Hi everybody.
first of all my working environment:
OpenCL on arch linux with latest nvidia sdk, nvidia drivers for linux version 190.29.
i can compile and execute kernels with no comments in it such as
__kernel void update(__global float *data)
but if i try to run the same code with this kernel:
//this is a comment
i get a build error as if i have an error on the source code (error 1 on clBuildProgram).
ideas?
please ask if you need more info
revers
November 19, 2009, 1:17pm
2
I’m not sure if it can be that. But I guess depending on how you give the program source to the compiler, if it gives the whole code in a unique line then the end your code is still considered as commented…
Maybe you can try this :
/*this is a comment*/
Thanks for the answer.
your suggestions has been very useful.
in fact, there was an error in the function i used to load a *.cl file.
now i corrected it, and now it loads the file correctly (at least i think so).
anyway, the problem is not solved :(
let me show you what it happens:
if i try to run my code with this kernel, everything goes fine:
$ ./OpenCLcpp
__kernel void increment(
const uint index = get_global_id(0);
// comment
data[index] = data[index]+1;
Size is 136
input 0 output 10
input 0 output 10
input 0 output 10
input 0 output 10
input 0 output 10
input 0 output 10
input 0 output 10
input 0 output 10
input 0 output 10
input 0 output 10
Execution finished correctly
If i try to execute the same code with this kernel, an error occours!!!
$ ./OpenCLcpp
// comment long
Size is 141
ERROR: clCreateKernel(-46)
-46 is CL_INVALID_KERNEL_NAME but the name of the kernel and the cpp code is the same!!!
this is the function i use to load the *.cl sources:
#include <fstream>
std::pair<const char*, unsigned int> ReadClFromFile(const char* path)
std::string str,KernelSource;
std::ifstream in;
if(! in)
std::cerr << "File not found??" << std::endl;
in.open(path);
std::getline(in,str);
while ( in ) {
KernelSource += str + "\n";
in.close();
std::cout << KernelSource << std::endl;
std::cout << "Size is " << KernelSource.length() << std::endl;
return std::make_pair(KernelSource.c_str(), KernelSource.length());
Are you aware that your ReadClFromFile() function is returning pointer from a string object (KernelSource) that is destructed at the end of the function? Change the first pair element to std::string, and see if that helps.
it worked, thanks a lot. very noob problem :)
