When i click to generate my API key, the dialog box disappears and I’m never given my key.
I’ve tried on different browsers but still no luck. Can anybody help me?
Hi @OhDim! Thanks for reaching out with your question.
The dialog box should disappear once you click “Generate API Key” and your API key should be appear on the page as a third code snippet block.
The expected steps are as follows:
I gave this a try from my end just now and it worked as expected.
If you’re still unable to generate the API key, can you please share a screen recording of your experience along with the exact browser name and version you’re using for further triage? I’ll be happy to route this internally to have your issue resolved at the earliest.
(post deleted by author)
When I try to generate an API key I get the message ‘Selecting “Confirm” will generate a new API Key, and your old API Key will become invalid.’ However, when I click on Confirm the dialog box disappears and never got my key.
I’ve tried this several times in different browsers but…not getting…
