Thank you for guidance,
I have managed to create a Python 3.8 environment and even, managed to make to notebook run until !tao heartratenet dataset_convert --experiment_spec_file $DATAIO_SPEC
command. But after running the command:
I got this output:
HTTP request sent, awaiting response...
2023-10-19 12:18:01,029 [INFO] root: Registry: ['nvcr.io']
2023-10-19 12:18:01,072 [INFO] tlt.components.instance_handler.local_instance: Running command in container: nvcr.io/nvidia/tao/tao-toolkit:4.0.0-tf1.15.5
2023-10-19 12:18:01,084 [WARNING] tlt.components.docker_handler.docker_handler:
Docker will run the commands as root. If you would like to retain your
local host permissions, please add the "user":"UID:GID" in the
DockerOptions portion of the "/home/mericgeren/.tao_mounts.json" file. You can obtain your
users UID and GID by using the "id -u" and "id -g" commands on the
terminal.
302 Found
Location: https://raw.githubusercontent.com/opencv/opencv/master/data/haarcascades/haarcascade_frontalface_default.xml [following]
--2023-10-19 12:18:00-- https://raw.githubusercontent.com/opencv/opencv/master/data/haarcascades/haarcascade_frontalface_default.xml
Resolving raw.githubusercontent.com (raw.githubusercontent.com)... 185.199.110.133, 185.199.111.133, 185.199.108.133, ...
Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|185.199.110.133|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 930127 (908K) [text/plain]
Saving to: ‘/home/mericgeren/the_tao_workspace/cv_samples_v1.4.1/heartratenet/heartratenet/data/haarcascade_frontalface_default.xml.12’
0K .......... .......... .......... .......... .......... 5% 749K 1s
50K .......... .......... .......... .......... .......... 11% 1.02M 1s
100K .......... .......... .......... .......... .......... 16% 3.30M 1s
150K .......... .......... .......... .......... .......... 22% 4.27M 0s
200K .......... .......... .......... .......... .......... 27% 1.63M 0s
250K .......... .......... .......... .......... .......... 33% 5.68M 0s
300K .......... .......... .......... .......... .......... 38% 6.96M 0s
350K .......... .......... .......... .......... .......... 44% 7.00M 0s
400K .......... .......... .......... .......... .......... 49% 6.38M 0s
450K .......... .......... .......... .......... .......... 55% 2.24M 0s
500K .......... .......... .......... .......... .......... 60% 6.56M 0s
550K .......... .......... .......... .......... .......... 66% 10.2M 0s
600K .......... .......... .......... .......... .......... 71% 11.2M 0s
650K .......... .......... .......... .......... .......... 77% 8.61M 0s
700K .......... .......... .......... .......... .......... 82% 28.0M 0s
750K .......... .......... .......... .......... .......... 88% 11.1M 0s
800K .......... .......... .......... .......... .......... 93% 12.5M 0s
850K .......... .......... .......... .......... .......... 99% 21.2M 0s
900K ........ 100% 189M=0.3s
2023-10-19 12:18:01 (3.45 MB/s) - ‘/home/mericgeren/the_tao_workspace/cv_samples_v1.4.1/heartratenet/heartratenet/data/haarcascade_frontalface_default.xml.12’ saved [930127/930127]
Using TensorFlow backend.
2023-10-19 09:18:03.192036: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcudart.so.11.0
WARNING:tensorflow:Deprecation warnings have been disabled. Set TF_ENABLE_DEPRECATION_WARNINGS=1 to re-enable them.
/usr/local/lib/python3.6/dist-packages/requests/__init__.py:91: RequestsDependencyWarning: urllib3 (1.26.5) or chardet (3.0.4) doesn't match a supported version!
RequestsDependencyWarning)
/usr/local/lib/python3.6/dist-packages/driveix/heartratenet/scripts/dataset_convert.py:62: YAMLLoadWarning: calling yaml.load() without Loader=... is deprecated, as the default Loader is unsafe. Please read https://msg.pyyaml.org/load for full details.
[image2 @ 0x7200e00] Could find no file with path '/workspace/tao-experiments/heartratenet/data/cohface_processed/1/0/images/%04d.bmp' and index in the range 0-4
File "</usr/local/lib/python3.6/dist-packages/driveix/heartratenet/scripts/dataset_convert.py>", line 3, in <module>
File "<frozen driveix.heartratenet.scripts.dataset_convert>", line 70, in <module>
File "<frozen driveix.heartratenet.scripts.dataset_convert>", line 64, in main
File "<frozen driveix.heartratenet.dataio.generate_dataset>", line 121, in preprocess_subjects
File "<frozen driveix.heartratenet.dataio.generate_dataset>", line 135, in preprocess_subject
File "<frozen driveix.heartratenet.dataio.generate_dataset>", line 297, in load_subject_files
File "/usr/local/lib/python3.6/dist-packages/pandas/io/parsers.py", line 685, in parser_f
return _read(filepath_or_buffer, kwds)
File "/usr/local/lib/python3.6/dist-packages/pandas/io/parsers.py", line 457, in _read
parser = TextFileReader(fp_or_buf, **kwds)
File "/usr/local/lib/python3.6/dist-packages/pandas/io/parsers.py", line 895, in __init__
self._make_engine(self.engine)
File "/usr/local/lib/python3.6/dist-packages/pandas/io/parsers.py", line 1147, in _make_engine
self._engine = klass(self.f, **self.options)
File "/usr/local/lib/python3.6/dist-packages/pandas/io/parsers.py", line 2293, in __init__
memory_map=self.memory_map,
File "/usr/local/lib/python3.6/dist-packages/pandas/io/common.py", line 402, in _get_handle
f = open(path_or_buf, mode, errors="replace", newline="")
FileNotFoundError: [Errno 2] No such file or directory: '/workspace/tao-experiments/heartratenet/data/cohface_processed/1/0/ground_truth.csv'
Execution status: FAIL
2023-10-19 12:18:11,377 [INFO] tlt.components.docker_handler.docker_handler: Stopping container.
Later after running the command:
!tao heartratenet train -e $TRAIN_SPEC \
-k $KEY \
-r $USER_EXPERIMENT_DIR/model
I got this output:
2023-10-19 12:18:12,721 [INFO] root: Registry: ['nvcr.io']
2023-10-19 12:18:12,764 [INFO] tlt.components.instance_handler.local_instance: Running command in container: nvcr.io/nvidia/tao/tao-toolkit:4.0.0-tf1.15.5
2023-10-19 12:18:12,772 [WARNING] tlt.components.docker_handler.docker_handler:
terminal.
2023-10-19 09:18:14.225673: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcudart.so.11.0
/usr/local/lib/python3.6/dist-packages/driveix/heartratenet/scripts/train.py:102: YAMLLoadWarning: calling yaml.load() without Loader=... is deprecated, as the default Loader is unsafe. Please read https://msg.pyyaml.org/load for full details.
/workspace/tao-experiments/heartratenet/model
2023-10-19 09:18:18,625 [INFO] iva.common.logging.logging: Log file already exists at /workspace/tao-experiments/heartratenet/model/status.json
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:153: The name tf.get_default_graph is deprecated. Please use tf.compat.v1.get_default_graph instead.
2023-10-19 09:18:18,636 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:153: The name tf.get_default_graph is deprecated. Please use tf.compat.v1.get_default_graph instead.
File "</usr/local/lib/python3.6/dist-packages/driveix/heartratenet/scripts/train.py>", line 3, in <module>
File "<frozen driveix.heartratenet.scripts.train>", line 158, in <module>
File "<frozen driveix.heartratenet.scripts.train>", line 138, in main
File "<frozen driveix.heartratenet.trainers.heartratenet_trainer>", line 101, in build
File "<frozen driveix.heartratenet.dataloader.heartratenet_dataloader>", line 69, in __call__
File "<frozen driveix.heartratenet.dataloader.heartratenet_dataloader>", line 237, in _get_tfrecords_iterator
File "<frozen moduluspy.modulus.modulusobject.modulusobject>", line 432, in wrapper
File "<frozen moduluspy.modulus.processors.tfrecords_iterator>", line 91, in __init__
ValueError: 'shuffle' is True while 'shuffle_buffer_size' is 0.
2023-10-19 12:18:22,264 [INFO] tlt.components.docker_handler.docker_handler: Stopping container.
Here is the output of !tao info
Configuration of the TAO Toolkit Instance
dockers: ['nvidia/tao/tao-toolkit']
format_version: 2.0
toolkit_version: 4.0.1
published_date: 03/06/2023
Could you offer your advice please?
Kindest regards.
P.S. I couldn’t get and download COHFACE for now. So, i wanted to try it without COHFACE. Also, may i ask your guidance on where to put the COHFACE please?
