Unable to access memory at location: cuda gdb in fortran
I am new to cuda fortran and am currently trying to learn the cuda-gdb but have run into some issues. First, I am unable to print subroutine input variables when debugging inside the kernel as I receive the message “cannot access memory at address: 0x5” where the second number (5) changes depending on the size of the array.
In addition to this I am fully unable to see any shared variables that the current thread has access to. When I try to print them I get "No symbol “variable name” in current context.’
Below is a screenshot of my attempts to access the input and shared variables along with a minimum reproducing example and my compilation flags
flags: nvfortran -O0 -g -gpu=debug,nordc -cuda scratch.f90
Example:
module m
    use cudafor
    contains
    attributes(global) subroutine var_vis_test(array_d, n)
    ! Declare input variable
    integer, value :: n
    real :: array_d(:)
    ! Declare internal subroutine variables
    real, shared :: array_shared(n)
    if (threadIdx%x <= n) array_shared(threadIdx%x) = 1.0
    if (threadIdx%x <= size(array_d)) array_d(threadIdx%x) = array_d(threadIdx%x) + array_shared(threadIdx%x)
    end subroutine var_vis_test
end module m
program variable_visability_test
    use m
    use cudafor
    real :: array_h(5)
    real, device :: a_d(5)
    integer :: n = 4
    print*, 'Array before subroutine: ', array_h
    a_d = array_h
    call var_vis_test<<<1,n>>>(a_d, n)
    array_h = a_d
    print*, 'Array after subroutine: ', array_h
end program variable_visability_test
Other potentially pertinent info:
1. This behavior persists whether I have the input variable declared as device or not in the kernel
2. Making the file “scratch.cuf” rather than “scratch.f90” and removing the -cuda flag doesn’t affect this behavior
3. When trying to use the debugger GUI with nsight visual studio code edition, anytime I try to enter a kernel I get this message in the VSCode debugging terminal and then it hangs
cuda-gdb has received a SIGSEGV and will attempt to get its own backtrace."
4. I am using cuda 12.7 installed on WSL2 that runs Ubuntu 24.04 with Driver Version: 566.36, but compared this behavior to a native linux OS (also Ubuntu 24.04 but with cuda 12.4 and Driver Version: 550.120 ) and saw the same behavior so am not inclined to say its a WSL2 issue.
Any help on this is greatly appreciated as it’s been driving my nuts trying to figure out what’s wrong.
Thank you very much for your time!
-Gabe D.
Hi Gabe,
Thanks for reaching out. I can confirm that there is a few compiler issues present here. We will work on getting this fixed in a future release of the NVIDIA HPC SDK.
Sounds good. Thanks for that update. Any idea if older versions of Cuda had this problem too? I’m tempted to try one or two.
