Hi, I am trying to build the vmod folder in the nv_full in the hw-nvdla1 folder. However, the NVDLA Environment Setup Guide says that when the following command is run from TOT…
./tools/bin/tmake -build vmod
…the last line of the output should be…
[TMAKE]: DONE
However, in my case the output is different
files are generated under /home/usman/Documents/Work/repos/hw-nvdlav1/outdir/nv_full/vmod/nvdla/top
make: Leaving directory '/home/usman/Documents/Work/repos/hw-nvdlav1/vmod/nvdla/top'
logfile: outdir/build.log
Filehandle GEN1 opened only for input at /usr/share/perl5/IO/Tee.pm line 132.
==================BUILD PASS==================
Please notice this is not the complete log. Due to tmake not working properly I can’t proceed. The contents of my tree.make file are below.
## NVDLA Open Source Project
## Copyright(c) 2016 - 2017 NVIDIA Corporation. Licensed under the
## NVDLA Open Hardware License; Check LICENSE which comes with
## this distribution for more information.
## Project Name Setup, multiple projects supported
PROJECTS := nv_full
##Linux Environment Setup
## c pre-processor
CPP := /usr/bin/cpp
## c++ compiler
GCC := /usr/bin/gcc
## perl: many scripts is written in perl
PERL := /usr/bin/perl
## java: used in hardware regester spec compilation (not in current release)
JAVA := /usr/bin/java
## systemc: needed for Cmodel build (optional)
SYSTEMC := ~/Desktop/shrjeel/systemc-2.3.0/
## verilator: used to build testbench without VCS (optional)
VERILATOR := verilator
## clang: used to build Verilated binaries (optional)
CLANG := clang
## Modification(s)
DESIGNWARE_NOEXIST := 1
Here is a screenshot of the output in the terminal: tmake output hw-nvdla1 nv_full - Album on Imgur
Kindly help me to resolve this issue.
build.log (191 KB)
