Hi. I am trying to install the lxml library required for TensorFlow Object Detection API by executing: pip install lxml (inside a Python3 virtual environment). I am meeting with the following error:
Collecting lxml
Downloading https://files.pythonhosted.org/packages/e4/19/8dfeef50623892577dc05245093e090bb2bab4c8aed5cad5b03208959563/lxml-4.4.2.tar.gz (2.6MB)
|████████████████████████████████| 2.6MB 58kB/s
Building wheels for collected packages: lxml
WARNING: Building wheel for lxml failed: [Errno 13] Permission denied: '/home/pyimagesearch/.cache/pip/wheels/73'
Failed to build lxml
Installing collected packages: lxml
Running setup.py install for lxml ... error
ERROR: Command errored out with exit status 1:
command: /home/pyimagesearch/.virtualenvs/py3cv4/bin/python3 -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-hdz59_f3/lxml/setup.py'"'"'; __file__='"'"'/tmp/pip-install-hdz59_f3/lxml/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-9rvpxls3/install-record.txt --single-version-externally-managed --compile --install-headers /home/pyimagesearch/.virtualenvs/py3cv4/include/site/python3.6/lxml
cwd: /tmp/pip-install-hdz59_f3/lxml/
Complete output (93 lines):
Building lxml version 4.4.2.
Building without Cython.
ERROR: b'/bin/sh: 1: xslt-config: not found\n'
** make sure the development packages of libxml2 and libxslt are installed **
Using build configuration of libxslt
running install
running build
running build_py
creating build
creating build/lib.linux-aarch64-3.6
creating build/lib.linux-aarch64-3.6/lxml
copying src/lxml/sax.py -> build/lib.linux-aarch64-3.6/lxml
copying src/lxml/builder.py -> build/lib.linux-aarch64-3.6/lxml
copying src/lxml/ElementInclude.py -> build/lib.linux-aarch64-3.6/lxml
copying src/lxml/doctestcompare.py -> build/lib.linux-aarch64-3.6/lxml
copying src/lxml/pyclasslookup.py -> build/lib.linux-aarch64-3.6/lxml
copying src/lxml/__init__.py -> build/lib.linux-aarch64-3.6/lxml
copying src/lxml/usedoctest.py -> build/lib.linux-aarch64-3.6/lxml
copying src/lxml/_elementpath.py -> build/lib.linux-aarch64-3.6/lxml
copying src/lxml/cssselect.py -> build/lib.linux-aarch64-3.6/lxml
creating build/lib.linux-aarch64-3.6/lxml/includes
copying src/lxml/includes/__init__.py -> build/lib.linux-aarch64-3.6/lxml/includes
creating build/lib.linux-aarch64-3.6/lxml/html
copying src/lxml/html/html5parser.py -> build/lib.linux-aarch64-3.6/lxml/html
copying src/lxml/html/clean.py -> build/lib.linux-aarch64-3.6/lxml/html
copying src/lxml/html/defs.py -> build/lib.linux-aarch64-3.6/lxml/html
copying src/lxml/html/_setmixin.py -> build/lib.linux-aarch64-3.6/lxml/html
copying src/lxml/html/builder.py -> build/lib.linux-aarch64-3.6/lxml/html
copying src/lxml/html/_html5builder.py -> build/lib.linux-aarch64-3.6/lxml/html
copying src/lxml/html/_diffcommand.py -> build/lib.linux-aarch64-3.6/lxml/html
copying src/lxml/html/__init__.py -> build/lib.linux-aarch64-3.6/lxml/html
copying src/lxml/html/formfill.py -> build/lib.linux-aarch64-3.6/lxml/html
copying src/lxml/html/ElementSoup.py -> build/lib.linux-aarch64-3.6/lxml/html
copying src/lxml/html/diff.py -> build/lib.linux-aarch64-3.6/lxml/html
copying src/lxml/html/usedoctest.py -> build/lib.linux-aarch64-3.6/lxml/html
copying src/lxml/html/soupparser.py -> build/lib.linux-aarch64-3.6/lxml/html
creating build/lib.linux-aarch64-3.6/lxml/isoschematron
copying src/lxml/isoschematron/__init__.py -> build/lib.linux-aarch64-3.6/lxml/isoschematron
copying src/lxml/etree.h -> build/lib.linux-aarch64-3.6/lxml
copying src/lxml/etree_api.h -> build/lib.linux-aarch64-3.6/lxml
copying src/lxml/lxml.etree.h -> build/lib.linux-aarch64-3.6/lxml
copying src/lxml/lxml.etree_api.h -> build/lib.linux-aarch64-3.6/lxml
copying src/lxml/includes/dtdvalid.pxd -> build/lib.linux-aarch64-3.6/lxml/includes
copying src/lxml/includes/xmlparser.pxd -> build/lib.linux-aarch64-3.6/lxml/includes
copying src/lxml/includes/xmlschema.pxd -> build/lib.linux-aarch64-3.6/lxml/includes
copying src/lxml/includes/schematron.pxd -> build/lib.linux-aarch64-3.6/lxml/includes
copying src/lxml/includes/__init__.pxd -> build/lib.linux-aarch64-3.6/lxml/includes
copying src/lxml/includes/xmlerror.pxd -> build/lib.linux-aarch64-3.6/lxml/includes
copying src/lxml/includes/xpath.pxd -> build/lib.linux-aarch64-3.6/lxml/includes
copying src/lxml/includes/uri.pxd -> build/lib.linux-aarch64-3.6/lxml/includes
copying src/lxml/includes/etreepublic.pxd -> build/lib.linux-aarch64-3.6/lxml/includes
copying src/lxml/includes/config.pxd -> build/lib.linux-aarch64-3.6/lxml/includes
copying src/lxml/includes/relaxng.pxd -> build/lib.linux-aarch64-3.6/lxml/includes
copying src/lxml/includes/tree.pxd -> build/lib.linux-aarch64-3.6/lxml/includes
copying src/lxml/includes/xinclude.pxd -> build/lib.linux-aarch64-3.6/lxml/includes
copying src/lxml/includes/htmlparser.pxd -> build/lib.linux-aarch64-3.6/lxml/includes
copying src/lxml/includes/xslt.pxd -> build/lib.linux-aarch64-3.6/lxml/includes
copying src/lxml/includes/c14n.pxd -> build/lib.linux-aarch64-3.6/lxml/includes
copying src/lxml/includes/lxml-version.h -> build/lib.linux-aarch64-3.6/lxml/includes
copying src/lxml/includes/etree_defs.h -> build/lib.linux-aarch64-3.6/lxml/includes
creating build/lib.linux-aarch64-3.6/lxml/isoschematron/resources
creating build/lib.linux-aarch64-3.6/lxml/isoschematron/resources/rng
copying src/lxml/isoschematron/resources/rng/iso-schematron.rng -> build/lib.linux-aarch64-3.6/lxml/isoschematron/resources/rng
creating build/lib.linux-aarch64-3.6/lxml/isoschematron/resources/xsl
copying src/lxml/isoschematron/resources/xsl/RNG2Schtrn.xsl -> build/lib.linux-aarch64-3.6/lxml/isoschematron/resources/xsl
copying src/lxml/isoschematron/resources/xsl/XSD2Schtrn.xsl -> build/lib.linux-aarch64-3.6/lxml/isoschematron/resources/xsl
creating build/lib.linux-aarch64-3.6/lxml/isoschematron/resources/xsl/iso-schematron-xslt1
copying src/lxml/isoschematron/resources/xsl/iso-schematron-xslt1/iso_abstract_expand.xsl -> build/lib.linux-aarch64-3.6/lxml/isoschematron/resources/xsl/iso-schematron-xslt1
copying src/lxml/isoschematron/resources/xsl/iso-schematron-xslt1/iso_schematron_skeleton_for_xslt1.xsl -> build/lib.linux-aarch64-3.6/lxml/isoschematron/resources/xsl/iso-schematron-xslt1
copying src/lxml/isoschematron/resources/xsl/iso-schematron-xslt1/iso_svrl_for_xslt1.xsl -> build/lib.linux-aarch64-3.6/lxml/isoschematron/resources/xsl/iso-schematron-xslt1
copying src/lxml/isoschematron/resources/xsl/iso-schematron-xslt1/iso_dsdl_include.xsl -> build/lib.linux-aarch64-3.6/lxml/isoschematron/resources/xsl/iso-schematron-xslt1
copying src/lxml/isoschematron/resources/xsl/iso-schematron-xslt1/iso_schematron_message.xsl -> build/lib.linux-aarch64-3.6/lxml/isoschematron/resources/xsl/iso-schematron-xslt1
copying src/lxml/isoschematron/resources/xsl/iso-schematron-xslt1/readme.txt -> build/lib.linux-aarch64-3.6/lxml/isoschematron/resources/xsl/iso-schematron-xslt1
running build_ext
building 'lxml.etree' extension
creating build/temp.linux-aarch64-3.6
creating build/temp.linux-aarch64-3.6/src
creating build/temp.linux-aarch64-3.6/src/lxml
aarch64-linux-gnu-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -DCYTHON_CLINE_IN_TRACEBACK=0 -Isrc -Isrc/lxml/includes -I/usr/include/python3.6m -I/home/pyimagesearch/.virtualenvs/py3cv4/include/python3.6m -c src/lxml/etree.c -o build/temp.linux-aarch64-3.6/src/lxml/etree.o -w
In file included from src/lxml/etree.c:692:0:
src/lxml/includes/etree_defs.h:14:10: fatal error: libxml/xmlversion.h: No such file or directory
#include "libxml/xmlversion.h"
compilation terminated.
Compile failed: command 'aarch64-linux-gnu-gcc' failed with exit status 1
creating tmp
cc -I/usr/include/libxml2 -c /tmp/xmlXPathInitpm4dvm8o.c -o tmp/xmlXPathInitpm4dvm8o.o
/tmp/xmlXPathInitpm4dvm8o.c:2:1: warning: return type defaults to ‘int’ [-Wimplicit-int]
main (int argc, char **argv) {
cc tmp/xmlXPathInitpm4dvm8o.o -lxml2 -o a.out
error: command 'aarch64-linux-gnu-gcc' failed with exit status 1
ERROR: Command errored out with exit status 1: /home/pyimagesearch/.virtualenvs/py3cv4/bin/python3 -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-hdz59_f3/lxml/setup.py'"'"'; __file__='"'"'/tmp/pip-install-hdz59_f3/lxml/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-9rvpxls3/install-record.txt --single-version-externally-managed --compile --install-headers /home/pyimagesearch/.virtualenvs/py3cv4/include/site/python3.6/lxml Check the logs for full command output.
