when run deepstream_test1.py in a docker container, error shows as following:
"GStreamer-WARNING **: 12:20:54.141: Failed to load plugin ‘/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_infer.so’: /usr/lib/aarch64-linux-gnu/libnvparsers.so.8: file too short
Unable to create pgie
(python3:50): GStreamer-WARNING **: 12:20:54.148: Failed to load plugin ‘/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_osd.so’: /usr/lib/aarch64-linux-gnu/libnvinfer.so.8: file too short
Unable to create nvosd"
And, the docker is running well on another machine of same type.
Actually, I wanted to, but the JetPack need to be upgraded, so the OS, except for these, and I am afraid the hardware will not support which supplier told me. Maybe I need a good Jeston nx supplier.
