I’m getting the following message and no one from dcs support is responding. How do I get access to this?
Hello. Double-check that you are logging in with the correct credentials.
If you are certain that you are using the correct login information, consider checking the permissions associated with your account to see if there is anything preventing you from accessing the developer portal. If you have a team or organization account, make sure that the necessary permissions have been granted to your account.
