Hardware - GPU (T4)
Hardware - CPU
Operating System - ubuntu 20.04 running on AWS EC2 g4dn.2xlarge instance
I am currently trying to convert a model (several of different types but for now not even a FastPitch model is working)
In the past i had deployed several nemo pipelines to riva but that developing environment was lost during some updates and I have not been able to convert and deploy any nemo models since. I believe this lost environment was using nemo 1.20.0 and riva & nemo2riva version 2.13.1, however using those versions does not seem to work for me anymore.
Recently I have been testing several versions of nemo, nemo2riva and riva using the dockerfile below in order to deploy models. (will update with testing data as I continue to try and retry combinations)
FROM nvcr.io/nvidia/nemo:24.01.framework
#get a simple fastpitch model to convert
RUN wget --content-disposition \
'https://api.ngc.nvidia.com/v2/models/org/nvidia/team/nemo/tts_en_fastpitch/IPA_1.13.0/files?redirect=true&path=tts_en_fastpitch_align_ipa.nemo' \
-O tts_en_fastpitch_align_ipa.nemo
#without nemo_text_processing it errors with "TypeError: Can't instantiate abstract class ModelPT with abstract methods list_available_models, setup_training_data, setup_validation_data"
#without lhotse it also gets the same TypeError
RUN pip install nemo_text_processing
RUN pip install lhotse
#install nemo2riva
RUN pip install nvidia-pyindex
RUN pip install nemo2riva==2.14.0
#run the test
CMD nemo2riva --out FP_ipa.riva --key tlt_encode tts_en_fastpitch_align_ipa.nemo
As you can see in the dockerfile, it is using a pretrained model from ngc, however I get the same error even on a .nemo model that was trained using the latest nemo version
The error relates to nvidia-eff and being unable to encrypt the model. This error is consistent regardless of the nemo image used. I have also tried using a pytorch base image but this results in the same errors. I tried using a riva-servicemaker image too but that had an issue arising because the image uses python 3.8 but nemo has required 3.10 for a long time.
I really need some help resolving this as development is being delayed as I cannot update any ASR, NLP, or TTS models currently. How can I resolve this?
INFO: generated new fontManager
INFO: NumExpr defaulting to 8 threads.
[NeMo I 2024-03-04 01:59:20 nemo2riva:38] Logging level set to 20
[NeMo I 2024-03-04 01:59:20 convert:36] Restoring NeMo model from 'tts_en_fastpitch_align_ipa.nemo'
GPU available: True (cuda), used: True
TPU available: False, using: 0 TPU cores
IPU available: False, using: 0 IPUs
HPU available: False, using: 0 HPUs
`Trainer(limit_train_batches=1.0)` was configured so 100% of the batches per epoch will be used..
`Trainer(limit_val_batches=1.0)` was configured so 100% of the batches will be used..
`Trainer(limit_test_batches=1.0)` was configured so 100% of the batches will be used..
`Trainer(limit_predict_batches=1.0)` was configured so 100% of the batches will be used..
`Trainer(val_check_interval=1.0)` was configured so validation will run at the end of the training epoch..
NeMo-text-processing :: INFO :: Creating ClassifyFst grammars.
WARNING: Logging before flag parsing goes to stderr.
I0304 01:59:23.133829 139807560075072 tokenize_and_classify.py:86] Creating ClassifyFst grammars.
[NeMo W 2024-03-04 01:59:51 deprecated:65] Function ``g2p_backward_compatible_support`` is deprecated. But it will not be removed until a further notice. G2P object root directory `nemo_text_processing.g2p` has been replaced with `nemo.collections.tts.g2p`. Please use the latter instead as of NeMo 1.18.0.
[NeMo W 2024-03-04 01:59:52 experimental:26] `<class 'nemo.collections.tts.g2p.models.i18n_ipa.IpaG2p'>` is experimental and not ready for production yet. Use at your own risk.
[NeMo W 2024-03-04 01:59:53 i18n_ipa:124] apply_to_oov_word=None, This means that some of words will remain unchanged if they are not handled by any of the rules in self.parse_one_word(). This may be intended if phonemes and chars are both valid inputs, otherwise, you may see unexpected deletions in your input.
[NeMo W 2024-03-04 01:59:53 experimental:26] `<class 'nemo.collections.common.tokenizers.text_to_speech.tts_tokenizers.IPATokenizer'>` is experimental and not ready for production yet. Use at your own risk.
[NeMo W 2024-03-04 01:59:53 modelPT:165] If you intend to do training or fine-tuning, please call the ModelPT.setup_training_data() method and provide a valid configuration file to setup the train data loader.
Train config :
dataset:
_target_: nemo.collections.tts.torch.data.TTSDataset
manifest_filepath: /data3/LJSpeech/nvidia_ljspeech_train.json
sample_rate: 22050
sup_data_path: /data3/LJSpeech/tmp_ignoreamb/
sup_data_types:
- align_prior_matrix
- pitch
n_fft: 1024
win_length: 1024
hop_length: 256
window: hann
n_mels: 80
lowfreq: 0
highfreq: 8000
max_duration: null
min_duration: 0.1
ignore_file: null
trim: false
pitch_fmin: 65.40639132514966
pitch_fmax: 2093.004522404789
pitch_norm: true
pitch_mean: 212.35873413085938
pitch_std: 68.52806091308594
use_beta_binomial_interpolator: true
dataloader_params:
drop_last: false
shuffle: true
batch_size: 32
num_workers: 12
[NeMo W 2024-03-04 01:59:53 modelPT:172] If you intend to do validation, please call the ModelPT.setup_validation_data() or ModelPT.setup_multiple_validation_data() method and provide a valid configuration file to setup the validation data loader(s).
Validation config :
dataset:
manifest_filepath: /data3/LJSpeech/nvidia_ljspeech_val.json
sample_rate: 22050
sup_data_types:
- pitch
n_fft: 1024
win_length: 1024
hop_length: 256
window: hann
n_mels: 80
lowfreq: 0
highfreq: 8000
max_duration: null
min_duration: null
ignore_file: null
trim: false
pitch_norm: true
dataloader_params:
drop_last: false
shuffle: false
batch_size: 32
num_workers: 8
[NeMo I 2024-03-04 01:59:53 features:289] PADDING: 1
[NeMo I 2024-03-04 01:59:54 save_restore_connector:249] Model FastPitchModel was successfully restored from /workspace/tts_en_fastpitch_align_ipa.nemo.
[NeMo I 2024-03-04 01:59:54 schema:161] Loaded schema file /usr/local/lib/python3.10/dist-packages/nemo2riva/validation_schemas/nlp-isc-exported-bert.yaml for nemo.collections.nlp.models.IntentSlotClassificationModel
[NeMo I 2024-03-04 01:59:54 schema:161] Loaded schema file /usr/local/lib/python3.10/dist-packages/nemo2riva/validation_schemas/tts-exported-fastpitchmodel.yaml for nemo.collections.tts.models.FastPitchModel
[NeMo I 2024-03-04 01:59:54 schema:161] Loaded schema file /usr/local/lib/python3.10/dist-packages/nemo2riva/validation_schemas/tts-exported-hifiganmodel.yaml for nemo.collections.tts.models.HifiGanModel
[NeMo I 2024-03-04 01:59:54 schema:161] Loaded schema file /usr/local/lib/python3.10/dist-packages/nemo2riva/validation_schemas/tts-exported-radttsmodel.yaml for nemo.collections.tts.models.RadTTSModel
[NeMo I 2024-03-04 01:59:54 schema:161] Loaded schema file /usr/local/lib/python3.10/dist-packages/nemo2riva/validation_schemas/asr-stt-exported-encdecctcmodel.yaml for nemo.collections.asr.models.EncDecCTCModel
[NeMo I 2024-03-04 01:59:54 schema:161] Loaded schema file /usr/local/lib/python3.10/dist-packages/nemo2riva/validation_schemas/nlp-tc-exported-bert.yaml for nemo.collections.nlp.models.TextClassificationModel
[NeMo I 2024-03-04 01:59:54 schema:161] Loaded schema file /usr/local/lib/python3.10/dist-packages/nemo2riva/validation_schemas/nlp-mt-exported-encdecmtmodel.yaml for nemo.collections.nlp.models.MTEncDecModel
[NeMo I 2024-03-04 01:59:54 schema:161] Loaded schema file /usr/local/lib/python3.10/dist-packages/nemo2riva/validation_schemas/nlp-tkc-exported-bert.yaml for nemo.collections.nlp.models.TokenClassificationModel
[NeMo I 2024-03-04 01:59:54 schema:161] Loaded schema file /usr/local/lib/python3.10/dist-packages/nemo2riva/validation_schemas/asr-stt-exported-encdectcmodelbpe.yaml for nemo.collections.asr.models.EncDecCTCModelBPE
[NeMo I 2024-03-04 01:59:54 schema:161] Loaded schema file /usr/local/lib/python3.10/dist-packages/nemo2riva/validation_schemas/asr-scr-exported-encdecclsmodel.yaml for nemo.collections.asr.models.classification_models.EncDecClassificationModel
[NeMo I 2024-03-04 01:59:54 schema:161] Loaded schema file /usr/local/lib/python3.10/dist-packages/nemo2riva/validation_schemas/nlp-qa-exported-bert.yaml for nemo.collections.nlp.models.QAModel
[NeMo I 2024-03-04 01:59:54 schema:161] Loaded schema file /usr/local/lib/python3.10/dist-packages/nemo2riva/validation_schemas/nlp-mt-exported-megatronnmtmodel.yaml for nemo.collections.nlp.models.MegatronNMTModel
[NeMo I 2024-03-04 01:59:54 schema:161] Loaded schema file /usr/local/lib/python3.10/dist-packages/nemo2riva/validation_schemas/nlp-pc-exported-bert.yaml for nemo.collections.nlp.models.PunctuationCapitalizationModel
[NeMo I 2024-03-04 01:59:54 schema:200] Found validation schema for nemo.collections.tts.models.FastPitchModel at /usr/local/lib/python3.10/dist-packages/nemo2riva/validation_schemas/tts-exported-fastpitchmodel.yaml
[NeMo I 2024-03-04 01:59:54 schema:229] Checking installed NeMo version ... 1.23.0 OK (>=1.1)
[NeMo I 2024-03-04 01:59:54 artifacts:59] Found model at ./model_weights.ckpt
[NeMo I 2024-03-04 01:59:54 artifacts:136] Retrieved artifacts: dict_keys(['36d6b09d4dbc45dcb02222e1931e4c7c_lj_speech.tsv', '446fe5373191447190c14cdb8e967e58_ipa_cmudict-0.7b_nv22.08.txt', 'e2327d2f57dd41b88601774804001221_heteronyms-052722', 'model_config.yaml', 'mapping.txt'])
[NeMo I 2024-03-04 01:59:54 cookbook:78] Exporting model FastPitchModel with config=ExportConfig(export_subnet=None, export_format='ONNX', export_file='model_graph.onnx', encryption=True, autocast=True, max_dim=None, export_args={})
[NeMo I 2024-03-04 02:00:01 exportable:131] Successfully exported FastPitchModel to /tmp/tmp7gtd0omy/model_graph.onnx
[W] colored module is not installed, will not use colors when logging. To enable colors, please install the colored module: python3 -m pip install colored
[W] Attribute of type TYPE_PROTO is currently unsupported. Skipping attribute.
[W] Could not convert: UNDEFINED to a corresponding NumPy type. The original ONNX type will be preserved.
2024-03-04 02:00:01.862915635 [W:onnxruntime:, unsqueeze_elimination.cc:20 Apply] UnsqueezeElimination cannot remove node Unsqueeze_980
2024-03-04 02:00:01.862971956 [W:onnxruntime:, unsqueeze_elimination.cc:20 Apply] UnsqueezeElimination cannot remove node Unsqueeze_975
2024-03-04 02:00:01.862988821 [W:onnxruntime:, unsqueeze_elimination.cc:20 Apply] UnsqueezeElimination cannot remove node Unsqueeze_960
2024-03-04 02:00:01.863000639 [W:onnxruntime:, unsqueeze_elimination.cc:20 Apply] UnsqueezeElimination cannot remove node Unsqueeze_955
2024-03-04 02:00:01.863011349 [W:onnxruntime:, unsqueeze_elimination.cc:20 Apply] UnsqueezeElimination cannot remove node Unsqueeze_951
2024-03-04 02:00:01.863026569 [W:onnxruntime:, unsqueeze_elimination.cc:20 Apply] UnsqueezeElimination cannot remove node Unsqueeze_945
2024-03-04 02:00:01.863059506 [W:onnxruntime:, unsqueeze_elimination.cc:20 Apply] UnsqueezeElimination cannot remove node Unsqueeze_911
2024-03-04 02:00:01.863083302 [W:onnxruntime:, unsqueeze_elimination.cc:20 Apply] UnsqueezeElimination cannot remove node Unsqueeze_906
2024-03-04 02:00:01.863103596 [W:onnxruntime:, unsqueeze_elimination.cc:20 Apply] UnsqueezeElimination cannot remove node Unsqueeze_891
2024-03-04 02:00:01.863122579 [W:onnxruntime:, unsqueeze_elimination.cc:20 Apply] UnsqueezeElimination cannot remove node Unsqueeze_886
2024-03-04 02:00:01.863142365 [W:onnxruntime:, unsqueeze_elimination.cc:20 Apply] UnsqueezeElimination cannot remove node Unsqueeze_882
2024-03-04 02:00:01.863161463 [W:onnxruntime:, unsqueeze_elimination.cc:20 Apply] UnsqueezeElimination cannot remove node Unsqueeze_876
2024-03-04 02:00:01.863180990 [W:onnxruntime:, unsqueeze_elimination.cc:20 Apply] UnsqueezeElimination cannot remove node Unsqueeze_842
2024-03-04 02:00:01.863202010 [W:onnxruntime:, unsqueeze_elimination.cc:20 Apply] UnsqueezeElimination cannot remove node Unsqueeze_837
2024-03-04 02:00:01.863224208 [W:onnxruntime:, unsqueeze_elimination.cc:20 Apply] UnsqueezeElimination cannot remove node Unsqueeze_822
2024-03-04 02:00:01.863235010 [W:onnxruntime:, unsqueeze_elimination.cc:20 Apply] UnsqueezeElimination cannot remove node Unsqueeze_817
2024-03-04 02:00:01.863244066 [W:onnxruntime:, unsqueeze_elimination.cc:20 Apply] UnsqueezeElimination cannot remove node Unsqueeze_813
2024-03-04 02:00:01.863256423 [W:onnxruntime:, unsqueeze_elimination.cc:20 Apply] UnsqueezeElimination cannot remove node Unsqueeze_807
2024-03-04 02:00:01.877913305 [W:onnxruntime:, unsqueeze_elimination.cc:20 Apply] UnsqueezeElimination cannot remove node Unsqueeze_1055
2024-03-04 02:00:01.877951197 [W:onnxruntime:, unsqueeze_elimination.cc:20 Apply] UnsqueezeElimination cannot remove node Unsqueeze_1050
2024-03-04 02:00:01.877967245 [W:onnxruntime:, unsqueeze_elimination.cc:20 Apply] UnsqueezeElimination cannot remove node Unsqueeze_1035
2024-03-04 02:00:01.877974987 [W:onnxruntime:, unsqueeze_elimination.cc:20 Apply] UnsqueezeElimination cannot remove node Unsqueeze_1030
2024-03-04 02:00:01.877984501 [W:onnxruntime:, unsqueeze_elimination.cc:20 Apply] UnsqueezeElimination cannot remove node Unsqueeze_1026
2024-03-04 02:00:01.877994518 [W:onnxruntime:, unsqueeze_elimination.cc:20 Apply] UnsqueezeElimination cannot remove node Unsqueeze_1020
File "/usr/local/bin/nemo2riva", line 8, in <module>
sys.exit(nemo2riva())
File "/usr/local/lib/python3.10/dist-packages/nemo2riva/cli/nemo2riva.py", line 49, in nemo2riva
Nemo2Riva(args)
File "/usr/local/lib/python3.10/dist-packages/nemo2riva/convert.py", line 87, in Nemo2Riva
export_model(
File "/usr/local/lib/python3.10/dist-packages/nemo2riva/cookbook.py", line 141, in export_model
create_artifact(
File "/usr/local/lib/python3.10/dist-packages/nemo2riva/artifacts.py", line 92, in create_artifact
af.encrypt()
File "<frozen eff.core.file>", line 128, in encrypt
PermissionError: Cannot encrypt the artifact without encryption
