tensort:5.0.2.6
tensorflow:1.9
python 2.7
cuda:9.0
cuDNN:7.3.1
centOS:7.2
detail msg:
attr {
key: “shape”
value {
shape {
Using output node LSTMTDNN/output_projection/scores
Converting to UFF graph
Warning: keepdims is ignored by the UFF Parser and defaults to True
Warning: No conversion function registered for layer: Cast yet.
Converting LSTMTDNN/BILSTM/Cast as custom op: Cast
Warning: No conversion function registered for layer: ReverseSequence yet.
Converting LSTMTDNN/BILSTM/ReverseSequence as custom op: ReverseSequence
Warning: No conversion function registered for layer: TensorArrayGatherV3 yet.
Converting LSTMTDNN/BILSTM/bidirectional_rnn/bw/bw/TensorArrayStack/TensorArrayGatherV3 as custom op: TensorArrayGatherV3
Warning: No conversion function registered for layer: Exit yet.
Converting LSTMTDNN/BILSTM/bidirectional_rnn/bw/bw/while/Exit_1 as custom op: Exit
Warning: No conversion function registered for layer: Switch yet.
Converting LSTMTDNN/BILSTM/bidirectional_rnn/bw/bw/while/Switch_1 as custom op: Switch
Warning: No conversion function registered for layer: LoopCond yet.
Converting LSTMTDNN/BILSTM/bidirectional_rnn/bw/bw/while/LoopCond as custom op: LoopCond
Warning: No conversion function registered for layer: Less yet.
Converting LSTMTDNN/BILSTM/bidirectional_rnn/bw/bw/while/Less as custom op: Less
Warning: No conversion function registered for layer: Enter yet.
Converting LSTMTDNN/BILSTM/bidirectional_rnn/bw/bw/while/Less/Enter as custom op: Enter
Converting LSTMTDNN/BILSTM/bidirectional_rnn/bw/ReverseSequence as custom op: ReverseSequence
Warning: No conversion function registered for layer: Floor yet.
Converting LSTMTDNN/word_embedding/dropout/Floor as custom op: Floor
Warning: No conversion function registered for layer: RandomUniform yet.
Converting LSTMTDNN/word_embedding/dropout/random_uniform/RandomUniform as custom op: RandomUniform
Warning: No conversion function registered for layer: Merge yet.
Converting LSTMTDNN/BILSTM/bidirectional_rnn/bw/bw/while/Merge as custom op: Merge
Warning: No conversion function registered for layer: NextIteration yet.
Converting LSTMTDNN/BILSTM/bidirectional_rnn/bw/bw/while/NextIteration as custom op: NextIteration
Converting LSTMTDNN/BILSTM/bidirectional_rnn/bw/bw/while/Switch as custom op: Switch
Converting LSTMTDNN/BILSTM/bidirectional_rnn/bw/bw/while/Enter as custom op: Enter
Converting LSTMTDNN/BILSTM/bidirectional_rnn/bw/bw/while/Merge_1 as custom op: Merge
Converting LSTMTDNN/BILSTM/bidirectional_rnn/bw/bw/while/NextIteration_1 as custom op: NextIteration
Warning: No conversion function registered for layer: TensorArrayWriteV3 yet.
Converting LSTMTDNN/BILSTM/bidirectional_rnn/bw/bw/while/TensorArrayWrite/TensorArrayWriteV3 as custom op: TensorArrayWriteV3
Warning: No conversion function registered for layer: Select yet.
Converting LSTMTDNN/BILSTM/bidirectional_rnn/bw/bw/while/Select as custom op: Select
Warning: No conversion function registered for layer: Split yet.
Converting LSTMTDNN/BILSTM/bidirectional_rnn/bw/bw/while/lstm_cell/split as custom op: Split
File “/bin/convert-to-uff”, line 11, in
sys.exit(main())
File “/usr/lib/python2.7/site-packages/uff/bin/convert_to_uff.py”, line 89, in main
debug_mode=args.debug
File “/usr/lib/python2.7/site-packages/uff/converters/tensorflow/conversion_helpers.py”, line 187, in from_tensorflow_frozen_model
return from_tensorflow(graphdef, output_nodes, preprocessor, **kwargs)
File “/usr/lib/python2.7/site-packages/uff/converters/tensorflow/conversion_helpers.py”, line 157, in from_tensorflow
debug_mode=debug_mode)
File “/usr/lib/python2.7/site-packages/uff/converters/tensorflow/converter.py”, line 94, in convert_tf2uff_graph
uff_graph, input_replacements, debug_mode=debug_mode)
File “/usr/lib/python2.7/site-packages/uff/converters/tensorflow/converter.py”, line 79, in convert_tf2uff_node
op, name, tf_node, inputs, uff_graph, tf_nodes=tf_nodes, debug_mode=debug_mode)
File “/usr/lib/python2.7/site-packages/uff/converters/tensorflow/converter.py”, line 47, in convert_layer
return cls.registry_[op](name, tf_node, inputs, uff_graph, **kwargs)
File “/usr/lib/python2.7/site-packages/uff/converters/tensorflow/converter_functions.py”, line 380, in convert_bias_add
kwargs[“tf_nodes”][biases_name])
File “/usr/lib/python2.7/site-packages/uff/converters/tensorflow/converter.py”, line 132, in convert_tf2numpy_const_node
raise UffException(“Const node conversion requested, but node is not Const\n” + str(tf_node))
uff.model.exceptions.UffException: Const node conversion requested, but node is not Const
name: “LSTMTDNN/BILSTM/bidirectional_rnn/bw/bw/while/lstm_cell/lstm_cell_1/BiasAdd/Enter”
op: “Enter”
input: “LSTMTDNN/BILSTM/bidirectional_rnn/bw/lstm_cell/biases”
attr {
key: “T”
value {
type: DT_FLOAT
attr {
key: “_output_shapes”
value {
list {
shape {
dim {
attr {
key: “frame_name”
value {
s: “LSTMTDNN/BILSTM/bidirectional_rnn/bw/bw/while/LSTMTDNN/BILSTM/bidirectional_rnn/bw/bw/while/”
attr {
key: “is_constant”
value {
b: true
attr {
key: “parallel_iterations”
value {
i: 32
[root@localhost TensorFLowModel]#
