I am trying to follow this tutorial:
but when I run this command:
sudo pip3 install --pre --extra-index-url https://developer.download.nvidia.com/compute/redist/jp/v42 tensorflow-gpu
I get the following errors:
mojito@mojito-desktop:~$ sudo pip3 install --pre --extra-index-url https://developer.download.nvidia.com/compute/redist/jp/v42 tensorflow-gpu
[sudo] password for mojito:
WARNING: The directory '/home/mojito/.cache/pip/http' or its parent directory is not owned by the current user and the cache has been disabled. Please check the permissions and owner of that directory. If executing pip with sudo, you may want sudo's -H flag.
WARNING: The directory '/home/mojito/.cache/pip' or its parent directory is not owned by the current user and caching wheels has been disabled. check the permissions and owner of that directory. If executing pip with sudo, you may want sudo's -H flag.
Looking in indexes: https://pypi.org/simple, https://developer.download.nvidia.com/compute/redist/jp/v42
Collecting tensorflow-gpu
Downloading https://developer.download.nvidia.com/compute/redist/jp/v42/tensorflow-gpu/tensorflow_gpu-1.14.0%2Bnv19.9-cp36-cp36m-linux_aarch64.whl (225.3MB)
|████████████████████████████████| 225.3MB 764kB/s
Requirement already satisfied: wheel>=0.26 in /usr/local/lib/python3.6/dist-packages (from tensorflow-gpu) (0.33.6)
Collecting termcolor>=1.1.0
Downloading https://files.pythonhosted.org/packages/8a/48/a76be51647d0eb9f10e2a4511bf3ffb8cc1e6b14e9e4fab46173aa79f981/termcolor-1.1.0.tar.gz
Requirement already satisfied: tensorflow-estimator<1.15.0rc0,>=1.14.0rc0 in /usr/local/lib/python3.6/dist-packages (from tensorflow-gpu) (1.14.0)
Collecting tensorboard<1.15.0,>=1.14.0
Downloading https://files.pythonhosted.org/packages/91/2d/2ed263449a078cd9c8a9ba50ebd50123adf1f8cfbea1492f9084169b89d9/tensorboard-1.14.0-py3-none-any.whl (3.1MB)
|████████████████████████████████| 3.2MB 637kB/s
Collecting keras-preprocessing>=1.0.5
Downloading https://files.pythonhosted.org/packages/28/6a/8c1f62c37212d9fc441a7e26736df51ce6f0e38455816445471f10da4f0a/Keras_Preprocessing-1.1.0-py2.py3-none-any.whl (41kB)
|████████████████████████████████| 51kB 966kB/s
Collecting keras-applications>=1.0.6
Downloading https://files.pythonhosted.org/packages/71/e3/19762fdfc62877ae9102edf6342d71b28fbfd9dea3d2f96a882ce099b03f/Keras_Applications-1.0.8-py3-none-any.whl (50kB)
|████████████████████████████████| 51kB 1.2MB/s
Collecting grpcio>=1.8.6
Downloading https://files.pythonhosted.org/packages/0c/7b/97fce81c5f9bbe989c2f11e9d179b953f56c765af9427005e7d2f58277aa/grpcio-1.24.1.tar.gz (14.1MB)
|████████████████████████████████| 14.1MB 503kB/s
Requirement already satisfied: six>=1.10.0 in /usr/lib/python3/dist-packages (from tensorflow-gpu) (1.11.0)
Requirement already satisfied: protobuf>=3.6.1 in /usr/local/lib/python3.6/dist-packages (from tensorflow-gpu) (3.10.0)
Collecting wrapt>=1.11.1
Downloading https://files.pythonhosted.org/packages/23/84/323c2415280bc4fc880ac5050dddfb3c8062c2552b34c2e512eb4aa68f79/wrapt-1.11.2.tar.gz
Collecting google-pasta>=0.1.6
Downloading https://files.pythonhosted.org/packages/d0/33/376510eb8d6246f3c30545f416b2263eee461e40940c2a4413c711bdf62d/google_pasta-0.1.7-py3-none-any.whl (52kB)
|████████████████████████████████| 61kB 1.5MB/s
Collecting numpy<2.0,>=1.14.5
Downloading https://files.pythonhosted.org/packages/b6/d6/be8f975f5322336f62371c9abeb936d592c98c047ad63035f1b38ae08efe/numpy-1.17.3.zip (6.4MB)
|████████████████████████████████| 6.4MB 514kB/s
Collecting astor>=0.6.0
Downloading https://files.pythonhosted.org/packages/d1/4f/950dfae467b384fc96bc6469de25d832534f6b4441033c39f914efd13418/astor-0.8.0-py2.py3-none-any.whl
Requirement already satisfied: absl-py>=0.7.0 in /usr/local/lib/python3.6/dist-packages (from tensorflow-gpu) (0.8.1)
Collecting gast==0.2.2
Downloading https://files.pythonhosted.org/packages/4e/35/11749bf99b2d4e3cceb4d55ca22590b0d7c2c62b9de38ac4a4a7f4687421/gast-0.2.2.tar.gz
Requirement already satisfied: setuptools>=41.0.0 in /usr/local/lib/python3.6/dist-packages (from tensorboard<1.15.0,>=1.14.0->tensorflow-gpu) (41.4.0)
Requirement already satisfied: werkzeug>=0.11.15 in /usr/local/lib/python3.6/dist-packages (from tensorboard<1.15.0,>=1.14.0->tensorflow-gpu) (0.16.0)
Collecting markdown>=2.6.8
Downloading https://files.pythonhosted.org/packages/c0/4e/fd492e91abdc2d2fcb70ef453064d980688762079397f779758e055f6575/Markdown-3.1.1-py2.py3-none-any.whl (87kB)
|████████████████████████████████| 92kB 143kB/s
Collecting h5py
Downloading https://files.pythonhosted.org/packages/5f/97/a58afbcf40e8abecededd9512978b4e4915374e5b80049af082f49cebe9a/h5py-2.10.0.tar.gz (301kB)
|████████████████████████████████| 307kB 274kB/s
Building wheels for collected packages: termcolor, grpcio, wrapt, numpy, gast, h5py
Building wheel for termcolor (setup.py) ... done
Created wheel for termcolor: filename=termcolor-1.1.0-cp36-none-any.whl size=4832 sha256=3be1e170f86c0f43531ed667ac50ce962e62fa298d09c7fb4221e2654b1b304e
Stored in directory: /home/mojito/.cache/pip/wheels/7c/06/54/bc84598ba1daf8f970247f550b175aaaee85f68b4b0c5ab2c6
Building wheel for grpcio (setup.py) ... error
ERROR: Command errored out with exit status 1:
command: /usr/bin/python3 -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-uzmrzqtj/grpcio/setup.py'"'"'; __file__='"'"'/tmp/pip-install-uzmrzqtj/grpcio/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' bdist_wheel -d /tmp/pip-wheel-eyrrnghs --python-tag cp36
cwd: /tmp/pip-install-uzmrzqtj/grpcio/
Complete output (340 lines):
Found cython-generated files...
running bdist_wheel
running build
running build_py
running build_project_metadata
creating python_build
creating python_build/lib.linux-aarch64-3.6
creating python_build/lib.linux-aarch64-3.6/grpc
copying src/python/grpcio/grpc/_interceptor.py -> python_build/lib.linux-aarch64-3.6/grpc
copying src/python/grpcio/grpc/_server.py -> python_build/lib.linux-aarch64-3.6/grpc
copying src/python/grpcio/grpc/_compression.py -> python_build/lib.linux-aarch64-3.6/grpc
copying src/python/grpcio/grpc/_auth.py -> python_build/lib.linux-aarch64-3.6/grpc
copying src/python/grpcio/grpc/_common.py -> python_build/lib.linux-aarch64-3.6/grpc
copying src/python/grpcio/grpc/_channel.py -> python_build/lib.linux-aarch64-3.6/grpc
copying src/python/grpcio/grpc/_utilities.py -> python_build/lib.linux-aarch64-3.6/grpc
copying src/python/grpcio/grpc/_plugin_wrapping.py -> python_build/lib.linux-aarch64-3.6/grpc
copying src/python/grpcio/grpc/_grpcio_metadata.py -> python_build/lib.linux-aarch64-3.6/grpc
copying src/python/grpcio/grpc/__init__.py -> python_build/lib.linux-aarch64-3.6/grpc
creating python_build/lib.linux-aarch64-3.6/grpc/beta
copying src/python/grpcio/grpc/beta/interfaces.py -> python_build/lib.linux-aarch64-3.6/grpc/beta
copying src/python/grpcio/grpc/beta/utilities.py -> python_build/lib.linux-aarch64-3.6/grpc/beta
copying src/python/grpcio/grpc/beta/implementations.py -> python_build/lib.linux-aarch64-3.6/grpc/beta
copying src/python/grpcio/grpc/beta/_metadata.py -> python_build/lib.linux-aarch64-3.6/grpc/beta
copying src/python/grpcio/grpc/beta/_server_adaptations.py -> python_build/lib.linux-aarch64-3.6/grpc/beta
copying src/python/grpcio/grpc/beta/_client_adaptations.py -> python_build/lib.linux-aarch64-3.6/grpc/beta
copying src/python/grpcio/grpc/beta/__init__.py -> python_build/lib.linux-aarch64-3.6/grpc/beta
creating python_build/lib.linux-aarch64-3.6/grpc/_cython
copying src/python/grpcio/grpc/_cython/__init__.py -> python_build/lib.linux-aarch64-3.6/grpc/_cython
creating python_build/lib.linux-aarch64-3.6/grpc/experimental
copying src/python/grpcio/grpc/experimental/gevent.py -> python_build/lib.linux-aarch64-3.6/grpc/experimental
copying src/python/grpcio/grpc/experimental/session_cache.py -> python_build/lib.linux-aarch64-3.6/grpc/experimental
copying src/python/grpcio/grpc/experimental/__init__.py -> python_build/lib.linux-aarch64-3.6/grpc/experimental
creating python_build/lib.linux-aarch64-3.6/grpc/framework
copying src/python/grpcio/grpc/framework/__init__.py -> python_build/lib.linux-aarch64-3.6/grpc/framework
creating python_build/lib.linux-aarch64-3.6/grpc/_cython/_cygrpc
copying src/python/grpcio/grpc/_cython/_cygrpc/__init__.py -> python_build/lib.linux-aarch64-3.6/grpc/_cython/_cygrpc
creating python_build/lib.linux-aarch64-3.6/grpc/framework/interfaces
copying src/python/grpcio/grpc/framework/interfaces/__init__.py -> python_build/lib.linux-aarch64-3.6/grpc/framework/interfaces
creating python_build/lib.linux-aarch64-3.6/grpc/framework/common
copying src/python/grpcio/grpc/framework/common/style.py -> python_build/lib.linux-aarch64-3.6/grpc/framework/common
copying src/python/grpcio/grpc/framework/common/cardinality.py -> python_build/lib.linux-aarch64-3.6/grpc/framework/common
copying src/python/grpcio/grpc/framework/common/__init__.py -> python_build/lib.linux-aarch64-3.6/grpc/framework/common
creating python_build/lib.linux-aarch64-3.6/grpc/framework/foundation
copying src/python/grpcio/grpc/framework/foundation/callable_util.py -> python_build/lib.linux-aarch64-3.6/grpc/framework/foundation
copying src/python/grpcio/grpc/framework/foundation/stream.py -> python_build/lib.linux-aarch64-3.6/grpc/framework/foundation
copying src/python/grpcio/grpc/framework/foundation/logging_pool.py -> python_build/lib.linux-aarch64-3.6/grpc/framework/foundation
copying src/python/grpcio/grpc/framework/foundation/abandonment.py -> python_build/lib.linux-aarch64-3.6/grpc/framework/foundation
copying src/python/grpcio/grpc/framework/foundation/future.py -> python_build/lib.linux-aarch64-3.6/grpc/framework/foundation
copying src/python/grpcio/grpc/framework/foundation/stream_util.py -> python_build/lib.linux-aarch64-3.6/grpc/framework/foundation
copying src/python/grpcio/grpc/framework/foundation/__init__.py -> python_build/lib.linux-aarch64-3.6/grpc/framework/foundation
creating python_build/lib.linux-aarch64-3.6/grpc/framework/interfaces/base
copying src/python/grpcio/grpc/framework/interfaces/base/utilities.py -> python_build/lib.linux-aarch64-3.6/grpc/framework/interfaces/base
copying src/python/grpcio/grpc/framework/interfaces/base/base.py -> python_build/lib.linux-aarch64-3.6/grpc/framework/interfaces/base
copying src/python/grpcio/grpc/framework/interfaces/base/__init__.py -> python_build/lib.linux-aarch64-3.6/grpc/framework/interfaces/base
creating python_build/lib.linux-aarch64-3.6/grpc/framework/interfaces/face
copying src/python/grpcio/grpc/framework/interfaces/face/face.py -> python_build/lib.linux-aarch64-3.6/grpc/framework/interfaces/face
copying src/python/grpcio/grpc/framework/interfaces/face/utilities.py -> python_build/lib.linux-aarch64-3.6/grpc/framework/interfaces/face
copying src/python/grpcio/grpc/framework/interfaces/face/__init__.py -> python_build/lib.linux-aarch64-3.6/grpc/framework/interfaces/face
creating python_build/lib.linux-aarch64-3.6/grpc/_cython/_credentials
copying src/python/grpcio/grpc/_cython/_credentials/roots.pem -> python_build/lib.linux-aarch64-3.6/grpc/_cython/_credentials
running build_ext
building 'grpc._cython.cygrpc' extension
creating python_build/temp.linux-aarch64-3.6
creating python_build/temp.linux-aarch64-3.6/src
creating python_build/temp.linux-aarch64-3.6/src/python
creating python_build/temp.linux-aarch64-3.6/src/python/grpcio
creating python_build/temp.linux-aarch64-3.6/src/python/grpcio/grpc
creating python_build/temp.linux-aarch64-3.6/src/python/grpcio/grpc/_cython
creating python_build/temp.linux-aarch64-3.6/third_party
creating python_build/temp.linux-aarch64-3.6/third_party/address_sorting
creating python_build/temp.linux-aarch64-3.6/src/core
creating python_build/temp.linux-aarch64-3.6/src/core/lib
creating python_build/temp.linux-aarch64-3.6/src/core/lib/gpr
creating python_build/temp.linux-aarch64-3.6/src/core/lib/gprpp
creating python_build/temp.linux-aarch64-3.6/src/core/lib/profiling
creating python_build/temp.linux-aarch64-3.6/src/core/lib/surface
creating python_build/temp.linux-aarch64-3.6/src/core/lib/avl
creating python_build/temp.linux-aarch64-3.6/src/core/lib/backoff
creating python_build/temp.linux-aarch64-3.6/src/core/lib/channel
creating python_build/temp.linux-aarch64-3.6/src/core/lib/compression
creating python_build/temp.linux-aarch64-3.6/src/core/lib/debug
creating python_build/temp.linux-aarch64-3.6/src/core/lib/http
creating python_build/temp.linux-aarch64-3.6/src/core/lib/iomgr
creating python_build/temp.linux-aarch64-3.6/src/core/lib/iomgr/executor
creating python_build/temp.linux-aarch64-3.6/src/core/lib/json
creating python_build/temp.linux-aarch64-3.6/src/core/lib/slice
creating python_build/temp.linux-aarch64-3.6/src/core/lib/transport
creating python_build/temp.linux-aarch64-3.6/src/core/lib/uri
creating python_build/temp.linux-aarch64-3.6/src/core/ext
creating python_build/temp.linux-aarch64-3.6/src/core/ext/transport
creating python_build/temp.linux-aarch64-3.6/src/core/ext/transport/chttp2
creating python_build/temp.linux-aarch64-3.6/src/core/ext/transport/chttp2/server
creating python_build/temp.linux-aarch64-3.6/src/core/ext/transport/chttp2/server/secure
creating python_build/temp.linux-aarch64-3.6/src/core/ext/transport/chttp2/transport
creating python_build/temp.linux-aarch64-3.6/src/core/ext/transport/chttp2/alpn
creating python_build/temp.linux-aarch64-3.6/src/core/ext/filters
creating python_build/temp.linux-aarch64-3.6/src/core/ext/filters/http
creating python_build/temp.linux-aarch64-3.6/src/core/ext/filters/http/client
creating python_build/temp.linux-aarch64-3.6/src/core/ext/filters/http/message_compress
creating python_build/temp.linux-aarch64-3.6/src/core/ext/filters/http/server
creating python_build/temp.linux-aarch64-3.6/src/core/lib/security
creating python_build/temp.linux-aarch64-3.6/src/core/lib/security/context
creating python_build/temp.linux-aarch64-3.6/src/core/lib/security/credentials
creating python_build/temp.linux-aarch64-3.6/src/core/lib/security/credentials/alts
creating python_build/temp.linux-aarch64-3.6/src/core/lib/security/credentials/composite
creating python_build/temp.linux-aarch64-3.6/src/core/lib/security/credentials/fake
creating python_build/temp.linux-aarch64-3.6/src/core/lib/security/credentials/google_default
creating python_build/temp.linux-aarch64-3.6/src/core/lib/security/credentials/iam
creating python_build/temp.linux-aarch64-3.6/src/core/lib/security/credentials/jwt
creating python_build/temp.linux-aarch64-3.6/src/core/lib/security/credentials/local
creating python_build/temp.linux-aarch64-3.6/src/core/lib/security/credentials/oauth2
creating python_build/temp.linux-aarch64-3.6/src/core/lib/security/credentials/plugin
creating python_build/temp.linux-aarch64-3.6/src/core/lib/security/credentials/ssl
creating python_build/temp.linux-aarch64-3.6/src/core/lib/security/credentials/tls
creating python_build/temp.linux-aarch64-3.6/src/core/lib/security/security_connector
creating python_build/temp.linux-aarch64-3.6/src/core/lib/security/security_connector/alts
creating python_build/temp.linux-aarch64-3.6/src/core/lib/security/security_connector/fake
creating python_build/temp.linux-aarch64-3.6/src/core/lib/security/security_connector/local
creating python_build/temp.linux-aarch64-3.6/src/core/lib/security/security_connector/ssl
creating python_build/temp.linux-aarch64-3.6/src/core/lib/security/security_connector/tls
creating python_build/temp.linux-aarch64-3.6/src/core/lib/security/transport
creating python_build/temp.linux-aarch64-3.6/src/core/lib/security/util
creating python_build/temp.linux-aarch64-3.6/src/core/tsi
creating python_build/temp.linux-aarch64-3.6/src/core/tsi/alts
creating python_build/temp.linux-aarch64-3.6/src/core/tsi/alts/crypt
creating python_build/temp.linux-aarch64-3.6/src/core/tsi/alts/frame_protector
creating python_build/temp.linux-aarch64-3.6/src/core/tsi/alts/handshaker
creating python_build/temp.linux-aarch64-3.6/src/core/tsi/alts/zero_copy_frame_protector
creating python_build/temp.linux-aarch64-3.6/src/core/ext/upb-generated
creating python_build/temp.linux-aarch64-3.6/src/core/ext/upb-generated/src
creating python_build/temp.linux-aarch64-3.6/src/core/ext/upb-generated/src/proto
creating python_build/temp.linux-aarch64-3.6/src/core/ext/upb-generated/src/proto/grpc
creating python_build/temp.linux-aarch64-3.6/src/core/ext/upb-generated/src/proto/grpc/gcp
creating python_build/temp.linux-aarch64-3.6/third_party/upb
creating python_build/temp.linux-aarch64-3.6/third_party/upb/upb
creating python_build/temp.linux-aarch64-3.6/src/core/ext/transport/chttp2/client
creating python_build/temp.linux-aarch64-3.6/src/core/ext/transport/chttp2/client/insecure
creating python_build/temp.linux-aarch64-3.6/src/core/ext/filters/client_channel
creating python_build/temp.linux-aarch64-3.6/src/core/ext/filters/client_channel/health
creating python_build/temp.linux-aarch64-3.6/src/core/ext/filters/deadline
creating python_build/temp.linux-aarch64-3.6/src/core/ext/upb-generated/src/proto/grpc/health
creating python_build/temp.linux-aarch64-3.6/src/core/ext/upb-generated/src/proto/grpc/health/v1
creating python_build/temp.linux-aarch64-3.6/src/core/ext/upb-generated/udpa
creating python_build/temp.linux-aarch64-3.6/src/core/ext/upb-generated/udpa/data
creating python_build/temp.linux-aarch64-3.6/src/core/ext/upb-generated/udpa/data/orca
creating python_build/temp.linux-aarch64-3.6/src/core/ext/upb-generated/udpa/data/orca/v1
creating python_build/temp.linux-aarch64-3.6/src/core/ext/upb-generated/gogoproto
creating python_build/temp.linux-aarch64-3.6/src/core/ext/upb-generated/validate
creating python_build/temp.linux-aarch64-3.6/src/core/ext/upb-generated/google
creating python_build/temp.linux-aarch64-3.6/src/core/ext/upb-generated/google/api
creating python_build/temp.linux-aarch64-3.6/src/core/ext/upb-generated/google/protobuf
creating python_build/temp.linux-aarch64-3.6/src/core/ext/upb-generated/google/rpc
creating python_build/temp.linux-aarch64-3.6/src/core/tsi/ssl
creating python_build/temp.linux-aarch64-3.6/src/core/tsi/ssl/session_cache
creating python_build/temp.linux-aarch64-3.6/src/core/ext/transport/chttp2/client/secure
creating python_build/temp.linux-aarch64-3.6/src/core/ext/transport/chttp2/server/insecure
creating python_build/temp.linux-aarch64-3.6/src/core/ext/transport/inproc
creating python_build/temp.linux-aarch64-3.6/src/core/ext/filters/client_channel/lb_policy
creating python_build/temp.linux-aarch64-3.6/src/core/ext/filters/client_channel/lb_policy/grpclb
creating python_build/temp.linux-aarch64-3.6/src/core/ext/upb-generated/src/proto/grpc/lb
creating python_build/temp.linux-aarch64-3.6/src/core/ext/upb-generated/src/proto/grpc/lb/v1
creating python_build/temp.linux-aarch64-3.6/src/core/ext/filters/client_channel/resolver
creating python_build/temp.linux-aarch64-3.6/src/core/ext/filters/client_channel/resolver/fake
creating python_build/temp.linux-aarch64-3.6/src/core/ext/filters/client_channel/lb_policy/xds
creating python_build/temp.linux-aarch64-3.6/src/core/ext/upb-generated/envoy
creating python_build/temp.linux-aarch64-3.6/src/core/ext/upb-generated/envoy/api
creating python_build/temp.linux-aarch64-3.6/src/core/ext/upb-generated/envoy/api/v2
creating python_build/temp.linux-aarch64-3.6/src/core/ext/upb-generated/envoy/api/v2/auth
creating python_build/temp.linux-aarch64-3.6/src/core/ext/upb-generated/envoy/api/v2/cluster
creating python_build/temp.linux-aarch64-3.6/src/core/ext/upb-generated/envoy/api/v2/endpoint
creating python_build/temp.linux-aarch64-3.6/src/core/ext/upb-generated/envoy/service
creating python_build/temp.linux-aarch64-3.6/src/core/ext/upb-generated/envoy/service/discovery
creating python_build/temp.linux-aarch64-3.6/src/core/ext/upb-generated/envoy/service/discovery/v2
creating python_build/temp.linux-aarch64-3.6/src/core/ext/upb-generated/envoy/service/load_stats
creating python_build/temp.linux-aarch64-3.6/src/core/ext/upb-generated/envoy/service/load_stats/v2
creating python_build/temp.linux-aarch64-3.6/src/core/ext/upb-generated/envoy/api/v2/core
creating python_build/temp.linux-aarch64-3.6/src/core/ext/upb-generated/envoy/type
creating python_build/temp.linux-aarch64-3.6/src/core/ext/filters/client_channel/lb_policy/pick_first
creating python_build/temp.linux-aarch64-3.6/src/core/ext/filters/client_channel/lb_policy/round_robin
creating python_build/temp.linux-aarch64-3.6/src/core/ext/filters/client_channel/resolver/dns
creating python_build/temp.linux-aarch64-3.6/src/core/ext/filters/client_channel/resolver/dns/c_ares
creating python_build/temp.linux-aarch64-3.6/src/core/ext/filters/client_channel/resolver/dns/native
creating python_build/temp.linux-aarch64-3.6/src/core/ext/filters/client_channel/resolver/sockaddr
creating python_build/temp.linux-aarch64-3.6/src/core/ext/filters/client_channel/resolver/xds
creating python_build/temp.linux-aarch64-3.6/src/core/ext/filters/census
creating python_build/temp.linux-aarch64-3.6/src/core/ext/filters/client_idle
creating python_build/temp.linux-aarch64-3.6/src/core/ext/filters/max_age
creating python_build/temp.linux-aarch64-3.6/src/core/ext/filters/message_size
creating python_build/temp.linux-aarch64-3.6/src/core/ext/filters/workarounds
creating python_build/temp.linux-aarch64-3.6/src/core/plugin_registry
creating python_build/temp.linux-aarch64-3.6/src/boringssl
creating python_build/temp.linux-aarch64-3.6/third_party/boringssl
creating python_build/temp.linux-aarch64-3.6/third_party/boringssl/crypto
creating python_build/temp.linux-aarch64-3.6/third_party/boringssl/crypto/asn1
creating python_build/temp.linux-aarch64-3.6/third_party/boringssl/crypto/base64
creating python_build/temp.linux-aarch64-3.6/third_party/boringssl/crypto/bio
creating python_build/temp.linux-aarch64-3.6/third_party/boringssl/crypto/bn_extra
creating python_build/temp.linux-aarch64-3.6/third_party/boringssl/crypto/buf
creating python_build/temp.linux-aarch64-3.6/third_party/boringssl/crypto/bytestring
creating python_build/temp.linux-aarch64-3.6/third_party/boringssl/crypto/chacha
creating python_build/temp.linux-aarch64-3.6/third_party/boringssl/crypto/cipher_extra
creating python_build/temp.linux-aarch64-3.6/third_party/boringssl/crypto/cmac
creating python_build/temp.linux-aarch64-3.6/third_party/boringssl/crypto/conf
creating python_build/temp.linux-aarch64-3.6/third_party/boringssl/crypto/curve25519
creating python_build/temp.linux-aarch64-3.6/third_party/boringssl/crypto/dh
creating python_build/temp.linux-aarch64-3.6/third_party/boringssl/crypto/digest_extra
creating python_build/temp.linux-aarch64-3.6/third_party/boringssl/crypto/dsa
creating python_build/temp.linux-aarch64-3.6/third_party/boringssl/crypto/ec_extra
creating python_build/temp.linux-aarch64-3.6/third_party/boringssl/crypto/ecdh
creating python_build/temp.linux-aarch64-3.6/third_party/boringssl/crypto/ecdsa_extra
creating python_build/temp.linux-aarch64-3.6/third_party/boringssl/crypto/engine
creating python_build/temp.linux-aarch64-3.6/third_party/boringssl/crypto/err
creating python_build/temp.linux-aarch64-3.6/third_party/boringssl/crypto/evp
creating python_build/temp.linux-aarch64-3.6/third_party/boringssl/crypto/fipsmodule
creating python_build/temp.linux-aarch64-3.6/third_party/boringssl/crypto/hkdf
creating python_build/temp.linux-aarch64-3.6/third_party/boringssl/crypto/lhash
creating python_build/temp.linux-aarch64-3.6/third_party/boringssl/crypto/obj
creating python_build/temp.linux-aarch64-3.6/third_party/boringssl/crypto/pem
creating python_build/temp.linux-aarch64-3.6/third_party/boringssl/crypto/pkcs7
creating python_build/temp.linux-aarch64-3.6/third_party/boringssl/crypto/pkcs8
creating python_build/temp.linux-aarch64-3.6/third_party/boringssl/crypto/poly1305
creating python_build/temp.linux-aarch64-3.6/third_party/boringssl/crypto/pool
creating python_build/temp.linux-aarch64-3.6/third_party/boringssl/crypto/rand_extra
creating python_build/temp.linux-aarch64-3.6/third_party/boringssl/crypto/rc4
creating python_build/temp.linux-aarch64-3.6/third_party/boringssl/crypto/rsa_extra
creating python_build/temp.linux-aarch64-3.6/third_party/boringssl/crypto/stack
creating python_build/temp.linux-aarch64-3.6/third_party/boringssl/crypto/x509
creating python_build/temp.linux-aarch64-3.6/third_party/boringssl/crypto/x509v3
creating python_build/temp.linux-aarch64-3.6/third_party/boringssl/ssl
creating python_build/temp.linux-aarch64-3.6/third_party/boringssl/third_party
creating python_build/temp.linux-aarch64-3.6/third_party/boringssl/third_party/fiat
creating python_build/temp.linux-aarch64-3.6/third_party/zlib
creating python_build/temp.linux-aarch64-3.6/third_party/cares
creating python_build/temp.linux-aarch64-3.6/third_party/cares/cares
aarch64-linux-gnu-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -DOPENSSL_NO_ASM=1 -D_WIN32_WINNT=1536 -DGPR_BACKWARDS_COMPATIBILITY_MODE=1 -DHAVE_CONFIG_H=1 -DGRPC_ENABLE_FORK_SUPPORT=1 -DPyMODINIT_FUNC=extern "C" __attribute__((visibility ("default"))) PyObject* -DGRPC_POSIX_FORK_ALLOW_PTHREAD_ATFORK=1 -Isrc/python/grpcio -Iinclude -I. -Ithird_party/address_sorting/include -Ithird_party/cares -Ithird_party/cares/cares -Ithird_party/cares/config_linux -Ithird_party/boringssl/include -Ithird_party/upb -Isrc/core/ext/upb-generated -Ithird_party/zlib -I/usr/include/python3.6m -c src/python/grpcio/grpc/_cython/cygrpc.cpp -o python_build/temp.linux-aarch64-3.6/src/python/grpcio/grpc/_cython/cygrpc.o -std=c++11 -std=gnu99 -fvisibility=hidden -fno-wrapv -fno-exceptions -pthread
cc1plus: warning: command line option ‘-std=gnu99’ is valid for C/ObjC but not for C++
src/python/grpcio/grpc/_cython/cygrpc.cpp:837:10: fatal error: Python.h: No such file or directory
#include "Python.h"
compilation terminated.
creating tmp
creating tmp/tmpxwoylyup
aarch64-linux-gnu-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -I/usr/include/python3.6m -c /tmp/tmpxwoylyup/a.c -o tmp/tmpxwoylyup/a.o
/tmp/tmpxwoylyup/a.c:2:10: fatal error: Python.h: No such file or directory
#include <Python.h>
Could not find <Python.h>. This could mean the following:
* You're on Ubuntu and haven't run `apt-get install python-dev`.
* You're on RHEL/Fedora and haven't run `yum install python-devel` or
`dnf install python-devel` (make sure you also have redhat-rpm-config
installed)
* You're on Mac OS X and the usual Python framework was somehow corrupted
(check your environment variables or try re-installing?)
* You're on Windows and your Python installation was somehow corrupted
File "/usr/lib/python3.6/distutils/unixccompiler.py", line 118, in _compile
extra_postargs)
File "/tmp/pip-install-uzmrzqtj/grpcio/src/python/grpcio/_spawn_patch.py", line 54, in _commandfile_spawn
_classic_spawn(self, command)
File "/usr/lib/python3.6/distutils/ccompiler.py", line 909, in spawn
spawn(cmd, dry_run=self.dry_run)
File "/usr/lib/python3.6/distutils/spawn.py", line 36, in spawn
_spawn_posix(cmd, search_path, dry_run=dry_run)
File "/usr/lib/python3.6/distutils/spawn.py", line 159, in _spawn_posix
% (cmd, exit_status))
distutils.errors.DistutilsExecError: command 'aarch64-linux-gnu-gcc' failed with exit status 1
During handling of the above exception, another exception occurred:
File "/tmp/pip-install-uzmrzqtj/grpcio/src/python/grpcio/commands.py", line 262, in build_extensions
build_ext.build_ext.build_extensions(self)
File "/usr/lib/python3.6/distutils/command/build_ext.py", line 448, in build_extensions
self._build_extensions_serial()
File "/usr/lib/python3.6/distutils/command/build_ext.py", line 473, in _build_extensions_serial
self.build_extension(ext)
File "/usr/local/lib/python3.6/dist-packages/setuptools/command/build_ext.py", line 205, in build_extension
_build_ext.build_extension(self, ext)
File "/usr/lib/python3.6/distutils/command/build_ext.py", line 533, in build_extension
depends=ext.depends)
File "/usr/lib/python3.6/distutils/ccompiler.py", line 574, in compile
self._compile(obj, src, ext, cc_args, extra_postargs, pp_opts)
File "/usr/lib/python3.6/distutils/unixccompiler.py", line 120, in _compile
raise CompileError(msg)
distutils.errors.CompileError: command 'aarch64-linux-gnu-gcc' failed with exit status 1
File "<string>", line 1, in <module>
File "/tmp/pip-install-uzmrzqtj/grpcio/setup.py", line 379, in <module>
cmdclass=COMMAND_CLASS,
File "/usr/local/lib/python3.6/dist-packages/setuptools/__init__.py", line 145, in setup
return distutils.core.setup(**attrs)
File "/usr/lib/python3.6/distutils/core.py", line 148, in setup
dist.run_commands()
File "/usr/lib/python3.6/distutils/dist.py", line 955, in run_commands
self.run_command(cmd)
File "/usr/lib/python3.6/distutils/dist.py", line 974, in run_command
cmd_obj.run()
File "/usr/local/lib/python3.6/dist-packages/wheel/bdist_wheel.py", line 192, in run
self.run_command('build')
File "/usr/lib/python3.6/distutils/cmd.py", line 313, in run_command
self.distribution.run_command(command)
cmd_obj.run()
File "/usr/lib/python3.6/distutils/command/build.py", line 135, in run
self.run_command(cmd_name)
cmd_obj.run()
File "/usr/local/lib/python3.6/dist-packages/setuptools/command/build_ext.py", line 84, in run
_build_ext.run(self)
File "/usr/lib/python3.6/distutils/command/build_ext.py", line 339, in run
self.build_extensions()
File "/tmp/pip-install-uzmrzqtj/grpcio/src/python/grpcio/commands.py", line 265, in build_extensions
support.diagnose_build_ext_error(self, error, formatted_exception)
File "/tmp/pip-install-uzmrzqtj/grpcio/src/python/grpcio/support.py", line 111, in diagnose_build_ext_error
diagnostic(build_ext, error)
File "/tmp/pip-install-uzmrzqtj/grpcio/src/python/grpcio/support.py", line 70, in diagnose_compile_error
_expect_compile(build_ext.compiler, c_check, message)
File "/tmp/pip-install-uzmrzqtj/grpcio/src/python/grpcio/support.py", line 64, in _expect_compile
.format(error_message))
commands.CommandError: Diagnostics found a compilation environment issue:
installed)
ERROR: Failed building wheel for grpcio
Running setup.py clean for grpcio
Building wheel for wrapt (setup.py) ... done
Created wheel for wrapt: filename=wrapt-1.11.2-cp36-none-any.whl size=19590 sha256=0fbd49c603637c5a371660650c7c2b3b72ecbb8188488b3b166cff593054a7a4
Stored in directory: /home/mojito/.cache/pip/wheels/d7/de/2e/efa132238792efb6459a96e85916ef8597fcb3d2ae51590dfd
Building wheel for numpy (setup.py) ... error
command: /usr/bin/python3 -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-uzmrzqtj/numpy/setup.py'"'"'; __file__='"'"'/tmp/pip-install-uzmrzqtj/numpy/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' bdist_wheel -d /tmp/pip-wheel-29posl39 --python-tag cp36
cwd: /tmp/pip-install-uzmrzqtj/numpy/
Complete output (341 lines):
Running from numpy source directory.
blas_opt_info:
blas_mkl_info:
customize UnixCCompiler
libraries mkl_rt not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/aarch64-linux-gnu']
NOT AVAILABLE
blis_info:
libraries blis not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/aarch64-linux-gnu']
NOT AVAILABLE
openblas_info:
libraries openblas not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/aarch64-linux-gnu']
NOT AVAILABLE
atlas_3_10_blas_threads_info:
Setting PTATLAS=ATLAS
libraries tatlas not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/aarch64-linux-gnu']
NOT AVAILABLE
atlas_3_10_blas_info:
libraries satlas not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/aarch64-linux-gnu']
NOT AVAILABLE
atlas_blas_threads_info:
libraries ptf77blas,ptcblas,atlas not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/aarch64-linux-gnu']
NOT AVAILABLE
atlas_blas_info:
libraries f77blas,cblas,atlas not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/aarch64-linux-gnu']
NOT AVAILABLE
accelerate_info:
NOT AVAILABLE
/tmp/pip-install-uzmrzqtj/numpy/numpy/distutils/system_info.py:690: UserWarning:
Optimized (vendor) Blas libraries are not found.
Falls back to netlib Blas library which has worse performance.
A better performance should be easily gained by switching
Blas library.
self.calc_info()
blas_info:
libraries blas not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/aarch64-linux-gnu']
NOT AVAILABLE
Blas (http://www.netlib.org/blas/) libraries not found.
Directories to search for the libraries can be specified in the
numpy/distutils/site.cfg file (section [blas]) or by setting
the BLAS environment variable.
self.calc_info()
blas_src_info:
NOT AVAILABLE
Blas (http://www.netlib.org/blas/) sources not found.
Directories to search for the sources can be specified in the
numpy/distutils/site.cfg file (section [blas_src]) or by setting
the BLAS_SRC environment variable.
self.calc_info()
NOT AVAILABLE
/bin/sh: 1: svnversion: not found
non-existing path in 'numpy/distutils': 'site.cfg'
lapack_opt_info:
lapack_mkl_info:
NOT AVAILABLE
openblas_lapack_info:
NOT AVAILABLE
openblas_clapack_info:
libraries openblas,lapack not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/aarch64-linux-gnu']
NOT AVAILABLE
flame_info:
libraries flame not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/aarch64-linux-gnu']
NOT AVAILABLE
atlas_3_10_threads_info:
libraries lapack_atlas not found in /usr/local/lib
libraries tatlas,tatlas not found in /usr/local/lib
libraries lapack_atlas not found in /usr/lib
libraries tatlas,tatlas not found in /usr/lib
libraries lapack_atlas not found in /usr/lib/aarch64-linux-gnu
libraries tatlas,tatlas not found in /usr/lib/aarch64-linux-gnu
<class 'numpy.distutils.system_info.atlas_3_10_threads_info'>
NOT AVAILABLE
atlas_3_10_info:
libraries satlas,satlas not found in /usr/local/lib
libraries satlas,satlas not found in /usr/lib
libraries satlas,satlas not found in /usr/lib/aarch64-linux-gnu
<class 'numpy.distutils.system_info.atlas_3_10_info'>
NOT AVAILABLE
atlas_threads_info:
libraries ptf77blas,ptcblas,atlas not found in /usr/local/lib
libraries ptf77blas,ptcblas,atlas not found in /usr/lib
libraries ptf77blas,ptcblas,atlas not found in /usr/lib/aarch64-linux-gnu
<class 'numpy.distutils.system_info.atlas_threads_info'>
NOT AVAILABLE
atlas_info:
libraries f77blas,cblas,atlas not found in /usr/local/lib
libraries f77blas,cblas,atlas not found in /usr/lib
libraries f77blas,cblas,atlas not found in /usr/lib/aarch64-linux-gnu
<class 'numpy.distutils.system_info.atlas_info'>
NOT AVAILABLE
lapack_info:
libraries lapack not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/aarch64-linux-gnu']
NOT AVAILABLE
/tmp/pip-install-uzmrzqtj/numpy/numpy/distutils/system_info.py:1712: UserWarning:
Lapack (http://www.netlib.org/lapack/) libraries not found.
numpy/distutils/site.cfg file (section [lapack]) or by setting
the LAPACK environment variable.
if getattr(self, '_calc_info_{}'.format(lapack))():
lapack_src_info:
NOT AVAILABLE
Lapack (http://www.netlib.org/lapack/) sources not found.
numpy/distutils/site.cfg file (section [lapack_src]) or by setting
the LAPACK_SRC environment variable.
NOT AVAILABLE
/usr/lib/python3.6/distutils/dist.py:261: UserWarning: Unknown distribution option: 'define_macros'
warnings.warn(msg)
running bdist_wheel
running build
running config_cc
unifing config_cc, config, build_clib, build_ext, build commands --compiler options
running config_fc
unifing config_fc, config, build_clib, build_ext, build commands --fcompiler options
running build_src
build_src
building py_modules sources
creating build
creating build/src.linux-aarch64-3.6
creating build/src.linux-aarch64-3.6/numpy
creating build/src.linux-aarch64-3.6/numpy/distutils
building library "npymath" sources
get_default_fcompiler: matching types: '['gnu95', 'intel', 'lahey', 'pg', 'absoft', 'nag', 'vast', 'compaq', 'intele', 'intelem', 'gnu', 'g95', 'pathf95', 'nagfor']'
customize Gnu95FCompiler
Could not locate executable gfortran
Could not locate executable f95
customize IntelFCompiler
Could not locate executable ifort
Could not locate executable ifc
customize LaheyFCompiler
Could not locate executable lf95
customize PGroupFCompiler
Could not locate executable pgfortran
customize AbsoftFCompiler
Could not locate executable f90
Could not locate executable f77
customize NAGFCompiler
customize VastFCompiler
customize CompaqFCompiler
Could not locate executable fort
customize IntelItaniumFCompiler
Could not locate executable efort
Could not locate executable efc
customize IntelEM64TFCompiler
customize GnuFCompiler
Could not locate executable g77
customize G95FCompiler
Could not locate executable g95
customize PathScaleFCompiler
Could not locate executable pathf95
customize NAGFORCompiler
Could not locate executable nagfor
don't know how to compile Fortran code on platform 'posix'
C compiler: aarch64-linux-gnu-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC
compile options: '-Inumpy/core/src/common -Inumpy/core/src -Inumpy/core -Inumpy/core/src/npymath -Inumpy/core/src/multiarray -Inumpy/core/src/umath -Inumpy/core/src/npysort -I/usr/include/python3.6m -c'
aarch64-linux-gnu-gcc: _configtest.c
aarch64-linux-gnu-gcc -pthread _configtest.o -o _configtest
success!
removing: _configtest.c _configtest.o _configtest.o.d _configtest
_configtest.c:1:5: warning: conflicting types for built-in function ‘exp’ [-Wbuiltin-declaration-mismatch]
int exp (void);
_configtest.o: In function `main':
/tmp/pip-install-uzmrzqtj/numpy/_configtest.c:6: undefined reference to `exp'
collect2: error: ld returned 1 exit status
failure.
int exp (void);
aarch64-linux-gnu-gcc -pthread _configtest.o -lm -o _configtest
success!
creating build/src.linux-aarch64-3.6/numpy/core
creating build/src.linux-aarch64-3.6/numpy/core/src
creating build/src.linux-aarch64-3.6/numpy/core/src/npymath
conv_template:> build/src.linux-aarch64-3.6/numpy/core/src/npymath/npy_math_internal.h
adding 'build/src.linux-aarch64-3.6/numpy/core/src/npymath' to include_dirs.
conv_template:> build/src.linux-aarch64-3.6/numpy/core/src/npymath/ieee754.c
conv_template:> build/src.linux-aarch64-3.6/numpy/core/src/npymath/npy_math_complex.c
None - nothing done with h_files = ['build/src.linux-aarch64-3.6/numpy/core/src/npymath/npy_math_internal.h']
building library "npysort" sources
creating build/src.linux-aarch64-3.6/numpy/core/src/common
conv_template:> build/src.linux-aarch64-3.6/numpy/core/src/common/npy_sort.h
adding 'build/src.linux-aarch64-3.6/numpy/core/src/common' to include_dirs.
creating build/src.linux-aarch64-3.6/numpy/core/src/npysort
conv_template:> build/src.linux-aarch64-3.6/numpy/core/src/npysort/quicksort.c
conv_template:> build/src.linux-aarch64-3.6/numpy/core/src/npysort/mergesort.c
conv_template:> build/src.linux-aarch64-3.6/numpy/core/src/npysort/timsort.c
conv_template:> build/src.linux-aarch64-3.6/numpy/core/src/npysort/heapsort.c
conv_template:> build/src.linux-aarch64-3.6/numpy/core/src/npysort/radixsort.c
conv_template:> build/src.linux-aarch64-3.6/numpy/core/src/common/npy_partition.h
conv_template:> build/src.linux-aarch64-3.6/numpy/core/src/npysort/selection.c
conv_template:> build/src.linux-aarch64-3.6/numpy/core/src/common/npy_binsearch.h
conv_template:> build/src.linux-aarch64-3.6/numpy/core/src/npysort/binsearch.c
None - nothing done with h_files = ['build/src.linux-aarch64-3.6/numpy/core/src/common/npy_sort.h', 'build/src.linux-aarch64-3.6/numpy/core/src/common/npy_partition.h', 'build/src.linux-aarch64-3.6/numpy/core/src/common/npy_binsearch.h']
building extension "numpy.core._dummy" sources
Generating build/src.linux-aarch64-3.6/numpy/core/include/numpy/config.h
_configtest.c:1:10: fatal error: Python.h: No such file or directory
#include <Python.h>
failure.
File "/tmp/pip-install-uzmrzqtj/numpy/setup.py", line 443, in <module>
setup_package()
File "/tmp/pip-install-uzmrzqtj/numpy/setup.py", line 435, in setup_package
setup(**metadata)
File "/tmp/pip-install-uzmrzqtj/numpy/numpy/distutils/core.py", line 171, in setup
return old_setup(**new_attr)
dist.run_commands()
cmd_obj.run()
cmd_obj.run()
File "/tmp/pip-install-uzmrzqtj/numpy/numpy/distutils/command/build.py", line 47, in run
old_build.run(self)
cmd_obj.run()
File "/tmp/pip-install-uzmrzqtj/numpy/numpy/distutils/command/build_src.py", line 142, in run
self.build_sources()
File "/tmp/pip-install-uzmrzqtj/numpy/numpy/distutils/command/build_src.py", line 159, in build_sources
self.build_extension_sources(ext)
File "/tmp/pip-install-uzmrzqtj/numpy/numpy/distutils/command/build_src.py", line 316, in build_extension_sources
sources = self.generate_sources(sources, ext)
File "/tmp/pip-install-uzmrzqtj/numpy/numpy/distutils/command/build_src.py", line 369, in generate_sources
source = func(extension, build_dir)
File "numpy/core/setup.py", line 430, in generate_config_h
moredefs, ignored = cocache.check_types(config_cmd, ext, build_dir)
File "numpy/core/setup.py", line 49, in check_types
out = check_types(*a, **kw)
File "numpy/core/setup.py", line 288, in check_types
"install {0}-dev|{0}-devel.".format(python))
SystemError: Cannot compile 'Python.h'. Perhaps you need to install python-dev|python-devel.
ERROR: Failed building wheel for numpy
Running setup.py clean for numpy
command: /usr/bin/python3 -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-uzmrzqtj/numpy/setup.py'"'"'; __file__='"'"'/tmp/pip-install-uzmrzqtj/numpy/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' clean --all
Complete output (10 lines):
`setup.py clean` is not supported, use one of the following instead:
- `git clean -xdf` (cleans all files)
- `git clean -Xdf` (cleans all versioned files, doesn't touch
files that aren't checked into the git repo)
Add `--force` to your command to use it anyway if you must (unsupported).
ERROR: Failed cleaning build dir for numpy
Building wheel for gast (setup.py) ... done
Created wheel for gast: filename=gast-0.2.2-cp36-none-any.whl size=7540 sha256=5ce79ff48d8cd6019f7fe33e879e5629c20fe3540fb732993914041470b90061
Stored in directory: /home/mojito/.cache/pip/wheels/5c/2e/7e/a1d4d4fcebe6c381f378ce7743a3ced3699feb89bcfbdadadd
Building wheel for h5py (setup.py) ... error
command: /usr/bin/python3 -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-uzmrzqtj/h5py/setup.py'"'"'; __file__='"'"'/tmp/pip-install-uzmrzqtj/h5py/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' bdist_wheel -d /tmp/pip-wheel-ohkm9ki2 --python-tag cp36
cwd: /tmp/pip-install-uzmrzqtj/h5py/
Complete output (163 lines):
Unable to find pgen, not compiling formal grammar.
Compiling /tmp/easy_install-9wwlpoz6/Cython-0.29.13/Cython/Plex/Scanners.py because it changed.
Compiling /tmp/easy_install-9wwlpoz6/Cython-0.29.13/Cython/Plex/Actions.py because it changed.
Compiling /tmp/easy_install-9wwlpoz6/Cython-0.29.13/Cython/Compiler/Scanning.py because it changed.
Compiling /tmp/easy_install-9wwlpoz6/Cython-0.29.13/Cython/Compiler/Visitor.py because it changed.
Compiling /tmp/easy_install-9wwlpoz6/Cython-0.29.13/Cython/Compiler/FlowControl.py because it changed.
Compiling /tmp/easy_install-9wwlpoz6/Cython-0.29.13/Cython/Runtime/refnanny.pyx because it changed.
Compiling /tmp/easy_install-9wwlpoz6/Cython-0.29.13/Cython/Compiler/FusedNode.py because it changed.
Compiling /tmp/easy_install-9wwlpoz6/Cython-0.29.13/Cython/Tempita/_tempita.py because it changed.
[1/8] Cythonizing /tmp/easy_install-9wwlpoz6/Cython-0.29.13/Cython/Compiler/FlowControl.py
[2/8] Cythonizing /tmp/easy_install-9wwlpoz6/Cython-0.29.13/Cython/Compiler/FusedNode.py
[3/8] Cythonizing /tmp/easy_install-9wwlpoz6/Cython-0.29.13/Cython/Compiler/Scanning.py
[4/8] Cythonizing /tmp/easy_install-9wwlpoz6/Cython-0.29.13/Cython/Compiler/Visitor.py
[5/8] Cythonizing /tmp/easy_install-9wwlpoz6/Cython-0.29.13/Cython/Plex/Actions.py
[6/8] Cythonizing /tmp/easy_install-9wwlpoz6/Cython-0.29.13/Cython/Plex/Scanners.py
[7/8] Cythonizing /tmp/easy_install-9wwlpoz6/Cython-0.29.13/Cython/Runtime/refnanny.pyx
[8/8] Cythonizing /tmp/easy_install-9wwlpoz6/Cython-0.29.13/Cython/Tempita/_tempita.py
warning: no files found matching 'Doc/*'
warning: no files found matching '*.pyx' under directory 'Cython/Debugger/Tests'
warning: no files found matching '*.pxd' under directory 'Cython/Debugger/Tests'
warning: no files found matching '*.pxd' under directory 'Cython/Utility'
warning: no files found matching 'pyximport/README'
/tmp/easy_install-9wwlpoz6/Cython-0.29.13/Cython/Plex/Scanners.c:19:10: fatal error: Python.h: No such file or directory
#include "Python.h"
extra_postargs)
dist.run_commands()
cmd_obj.run()
File "/usr/local/lib/python3.6/dist-packages/setuptools/command/bdist_egg.py", line 172, in run
cmd = self.call_command('install_lib', warn_dir=0)
File "/usr/local/lib/python3.6/dist-packages/setuptools/command/bdist_egg.py", line 158, in call_command
self.run_command(cmdname)
cmd_obj.run()
File "/usr/local/lib/python3.6/dist-packages/setuptools/command/install_lib.py", line 11, in run
self.build()
File "/usr/lib/python3.6/distutils/command/install_lib.py", line 109, in build
self.run_command('build_ext')
cmd_obj.run()
File "/usr/local/lib/python3.6/dist-packages/setuptools/sandbox.py", line 154, in save_modules
yield saved
File "/usr/local/lib/python3.6/dist-packages/setuptools/sandbox.py", line 195, in setup_context
yield
File "/usr/local/lib/python3.6/dist-packages/setuptools/sandbox.py", line 250, in run_setup
_execfile(setup_script, ns)
File "/usr/local/lib/python3.6/dist-packages/setuptools/sandbox.py", line 45, in _execfile
exec(code, globals, locals)
File "/tmp/easy_install-9wwlpoz6/Cython-0.29.13/setup.py", line 285, in <module>
File "/usr/lib/python3.6/distutils/core.py", line 163, in setup
raise SystemExit("error: " + str(msg))
SystemExit: error: command 'aarch64-linux-gnu-gcc' failed with exit status 1
File "/usr/local/lib/python3.6/dist-packages/setuptools/command/easy_install.py", line 1144, in run_setup
run_setup(setup_script, args)
File "/usr/local/lib/python3.6/dist-packages/setuptools/sandbox.py", line 253, in run_setup
raise
File "/usr/lib/python3.6/contextlib.py", line 99, in __exit__
self.gen.throw(type, value, traceback)
yield
File "/usr/local/lib/python3.6/dist-packages/setuptools/sandbox.py", line 166, in save_modules
saved_exc.resume()
File "/usr/local/lib/python3.6/dist-packages/setuptools/sandbox.py", line 141, in resume
six.reraise(type, exc, self._tb)
File "/usr/local/lib/python3.6/dist-packages/setuptools/_vendor/six.py", line 685, in reraise
raise value.with_traceback(tb)
yield saved
yield
File "/tmp/pip-install-uzmrzqtj/h5py/setup.py", line 159, in <module>
cmdclass = CMDCLASS,
File "/usr/local/lib/python3.6/dist-packages/setuptools/__init__.py", line 144, in setup
_install_setup_requires(attrs)
File "/usr/local/lib/python3.6/dist-packages/setuptools/__init__.py", line 139, in _install_setup_requires
dist.fetch_build_eggs(dist.setup_requires)
File "/usr/local/lib/python3.6/dist-packages/setuptools/dist.py", line 720, in fetch_build_eggs
replace_conflicting=True,
File "/usr/local/lib/python3.6/dist-packages/pkg_resources/__init__.py", line 782, in resolve
replace_conflicting=replace_conflicting
File "/usr/local/lib/python3.6/dist-packages/pkg_resources/__init__.py", line 1065, in best_match
return self.obtain(req, installer)
File "/usr/local/lib/python3.6/dist-packages/pkg_resources/__init__.py", line 1077, in obtain
return installer(requirement)
File "/usr/local/lib/python3.6/dist-packages/setuptools/dist.py", line 787, in fetch_build_egg
return cmd.easy_install(req)
File "/usr/local/lib/python3.6/dist-packages/setuptools/command/easy_install.py", line 679, in easy_install
return self.install_item(spec, dist.location, tmpdir, deps)
File "/usr/local/lib/python3.6/dist-packages/setuptools/command/easy_install.py", line 705, in install_item
dists = self.install_eggs(spec, download, tmpdir)
File "/usr/local/lib/python3.6/dist-packages/setuptools/command/easy_install.py", line 890, in install_eggs
return self.build_and_install(setup_script, setup_base)
File "/usr/local/lib/python3.6/dist-packages/setuptools/command/easy_install.py", line 1158, in build_and_install
self.run_setup(setup_script, setup_base, args)
File "/usr/local/lib/python3.6/dist-packages/setuptools/command/easy_install.py", line 1146, in run_setup
raise DistutilsError("Setup script exited with %s" % (v.args[0],))
distutils.errors.DistutilsError: Setup script exited with error: command 'aarch64-linux-gnu-gcc' failed with
