000.rtc: setting system clock to 1970-01-01T00:00:27 UTC (27)
[ 3.002665] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 3.009246] i2c /dev entries driver
[ 3.012281] tegra-i2c 3160000.i2c: Adding to iommu group 2
[ 3.018245] tegra-i2c c240000.i2c: Adding to iommu group 2
[ 3.023653] tegra-i2c 3180000.i2c: Adding to iommu group 2
[ 3.028807] tegra-i2c 3190000.i2c: Adding to iommu group 2
[ 3.034107] tegra-i2c 31b0000.i2c: Adding to iommu group 2
[ 3.039669] tegra-i2c 31c0000.i2c: Adding to iommu group 2
[ 3.045342] tegra-i2c c250000.i2c: Adding to iommu group 2
[ 3.058270] tegra-oc-event d280000.soctherm-oc-event: OC driver initialized
[ 3.059049] device-mapper: uevent: version 1.0.3
[ 3.062180] device-mapper: ioctl: 4.43.0-ioctl (2020-10-01) initialised: dm-devel@redhat.com
[ 3.072679] cpuidle: Initializing cpuidle driver
[ 3.076462] sdhci: Secure Digital Host Controller Interface driver
[ 3.080962] sdhci: Copyright(c) Pierre Ossman
[ 3.085411] Synopsys Designware Multimedia Card Interface Driver
[ 3.091620] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.097560] sdhci-tegra 3460000.sdhci: Adding to iommu group 3
[ 3.098361] SMCCC: SOC_ID: ID = jep106:036b:0019 Revision = 0x00000102
[ 3.111113] tegra-bpmp bpmp: firmware: 128431eec76692047e1ac1ebc0392266
[ 3.133330] max77620 4-003c: PMIC Version OTP:0x51 and ES:0x1
[ 3.143383] vdd-1v0: supplied by regulator-dummy
[ 3.148824] vdd-1v8-hs: supplied by regulator-dummy
[ 3.153627] vdd-1v8-ls: supplied by regulator-dummy
[ 3.158395] vdd-1v8-ao: supplied by regulator-dummy
[ 3.162272] vddio-ddr-1v1: supplied by regulator-dummy
[ 3.167013] vdd-rtc: supplied by regulator-dummy
[ 3.169015] spmic-ldo1: supplied by regulator-dummy
[ 3.170643] vdd-ao-3v3: supplied by regulator-dummy
[ 3.177218] vddio-emmc-3v3: supplied by regulator-dummy
[ 3.183813] spmic-ldo4: supplied by regulator-dummy
[ 3.185310] vdd-usb-3v3: supplied by regulator-dummy
[ 3.191764] vddio-sdmmc1-3v3: supplied by regulator-dummy
[ 3.198180] vdd-csi-1v2: supplied by vdd-1v8-ls
[ 3.204303] spmic-ldo8: supplied by vdd-1v8-ls
[ 3.206258] gpio-510 (gpio_default): hogged as output/high
[ 3.208273] gpio-511 (gpio_default): hogged as output/high
[ 3.211096] gpiochip0: registered GPIOs 504 to 511 on max77620-gpio
[ 3.346545] max77686-rtc max77620-rtc: registered as rtc0
[ 3.347590] max77620-power max20024-power: Event recorder REG_NVERC : 0x80
[ 3.347923] max77620 4-003c: max77620 probe successful
[ 3.470552] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 3.471711] hid: raw HID events driver (C) Jiri Kosina
[ 3.472538] usbcore: registered new interface driver usbhid
[ 3.472688] usbhid: USB HID core driver
[ 3.474817] tegra186-cam-rtcpu bc00000.rtcpu: Adding to iommu group 4
[ 3.476088] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
▒▒[ 27.769849] Camera-FW on t194-rce-safe started
TCU early console enabled.
[ 27.844154] Camera-FW on t194-rce-safe ready SHA1=26f9e5f7 (crt 0.775 ms, total boot 75.110 ms)
▒▒[ 3.560314] tegra-ivc-bus bc00000.rtcpu:ivc-bus: region 0: iova=0xbfec0000-0xbfee01ff size=131584
[ 3.560736] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 3.561660] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: dbg: ver=0 grp=1 RX[1x448]=0x1900-0x1b40 TX[1x448]=0x1b40-0x1d80
[ 3.562374] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d80-0x3e00 TX[1x8192]=0x3e00-0x5e80
[ 3.564338] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e80-0xaf00 TX[64x320]=0xaf00-0xff80
[ 3.565018] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff80-0x18000 TX[512x64]=0x18000-0x20080
[ 3.565543] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: diag: ver=0 grp=1 RX[1x64]=0x20080-0x20140 TX[1x64]=0x20140-0x20200
[ 3.566915] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (48)
[ 3.567270] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[ 3.569814] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=6 sha1=26f9e5f7dc48f7914a7654904022cf8ae53e1e9f
[ 3.576966] tegra_aon c1a0000.aon: Adding to iommu group 5
[ 3.582869] tegra_aon c1a0000.aon: tegra aon driver probe OK
[ 3.588239] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 3.594594] denver_knobs_init:MTS_VERSION:55637613
[ 3.606678] t19x_cache tegra-cache: probed
[ 3.609632] optee: probing for conduit method.
[ 3.610447] optee: revision 3.19 (3f29c61f)
[ 3.611525] optee: dynamic shared memory is enabled
[ 3.615746] optee: initialized driver
[ 3.621413] nvpmodel: initialized successfully
[ 3.623032] tegra_hv: get_hvd: not initialized yet
[ 3.627656] user_ivc_mempool: hypervisor not present
[ 3.633089] usbcore: registered new interface driver snd-usb-audio
[ 3.640093] u32 classifier
[ 3.641432] input device check on
[ 3.645245] Actions configured
[ 3.648522] Initializing XFRM netlink socket
[ 3.653439] NET: Registered protocol family 10
[ 3.659794] Segment Routing with IPv6
[ 3.661031] NET: Registered protocol family 17
[ 3.665050] NET: Registered protocol family 15
[ 3.669723] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 3.683451] Bluetooth: RFCOMM socket layer initialized
[ 3.687755] Bluetooth: RFCOMM ver 1.11
[ 3.691928] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 3.697536] Bluetooth: HIDP socket layer initialized
[ 3.703547] 9pnet: Installing 9P2000 support
[ 3.707177] Key type dns_resolver registered
[ 3.712292] registered taskstats version 1
[ 3.715377] Loading compiled-in X.509 certificates
[ 3.753846] Loaded X.509 cert 'Build time autogenerated kernel key: abbb12ace44f7a1aef75190aed9faf7e7ae98700'
[ 3.755653] tegra194-pcie 14160000.pcie: Adding to iommu group 6
[ 3.760791] tegra194-pcie 14160000.pcie: host bridge /pcie@14160000 ranges:
[ 3.761176] tegra194-pcie 14160000.pcie: IO 0x0036100000..0x00361fffff -> 0x0036100000
[ 3.761538] tegra194-pcie 14160000.pcie: MEM 0x1400000000..0x173fffffff -> 0x1400000000
[ 3.761885] tegra194-pcie 14160000.pcie: MEM 0x1740000000..0x17ffffffff -> 0x0040000000
[ 4.875565] tegra194-pcie 14160000.pcie: Phy link never came up
[ 4.876203] tegra194-pcie 14160000.pcie: PCI host bridge to bus 0004:00
[ 4.876393] pci_bus 0004:00: root bus resource [bus 00-ff]
[ 4.876639] pci_bus 0004:00: root bus resource [io 0x0000-0xfffff] (bus address [0x36100000-0x361fffff])
[ 4.877134] pci_bus 0004:00: root bus resource [mem 0x1400000000-0x173fffffff pref]
[ 4.877297] pci_bus 0004:00: root bus resource [mem 0x1740000000-0x17ffffffff] (bus address [0x40000000-0xffffffff])
[ 4.877879] pci 0004:00:00.0: [10de:1ad1] type 01 class 0x060400
[ 4.878340] pci 0004:00:00.0: PME# supported from D0 D3hot D3cold
[ 4.900097] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[ 4.900550] pci 0004:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 4.902515] pcieport 0004:00:00.0: Adding to iommu group 6
[ 4.904114] pcieport 0004:00:00.0: PME: Signaling with IRQ 24
[ 4.905467] pcieport 0004:00:00.0: AER: enabled with IRQ 24
[ 4.907051] pci_bus 0004:01: busn_res: [bus 01-ff] is released
[ 4.908230] pci 0004:00:00.0: Removing from iommu group 6
[ 4.908705] pci_bus 0004:00: busn_res: [bus 00-ff] is released
[ 4.912553] tegra194-pcie 141a0000.pcie: Adding to iommu group 7
[ 4.918300] tegra194-pcie 141a0000.pcie: host bridge /pcie@141a0000 ranges:
[ 4.918736] tegra194-pcie 141a0000.pcie: IO 0x003a100000..0x003a1fffff -> 0x003a100000
[ 4.919190] tegra194-pcie 141a0000.pcie: MEM 0x1c00000000..0x1f3fffffff -> 0x1c00000000
[ 4.920842] tegra194-pcie 141a0000.pcie: MEM 0x1f40000000..0x1fffffffff -> 0x0040000000
[ 6.035704] tegra194-pcie 141a0000.pcie: Phy link never came up
[ 6.036543] tegra194-pcie 141a0000.pcie: PCI host bridge to bus 0005:00
[ 6.036773] pci_bus 0005:00: root bus resource [bus 00-ff]
[ 6.036982] pci_bus 0005:00: root bus resource [io 0x100000-0x1fffff] (bus address [0x3a100000-0x3a1fffff])
[ 6.037311] pci_bus 0005:00: root bus resource [mem 0x1c00000000-0x1f3fffffff pref]
[ 6.037546] pci_bus 0005:00: root bus resource [mem 0x1f40000000-0x1fffffffff] (bus address [0x40000000-0xffffffff])
[ 6.037946] pci 0005:00:00.0: [10de:1ad0] type 01 class 0x060400
[ 6.038360] pci 0005:00:00.0: PME# supported from D0 D3hot D3cold
[ 6.055245] pci 0005:00:00.0: PCI bridge to [bus 01-ff]
[ 6.055819] pci 0005:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 6.057651] pcieport 0005:00:00.0: Adding to iommu group 7
[ 6.059188] pcieport 0005:00:00.0: PME: Signaling with IRQ 26
[ 6.060701] pcieport 0005:00:00.0: AER: enabled with IRQ 26
[ 6.061882] pci_bus 0005:01: busn_res: [bus 01-ff] is released
[ 6.062664] pci 0005:00:00.0: Removing from iommu group 7
[ 6.062926] pci_bus 0005:00: busn_res: [bus 00-ff] is released
[ 6.098497] host1x 13e10000.host1x: Adding to iommu group 8
[ 6.122358] host1x 13e10000.host1x: initialized
[ 6.124203] iommu_context_dev 13e10000.host1x:ctx0: Adding to iommu group 9
[ 6.125036] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56, iommu=smmu.0x0000000012000000)
[ 6.126260] iommu_context_dev 13e10000.host1x:ctx1: Adding to iommu group 10
[ 6.126829] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57, iommu=smmu.0x0000000012000000)
[ 6.128038] iommu_context_dev 13e10000.host1x:ctx2: Adding to iommu group 11
[ 6.128640] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58, iommu=smmu.0x0000000012000000)
[ 6.129580] iommu_context_dev 13e10000.host1x:ctx3: Adding to iommu group 12
[ 6.130228] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59, iommu=smmu.0x0000000012000000)
[ 6.131191] iommu_context_dev 13e10000.host1x:ctx4: Adding to iommu group 13
[ 6.135800] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60, iommu=smmu.0x0000000012000000)
[ 6.145609] iommu_context_dev 13e10000.host1x:ctx5: Adding to iommu group 14
[ 6.152782] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61, iommu=smmu.0x0000000012000000)
[ 6.162561] iommu_context_dev 13e10000.host1x:ctx6: Adding to iommu group 15
[ 6.169595] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62, iommu=smmu.0x0000000012000000)
[ 6.179750] iommu_context_dev 13e10000.host1x:ctx7: Adding to iommu group 16
[ 6.186554] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63, iommu=smmu.0x0000000012000000)
[ 6.196489] falcon 15340000.vic: Adding to iommu group 17
[ 6.210744] falcon 15340000.vic: initialized
[ 6.211644] falcon 15380000.nvjpg: Adding to iommu group 17
[ 6.216924] falcon 15380000.nvjpg: initialized
[ 6.217489] falcon 154c0000.nvenc: Adding to iommu group 17
[ 6.230104] falcon 154c0000.nvenc: initialized
[ 6.230592] falcon 15a80000.nvenc1: Adding to iommu group 17
[ 6.240477] falcon 15a80000.nvenc1: initialized
[ 6.241191] nvdec 15480000.nvdec: Adding to iommu group 17
[ 6.251624] nvdec 15480000.nvdec: initialized
[ 6.252295] nvdec 15140000.nvdec1: Adding to iommu group 17
[ 6.261245] nvdec 15140000.nvdec1: initialized
[ 6.261783] tsec 15500000.tsec: Adding to iommu group 18
[ 6.267557] tsec 15500000.tsec: initialized
[ 6.268119] tsec 15100000.tsecb: Adding to iommu group 19
[ 6.277258] tsec 15100000.tsecb: initialized
[ 6.284084] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 6.311575] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 6.324857] gpio-374 (wifi-enable): hogged as output/high
[ 6.325130] gpio-431 (camera-control-output-low): hogged as output/low
[ 6.325372] gpio-432 (camera-control-output-low): hogged as output/low
[ 6.327042] gpiochip1: registered GPIOs 335 to 503 on tegra194-gpio
[ 6.329022] gpiochip2: registered GPIOs 305 to 334 on tegra194-gpio-aon
[ 6.329533] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 6.331109] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 6.333072] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 6.339452] tegra-pwm 32d0000.pwm: PWM clk can sleep in ops
[ 6.344449] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 6.353166] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1500000, vi_iso_bw=1500000, max_bw=1500000
[ 6.360424] tegra194-isp5 13e10000.host1x:isp@14800000: Adding to iommu group 20
[ 6.371557] t194-nvcsi 13e10000.host1x:nvcsi@15a00000: context isolation disabled due to no IOMMU
[ 6.377004] t194-nvcsi 13e10000.host1x:nvcsi@15a00000: initialized
[ 6.383025] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e10000.host1x:nvcsi@15a00000- bound
[ 6.391851] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e10000.host1x:nvcsi@15a00000- bound
[ 6.400861] tegra194-vi5 15c10000.vi: Adding to iommu group 21
[ 6.407947] scare-pigeon 13e10000.host1x:vi-thi@15f00000: context isolation disabled due to no IOMMU
[ 6.415819] scare-pigeon 13e10000.host1x:vi-thi@15f00000: initialized
[ 6.422134] scare-pigeon 13e10000.host1x:isp-thi@14b00000: context isolation disabled due to no IOMMU
[ 6.431405] scare-pigeon 13e10000.host1x:isp-thi@14b00000: initialized
[ 6.438024] pva 16000000.pva0: Adding to iommu group 22
[ 6.464661] pva 16000000.pva0: initialized
[ 6.470070] pva 16800000.pva1: Adding to iommu group 23
[ 6.482200] pva 16800000.pva1: initialized
[ 6.487804] nvdla 15880000.nvdla0: Adding to iommu group 24
[ 6.501252] nvdla 15880000.nvdla0: initialized
[ 6.502911] nvdla 158c0000.nvdla1: Adding to iommu group 25
[ 6.511370] nvdla 158c0000.nvdla1: initialized
[ 6.516488] tegradccommon 15200000.display-hub: host1x channel mapped
[ 6.516745] tegra_cec 3960000.tegra_cec: dt=1 start=0x03960000 end=0x03960FFF irq=62
[ 6.516869] tegradccommon 15200000.display-hub: dc_common syncpt # 1 allocated
[ 6.517046] tegradc 15200000.display: Adding to iommu group 26
[ 6.517337] tegra_cec 3960000.tegra_cec: Unpowergated DISP
[ 6.518290] tegradccommon 15200000.display-hub: dma mapping done
[ 6.518725] tegra_cec 3960000.tegra_cec: Enable clock result: 0.
[ 6.522601] tegra_cec 3960000.tegra_cec: cec_add_sysfs ret=0
[ 6.524633] tegradc 15210000.display: Adding to iommu group 26
[ 6.524803] tegradc 15200000.display: disp0 connected to head0->sor1
[ 6.524915] generic_infoframe_type: 0x87
[ 6.525013] tegradc 15200000.display: DT parsed successfully
[ 6.525133] tegradc 15200000.display: Display dc.(____ptrval____) registered with id=0
[ 6.527391] tegra_cec 3960000.tegra_cec: probed
[ 6.528590] tegra-gpcdma 2600000.dma: Adding to iommu group 2
[ 6.528715] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 15681600 KB/s
[ 6.528730] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 933000000 Hz
[ 6.528734] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 300000000 Hz
[ 6.529921] tegradc 15200000.display: vblank syncpt # 8 for dc 0
[ 6.529933] tegradc 15200000.display: vpulse3 syncpt # 9 for dc 0
[ 6.531384] tegradc 15200000.display: Bootloader disp_param detected. Detected mode: 1920x1080 (on 0x0mm) pclk=148350937
[ 6.535232] tegradc 15200000.display: hdmi: can't get adpater for ddc bus 3
[ 6.540147] tegra_cec 3960000.tegra_cec: tegra_cec_init started
[ 6.544027] tegradc 15200000.display: out->type:1 out_ops->init err = -517
[ 6.551450] tegra-gpcdma 2600000.dma: GPC DMA driver register 31 channels
[ 6.559247] tegradc 15210000.display: disp0 connected to head1->sor
[ 6.562552] kfuse 3830000.kfuse: initialized
[ 6.567574] tegradc 15210000.display: parse_dp_settings: No dp-lt-settings node
[ 6.576394] tegra-fuse-burn efuse-burn: shutdown limit check disabled
[ 6.584242] tegradc 15210000.display: DT parsed successfully
[ 6.592398] tegra-fuse-burn efuse-burn: Fuse burn driver initialized
[ 6.593028] serial-tegra 3100000.serial: Adding to iommu group 2
[ 6.598074] tegradc 15210000.display: dc.1 probe not in device tree order, deferring
[ 6.693145] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 31, base_baud = 0) is a TEGRA_UART
[ 6.702210] serial-tegra 3110000.serial: Adding to iommu group 2
[ 6.707504] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 32, base_baud = 0) is a TEGRA_UART
[ 6.716959] serial-tegra 3140000.serial: Adding to iommu group 2
[ 6.722165] 3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 33, base_baud = 0) is a TEGRA_UART
[ 6.742088] tegra-xusb 3610000.xhci: Firmware timestamp: 2022-03-16 11:07:43 UTC, Version: 60.13 release
[ 6.742457] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 6.745461] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[ 6.754183] tegra-xusb 3610000.xhci: hcc params 0x0184ff25 hci version 0x110 quirks 0x0000000000050810
[ 6.762468] tegra-xusb 3610000.xhci: irq 187, io mem 0x03610000
[ 6.769352] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 6.776598] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 6.783782] usb usb1: Product: xHCI Host Controller
[ 6.788722] usb usb1: Manufacturer: Linux 5.10.104-tegra xhci-hcd
[ 6.795075] usb usb1: SerialNumber: 3610000.xhci
[ 6.800821] hub 1-0:1.0: USB hub found
[ 6.803600] hub 1-0:1.0: 4 ports detected
[ 6.808238] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 6.813254] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[ 6.820599] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[ 6.828177] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[ 6.836431] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 6.843419] usb usb2: Product: xHCI Host Controller
[ 6.848653] usb usb2: Manufacturer: Linux 5.10.104-tegra xhci-hcd
[ 6.854889] usb usb2: SerialNumber: 3610000.xhci
[ 6.860250] hub 2-0:1.0: USB hub found
[ 6.863351] hub 2-0:1.0: 4 ports detected
[ 6.903769] tegra-i2c 31e0000.i2c: Adding to iommu group 2
[ 6.910395] i2c i2c-2: Added multiplexed i2c bus 9
[ 6.912186] i2c i2c-2: Added multiplexed i2c bus 10
[ 6.912387] i2c-mux-gpio cam_i2cmux: 2 port mux on 3180000.i2c adapter
[ 6.926094] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 1907000 KHz, changing to: 1907200 KHz
[ 6.927181] tegra194-cpufreq ccplex: probed with BWMGR
[ 6.928331] sdhci-tegra 3460000.sdhci: BWMGR client registration for eMC Successful
[ 6.928758] irq: IRQ261: trimming hierarchy from :pmc@c360000
[ 6.929202] usb-conn-gpio 3520000.xusb_padctl:ports:usb2-0:connector: repeated role: 0
[ 6.930364] tegra194-isp5 13e10000.host1x:isp@14800000: initialized
[ 6.937475] tegra194-vi5 15c10000.vi: initialized
[ 6.938757] tegradc 15200000.display: disp0 connected to head0->sor1
[ 6.940070] nvethernet 2490000.ethernet: Adding to iommu group 27
[ 6.940239] mmc0: CQHCI version 5.10
[ 6.943310] generic_infoframe_type: 0x87
[ 6.949797] nvethernet 2490000.ethernet: failed to read skip mac reset flag, default 0
[ 6.953430] tegradc 15200000.display: DT parsed successfully
[ 6.957320] nvethernet 2490000.ethernet: failed to read MDIO address
[ 6.965505] tegradc 15200000.display: Display dc.(____ptrval____) registered with id=0
[ 6.971012] nvethernet 2490000.ethernet: setting to default DMA bit mask
[ 6.971984] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit
[ 6.977971] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 15681600 KB/s
[ 6.985259] nvethernet 2490000.ethernet: set default TXQ to TC mapping
[ 6.992140] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 933000000 Hz
[ 6.992148] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 300000000 Hz
[ 7.000026] nvethernet 2490000.ethernet: Setting default PTP RX queue
[ 7.008744] tegradc 15200000.display: vblank syncpt # 11 for dc 0
[ 7.014816] nvethernet 2490000.ethernet: Failed to read DMA Tx ring size, using default [1024]
[ 7.022946] tegradc 15200000.display: vpulse3 syncpt # 12 for dc 0
[ 7.023133] tegradc 15200000.display: Bootloader disp_param detected. Detected mode: 1920x1080 (on 0x0mm) pclk=148350937
[ 7.031086] nvethernet 2490000.ethernet: Failed to read DMA Tx ring size, using default [1024]
[ 7.038417] tegradc 15200000.display: hdmi: invalid prod list prod_list_hdmi_board
[ 7.043485] nvethernet 2490000.ethernet: invalid resource
[ 7.051744] tegradc 15200000.display: hdmi: tegra_hdmi_tmds_range_read(bd) failed
[ 7.053843] tegradc 15200000.display: probed
[ 7.057790] mmc0: Command Queue Engine enabled
[ 7.057795] mmc0: periodic cache flush enabled
[ 7.057806] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 7.058203] nvethernet 2490000.ethernet: failed to ioremap MAC base address
[ 7.058207] nvethernet 2490000.ethernet: failed to allocate platform resources
[ 7.058275] nvethernet: probe of 2490000.ethernet failed with error -22
[ 7.058319] mmcblk0: mmc0:0001 DG4016 14.7 GiB
[ 7.058465] mmcblk0rpmb: mmc0:0001 DG4016 partition 3 4.00 MiB, chardev (510:0)
[ 7.062136] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19 p20 p21 p22
[ 7.070977] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 7.078207] irq: IRQ263: trimming hierarchy from :pmc@c360000
[ 7.172780] irq: IRQ264: trimming hierarchy from :interrupt-controller@3881000
[ 7.172855] Console: switching to colour frame buffer device 240x67
[ 7.172953] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 7.180113] tegradc 15200000.display: fb registered
[ 7.187674] tegra-se-nvhost 15810000.se: Adding to iommu group 28
[ 7.193021] irq: IRQ265: trimming hierarchy from :pmc@c360000
[ 7.199708] tegra-se-nvhost 15810000.se: initialized
[ 7.204823] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 7.215221] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 7.220822] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 7.227490] tegra-se-nvhost 15820000.se: Adding to iommu group 29
[ 7.239667] tegra-se-nvhost 15820000.se: initialized
[ 7.246132] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 7.250915] usb 1-2: New USB device found, idVendor=0424, idProduct=2513, bcdDevice= b.b3
[ 7.255132] tegra-se-nvhost 15830000.se: Adding to iommu group 30
[ 7.258516] usb 1-2: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 7.265639] tegra-se-nvhost 15830000.se: initialized
[ 7.273226] hub 1-2:1.0: USB hub found
[ 7.278208] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[ 7.280873] hub 1-2:1.0: 3 ports detected
[ 7.287786] tegra-se-nvhost 15840000.se: Adding to iommu group 31
[ 7.298144] tegra-se-nvhost 15840000.se: initialized
[ 7.300506] tegradc 15200000.display: hdmi: tmds rate:148351K prod-setting:prod_c_hdmi_111m_223m
[ 7.304401] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 7.312185] tegradc 15200000.display: hdmi: get RGB quant from REG programmed by BL.
[ 7.318999] tegra_actmon d230000.actmon: in actmon_register()...
[ 7.324920] tegradc 15200000.display: hdmi: get YCC quant from REG programmed by BL.
[ 7.325503] extcon-disp-state external-connection:disp-state: cable 47 state 1
[ 7.331226] tegra_actmon d230000.actmon: bwmgr_disable = 0
[ 7.338471] Extcon AUX1(HDMI) enable
[ 7.338589] tegradc 15210000.display: disp1 connected to head1->sor
[ 7.355204] tegra_actmon d230000.actmon: initialization Completed for the device mc_all
[ 7.360838] tegradc 15210000.display: parse_dp_settings: No dp-lt-settings node
[ 7.369615] hvc_sysfs: hypervisor is not present
[ 7.376292] tegradc 15210000.display: DT parsed successfully
[ 7.386674] tegradc 15210000.display: Display dc.(____ptrval____) registered with id=1
[ 7.421300] ALSA device list:
[ 7.421403] No soundcards found.
[ 7.421645] tegradc 15210000.display: vblank syncpt # 17 for dc 1
[ 7.421890] tegradc 15210000.display: vpulse3 syncpt # 18 for dc 1
[ 7.428905] tegradc 15210000.display: probed
[ 7.429241] tegradc 15210000.display: fb registered
[ 7.432777] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[ 7.432989] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[ 7.436725] Freeing unused kernel memory: 3968K
[ 7.437949] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[ 7.443116] Run /init as init process
[ 7.452005] tegradc 15210000.display: blank - powerdown
[ 7.456960] extcon-disp-state external-connection:disp-state: cable 44 state 0 already set.
[ 7.456963] Extcon DP: HPD disabled
[ 7.456984] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[ 7.457001] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[ 7.481581] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[ 7.505684] tegradc 15200000.display: blank - powerdown
[ 7.513753] Root device found: mmcblk0p1
[ 7.550919] extcon-disp-state external-connection:disp-state: cable 47 state 0
[ 7.550961] Extcon AUX1(HDMI) disable
[ 7.574522] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 7.575479] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 7.582987] tegra_cec 3960000.tegra_cec: Can't find physical address.
[ 7.582992] tegra_cec 3960000.tegra_cec: tegra_cec_init Done.
[ 7.588804] tegradc 15200000.display: unblank
[ 7.589937] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 7.590132] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 7.596224] tegradc 15200000.display: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_111m_223m
[ 7.598214] tegradc 15200000.display: hdmi: get YCC quant from EDID.
[ 7.602207] extcon-disp-state external-connection:disp-state: cable 47 state 1
[ 7.602211] Extcon AUX1(HDMI) enable
[ 7.615019] tegradc 15200000.display: sync windows ret = 246
[ 7.643549] extcon-disp-state external-connection:disp-state: cable 53 state 1
[ 7.643553] Extcon HDMI: HPD enabled
[ 7.643558] tegradc 15200000.display: hdmi: plugged
[ 7.654193] Found dev node: /dev/mmcblk0p1
[ 7.691589] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 7.697204] Rootfs mounted over mmcblk0p1
[ 7.737166] Switching from initrd to actual rootfs
[ 7.886226] systemd[1]: System time before build time, advancing clock.
[ 7.910513] x_tables: module verification failed: signature and/or required key missing - tainting kernel
[ 8.214661] systemd[1]: systemd 245.4-4ubuntu3.19 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[ 8.220265] systemd[1]: Detected architecture arm64.
[ 8.257762] systemd[1]: No hostname configured.
[ 8.259321] systemd[1]: Set hostname to <localhost>.
[ 8.783456] random: crng init done
[ 8.970471] systemd[1]: system-modprobe.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[ 8.972372] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[ 8.978046] systemd[1]: Created slice system-modprobe.slice.
[ 8.982846] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 8.986277] systemd[1]: Reached target Slices.
[ 8.989636] systemd[1]: Reached target Swap.
[ 8.993747] systemd[1]: Listening on RPCbind Server Activation Socket.
[ 8.997540] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 9.001068] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 9.005386] systemd[1]: Listening on Journal Audit Socket.
[ 9.007066] tegra-xusb 3610000.xhci: entering ELPG done
[ 9.011125] systemd[1]: Listening on Journal Socket (/dev/log).
[ 9.015157] systemd[1]: Listening on Journal Socket.
[ 9.019126] systemd[1]: Listening on udev Control Socket.
[ 9.022727] systemd[1]: Listening on udev Kernel Socket.
[ 9.030719] systemd[1]: Mounting Huge Pages File System...
[ 9.039122] systemd[1]: Mounting POSIX Message Queue File System...
[ 9.047993] systemd[1]: Mounting Kernel Debug File System...
[ 9.056718] systemd[1]: Mounting Kernel Trace File System...
[ 9.066664] systemd[1]: Starting Journal Service...
[ 9.074545] systemd[1]: Starting Set the console keyboard layout...
[ 9.083196] systemd[1]: Starting Create list of static device nodes for the current kernel...
[ 9.091684] systemd[1]: Starting Load Kernel Module chromeos_pstore...
[ 9.100500] systemd[1]: Starting Load Kernel Module efi_pstore...
[ 9.109454] systemd[1]: Starting Load Kernel Module pstore_blk...
[ 9.118542] systemd[1]: Starting Load Kernel Module pstore_zone...
[ 9.127342] systemd[1]: Starting Load Kernel Module ramoops...
[ 9.137294] systemd[1]: Starting NVIDIA specific first-boot udev script...
[ 9.169276] systemd[1]: Started Nameserver information manager.
[ 9.173980] systemd[1]: Reached target Network (Pre).
[ 9.182965] systemd[1]: Starting Set console scheme...
[ 9.187420] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 9.189177] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 9.196986] systemd[1]: Starting Load Kernel Modules...
[ 9.204278] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 9.212770] systemd[1]: Starting udev Coldplug all Devices...
[ 9.250005] systemd[1]: Mounted Huge Pages File System.
[ 9.259199] systemd[1]: Mounted POSIX Message Queue File System.
[ 9.263201] systemd[1]: Mounted Kernel Debug File System.
[ 9.274497] systemd[1]: Mounted Kernel Trace File System.
[ 9.289754] systemd[1]: Finished Create list of static device nodes for the current kernel.
[ 9.292170] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 9.301076] systemd[1]: modprobe@chromeos_pstore.service: Succeeded.
[ 9.301204] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 9.304866] systemd[1]: Finished Load Kernel Module chromeos_pstore.
[ 9.305415] tegra-carveouts tegra-carveouts: vpr :dma coherent mem declare 0x00000000ce000000,704643072
[ 9.307807] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[ 9.307820] nvmap_page_pool_init: Total RAM pages: 1753405
[ 9.307825] nvmap_page_pool_init: nvmap page pool size: 219175 pages (856 MB)
[ 9.308168] nvmap_background_zero_thread: PP zeroing thread starting.
[ 9.309576] misc nvmap: created heap vpr base 0x00000000ce000000 size (688128KiB)
[ 9.315649] misc nvmap: cvsram :dma coherent mem declare 0x0000000050000000,4194304
[ 9.315660] misc nvmap: created heap cvsram base 0x0000000050000000 size (4096KiB)
[ 9.321638] systemd[1]: modprobe@efi_pstore.service: Succeeded.
[ 9.325477] systemd[1]: Finished Load Kernel Module efi_pstore.
[ 9.330982] systemd[1]: modprobe@pstore_blk.service: Succeeded.
[ 9.334893] systemd[1]: Finished Load Kernel Module pstore_blk.
[ 9.339798] systemd[1]: modprobe@pstore_zone.service: Succeeded.
[ 9.345233] systemd[1]: Finished Load Kernel Module pstore_zone.
[ 9.350013] systemd[1]: modprobe@ramoops.service: Succeeded.
[ 9.355307] systemd[1]: Finished Load Kernel Module ramoops.
[ 9.365978] systemd[1]: Finished Set console scheme.
[ 9.372564] systemd[1]: Finished Remount Root and Kernel File Systems.
[ 9.385859] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[ 9.388235] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
[ 9.394350] systemd[1]: Starting Load/Save Random Seed...
[ 9.404950] systemd[1]: Starting Create System Users...
[ 9.410186] nvgpu: 17000000.gv11b nvgpu_nvhost_syncpt_init:135 [INFO] syncpt_unit_base 60000000 syncpt_unit_size 400000 size 1000
[ 9.410186]
[ 9.411985] systemd[1]: Finished Set the console keyboard layout.
[ 9.464479] systemd[1]: Finished Load Kernel Modules.
[ 9.472002] systemd[1]: Finished Load/Save Random Seed.
[ 9.476759] systemd[1]: Condition check resulted in FUSE Control File System being skipped.
[ 9.483536] systemd[1]: Mounting Kernel Configuration File System...
[ 9.491926] systemd[1]: Started OP-TEE Client Supplicant.
[ 9.500032] systemd[1]: Starting Apply Kernel Variables...
[ 9.508007] systemd[1]: nvfb-udev.service: Succeeded.
[ 9.511995] systemd[1]: Finished NVIDIA specific first-boot udev script.
[ 9.516176] systemd[1]: Mounted Kernel Configuration File System.
[ 11.222334] nv_imx219: disagrees about version of symbol tegracam_v4l2subdev_unregister
[ 11.224289] nv_imx219: Unknown symbol tegracam_v4l2subdev_unregister (err -22)
[ 11.233015] nv_imx219: disagrees about version of symbol tegracam_v4l2subdev_register
[ 11.241931] nv_imx219: Unknown symbol tegracam_v4l2subdev_register (err -22)
[ 11.243437] nv_imx219: disagrees about version of symbol tegracam_device_unregister
[ 11.255376] nv_imx219: Unknown symbol tegracam_device_unregister (err -22)
[ 11.256762] nv_imx219: disagrees about version of symbol tegracam_get_privdata
[ 11.257994] nv_imx219: Unknown symbol tegracam_get_privdata (err -22)
[ 11.259263] nv_imx219: disagrees about version of symbol camera_common_mclk_enable
[ 11.260581] nv_imx219: Unknown symbol camera_common_mclk_enable (err -22)
[ 11.267689] nv_imx219: disagrees about version of symbol camera_common_mclk_disable
[ 11.269061] nv_imx219: Unknown symbol camera_common_mclk_disable (err -22)
[ 11.270375] nv_imx219: disagrees about version of symbol tegracam_set_privdata
[ 11.272769] nv_imx219: Unknown symbol tegracam_set_privdata (err -22)
[ 11.274132] nv_imx219: disagrees about version of symbol tegracam_device_register
[ 11.275744] nv_imx219: Unknown symbol tegracam_device_register (err -22)
[ 11.316897] nv_imx219: disagrees about version of symbol tegracam_v4l2subdev_unregister
[ 11.318260] nv_imx219: Unknown symbol tegracam_v4l2subdev_unregister (err -22)
[ 11.319745] nv_imx219: disagrees about version of symbol tegracam_v4l2subdev_register
[ 11.321121] nv_imx219: Unknown symbol tegracam_v4l2subdev_register (err -22)
[ 11.322438] nv_imx219: disagrees about version of symbol tegracam_device_unregister
[ 11.329522] nv_imx219: Unknown symbol tegracam_device_unregister (err -22)
[ 11.332079] nv_imx219: disagrees about version of symbol tegracam_get_privdata
[ 11.333545] nv_imx219: Unknown symbol tegracam_get_privdata (err -22)
[ 11.334856] nv_imx219: disagrees about version of symbol camera_common_mclk_enable
[ 11.336209] nv_imx219: Unknown symbol camera_common_mclk_enable (err -22)
[ 11.337536] nv_imx219: disagrees about version of symbol camera_common_mclk_disable
[ 11.338892] nv_imx219: Unknown symbol camera_common_mclk_disable (err -22)
[ 11.340326] nv_imx219: disagrees about version of symbol tegracam_set_privdata
[ 11.343818] nv_imx219: Unknown symbol tegracam_set_privdata (err -22)
[ 11.354122] nv_imx219: disagrees about version of symbol tegracam_device_register
[ 11.378433] nv_imx219: Unknown symbol tegracam_device_register (err -22)
[ 11.776886] using random self ethernet address
[ 11.778313] using random host ethernet address
[ 12.873140] using random self ethernet address
[ 12.874620] using random host ethernet address
[ 13.148479] CPU4: shutdown
[ 13.188269] CPU5: shutdown
[ 16.351082] nvadsp 2993000.adsp: ADSP OS loading timed out
[ 16.352753] nvadsp 2993000.adsp: Unable to start ADSP OS
[ 16.354061] nvadsp 2993000.adsp: adsp failed to boot with ret = -62
[ 16.355339] nvadsp 2993000.adsp: Dumping ADSP logs ........
[ 16.357968] nvadsp 2993000.adsp: End of ADSP log dump .....
[ 16.359240] nvadsp 2993000.adsp: dumping fault frame...
[ 16.360433] nvadsp 2993000.adsp: r0 0x00000000 r1 0x00000000 r2 0x00000000 r3 0x00000000
[ 16.361714] nvadsp 2993000.adsp: r4 0x00000000 r5 0x00000000 r6 0x00000000 r7 0x00000000
[ 16.363051] nvadsp 2993000.adsp: r8 0x00000000 r9 0x00000000 r10 0x00000000 r11 0x00000000
[ 16.364350] nvadsp 2993000.adsp: r12 0x00000000 usp 0x00000000 ulr 0x00000000 pc 0x00000000
[ 16.365661] nvadsp 2993000.adsp: spsr 0x00000000
[ 16.366864] nvadsp 2993000.adsp: dumping arm mode register data...
[ 16.368139] nvadsp 2993000.adsp: fiq r13 0x00000000 r14 0x00000000
[ 16.369428] nvadsp 2993000.adsp: irq r13 0x00000000 r14 0x00000000
[ 16.370659] nvadsp 2993000.adsp: svc r13 0x00000000 r14 0x00000000
[ 16.371921] nvadsp 2993000.adsp: und r13 0x00000000 r14 0x00000000
[ 16.373108] nvadsp 2993000.adsp: sys r13 0x00000000 r14 0x00000000
[ 16.374315] nvadsp 2993000.adsp: abt r13 0x00000000 r14 0x00000000
[ 16.380046] tegra210-adsp tegra210-adsp: Failed to start OS
[ 16.384846] tegra210-adsp tegra210-adsp: Failed to init ADSP.
[ 16.470086] tegra210-adsp: probe of tegra210-adsp failed with error -62
[ 21.065596] nvidia: loading out-of-tree module taints kernel.
[ 23.684869] Please complete system configuration setup on desktop to proceed...
Do you have any idea ?
Best regards,
Julien.
