Unable to get gpu metrics on Quadro GV100
I am using a Quadro GV100 2EA on Ubuntu 22.04
i ran nsys to get the GPU metrics but could not get them.
░▒▓    ~/Tools  nsys --version
NVIDIA Nsight Systems version 2023.4.1.97-234133557503v0
▒▓    ~/Tools  sudo nsys profile --gpu-metrics-device=help
Possible --gpu-metrics-device values are:
Some GPUs are not supported:
Quadro GV100 PCI[0000:17:00.0]
Quadro GV100 PCI[0000:73:00.0]
See the user guide: User Guide — Nsight Systems
I’ve done the following to fix the problem, but it still says it doesn’t support it.
I wonder if the GV100 is really not supported.
GPU Metrics are supported on Compute Capability 7.5 (Turing) and above. GPU Metrics are not supported on Compute Capability <7.5 (Volta, Pascal, Maxwell, …).
@Greg , Thanks for the answer.
I would like to try to pull the GPU Bandwidth value. Is there any other way besides Nsys?
The NVIDIA Data Center GPU Monitoring tool supports GV100 on most platforms. DCGM GPU Profiler can sample PROF_DRAM_ACTIVE at a low frequency (1-10Hz). This is reported as a percentage which can be converted back to a value. It does not breakdown reads vs. writes.
https://docs.nvidia.com/datacenter/dcgm/latest/user-guide/feature-overview.html#profiling-metrics
