Hello everybody,
I have almost the same problem as described here: Unable to change extreme resolution
Unfortunately, the solution proposed by @generix doesn’t work in my case:
$ cvt -r 1920 1080 60
# 1920x1080 59.93 Hz (CVT 2.07M9-R) hsync: 66.59 kHz; pclk: 138.50 MHz
Modeline "1920x1080R" 138.50 1920 1968 2000 2080 1080 1083 1088 1111 +hsync -vsync
$ xrandr --newmode "1920x1080R" 138.50 1920 1968 2000 2080 1080 1083 1088 1111 +hsync -vsync
$ xrandr --addmode DP-2 "1920x1080R"
X Error of failed request: BadMatch (invalid parameter attributes)
Major opcode of failed request: 140 (RANDR)
Minor opcode of failed request: 18 (RRAddOutputMode)
Serial number of failed request: 43
Current serial number in output stream: 44
Additional information:
OS: Ubuntu 20 04
GPU: Quadro M2200
GPU driver: nvidia-driver-510
I have two displays: built into my laptop (DP-2) and external (DP-4). The problem above is about built-in display, the external one works perfectly.
Also please find attached the report of nvidia-bug-report.sh (executed as root)
nvidia-bug-report.log (3.4 MB)
Please help.
