bmears
August 4, 2017, 11:36pm
#1
I am modifying the sample program backend and am unable to get nvosd_put_text() to work as expected. The API declared in nvosd.h is clear enough but nothing gets displayed on the screen. None of the provided examples use this function so I may well be doing something incorrectly. My suspicion is that I specified the font name incorrectly.
Attached is the snippet of code I added to v4l2_backend_main.cpp. This was inserted after the block containing the call to nvosd_draw_rectangles(). I have also shown this as a patch file at the bottom of the message.
char text[] = "Hello world";
char font[] = "Arial";
NvOSD_TextParams textParams;
textParams.display_text = text;
textParams.x_offset = textX;
textParams.y_offset = textY;
textParams.font_params.font_name = font;
textParams.font_params.font_size = 18;
textParams.font_params.font_color.red = 1.0;
textParams.font_params.font_color.green = 0.0;
textParams.font_params.font_color.blue = 1.0;
textParams.font_params.font_color.alpha = 1.0;
nvosd_put_text(ctx->nvosd_context, MODE_CPU, buffer->planes[0].fd, 1, &textParams);
Thank you for your help.
— v4l2_backend_main.cpp 2017-08-04 17:26:38.962814334 -0600
+++ /home/nvidia/tegra_multimedia_api/samples/backend/v4l2_backend_main.cpp 2017-03-01 22:15:06.000000000 -0700
@@ -76,9 +76,6 @@
#define IS_NAL_UNIT_START1(buffer_ptr) (!buffer_ptr[0] && !buffer_ptr[1] &&
(buffer_ptr[2] == 1))
-const int textX = 800;
-const int textY = 50;
using namespace std;
#ifdef ENABLE_GIE
@@ -434,25 +431,7 @@
nvosd_draw_rectangles(ctx->nvosd_context, MODE_HW,
buffer->planes[0].fd, temp_bbox.g_rect_num, temp_bbox.g_rect);
#endif
//////////////////// Brad's attempt to add text to the OSD
//////////////////// End of hacking in some text
// EglRenderer requires the fd of the 0th plane to render
ctx->renderer->render(buffer->planes[0].fd);
// Write raw video frame to file and return the buffer to converter
@@ -534,7 +513,6 @@
#ifdef ENABLE_GIE
void *gie_thread(void *data)
int buf_num = 0;
HI bmears,
I am checking this internally. Thanks for your patience.
HI bmears,
Because nvosd_put_text with MODE_CPU only accepts RGBA buffer and backend sample is using YUV buffer, you need to convert it to RGBA buffer first.
A simple patch for you by using 02_video_dec_cuda
.../samples/02_video_dec_cuda/videodec.h | 1 +
.../samples/02_video_dec_cuda/videodec_main.cpp | 25 +++++++++++++++++++++-
2 files changed, 25 insertions(+), 1 deletion(-)
diff --git a/multimedia_api/ll_samples/samples/02_video_dec_cuda/videodec.h b/multimedia_api/ll_samples/samples/02_video_dec_cuda/videodec.h
index 00d86c4..2727ad3 100644
--- a/multimedia_api/ll_samples/samples/02_video_dec_cuda/videodec.h
+++ b/multimedia_api/ll_samples/samples/02_video_dec_cuda/videodec.h
@@ -73,6 +73,7 @@ typedef struct
char *osd_file_path;
std::ifstream *osd_file;
NvOSD_RectParams g_rect[MAX_RECT_NUM];
+ NvOSD_TextParams textParams;
int g_rect_num;
std::queue < NvBuffer * > *conv_output_plane_buf_queue;
diff --git a/multimedia_api/ll_samples/samples/02_video_dec_cuda/videodec_main.cpp b/multimedia_api/ll_samples/samples/02_video_dec_cuda/videodec_main.cpp
index 08b8c5d..21b2ab1 100644
--- a/multimedia_api/ll_samples/samples/02_video_dec_cuda/videodec_main.cpp
+++ b/multimedia_api/ll_samples/samples/02_video_dec_cuda/videodec_main.cpp
@@ -162,6 +162,20 @@ abort(context_t *ctx)
pthread_cond_broadcast(&ctx->queue_cond);
+static void
+set_text(context_t* ctx)
+ ctx->textParams.display_text = strdup("Hello world");
+ ctx->textParams.x_offset = 400;
+ ctx->textParams.y_offset = 30;
+ ctx->textParams.font_params.font_name = strdup("Arial");
+ ctx->textParams.font_params.font_size = 18;
+ ctx->textParams.font_params.font_color.red = 1.0;
+ ctx->textParams.font_params.font_color.green = 0.0;
+ ctx->textParams.font_params.font_color.blue = 1.0;
+ ctx->textParams.font_params.font_color.alpha = 1.0;
static void
get_rect(context_t *ctx)
@@ -352,6 +366,12 @@ conv0_capture_dqbuf_thread_callback(struct v4l2_buffer *v4l2_buf,
ctx->g_rect_num,
ctx->g_rect);
+ set_text(ctx);
+ nvosd_put_text(ctx->nvosd_context,
+ MODE_CPU,
+ buffer->planes[0].fd,
+ 1,
+ &ctx->textParams);
// capture plane
@@ -530,7 +550,7 @@ query_and_set_capture(context_t * ctx)
error);
ret = ctx->conv->setCapturePlaneFormat((ctx->out_pixfmt == 1 ?
- V4L2_PIX_FMT_NV12M :
+ V4L2_PIX_FMT_ABGR32 :
V4L2_PIX_FMT_YUV420M),
crop.c.width,
crop.c.height,
@@ -810,6 +830,7 @@ main(int argc, char *argv[])
return -1;
+ ctx.nvosd_context = nvosd_create_context();
if (ctx.enable_osd) {
cout << "ctx.osd_file_path:" << ctx.osd_file_path << endl;
@@ -1050,6 +1071,8 @@ cleanup:
nvosd_destroy_context(ctx.nvosd_context);
ctx.nvosd_context = NULL;
+ nvosd_destroy_context(ctx.nvosd_context);
+ ctx.nvosd_context = NULL;
if (error)
2.1.4
I have a similar question on the NvOSD circle and arrow functions. They both throw an “unsupported color format” error on NV12 and ARGB32 type NvBuffers, using either MODE_HW or MODE_CPU. Are these implemented? If so, what type of buffer do they work with? thanks!
DaneLLL
September 27, 2018, 8:43am
#6
Please share a patch on 02_video_dec_cuda so that we can check the issue. Thanks.
A BRGA buffer does work with circles and arrows, but the RGBA does not. I can move forward, since I have a solution. Thanks.
