Unable to create pgie, nvosd
**• Hardware Platform : Jetson Tx2
**• DeepStream Version : 6.0.1 (deepstream-l4t:6.0.1-samples)
**• JetPack Version : 4.6.1
Getting the following error when try to run deepstream python app
Creating Pipeline
 Unable to create nvosd
Creating EGLSink
  File "deepstream_test_4.py", line 596, in ds_main
    main(sys.argv)
  File "deepstream_test_4.py", line 478, in main
    pgie.set_property('config-file-path', PGIE_CONFIG_FILE)
AttributeError: 'NoneType' object has no attribute 'set_property'
tried after removing gstreamer cache by using the below command, but still getting the same error
rm ${HOME}/.cache/gstreamer-1.0/*
ll /usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/
 libcustom2d_preprocess.so*
 libgstnvvideoconvert.so*
 libnvdsgst_audiotemplate.so*
 libnvdsgst_deepstream_bins.so*
 libnvdsgst_dewarper.so*
 libnvdsgst_dsanalytics.so*
 libnvdsgst_dsexample.so*
 libnvdsgst_infer.so*
 libnvdsgst_inferaudio.so*
 libnvdsgst_inferserver.so*
 libnvdsgst_logger.so*
 libnvdsgst_msgbroker.so*
 libnvdsgst_msgconv.so*
 libnvdsgst_multistream.so*
 libnvdsgst_multistreamtiler.so*
 libnvdsgst_of.so*
 libnvdsgst_ofvisual.so*
 libnvdsgst_osd.so*
 libnvdsgst_preprocess.so*
 libnvdsgst_segvisual.so*
 libnvdsgst_tracker.so*
 libnvdsgst_udp.so*
 libnvdsgst_videotemplate.so*
Did you follow the installation guide to install python binding? (deepstream_python_apps/bindings at master · NVIDIA-AI-IOT/deepstream_python_apps · GitHub tag v1.1.1)
Did you success to run other python examples?
Yes, I have installed python bindings as mentioned in the repo (v1.1.1).
But getting the same error
The same steps i have tried in a jetson nano (Jetpack 4.5, Deepstream 6.0.1), and I’m able to run deepstream python apps there
Can you run success directly on the device?
Sorry,
What do you meant by ‘ Can you run success directly on the device?’
I see you run the python app within docker failed. so suggest you if or not can run directly on device?
I’m wondering, how the same docker file and scripts is working on a jetson device!.
I forgot to mention the below error which I’m getting while building the container in the Jetson TX2 NX, but this error is not in the jetson nano
ERROR: for DS  Cannot start service DS_container: OCI runtime create failed: container_linux.go:380: starting container process caused: process_linux.go:545: container init caused: Running hook #0:: error running hook: exit status 1, stdout: , stderr: Auto-detected mode as 'csv'
invoking the NVIDIA Container Runtime Hook directly (e.g. specifying the docker --gpus flag) is not supported. Please use the NVIDIA Container Runtime (e.g. specify the --runtime=nvidia flag) instead.: unknown
ERROR: Encountered errors while bringing up the project.
This link stating that the above error is happening since nvidia-container-toolkit is missing.
Then i tried to install nvidia container toolkit on the device by using below command , but its showing that it is already installed
Command
sudo apt-get install -y nvidia-container-toolkit
Output
nvidia-container-toolkit is already the newest version (1.11.0-1).
nvidia-container-toolkit set to manually installed.
Hi @samjith888 ,
The docker toolkit should be installed through SDKManager
