Tensorflow
I am new to programming and not quite familiar with ubuntu etc..
I am trying to install Tensorflow according to the following instructions:
however this fails in several places.
After the following command:
sudo pip3 install -U numpy grpcio absl-py py-cpuinfo psutil portpicker six mock requests gast h5py astor termcolor protobuf keras-applications keras-preprocessing wrapt google-pasta
I get this error message:
define NPY_RELAXED_STRIDES_CHECKING 1
define HAVE_LDOUBLE_IEEE_QUAD_LE 1
define NPY_PY3K 1
#ifndef __cplusplus
/* #undef inline */
endif
#ifndef _NPY_NPY_CONFIG_H_
#error config.h should never be included directly, include npy_config.h instead
#endif
EOF
  adding 'build/src.linux-aarch64-3.6/numpy/core/include/numpy/config.h' to sources.
Generating build/src.linux-aarch64-3.6/numpy/core/include/numpy/_numpyconfig.h
C compiler: aarch64-linux-gnu-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC
compile options: '-Inumpy/core/src/private -Inumpy/core/src -Inumpy/core -Inumpy/core/src/npymath -Inumpy/core/src/multiarray -Inumpy/core/src/umath -Inumpy/core/src/npysort -I/usr/include/python3.6m -c'
aarch64-linux-gnu-gcc: _configtest.c
_configtest.c:1:5: warning: conflicting types for built-in function ‘exp’ [-Wbuiltin-declaration-mismatch]
 int exp (void);
aarch64-linux-gnu-gcc -pthread _configtest.o -o _configtest
_configtest.o: In Funktion »main«:
/tmp/pip-install-z270b_cp/numpy_21cb614a79104d9aa17cd6c03524ee4a/_configtest.c:6: Warnung: undefinierter Verweis auf »exp«
collect2: error: ld returned 1 exit status
failure.
removing: _configtest.c _configtest.o
 int exp (void);
aarch64-linux-gnu-gcc -pthread _configtest.o -lm -o _configtest
success!
removing: _configtest.c _configtest.o _configtest
success!
success!
File: build/src.linux-aarch64-3.6/numpy/core/include/numpy/_numpyconfig.h
#define NPY_HAVE_ENDIAN_H 1
#define NPY_SIZEOF_SHORT SIZEOF_SHORT
#define NPY_SIZEOF_INT SIZEOF_INT
#define NPY_SIZEOF_LONG SIZEOF_LONG
#define NPY_SIZEOF_FLOAT 4
#define NPY_SIZEOF_COMPLEX_FLOAT 8
#define NPY_SIZEOF_DOUBLE 8
#define NPY_SIZEOF_COMPLEX_DOUBLE 16
#define NPY_SIZEOF_LONGDOUBLE 16
#define NPY_SIZEOF_COMPLEX_LONGDOUBLE 32
#define NPY_SIZEOF_PY_INTPTR_T 8
#define NPY_SIZEOF_OFF_T 8
#define NPY_SIZEOF_PY_LONG_LONG 8
#define NPY_SIZEOF_LONGLONG 8
#define NPY_NO_SMP 0
#define NPY_HAVE_DECL_ISNAN
#define NPY_HAVE_DECL_ISINF
#define NPY_HAVE_DECL_ISFINITE
#define NPY_HAVE_DECL_SIGNBIT
#define NPY_USE_C99_COMPLEX 1
#define NPY_HAVE_COMPLEX_DOUBLE 1
#define NPY_HAVE_COMPLEX_FLOAT 1
#define NPY_HAVE_COMPLEX_LONG_DOUBLE 1
#define NPY_RELAXED_STRIDES_CHECKING 1
#define NPY_USE_C99_FORMATS 1
#define NPY_VISIBILITY_HIDDEN __attribute__((visibility("hidden")))
#define NPY_ABI_VERSION 0x01000009
#define NPY_API_VERSION 0x0000000A
#ifndef __STDC_FORMAT_MACROS
#define __STDC_FORMAT_MACROS 1
#endif
EOF
  adding 'build/src.linux-aarch64-3.6/numpy/core/include/numpy/_numpyconfig.h' to sources.
executing numpy/core/code_generators/generate_numpy_api.py
  adding 'build/src.linux-aarch64-3.6/numpy/core/include/numpy/__multiarray_api.h' to sources.
numpy.core - nothing done with h_files = ['build/src.linux-aarch64-3.6/numpy/core/include/numpy/config.h', 'build/src.linux-aarch64-3.6/numpy/core/include/numpy/_numpyconfig.h', 'build/src.linux-aarch64-3.6/numpy/core/include/numpy/__multiarray_api.h']
building extension "numpy.core.multiarray" sources
creating build/src.linux-aarch64-3.6/numpy/core/src/multiarray
conv_template:> build/src.linux-aarch64-3.6/numpy/core/src/multiarray/arraytypes.c
conv_template:> build/src.linux-aarch64-3.6/numpy/core/src/multiarray/einsum.c
conv_template:> build/src.linux-aarch64-3.6/numpy/core/src/multiarray/lowlevel_strided_loops.c
conv_template:> build/src.linux-aarch64-3.6/numpy/core/src/multiarray/nditer_templ.c
conv_template:> build/src.linux-aarch64-3.6/numpy/core/src/multiarray/scalartypes.c
conv_template:> build/src.linux-aarch64-3.6/numpy/core/src/private/templ_common.h
  adding 'build/src.linux-aarch64-3.6/numpy/core/src/private' to include_dirs.
numpy.core - nothing done with h_files = ['build/src.linux-aarch64-3.6/numpy/core/src/private/templ_common.h', 'build/src.linux-aarch64-3.6/numpy/core/include/numpy/config.h', 'build/src.linux-aarch64-3.6/numpy/core/include/numpy/_numpyconfig.h', 'build/src.linux-aarch64-3.6/numpy/core/include/numpy/__multiarray_api.h']
building extension "numpy.core.umath" sources
executing numpy/core/code_generators/generate_ufunc_api.py
  adding 'build/src.linux-aarch64-3.6/numpy/core/include/numpy/__ufunc_api.h' to sources.
creating build/src.linux-aarch64-3.6/numpy/core/src/umath
conv_template:> build/src.linux-aarch64-3.6/numpy/core/src/umath/funcs.inc
  adding 'build/src.linux-aarch64-3.6/numpy/core/src/umath' to include_dirs.
conv_template:> build/src.linux-aarch64-3.6/numpy/core/src/umath/simd.inc
conv_template:> build/src.linux-aarch64-3.6/numpy/core/src/umath/loops.h
conv_template:> build/src.linux-aarch64-3.6/numpy/core/src/umath/loops.c
conv_template:> build/src.linux-aarch64-3.6/numpy/core/src/umath/scalarmath.c
numpy.core - nothing done with h_files = ['build/src.linux-aarch64-3.6/numpy/core/src/umath/funcs.inc', 'build/src.linux-aarch64-3.6/numpy/core/src/umath/simd.inc', 'build/src.linux-aarch64-3.6/numpy/core/src/umath/loops.h', 'build/src.linux-aarch64-3.6/numpy/core/include/numpy/config.h', 'build/src.linux-aarch64-3.6/numpy/core/include/numpy/_numpyconfig.h', 'build/src.linux-aarch64-3.6/numpy/core/include/numpy/__ufunc_api.h']
building extension "numpy.core.umath_tests" sources
conv_template:> build/src.linux-aarch64-3.6/numpy/core/src/umath/umath_tests.c
building extension "numpy.core.test_rational" sources
conv_template:> build/src.linux-aarch64-3.6/numpy/core/src/umath/test_rational.c
building extension "numpy.core.struct_ufunc_test" sources
conv_template:> build/src.linux-aarch64-3.6/numpy/core/src/umath/struct_ufunc_test.c
building extension "numpy.core.multiarray_tests" sources
conv_template:> build/src.linux-aarch64-3.6/numpy/core/src/multiarray/multiarray_tests.c
building extension "numpy.core.operand_flag_tests" sources
conv_template:> build/src.linux-aarch64-3.6/numpy/core/src/umath/operand_flag_tests.c
building extension "numpy.fft.fftpack_lite" sources
building extension "numpy.linalg.lapack_lite" sources
creating build/src.linux-aarch64-3.6/numpy/linalg
  adding 'numpy/linalg/lapack_lite/python_xerbla.c' to sources.
building extension "numpy.linalg._umath_linalg" sources
conv_template:> build/src.linux-aarch64-3.6/numpy/linalg/umath_linalg.c
building extension "numpy.random.mtrand" sources
creating build/src.linux-aarch64-3.6/numpy/random
building data_files sources
build_src: building npy-pkg config files
running build_py
creating build/lib.linux-aarch64-3.6
creating build/lib.linux-aarch64-3.6/numpy
copying numpy/add_newdocs.py -> build/lib.linux-aarch64-3.6/numpy
copying numpy/_import_tools.py -> build/lib.linux-aarch64-3.6/numpy
copying numpy/matlib.py -> build/lib.linux-aarch64-3.6/numpy
copying numpy/dual.py -> build/lib.linux-aarch64-3.6/numpy
copying numpy/ctypeslib.py -> build/lib.linux-aarch64-3.6/numpy
copying numpy/_distributor_init.py -> build/lib.linux-aarch64-3.6/numpy
copying numpy/__init__.py -> build/lib.linux-aarch64-3.6/numpy
copying numpy/_globals.py -> build/lib.linux-aarch64-3.6/numpy
copying numpy/setup.py -> build/lib.linux-aarch64-3.6/numpy
copying numpy/version.py -> build/lib.linux-aarch64-3.6/numpy
copying build/src.linux-aarch64-3.6/numpy/__config__.py -> build/lib.linux-aarch64-3.6/numpy
creating build/lib.linux-aarch64-3.6/numpy/compat
copying numpy/compat/py3k.py -> build/lib.linux-aarch64-3.6/numpy/compat
copying numpy/compat/_inspect.py -> build/lib.linux-aarch64-3.6/numpy/compat
copying numpy/compat/__init__.py -> build/lib.linux-aarch64-3.6/numpy/compat
copying numpy/compat/setup.py -> build/lib.linux-aarch64-3.6/numpy/compat
creating build/lib.linux-aarch64-3.6/numpy/core
copying numpy/core/setup_common.py -> build/lib.linux-aarch64-3.6/numpy/core
copying numpy/core/shape_base.py -> build/lib.linux-aarch64-3.6/numpy/core
copying numpy/core/fromnumeric.py -> build/lib.linux-aarch64-3.6/numpy/core
copying numpy/core/defchararray.py -> build/lib.linux-aarch64-3.6/numpy/core
copying numpy/core/numerictypes.py -> build/lib.linux-aarch64-3.6/numpy/core
copying numpy/core/arrayprint.py -> build/lib.linux-aarch64-3.6/numpy/core
copying numpy/core/function_base.py -> build/lib.linux-aarch64-3.6/numpy/core
copying numpy/core/getlimits.py -> build/lib.linux-aarch64-3.6/numpy/core
copying numpy/core/einsumfunc.py -> build/lib.linux-aarch64-3.6/numpy/core
copying numpy/core/machar.py -> build/lib.linux-aarch64-3.6/numpy/core
copying numpy/core/info.py -> build/lib.linux-aarch64-3.6/numpy/core
copying numpy/core/_internal.py -> build/lib.linux-aarch64-3.6/numpy/core
copying numpy/core/__init__.py -> build/lib.linux-aarch64-3.6/numpy/core
copying numpy/core/_methods.py -> build/lib.linux-aarch64-3.6/numpy/core
copying numpy/core/numeric.py -> build/lib.linux-aarch64-3.6/numpy/core
copying numpy/core/setup.py -> build/lib.linux-aarch64-3.6/numpy/core
copying numpy/core/memmap.py -> build/lib.linux-aarch64-3.6/numpy/core
copying numpy/core/cversions.py -> build/lib.linux-aarch64-3.6/numpy/core
copying numpy/core/records.py -> build/lib.linux-aarch64-3.6/numpy/core
copying numpy/core/code_generators/generate_numpy_api.py -> build/lib.linux-aarch64-3.6/numpy/core
creating build/lib.linux-aarch64-3.6/numpy/distutils
copying numpy/distutils/lib2def.py -> build/lib.linux-aarch64-3.6/numpy/distutils
copying numpy/distutils/msvc9compiler.py -> build/lib.linux-aarch64-3.6/numpy/distutils
copying numpy/distutils/npy_pkg_config.py -> build/lib.linux-aarch64-3.6/numpy/distutils
copying numpy/distutils/__version__.py -> build/lib.linux-aarch64-3.6/numpy/distutils
copying numpy/distutils/from_template.py -> build/lib.linux-aarch64-3.6/numpy/distutils
copying numpy/distutils/core.py -> build/lib.linux-aarch64-3.6/numpy/distutils
copying numpy/distutils/mingw32ccompiler.py -> build/lib.linux-aarch64-3.6/numpy/distutils
copying numpy/distutils/environment.py -> build/lib.linux-aarch64-3.6/numpy/distutils
copying numpy/distutils/ccompiler.py -> build/lib.linux-aarch64-3.6/numpy/distutils
copying numpy/distutils/misc_util.py -> build/lib.linux-aarch64-3.6/numpy/distutils
copying numpy/distutils/conv_template.py -> build/lib.linux-aarch64-3.6/numpy/distutils
copying numpy/distutils/pathccompiler.py -> build/lib.linux-aarch64-3.6/numpy/distutils
copying numpy/distutils/cpuinfo.py -> build/lib.linux-aarch64-3.6/numpy/distutils
copying numpy/distutils/compat.py -> build/lib.linux-aarch64-3.6/numpy/distutils
copying numpy/distutils/unixccompiler.py -> build/lib.linux-aarch64-3.6/numpy/distutils
copying numpy/distutils/system_info.py -> build/lib.linux-aarch64-3.6/numpy/distutils
copying numpy/distutils/extension.py -> build/lib.linux-aarch64-3.6/numpy/distutils
copying numpy/distutils/info.py -> build/lib.linux-aarch64-3.6/numpy/distutils
copying numpy/distutils/line_endings.py -> build/lib.linux-aarch64-3.6/numpy/distutils
copying numpy/distutils/numpy_distribution.py -> build/lib.linux-aarch64-3.6/numpy/distutils
copying numpy/distutils/__init__.py -> build/lib.linux-aarch64-3.6/numpy/distutils
copying numpy/distutils/msvccompiler.py -> build/lib.linux-aarch64-3.6/numpy/distutils
copying numpy/distutils/log.py -> build/lib.linux-aarch64-3.6/numpy/distutils
copying numpy/distutils/setup.py -> build/lib.linux-aarch64-3.6/numpy/distutils
copying numpy/distutils/exec_command.py -> build/lib.linux-aarch64-3.6/numpy/distutils
copying numpy/distutils/intelccompiler.py -> build/lib.linux-aarch64-3.6/numpy/distutils
copying build/src.linux-aarch64-3.6/numpy/distutils/__config__.py -> build/lib.linux-aarch64-3.6/numpy/distutils
creating build/lib.linux-aarch64-3.6/numpy/distutils/command
copying numpy/distutils/command/build_py.py -> build/lib.linux-aarch64-3.6/numpy/distutils/command
copying numpy/distutils/command/bdist_rpm.py -> build/lib.linux-aarch64-3.6/numpy/distutils/command
copying numpy/distutils/command/sdist.py -> build/lib.linux-aarch64-3.6/numpy/distutils/command
copying numpy/distutils/command/build_src.py -> build/lib.linux-aarch64-3.6/numpy/distutils/command
copying numpy/distutils/command/install.py -> build/lib.linux-aarch64-3.6/numpy/distutils/command
copying numpy/distutils/command/install_headers.py -> build/lib.linux-aarch64-3.6/numpy/distutils/command
copying numpy/distutils/command/build_clib.py -> build/lib.linux-aarch64-3.6/numpy/distutils/command
copying numpy/distutils/command/build_scripts.py -> build/lib.linux-aarch64-3.6/numpy/distutils/command
copying numpy/distutils/command/egg_info.py -> build/lib.linux-aarch64-3.6/numpy/distutils/command
copying numpy/distutils/command/config_compiler.py -> build/lib.linux-aarch64-3.6/numpy/distutils/command
copying numpy/distutils/command/develop.py -> build/lib.linux-aarch64-3.6/numpy/distutils/command
copying numpy/distutils/command/install_clib.py -> build/lib.linux-aarch64-3.6/numpy/distutils/command
copying numpy/distutils/command/install_data.py -> build/lib.linux-aarch64-3.6/numpy/distutils/command
copying numpy/distutils/command/__init__.py -> build/lib.linux-aarch64-3.6/numpy/distutils/command
copying numpy/distutils/command/build.py -> build/lib.linux-aarch64-3.6/numpy/distutils/command
copying numpy/distutils/command/build_ext.py -> build/lib.linux-aarch64-3.6/numpy/distutils/command
copying numpy/distutils/command/config.py -> build/lib.linux-aarch64-3.6/numpy/distutils/command
copying numpy/distutils/command/autodist.py -> build/lib.linux-aarch64-3.6/numpy/distutils/command
creating build/lib.linux-aarch64-3.6/numpy/distutils/fcompiler
copying numpy/distutils/fcompiler/mips.py -> build/lib.linux-aarch64-3.6/numpy/distutils/fcompiler
copying numpy/distutils/fcompiler/pathf95.py -> build/lib.linux-aarch64-3.6/numpy/distutils/fcompiler
copying numpy/distutils/fcompiler/ibm.py -> build/lib.linux-aarch64-3.6/numpy/distutils/fcompiler
copying numpy/distutils/fcompiler/vast.py -> build/lib.linux-aarch64-3.6/numpy/distutils/fcompiler
copying numpy/distutils/fcompiler/compaq.py -> build/lib.linux-aarch64-3.6/numpy/distutils/fcompiler
copying numpy/distutils/fcompiler/absoft.py -> build/lib.linux-aarch64-3.6/numpy/distutils/fcompiler
copying numpy/distutils/fcompiler/pg.py -> build/lib.linux-aarch64-3.6/numpy/distutils/fcompiler
copying numpy/distutils/fcompiler/sun.py -> build/lib.linux-aarch64-3.6/numpy/distutils/fcompiler
copying numpy/distutils/fcompiler/intel.py -> build/lib.linux-aarch64-3.6/numpy/distutils/fcompiler
copying numpy/distutils/fcompiler/hpux.py -> build/lib.linux-aarch64-3.6/numpy/distutils/fcompiler
copying numpy/distutils/fcompiler/none.py -> build/lib.linux-aarch64-3.6/numpy/distutils/fcompiler
copying numpy/distutils/fcompiler/g95.py -> build/lib.linux-aarch64-3.6/numpy/distutils/fcompiler
copying numpy/distutils/fcompiler/__init__.py -> build/lib.linux-aarch64-3.6/numpy/distutils/fcompiler
copying numpy/distutils/fcompiler/lahey.py -> build/lib.linux-aarch64-3.6/numpy/distutils/fcompiler
copying numpy/distutils/fcompiler/nag.py -> build/lib.linux-aarch64-3.6/numpy/distutils/fcompiler
copying numpy/distutils/fcompiler/gnu.py -> build/lib.linux-aarch64-3.6/numpy/distutils/fcompiler
creating build/lib.linux-aarch64-3.6/numpy/doc
copying numpy/doc/constants.py -> build/lib.linux-aarch64-3.6/numpy/doc
copying numpy/doc/misc.py -> build/lib.linux-aarch64-3.6/numpy/doc
copying numpy/doc/creation.py -> build/lib.linux-aarch64-3.6/numpy/doc
copying numpy/doc/internals.py -> build/lib.linux-aarch64-3.6/numpy/doc
copying numpy/doc/broadcasting.py -> build/lib.linux-aarch64-3.6/numpy/doc
copying numpy/doc/indexing.py -> build/lib.linux-aarch64-3.6/numpy/doc
copying numpy/doc/basics.py -> build/lib.linux-aarch64-3.6/numpy/doc
copying numpy/doc/ufuncs.py -> build/lib.linux-aarch64-3.6/numpy/doc
copying numpy/doc/structured_arrays.py -> build/lib.linux-aarch64-3.6/numpy/doc
copying numpy/doc/glossary.py -> build/lib.linux-aarch64-3.6/numpy/doc
copying numpy/doc/__init__.py -> build/lib.linux-aarch64-3.6/numpy/doc
copying numpy/doc/byteswapping.py -> build/lib.linux-aarch64-3.6/numpy/doc
copying numpy/doc/subclassing.py -> build/lib.linux-aarch64-3.6/numpy/doc
creating build/lib.linux-aarch64-3.6/numpy/f2py
copying numpy/f2py/__version__.py -> build/lib.linux-aarch64-3.6/numpy/f2py
copying numpy/f2py/auxfuncs.py -> build/lib.linux-aarch64-3.6/numpy/f2py
copying numpy/f2py/rules.py -> build/lib.linux-aarch64-3.6/numpy/f2py
copying numpy/f2py/capi_maps.py -> build/lib.linux-aarch64-3.6/numpy/f2py
copying numpy/f2py/__main__.py -> build/lib.linux-aarch64-3.6/numpy/f2py
copying numpy/f2py/f90mod_rules.py -> build/lib.linux-aarch64-3.6/numpy/f2py
copying numpy/f2py/crackfortran.py -> build/lib.linux-aarch64-3.6/numpy/f2py
copying numpy/f2py/func2subr.py -> build/lib.linux-aarch64-3.6/numpy/f2py
copying numpy/f2py/cb_rules.py -> build/lib.linux-aarch64-3.6/numpy/f2py
copying numpy/f2py/diagnose.py -> build/lib.linux-aarch64-3.6/numpy/f2py
copying numpy/f2py/f2py_testing.py -> build/lib.linux-aarch64-3.6/numpy/f2py
copying numpy/f2py/common_rules.py -> build/lib.linux-aarch64-3.6/numpy/f2py
copying numpy/f2py/info.py -> build/lib.linux-aarch64-3.6/numpy/f2py
copying numpy/f2py/__init__.py -> build/lib.linux-aarch64-3.6/numpy/f2py
copying numpy/f2py/f2py2e.py -> build/lib.linux-aarch64-3.6/numpy/f2py
copying numpy/f2py/use_rules.py -> build/lib.linux-aarch64-3.6/numpy/f2py
copying numpy/f2py/setup.py -> build/lib.linux-aarch64-3.6/numpy/f2py
copying numpy/f2py/cfuncs.py -> build/lib.linux-aarch64-3.6/numpy/f2py
creating build/lib.linux-aarch64-3.6/numpy/fft
copying numpy/fft/fftpack.py -> build/lib.linux-aarch64-3.6/numpy/fft
copying numpy/fft/info.py -> build/lib.linux-aarch64-3.6/numpy/fft
copying numpy/fft/__init__.py -> build/lib.linux-aarch64-3.6/numpy/fft
copying numpy/fft/setup.py -> build/lib.linux-aarch64-3.6/numpy/fft
copying numpy/fft/helper.py -> build/lib.linux-aarch64-3.6/numpy/fft
creating build/lib.linux-aarch64-3.6/numpy/lib
copying numpy/lib/scimath.py -> build/lib.linux-aarch64-3.6/numpy/lib
copying numpy/lib/nanfunctions.py -> build/lib.linux-aarch64-3.6/numpy/lib
copying numpy/lib/shape_base.py -> build/lib.linux-aarch64-3.6/numpy/lib
copying numpy/lib/_version.py -> build/lib.linux-aarch64-3.6/numpy/lib
copying numpy/lib/arraypad.py -> build/lib.linux-aarch64-3.6/numpy/lib
copying numpy/lib/format.py -> build/lib.linux-aarch64-3.6/numpy/lib
copying numpy/lib/polynomial.py -> build/lib.linux-aarch64-3.6/numpy/lib
copying numpy/lib/arraysetops.py -> build/lib.linux-aarch64-3.6/numpy/lib
copying numpy/lib/twodim_base.py -> build/lib.linux-aarch64-3.6/numpy/lib
copying numpy/lib/ufunclike.py -> build/lib.linux-aarch64-3.6/numpy/lib
copying numpy/lib/utils.py -> build/lib.linux-aarch64-3.6/numpy/lib
copying numpy/lib/function_base.py -> build/lib.linux-aarch64-3.6/numpy/lib
copying numpy/lib/stride_tricks.py -> build/lib.linux-aarch64-3.6/numpy/lib
copying numpy/lib/index_tricks.py -> build/lib.linux-aarch64-3.6/numpy/lib
copying numpy/lib/type_check.py -> build/lib.linux-aarch64-3.6/numpy/lib
copying numpy/lib/arrayterator.py -> build/lib.linux-aarch64-3.6/numpy/lib
copying numpy/lib/info.py -> build/lib.linux-aarch64-3.6/numpy/lib
copying numpy/lib/financial.py -> build/lib.linux-aarch64-3.6/numpy/lib
copying numpy/lib/_iotools.py -> build/lib.linux-aarch64-3.6/numpy/lib
copying numpy/lib/__init__.py -> build/lib.linux-aarch64-3.6/numpy/lib
copying numpy/lib/recfunctions.py -> build/lib.linux-aarch64-3.6/numpy/lib
copying numpy/lib/user_array.py -> build/lib.linux-aarch64-3.6/numpy/lib
copying numpy/lib/setup.py -> build/lib.linux-aarch64-3.6/numpy/lib
copying numpy/lib/_datasource.py -> build/lib.linux-aarch64-3.6/numpy/lib
copying numpy/lib/npyio.py -> build/lib.linux-aarch64-3.6/numpy/lib
creating build/lib.linux-aarch64-3.6/numpy/linalg
copying numpy/linalg/info.py -> build/lib.linux-aarch64-3.6/numpy/linalg
copying numpy/linalg/linalg.py -> build/lib.linux-aarch64-3.6/numpy/linalg
copying numpy/linalg/__init__.py -> build/lib.linux-aarch64-3.6/numpy/linalg
copying numpy/linalg/setup.py -> build/lib.linux-aarch64-3.6/numpy/linalg
creating build/lib.linux-aarch64-3.6/numpy/ma
copying numpy/ma/core.py -> build/lib.linux-aarch64-3.6/numpy/ma
copying numpy/ma/timer_comparison.py -> build/lib.linux-aarch64-3.6/numpy/ma
copying numpy/ma/bench.py -> build/lib.linux-aarch64-3.6/numpy/ma
copying numpy/ma/mrecords.py -> build/lib.linux-aarch64-3.6/numpy/ma
copying numpy/ma/testutils.py -> build/lib.linux-aarch64-3.6/numpy/ma
copying numpy/ma/extras.py -> build/lib.linux-aarch64-3.6/numpy/ma
copying numpy/ma/__init__.py -> build/lib.linux-aarch64-3.6/numpy/ma
copying numpy/ma/setup.py -> build/lib.linux-aarch64-3.6/numpy/ma
copying numpy/ma/version.py -> build/lib.linux-aarch64-3.6/numpy/ma
creating build/lib.linux-aarch64-3.6/numpy/matrixlib
copying numpy/matrixlib/defmatrix.py -> build/lib.linux-aarch64-3.6/numpy/matrixlib
copying numpy/matrixlib/__init__.py -> build/lib.linux-aarch64-3.6/numpy/matrixlib
copying numpy/matrixlib/setup.py -> build/lib.linux-aarch64-3.6/numpy/matrixlib
creating build/lib.linux-aarch64-3.6/numpy/polynomial
copying numpy/polynomial/legendre.py -> build/lib.linux-aarch64-3.6/numpy/polynomial
copying numpy/polynomial/chebyshev.py -> build/lib.linux-aarch64-3.6/numpy/polynomial
copying numpy/polynomial/laguerre.py -> build/lib.linux-aarch64-3.6/numpy/polynomial
copying numpy/polynomial/hermite.py -> build/lib.linux-aarch64-3.6/numpy/polynomial
copying numpy/polynomial/polynomial.py -> build/lib.linux-aarch64-3.6/numpy/polynomial
copying numpy/polynomial/__init__.py -> build/lib.linux-aarch64-3.6/numpy/polynomial
copying numpy/polynomial/_polybase.py -> build/lib.linux-aarch64-3.6/numpy/polynomial
copying numpy/polynomial/polyutils.py -> build/lib.linux-aarch64-3.6/numpy/polynomial
copying numpy/polynomial/setup.py -> build/lib.linux-aarch64-3.6/numpy/polynomial
copying numpy/polynomial/hermite_e.py -> build/lib.linux-aarch64-3.6/numpy/polynomial
creating build/lib.linux-aarch64-3.6/numpy/random
copying numpy/random/info.py -> build/lib.linux-aarch64-3.6/numpy/random
copying numpy/random/__init__.py -> build/lib.linux-aarch64-3.6/numpy/random
copying numpy/random/setup.py -> build/lib.linux-aarch64-3.6/numpy/random
creating build/lib.linux-aarch64-3.6/numpy/testing
copying numpy/testing/decorators.py -> build/lib.linux-aarch64-3.6/numpy/testing
copying numpy/testing/nosetester.py -> build/lib.linux-aarch64-3.6/numpy/testing
copying numpy/testing/utils.py -> build/lib.linux-aarch64-3.6/numpy/testing
copying numpy/testing/print_coercion_tables.py -> build/lib.linux-aarch64-3.6/numpy/testing
copying numpy/testing/__init__.py -> build/lib.linux-aarch64-3.6/numpy/testing
copying numpy/testing/noseclasses.py -> build/lib.linux-aarch64-3.6/numpy/testing
copying numpy/testing/setup.py -> build/lib.linux-aarch64-3.6/numpy/testing
running build_clib
customize UnixCCompiler
customize UnixCCompiler using build_clib
building 'npymath' library
compiling C sources
creating build/temp.linux-aarch64-3.6
creating build/temp.linux-aarch64-3.6/build
creating build/temp.linux-aarch64-3.6/build/src.linux-aarch64-3.6
creating build/temp.linux-aarch64-3.6/build/src.linux-aarch64-3.6/numpy
creating build/temp.linux-aarch64-3.6/build/src.linux-aarch64-3.6/numpy/core
creating build/temp.linux-aarch64-3.6/build/src.linux-aarch64-3.6/numpy/core/src
creating build/temp.linux-aarch64-3.6/build/src.linux-aarch64-3.6/numpy/core/src/npymath
creating build/temp.linux-aarch64-3.6/numpy
creating build/temp.linux-aarch64-3.6/numpy/core
creating build/temp.linux-aarch64-3.6/numpy/core/src
creating build/temp.linux-aarch64-3.6/numpy/core/src/npymath
compile options: '-Inumpy/core/include -Ibuild/src.linux-aarch64-3.6/numpy/core/include/numpy -Inumpy/core/src/private -Inumpy/core/src -Inumpy/core -Inumpy/core/src/npymath -Inumpy/core/src/multiarray -Inumpy/core/src/umath -Inumpy/core/src/npysort -I/usr/include/python3.6m -Ibuild/src.linux-aarch64-3.6/numpy/core/src/private -Ibuild/src.linux-aarch64-3.6/numpy/core/src/private -Ibuild/src.linux-aarch64-3.6/numpy/core/src/private -c'
aarch64-linux-gnu-gcc: build/src.linux-aarch64-3.6/numpy/core/src/npymath/npy_math.c
aarch64-linux-gnu-gcc: build/src.linux-aarch64-3.6/numpy/core/src/npymath/ieee754.c
aarch64-linux-gnu-gcc: build/src.linux-aarch64-3.6/numpy/core/src/npymath/npy_math_complex.c
aarch64-linux-gnu-gcc: numpy/core/src/npymath/halffloat.c
aarch64-linux-gnu-gcc-ar: adding 4 object files to build/temp.linux-aarch64-3.6/libnpymath.a
building 'npysort' library
compiling C sources
creating build/temp.linux-aarch64-3.6/build/src.linux-aarch64-3.6/numpy/core/src/npysort
compile options: '-Ibuild/src.linux-aarch64-3.6/numpy/core/src/private -Inumpy/core/include -Ibuild/src.linux-aarch64-3.6/numpy/core/include/numpy -Inumpy/core/src/private -Inumpy/core/src -Inumpy/core -Inumpy/core/src/npymath -Inumpy/core/src/multiarray -Inumpy/core/src/umath -Inumpy/core/src/npysort -I/usr/include/python3.6m -Ibuild/src.linux-aarch64-3.6/numpy/core/src/private -Ibuild/src.linux-aarch64-3.6/numpy/core/src/private -Ibuild/src.linux-aarch64-3.6/numpy/core/src/private -c'
aarch64-linux-gnu-gcc: build/src.linux-aarch64-3.6/numpy/core/src/npysort/quicksort.c
aarch64-linux-gnu-gcc: build/src.linux-aarch64-3.6/numpy/core/src/npysort/mergesort.c
aarch64-linux-gnu-gcc: build/src.linux-aarch64-3.6/numpy/core/src/npysort/heapsort.c
aarch64-linux-gnu-gcc: build/src.linux-aarch64-3.6/numpy/core/src/npysort/selection.c
aarch64-linux-gnu-gcc: build/src.linux-aarch64-3.6/numpy/core/src/npysort/binsearch.c
aarch64-linux-gnu-gcc-ar: adding 5 object files to build/temp.linux-aarch64-3.6/libnpysort.a
running build_ext
customize UnixCCompiler using build_ext
building 'numpy.core._dummy' extension
compiling C sources
compile options: '-DHAVE_NPY_CONFIG_H=1 -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE=1 -D_LARGEFILE64_SOURCE=1 -Inumpy/core/include -Ibuild/src.linux-aarch64-3.6/numpy/core/include/numpy -Inumpy/core/src/private -Inumpy/core/src -Inumpy/core -Inumpy/core/src/npymath -Inumpy/core/src/multiarray -Inumpy/core/src/umath -Inumpy/core/src/npysort -I/usr/include/python3.6m -Ibuild/src.linux-aarch64-3.6/numpy/core/src/private -Ibuild/src.linux-aarch64-3.6/numpy/core/src/private -Ibuild/src.linux-aarch64-3.6/numpy/core/src/private -c'
aarch64-linux-gnu-gcc: numpy/core/src/dummymodule.c
aarch64-linux-gnu-gcc -pthread -shared -Wl,-O1 -Wl,-Bsymbolic-functions -Wl,-Bsymbolic-functions -Wl,-z,relro -Wl,-Bsymbolic-functions -Wl,-z,relro -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 build/temp.linux-aarch64-3.6/numpy/core/src/dummymodule.o -Lbuild/temp.linux-aarch64-3.6 -lm -o build/lib.linux-aarch64-3.6/numpy/core/_dummy.cpython-36m-aarch64-linux-gnu.so
building 'numpy.core.multiarray' extension
compiling C sources
creating build/temp.linux-aarch64-3.6/numpy/core/src/multiarray
creating build/temp.linux-aarch64-3.6/build/src.linux-aarch64-3.6/numpy/core/src/multiarray
creating build/temp.linux-aarch64-3.6/numpy/core/src/private
compile options: '-DHAVE_NPY_CONFIG_H=1 -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE=1 -D_LARGEFILE64_SOURCE=1 -DNO_ATLAS_INFO=1 -DHAVE_CBLAS -Ibuild/src.linux-aarch64-3.6/numpy/core/src/private -Inumpy/core/include -Ibuild/src.linux-aarch64-3.6/numpy/core/include/numpy -Inumpy/core/src/private -Inumpy/core/src -Inumpy/core -Inumpy/core/src/npymath -Inumpy/core/src/multiarray -Inumpy/core/src/umath -Inumpy/core/src/npysort -I/usr/include/python3.6m -Ibuild/src.linux-aarch64-3.6/numpy/core/src/private -Ibuild/src.linux-aarch64-3.6/numpy/core/src/private -Ibuild/src.linux-aarch64-3.6/numpy/core/src/private -c'
aarch64-linux-gnu-gcc: numpy/core/src/multiarray/alloc.c
aarch64-linux-gnu-gcc: numpy/core/src/multiarray/arrayobject.c
aarch64-linux-gnu-gcc: build/src.linux-aarch64-3.6/numpy/core/src/multiarray/arraytypes.c
aarch64-linux-gnu-gcc: numpy/core/src/multiarray/array_assign.c
aarch64-linux-gnu-gcc: numpy/core/src/multiarray/array_assign_scalar.c
aarch64-linux-gnu-gcc: numpy/core/src/multiarray/array_assign_array.c
aarch64-linux-gnu-gcc: numpy/core/src/multiarray/buffer.c
aarch64-linux-gnu-gcc: numpy/core/src/multiarray/calculation.c
aarch64-linux-gnu-gcc: numpy/core/src/multiarray/compiled_base.c
aarch64-linux-gnu-gcc: numpy/core/src/multiarray/common.c
aarch64-linux-gnu-gcc: numpy/core/src/multiarray/convert.c
aarch64-linux-gnu-gcc: numpy/core/src/multiarray/convert_datatype.c
aarch64-linux-gnu-gcc: numpy/core/src/multiarray/conversion_utils.c
aarch64-linux-gnu-gcc: numpy/core/src/multiarray/ctors.c
aarch64-linux-gnu-gcc: numpy/core/src/multiarray/datetime.c
aarch64-linux-gnu-gcc: numpy/core/src/multiarray/datetime_strings.c
aarch64-linux-gnu-gcc: numpy/core/src/multiarray/datetime_busday.c
aarch64-linux-gnu-gcc: numpy/core/src/multiarray/datetime_busdaycal.c
aarch64-linux-gnu-gcc: numpy/core/src/multiarray/descriptor.c
aarch64-linux-gnu-gcc: numpy/core/src/multiarray/dtype_transfer.c
aarch64-linux-gnu-gcc: build/src.linux-aarch64-3.6/numpy/core/src/multiarray/einsum.c
aarch64-linux-gnu-gcc: numpy/core/src/multiarray/flagsobject.c
aarch64-linux-gnu-gcc: numpy/core/src/multiarray/getset.c
aarch64-linux-gnu-gcc: numpy/core/src/multiarray/hashdescr.c
aarch64-linux-gnu-gcc: numpy/core/src/multiarray/item_selection.c
aarch64-linux-gnu-gcc: numpy/core/src/multiarray/iterators.c
aarch64-linux-gnu-gcc: build/src.linux-aarch64-3.6/numpy/core/src/multiarray/lowlevel_strided_loops.c
aarch64-linux-gnu-gcc: numpy/core/src/multiarray/mapping.c
aarch64-linux-gnu-gcc: numpy/core/src/multiarray/methods.c
aarch64-linux-gnu-gcc: numpy/core/src/multiarray/multiarraymodule.c
aarch64-linux-gnu-gcc: build/src.linux-aarch64-3.6/numpy/core/src/multiarray/nditer_templ.c
aarch64-linux-gnu-gcc: numpy/core/src/multiarray/nditer_api.c
aarch64-linux-gnu-gcc: numpy/core/src/multiarray/nditer_constr.c
aarch64-linux-gnu-gcc: numpy/core/src/multiarray/nditer_pywrap.c
aarch64-linux-gnu-gcc: numpy/core/src/multiarray/number.c
aarch64-linux-gnu-gcc: numpy/core/src/multiarray/numpymemoryview.c
aarch64-linux-gnu-gcc: numpy/core/src/multiarray/numpyos.c
numpy/core/src/multiarray/numpyos.c:18:10: fatal error: xlocale.h: Datei oder Verzeichnis nicht gefunden
 #include <xlocale.h>
compilation terminated.
error: Command "aarch64-linux-gnu-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -DHAVE_NPY_CONFIG_H=1 -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE=1 -D_LARGEFILE64_SOURCE=1 -DNO_ATLAS_INFO=1 -DHAVE_CBLAS -Ibuild/src.linux-aarch64-3.6/numpy/core/src/private -Inumpy/core/include -Ibuild/src.linux-aarch64-3.6/numpy/core/include/numpy -Inumpy/core/src/private -Inumpy/core/src -Inumpy/core -Inumpy/core/src/npymath -Inumpy/core/src/multiarray -Inumpy/core/src/umath -Inumpy/core/src/npysort -I/usr/include/python3.6m -Ibuild/src.linux-aarch64-3.6/numpy/core/src/private -Ibuild/src.linux-aarch64-3.6/numpy/core/src/private -Ibuild/src.linux-aarch64-3.6/numpy/core/src/private -c numpy/core/src/multiarray/numpyos.c -o build/temp.linux-aarch64-3.6/numpy/core/src/multiarray/numpyos.o" failed with exit status 1
ERROR: Failed building wheel for numpy
Running setup.py clean for numpy
ERROR: Command errored out with exit status 1:
 command: /usr/bin/python3 -u -c 'import io, os, sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-z270b_cp/numpy_21cb614a79104d9aa17cd6c03524ee4a/setup.py'"'"'; __file__='"'"'/tmp/pip-install-z270b_cp/numpy_21cb614a79104d9aa17cd6c03524ee4a/setup.py'"'"';f = getattr(tokenize, '"'"'open'"'"', open)(__file__) if os.path.exists(__file__) else io.StringIO('"'"'from setuptools import setup; setup()'"'"');code = f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' clean --all
     cwd: /tmp/pip-install-z270b_cp/numpy_21cb614a79104d9aa17cd6c03524ee4a
Complete output (10 lines):
Running from numpy source directory.
`setup.py clean` is not supported, use one of the following instead:
  - `git clean -xdf` (cleans all files)
  - `git clean -Xdf` (cleans all versioned files, doesn't touch
                      files that aren't checked into the git repo)
Add `--force` to your command to use it anyway if you must (unsupported).
ERROR: Failed cleaning build dir for numpy
Failed to build numpy
Installing collected packages: pkgconfig, numpy, Cython
Running setup.py install for numpy: started
Running setup.py install for numpy: still running…
Running setup.py install for numpy: finished with status ‘error’
command: /usr/bin/python3 -u -c ‘import io, os, sys, setuptools, tokenize; sys.argv[0] = ‘"’"’/tmp/pip-install-z270b_cp/numpy_21cb614a79104d9aa17cd6c03524ee4a/setup.py’“'”‘; file=’“'”‘/tmp/pip-install-z270b_cp/numpy_21cb614a79104d9aa17cd6c03524ee4a/setup.py’“'”‘;f = getattr(tokenize, ‘"’“‘open’”’“‘, open)(file) if os.path.exists(file) else io.StringIO(’”‘“‘from setuptools import setup; setup()’”’“‘);code = f.read().replace(’”‘"’\r\n’“'”‘, ‘"’"’\n’“'”‘);f.close();exec(compile(code, file, ‘"’“‘exec’”’"‘))’ install --record /tmp/pip-record-m3dr_0hl/install-record.txt --single-version-externally-managed --prefix /tmp/pip-build-env-tpw31hk8/normal --compile --install-headers /tmp/pip-build-env-tpw31hk8/normal/include/python3.6m/numpy
cwd: /tmp/pip-install-z270b_cp/numpy_21cb614a79104d9aa17cd6c03524ee4a/
Complete output (286 lines):
  Note: if you need reliable uninstall behavior, then install
  with pip instead of using `setup.py install`:
    - `pip install .`       (from a git repo or downloaded source
                             release)
    - `pip install numpy`   (last NumPy release on PyPi)
  blas_opt_info:
  blas_mkl_info:
    libraries mkl_rt not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/aarch64-linux-gnu']
    NOT AVAILABLE
  blis_info:
    libraries blis not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/aarch64-linux-gnu']
    NOT AVAILABLE
  openblas_info:
    libraries openblas not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/aarch64-linux-gnu']
    NOT AVAILABLE
  atlas_3_10_blas_threads_info:
  Setting PTATLAS=ATLAS
    libraries tatlas not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/aarch64-linux-gnu']
    NOT AVAILABLE
  atlas_3_10_blas_info:
    libraries satlas not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/aarch64-linux-gnu']
    NOT AVAILABLE
  atlas_blas_threads_info:
    libraries ptf77blas,ptcblas,atlas not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/aarch64-linux-gnu']
    NOT AVAILABLE
  atlas_blas_info:
    libraries f77blas,cblas,atlas not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/aarch64-linux-gnu']
    NOT AVAILABLE
  /tmp/pip-install-z270b_cp/numpy_21cb614a79104d9aa17cd6c03524ee4a/numpy/distutils/system_info.py:572: UserWarning:
      Atlas (http://math-atlas.sourceforge.net/) libraries not found.
      Directories to search for the libraries can be specified in the
      numpy/distutils/site.cfg file (section [atlas]) or by setting
      the ATLAS environment variable.
    self.calc_info()
  blas_info:
  creating /tmp/tmps1gpewmu/tmp
  creating /tmp/tmps1gpewmu/tmp/tmps1gpewmu
  compile options: '-I/usr/local/include -I/usr/include -c'
  aarch64-linux-gnu-gcc: /tmp/tmps1gpewmu/source.c
  aarch64-linux-gnu-gcc -pthread /tmp/tmps1gpewmu/tmp/tmps1gpewmu/source.o -lcblas -o /tmp/tmps1gpewmu/a.out
  /usr/bin/ld: -lcblas kann nicht gefunden werden
  aarch64-linux-gnu-gcc -pthread /tmp/tmps1gpewmu/tmp/tmps1gpewmu/source.o -lblas -o /tmp/tmps1gpewmu/a.out
    FOUND:
      libraries = ['blas', 'blas']
      library_dirs = ['/usr/lib/aarch64-linux-gnu']
      language = c
      define_macros = [('HAVE_CBLAS', None)]
    FOUND:
      define_macros = [('NO_ATLAS_INFO', 1), ('HAVE_CBLAS', None)]
      language = c
  /bin/sh: 1: svnversion: not found
  non-existing path in 'numpy/distutils': 'site.cfg'
  F2PY Version 2
  lapack_opt_info:
  lapack_mkl_info:
    NOT AVAILABLE
  openblas_lapack_info:
    NOT AVAILABLE
  atlas_3_10_threads_info:
    libraries tatlas,tatlas not found in /usr/local/lib
    libraries lapack_atlas not found in /usr/local/lib
    libraries tatlas,tatlas not found in /usr/lib
    libraries lapack_atlas not found in /usr/lib
    libraries tatlas,tatlas not found in /usr/lib/aarch64-linux-gnu
    libraries lapack_atlas not found in /usr/lib/aarch64-linux-gnu
  <class 'numpy.distutils.system_info.atlas_3_10_threads_info'>
    NOT AVAILABLE
  atlas_3_10_info:
    libraries satlas,satlas not found in /usr/local/lib
    libraries satlas,satlas not found in /usr/lib
    libraries satlas,satlas not found in /usr/lib/aarch64-linux-gnu
  <class 'numpy.distutils.system_info.atlas_3_10_info'>
    NOT AVAILABLE
  atlas_threads_info:
    libraries ptf77blas,ptcblas,atlas not found in /usr/local/lib
    libraries ptf77blas,ptcblas,atlas not found in /usr/lib
    libraries ptf77blas,ptcblas,atlas not found in /usr/lib/aarch64-linux-gnu
  <class 'numpy.distutils.system_info.atlas_threads_info'>
    NOT AVAILABLE
  atlas_info:
    libraries f77blas,cblas,atlas not found in /usr/local/lib
    libraries f77blas,cblas,atlas not found in /usr/lib
    libraries f77blas,cblas,atlas not found in /usr/lib/aarch64-linux-gnu
  <class 'numpy.distutils.system_info.atlas_info'>
    NOT AVAILABLE
  lapack_info:
    FOUND:
      libraries = ['lapack', 'lapack']
      language = f77
    FOUND:
      libraries = ['lapack', 'lapack', 'blas', 'blas']
      language = c
  /usr/lib/python3.6/distutils/dist.py:261: UserWarning: Unknown distribution option: 'define_macros'
    warnings.warn(msg)
  running install
  running build
  running config_cc
  unifing config_cc, config, build_clib, build_ext, build commands --compiler options
  running config_fc
  unifing config_fc, config, build_clib, build_ext, build commands --fcompiler options
  running build_src
  build_src
  building py_modules sources
  building library "npymath" sources
  customize Gnu95FCompiler
  Found executable /usr/bin/gfortran
  customize Gnu95FCompiler using config
  success!
   int exp (void);
  failure.
   int exp (void);
  success!
  building library "npysort" sources
  None - nothing done with h_files = ['build/src.linux-aarch64-3.6/numpy/core/src/private/npy_partition.h', 'build/src.linux-aarch64-3.6/numpy/core/src/private/npy_binsearch.h']
  building extension "numpy.core._dummy" sources
  running build_py
  running build_clib
  running build_ext
  compiling C sources
ERROR: Command errored out with exit status 1: /usr/bin/python3 -u -c ‘import io, os, sys, setuptools, tokenize; sys.argv[0] = ‘"’"’/tmp/pip-install-z270b_cp/numpy_21cb614a79104d9aa17cd6c03524ee4a/setup.py’“'”‘; file=’“'”‘/tmp/pip-install-z270b_cp/numpy_21cb614a79104d9aa17cd6c03524ee4a/setup.py’“'”‘;f = getattr(tokenize, ‘"’“‘open’”’“‘, open)(file) if os.path.exists(file) else io.StringIO(’”‘“‘from setuptools import setup; setup()’”’“‘);code = f.read().replace(’”‘"’\r\n’“'”‘, ‘"’"’\n’“'”‘);f.close();exec(compile(code, file, ‘"’“‘exec’”’"‘))’ install --record /tmp/pip-record-m3dr_0hl/install-record.txt --single-version-externally-managed --prefix /tmp/pip-build-env-tpw31hk8/normal --compile --install-headers /tmp/pip-build-env-tpw31hk8/normal/include/python3.6m/numpy Check the logs for full command output.
WARNING: Discarding https://files.pythonhosted.org/packages/15/fb/86d26128a5ea42d20f402109e76a63e59845d73171887a08a43a28b847dc/h5py-3.0.0.tar.gz#sha256=7d3803be1b530c68c2955faba726dc0f591079b68941a0c0269b5384a42ab519 (from Links for h5py) (requires-python:>=3.6). Command errored out with exit status 1: /usr/bin/python3 /usr/local/lib/python3.6/dist-packages/pip install --ignore-installed --no-user --prefix /tmp/pip-build-env-tpw31hk8/normal --no-warn-script-location --no-binary :none: --only-binary :none: -i Simple index – ‘numpy==1.19.3; python_version >= “3.9”’ ‘Cython>=0.29; python_version < “3.8”’ ‘numpy==1.14.5; python_version == “3.7”’ pkgconfig ‘numpy==1.12; python_version == “3.6”’ ‘Cython>=0.29.14; python_version >= “3.8”’ ‘numpy==1.17.5; python_version == “3.8”’ Check the logs for full command output.
Downloading h5py-2.10.0.tar.gz (301 kB)
|████████████████████████████████| 301 kB 14.1 MB/s
Requirement already satisfied: astor in /usr/local/lib/python3.6/dist-packages (0.8.1)
WARNING: Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by ‘ProtocolError(‘Connection aborted.’, ConnectionResetError(104, ‘Die Verbindung wurde vom Kommunikationspartner zurückgesetzt’))’: /simple/astor/
Requirement already satisfied: termcolor in /usr/local/lib/python3.6/dist-packages (1.1.0)
Requirement already satisfied: protobuf in /usr/local/lib/python3.6/dist-packages (3.11.3)
Collecting protobuf
Downloading protobuf-3.17.0-py2.py3-none-any.whl (173 kB)
|████████████████████████████████| 173 kB 13.9 MB/s
Requirement already satisfied: keras-applications in /usr/local/lib/python3.6/dist-packages (1.0.8)
Requirement already satisfied: keras-preprocessing in /usr/local/lib/python3.6/dist-packages (1.1.0)
Collecting keras-preprocessing
Downloading Keras_Preprocessing-1.1.2-py2.py3-none-any.whl (42 kB)
|████████████████████████████████| 42 kB 8.0 MB/s
Requirement already satisfied: wrapt in /usr/local/lib/python3.6/dist-packages (1.12.1)
Requirement already satisfied: google-pasta in /usr/local/lib/python3.6/dist-packages (0.2.0)
Requirement already satisfied: urllib3<1.27,>=1.21.1 in /usr/lib/python3/dist-packages (from requests) (1.22)
Requirement already satisfied: certifi>=2017.4.17 in /usr/lib/python3/dist-packages (from requests) (2018.1.18)
Requirement already satisfied: idna<3,>=2.5 in /usr/lib/python3/dist-packages (from requests) (2.6)
Requirement already satisfied: chardet<5,>=3.0.2 in /usr/lib/python3/dist-packages (from requests) (3.0.4)
Building wheels for collected packages: py-cpuinfo, psutil, h5py
Building wheel for py-cpuinfo (setup.py) … done
Created wheel for py-cpuinfo: filename=py_cpuinfo-8.0.0-py3-none-any.whl size=22472 sha256=6d37098178e4898d25ef0310a79835d34edad3bcc122fea3f428154439a736df
Stored in directory: /tmp/pip-ephem-wheel-cache-nwx75zxo/wheels/3e/e1/d9/9b782b170e5272d6500cee4d29dd6c724598b22dc399d81d01
Building wheel for psutil (setup.py) … done
Created wheel for psutil: filename=psutil-5.8.0-cp36-cp36m-linux_aarch64.whl size=297375 sha256=6e41eb6c2ffe56719d34fdf36bab05ee837571fae878858156fa19659f47f99f
Stored in directory: /tmp/pip-ephem-wheel-cache-nwx75zxo/wheels/6d/de/48/9e3627ec70b2df62377606d4fbe106025e60da976b8c7adabc
Building wheel for h5py (setup.py) … error
ERROR: Command errored out with exit status -4:
command: /usr/bin/python3 -u -c ‘import io, os, sys, setuptools, tokenize; sys.argv[0] = ‘"’"’/tmp/pip-install-f_p0tk4y/h5py_2a0b9128e3974d97bbb3a40519ef45ae/setup.py’“'”‘; file=’“'”‘/tmp/pip-install-f_p0tk4y/h5py_2a0b9128e3974d97bbb3a40519ef45ae/setup.py’“'”‘;f = getattr(tokenize, ‘"’“‘open’”’“‘, open)(file) if os.path.exists(file) else io.StringIO(’”‘“‘from setuptools import setup; setup()’”’“‘);code = f.read().replace(’”‘"’\r\n’“'”‘, ‘"’"’\n’“'”‘);f.close();exec(compile(code, file, ‘"’“‘exec’”’"‘))’ bdist_wheel -d /tmp/pip-wheel-ugvi9g4p
cwd: /tmp/pip-install-f_p0tk4y/h5py_2a0b9128e3974d97bbb3a40519ef45ae/
Complete output (63 lines):
WARNING: The directory ‘/home/jetbot/.cache/pip’ or its parent directory is not owned or is not writable by the current user. The cache has been disabled. Check the permissions and owner of that directory. If executing pip with sudo, you should use sudo’s -H flag.
running bdist_wheel
running build
running build_py
creating build
creating build/lib.linux-aarch64-3.6/h5py
copying h5py/h5py_warnings.py → build/lib.linux-aarch64-3.6/h5py
copying h5py/ipy_completer.py → build/lib.linux-aarch64-3.6/h5py
copying h5py/highlevel.py → build/lib.linux-aarch64-3.6/h5py
copying h5py/init.py → build/lib.linux-aarch64-3.6/h5py
copying h5py/version.py → build/lib.linux-aarch64-3.6/h5py
creating build/lib.linux-aarch64-3.6/h5py/_hl
copying h5py/_hl/dataset.py → build/lib.linux-aarch64-3.6/h5py/_hl
copying h5py/_hl/filters.py → build/lib.linux-aarch64-3.6/h5py/_hl
copying h5py/_hl/attrs.py → build/lib.linux-aarch64-3.6/h5py/_hl
copying h5py/_hl/selections2.py → build/lib.linux-aarch64-3.6/h5py/_hl
copying h5py/_hl/compat.py → build/lib.linux-aarch64-3.6/h5py/_hl
copying h5py/_hl/vds.py → build/lib.linux-aarch64-3.6/h5py/_hl
copying h5py/_hl/selections.py → build/lib.linux-aarch64-3.6/h5py/_hl
copying h5py/_hl/datatype.py → build/lib.linux-aarch64-3.6/h5py/_hl
copying h5py/_hl/init.py → build/lib.linux-aarch64-3.6/h5py/_hl
copying h5py/_hl/base.py → build/lib.linux-aarch64-3.6/h5py/_hl
copying h5py/_hl/group.py → build/lib.linux-aarch64-3.6/h5py/_hl
copying h5py/_hl/files.py → build/lib.linux-aarch64-3.6/h5py/_hl
copying h5py/_hl/dims.py → build/lib.linux-aarch64-3.6/h5py/_hl
creating build/lib.linux-aarch64-3.6/h5py/tests
copying h5py/tests/test_completions.py → build/lib.linux-aarch64-3.6/h5py/tests
copying h5py/tests/test_selections.py → build/lib.linux-aarch64-3.6/h5py/tests
copying h5py/tests/test_slicing.py → build/lib.linux-aarch64-3.6/h5py/tests
copying h5py/tests/test_dataset.py → build/lib.linux-aarch64-3.6/h5py/tests
copying h5py/tests/test_dimension_scales.py → build/lib.linux-aarch64-3.6/h5py/tests
copying h5py/tests/test_h5.py → build/lib.linux-aarch64-3.6/h5py/tests
copying h5py/tests/test_objects.py → build/lib.linux-aarch64-3.6/h5py/tests
copying h5py/tests/test_attribute_create.py → build/lib.linux-aarch64-3.6/h5py/tests
copying h5py/tests/common.py → build/lib.linux-aarch64-3.6/h5py/tests
copying h5py/tests/test_attrs.py → build/lib.linux-aarch64-3.6/h5py/tests
copying h5py/tests/test_datatype.py → build/lib.linux-aarch64-3.6/h5py/tests
copying h5py/tests/test_h5d_direct_chunk.py → build/lib.linux-aarch64-3.6/h5py/tests
copying h5py/tests/test_h5t.py → build/lib.linux-aarch64-3.6/h5py/tests
copying h5py/tests/test_threads.py → build/lib.linux-aarch64-3.6/h5py/tests
copying h5py/tests/test_dtype.py → build/lib.linux-aarch64-3.6/h5py/tests
copying h5py/tests/test_group.py → build/lib.linux-aarch64-3.6/h5py/tests
copying h5py/tests/test_file.py → build/lib.linux-aarch64-3.6/h5py/tests
copying h5py/tests/test_attrs_data.py → build/lib.linux-aarch64-3.6/h5py/tests
copying h5py/tests/test_deprecation.py → build/lib.linux-aarch64-3.6/h5py/tests
copying h5py/tests/test_dataset_getitem.py → build/lib.linux-aarch64-3.6/h5py/tests
copying h5py/tests/test_dims_dimensionproxy.py → build/lib.linux-aarch64-3.6/h5py/tests
copying h5py/tests/test_h5pl.py → build/lib.linux-aarch64-3.6/h5py/tests
copying h5py/tests/test_file2.py → build/lib.linux-aarch64-3.6/h5py/tests
copying h5py/tests/test_h5f.py → build/lib.linux-aarch64-3.6/h5py/tests
copying h5py/tests/init.py → build/lib.linux-aarch64-3.6/h5py/tests
copying h5py/tests/test_filters.py → build/lib.linux-aarch64-3.6/h5py/tests
copying h5py/tests/test_file_image.py → build/lib.linux-aarch64-3.6/h5py/tests
copying h5py/tests/test_h5p.py → build/lib.linux-aarch64-3.6/h5py/tests
copying h5py/tests/test_base.py → build/lib.linux-aarch64-3.6/h5py/tests
copying h5py/tests/test_dataset_swmr.py → build/lib.linux-aarch64-3.6/h5py/tests
creating build/lib.linux-aarch64-3.6/h5py/tests/test_vds
copying h5py/tests/test_vds/test_virtual_source.py → build/lib.linux-aarch64-3.6/h5py/tests/test_vds
copying h5py/tests/test_vds/test_highlevel_vds.py → build/lib.linux-aarch64-3.6/h5py/tests/test_vds
copying h5py/tests/test_vds/init.py → build/lib.linux-aarch64-3.6/h5py/tests/test_vds
copying h5py/tests/test_vds/test_lowlevel_vds.py → build/lib.linux-aarch64-3.6/h5py/tests/test_vds
running build_ext
ERROR: Failed building wheel for h5py
Running setup.py clean for h5py
Successfully built py-cpuinfo psutil
Failed to build h5py
Installing collected packages: h5py, requests, py-cpuinfo, psutil, protobuf, portpicker, mock, keras-preprocessing, grpcio, gast, absl-py
Attempting uninstall: h5py
Found existing installation: h5py 2.9.0
Uninstalling h5py-2.9.0:
Successfully uninstalled h5py-2.9.0
Running setup.py install for h5py … error
command: /usr/bin/python3 -u -c ‘import io, os, sys, setuptools, tokenize; sys.argv[0] = ‘"’"’/tmp/pip-install-f_p0tk4y/h5py_2a0b9128e3974d97bbb3a40519ef45ae/setup.py’“'”‘; file=’“'”‘/tmp/pip-install-f_p0tk4y/h5py_2a0b9128e3974d97bbb3a40519ef45ae/setup.py’“'”‘;f = getattr(tokenize, ‘"’“‘open’”’“‘, open)(file) if os.path.exists(file) else io.StringIO(’”‘“‘from setuptools import setup; setup()’”’“‘);code = f.read().replace(’”‘"’\r\n’“'”‘, ‘"’"’\n’“'”‘);f.close();exec(compile(code, file, ‘"’“‘exec’”’“‘))’ install --record /tmp/pip-record-xxhl08d1/install-record.txt --single-version-externally-managed --compile --install-headers /usr/local/include/python3.6/h5py
Complete output (62 lines):
running install
running build
running build_py
creating build
running build_ext
Rolling back uninstall of h5py
Moving to /usr/local/lib/python3.6/dist-packages/h5py-2.9.0.dist-info/
from /usr/local/lib/python3.6/dist-packages/~5py-2.9.0.dist-info
Moving to /usr/local/lib/python3.6/dist-packages/h5py/
ERROR: Command errored out with exit status -4: /usr/bin/python3 -u -c 'import io, os, sys, setuptools, tokenize; sys.argv[0] = '”‘"’/tmp/pip-install-f_p0tk4y/h5py_2a0b9128e3974d97bbb3a40519ef45ae/setup.py’“'”‘; file=’“'”‘/tmp/pip-install-f_p0tk4y/h5py_2a0b9128e3974d97bbb3a40519ef45ae/setup.py’“'”‘;f = getattr(tokenize, ‘"’“‘open’”’“‘, open)(file) if os.path.exists(file) else io.StringIO(’”‘“‘from setuptools import setup; setup()’”’“‘);code = f.read().replace(’”‘"’\r\n’“'”‘, ‘"’"’\n’“'”‘);f.close();exec(compile(code, file, ‘"’“‘exec’”’"‘))’ install --record /tmp/pip-record-xxhl08d1/install-record.txt --single-version-externally-managed --compile --install-headers /usr/local/include/python3.6/h5py Check the logs for full command output.
I would be glad for any support.
May I know which JetPack version do you use?
The instruction will be slightly different on the different software.
If the latest JetPack 4.5.1 is used, you can check below document to setup all the prerequisites and dependencies:
Hi
i am using JetPack 4.3
I use the following product from Sparkfun: SparkFun JetBot AI Kit v3.0 Powered by Jetson Nano - KIT-18486 - SparkFun Electronics
Since I’m new to the whole topic I’m also worried that the image files for the hardware components of sparkfun can be lost during any installations.
Sorry for the late update.
This is a known issue in pip3 for JetPack4.3.
Please use pip3==20.2.4 to meet the compatibility.
You can find the detailed installation steps below:
Hi @AastaLLL ,
i tryed the installation steps but it doesn’t works for me.
i get this error messages:
sudo pip3 install -U pip==20.2.4
[sudo] password for jetbot:
Collecting pip==20.2.4
Downloading pip-20.2.4-py2.py3-none-any.whl (1.5 MB)
|████████████████████████████████| 1.5 MB 4.8 MB/s
Installing collected packages: pip
Attempting uninstall: pip
Found existing installation: pip 21.1.2
Uninstalling pip-21.1.2:
Successfully uninstalled pip-21.1.2
Successfully installed pip-20.2.4
WARNING: Running pip as root will break packages and permissions. You should install packages reliably by using venv: 12. Virtual Environments and Packages — Python 3.10.7 documentation
jetbot@jetson:~$ sudo apt-get install libhdf5-serial-dev hdf5-tools libhdf5-dev zlib1g-dev zip libjpeg8-
Reading package lists… Done
Building dependency tree
Reading state information… Done
libhdf5-dev is already the newest version (1.10.0-patch1+docs-4).
zip is already the newest version (3.0-11build1).
libhdf5-serial-dev is already the newest version (1.10.0-patch1+docs-4).
hdf5-tools is already the newest version (1.10.0-patch1+docs-4).
zlib1g-dev is already the newest version (1:1.2.11.dfsg-0ubuntu2).
The following packages were automatically installed and are no longer required:
accountsservice acl adium-theme-ubuntu apg aptdaemon aptdaemon-data aspell
aspell-en bluez-obexd bubblewrap cheese-common colord-data compiz-core
compiz-plugins-default cracklib-runtime dconf-cli dictionaries-common
diffstat emacsen-common enchant evince-common fonts-dejavu-extra freepats
gdal-data gedit-common geoclue geoclue-2.0 geoclue-ubuntu-geoip
gir1.2-accounts-1.0 gir1.2-accountsservice-1.0 gir1.2-atk-1.0
gir1.2-atspi-2.0 gir1.2-dbusmenu-glib-0.4 gir1.2-dee-1.0 gir1.2-gck-1
gir1.2-gdata-0.0 gir1.2-gdesktopenums-3.0 gir1.2-geoclue-2.0 gir1.2-goa-1.0
gir1.2-ibus-1.0 gir1.2-javascriptcoregtk-4.0 gir1.2-json-1.0 gir1.2-nm-1.0
gir1.2-polkit-1.0 gir1.2-secret-1 gir1.2-signon-1.0 gir1.2-soup-2.4
gir1.2-totemplparser-1.0 gir1.2-unity-5.0 gir1.2-upowerglib-1.0
gnome-control-center-faces gnome-desktop3-data gnome-keyring-pkcs11
gnome-session-common gnome-settings-daemon-schemas gnome-shell-common
gnome-software-common gnome-terminal-data gnome-themes-extra-data
gnome-todo-common gnupg-l10n gnupg-utils gsfonts gstreamer1.0-x gtk3-nocsd
hunspell-en-us iio-sensor-proxy indicator-common indicator-messages
indicator-session ippusbxd java-common language-selector-common libaa1
libaacs0 libaccounts-glib0 libaccountsservice0 libapt-pkg-perl libaribb24-0
libarmadillo8 libarpack2 libaspell15 libass9 libassuan-dev
libatk-wrapper-java libatk-wrapper-java-jni libatkmm-1.6-1v5 libavc1394-0
libbamf3-2 libbasicusageenvironment1 libbdplus0 libbluray2 libbrotli1
libbs2b0 libbz2-dev libcaca0 libcairo-gobject-perl libcairo-gobject2
libcairo-perl libcairomm-1.0-1v5 libcanberra-pulse libcanberra0 libcddb2
libcdio-cdda2 libcdio-paranoia2 libcgi-fast-perl libcgi-pm-perl libcharls1
libclass-accessor-perl libclone-perl libclutter-1.0-common libcogl-common
libcolord2 libcolorhug2 libcolumbus1-common libcolumbus1v5 libcompizconfig0
libcrack2 libdap25 libdapclient6v5 libdbusmenu-glib4 libdc1394-22 libdca0
libde265-0 libdecoration0 libdee-1.0-4 libdjvulibre-text
libdouble-conversion1 libdv4 libdvbpsi10 libebml4v5 libeigen3-dev
libemail-valid-perl libenchant1c2a libepsilon1 libexempi3 libexif12
libexiv2-14 libexporter-tiny-perl libfaad2 libfam0 libfcgi-perl
libfcitx-config4 libfcitx-gclient1 libfcitx-utils0
libfile-copy-recursive-perl libflite1 libfluidsynth1 libframe6 libfreexl1
libfyba0 libgdcm2.8 libgdk-pixbuf2.0-common libgee-0.8-2 libgeis1
libgeoclue-2-0 libgeoclue0 libgeocode-glib0 libgeonames-common libgeonames0
libgeos-3.6.2 libgeos-c1v5 libgexiv2-2 libgif7 libglewmx1.13
libglib-object-introspection-perl libglib-perl libglibmm-2.4-1v5 libgme0
libgmime-3.0-0 libgnome-autoar-0-0 libgnome-games-support-common
libgnome-todo libgnomekbd-common libgom-1.0-0 libgpg-error-dev libgpgme-dev
libgphoto2-l10n libgphoto2-port12 libgrail6 libgraphene-1.0-0 libgrilo-0.3-0
libgroupsock8 libgsm1 libgspell-1-common libgssdp-1.0-3
libgstreamer-plugins-good1.0-0 libgtk-3-common libgtk2.0-common
libgtk3-nocsd0 libgtksourceview-3.0-common libgtop-2.0-11 libgtop2-common
libgupnp-1.0-4 libgupnp-igd-1.0-4 libgweather-common libhunspell-1.6-0
libhyphen0 libiec61883-0 libieee1284-3 libijs-0.35 libilmbase12
libimobiledevice6 libio-pty-perl libio-string-perl libipc-run-perl
libjavascriptcoregtk-4.0-18 libjbig0 libjbig2dec0 libjxr0 libkate1
libkf5archive5 libkf5auth-data libkf5codecs-data libkf5codecs5
libkf5config-data libkf5configcore5 libkf5configwidgets-data
libkf5coreaddons-data libkf5coreaddons5 libkf5dbusaddons-data
libkf5i18n-data libkf5i18n5 libkf5iconthemes-data libkf5itemviews-data
libkf5notifications-data libkf5service-data libkf5wallet-data
libkf5widgetsaddons-data libkf5windowsystem-data libkmlbase1 libkmldom1
libkmlengine1 liblightdm-gobject-1-0 liblilv-0-0 liblirc-client0
liblist-moreutils-perl liblivemedia62 liblqr-1-0 liblua5.2-0 liblua5.3-0
liblz4-dev libmad0 libmatroska6v5 libmessaging-menu0 libmicrodns0
libminiupnpc10 libminizip1 libmjpegutils-2.1-0 libmms0 libmodplug1
libmp3lame0 libmpcdec6 libmpeg2encpp-2.1-0 libmpg123-0 libmplex2-2.1-0
libmtp-common libmtp-runtime libmtp9 libmysofa0 libnatpmp1 libnet-dns-perl
libnet-domain-tld-perl libnet-ip-perl libnetcdf13 libnfs11 libnice10
libnm-glib4 libnm-util2 libnorm1 libofa0 libogdi3.2 libopenal-data
libopenal1 libopencv-core3.2 libopencv-imgproc3.2 libopenexr22 libopenjp2-7
libopenmpt-modplug1 libopenmpt0 libpangomm-1.4-1v5
libparse-debianchangelog-perl libpeas-common libperlio-gzip-perl
libpgm-5.2-0 libplacebo4 libplist3 libpq5 libproj12 libprotobuf-lite10
libpulse-mainloop-glib0 libpwquality-common libpwquality1 libqhull7
libqqwing2v5 libqt4-dbus libqt4-network libqt4-script libqt4-sql
libqt4-sql-mysql libqt4-xml libqt4-xmlpatterns libqt5concurrent5
libqt5core5a libqt5dbus5 libqt5network5 libqt5script5 libqt5sql5
libqt5sql5-sqlite libqt5test5 libqt5texttospeech5 libqt5xml5 libqtcore4
libqtdbus4 libraw1394-11 libresid-builder0c2a librest-0.7-0 librubberband2
libsane-common libsbc1 libsdl1.2debian libserd-0-0 libsgutils2-2 libshine3
libshout3 libsidplay2 libsigc+±2.0-0v5 libsignon-glib1 libsocket++1
libsodium23 libsord-0-0 libsoundtouch1 libsoup-gnome2.4-1 libspatialite7
libspeex1 libsratom-0-0 libsrtp2-1 libssh2-1 libstartup-notification0
libsuperlu5 libtag1v5 libtag1v5-vanilla libtelepathy-glib0
libtext-levenshtein-perl libtimezonemap-data libtotem-plparser-common
libtotem-plparser18 libtracker-sparql-2.0-0 libtwolame0
libunity-protocol-private0 libunity-scopes-json-def-desktop libunity9
libupnp6 libupower-glib3 liburiparser1 liburl-dispatcher1
libusageenvironment3 libusbmuxd4 libva-wayland2 libvlc5 libvlccore9
libvo-aacenc0 libvo-amrwbenc0 libvorbisfile3 libvpx5 libwavpack1
libwayland-egl1-mesa libwebp6 libwebpdemux2 libwebpmux3
libwhoopsie-preferences0 libwildmidi-config libwildmidi2 libwinpr2-2
libwnck-3-common libwoff1 libwxbase3.0-0v5 libx265-146 libxapian30
libxcb-res0 libxcb-xinerama0 libxerces-c3.2 libxkbcommon-x11-0 libxklavier16
libxml-libxml-perl libxml-namespacesupport-perl libxml-sax-base-perl
libxml-sax-expat-perl libxml-sax-perl libxml-simple-perl libxrandr-dev
libxrender-dev libxres1 libxvidcore4 libyaml-cpp-dev libyaml-cpp0.5v5
libyaml-libyaml-perl libzeitgeist-1.0-1 libzeitgeist-2.0-0 libzmq5
libzvbi-common libzvbi0 lintian media-player-info
mobile-broadband-provider-info notify-osd-icons odbcinst odbcinst1debian2
p11-kit p11-kit-modules patchutils poppler-data proj-bin proj-data
python-cairo python-defusedxml python-gps python-netifaces python-olefile
python-paramiko python-pyasn1 python-pycryptodome python-wxversion
python3-aptdaemon python3-blinker python3-bs4 python3-cairo python3-cups
python3-cupshelpers python3-dateutil python3-debconf python3-debian
python3-defer python3-feedparser python3-gi-cairo python3-html5lib
python3-jwt python3-lxml python3-macaroonbakery python3-mako
python3-markupsafe python3-nacl python3-oauthlib python3-olefile
python3-protobuf python3-pyatspi python3-pymacaroons python3-rfc3339
python3-speechd python3-tz python3-webencodings python3-yaml qdbus qt5-qmake
qt5-qmake-bin qtbase5-dev-tools qtchooser qtcore4-l10n qttranslations5-l10n
remmina-common rhythmbox-data ros-melodic-actionlib-msgs ros-melodic-bond
ros-melodic-bond-core ros-melodic-bondcpp ros-melodic-bondpy
ros-melodic-camera-calibration-parsers ros-melodic-camera-info-manager
ros-melodic-cmake-modules ros-melodic-common-msgs
ros-melodic-diagnostic-msgs ros-melodic-mk ros-melodic-nav-msgs
ros-melodic-nodelet ros-melodic-ros ros-melodic-rosbag-migration-rule
ros-melodic-rosbag-storage ros-melodic-rosbash ros-melodic-rosboost-cfg
ros-melodic-rosclean ros-melodic-rosconsole-bridge ros-melodic-roscpp-core
ros-melodic-roscreate ros-melodic-rosgraph ros-melodic-roslang
ros-melodic-roslaunch ros-melodic-roslisp ros-melodic-roslz4
ros-melodic-rosmake ros-melodic-rosmaster ros-melodic-rosout
ros-melodic-rosparam ros-melodic-rospy ros-melodic-rostest
ros-melodic-rosunit ros-melodic-shape-msgs ros-melodic-smclib
ros-melodic-std-srvs ros-melodic-stereo-msgs ros-melodic-topic-tools
ros-melodic-trajectory-msgs ros-melodic-visualization-msgs sbcl
session-migration shotwell-common sound-theme-freedesktop
system-config-printer-udev t1utils totem-common transmission-common
ubuntu-system-service ubuntu-touch-sounds ubuntu-wallpapers
ubuntu-wallpapers-bionic unity-gtk-module-common unity-lens-applications
unity-lens-files unity-lens-music unity-lens-photos unity-lens-video
unity-schemas unity-scope-chromiumbookmarks unity-scope-colourlovers
unity-scope-devhelp unity-scope-firefoxbookmarks unity-scope-home
unity-scope-openclipart unity-scope-texdoc unity-scope-tomboy
unity-scope-video-remote unity-scope-virtualbox unity-scope-yelp
unity-scope-zotero unity-scopes-master-default unity-scopes-runner
update-inetd update-notifier-common upower usbmuxd vlc-data
whoopsie-preferences x11proto-randr-dev yelp-xsl zeitgeist-core
zenity-common
Use ‘sudo apt autoremove’ to remove them.
The following packages will be REMOVED:
activity-log-manager adwaita-icon-theme aisleriot appmenu-qt apport-gtk
apturl bamfdaemon baobab ca-certificates-java cheese chromium-browser
chromium-browser-l10n colord compiz compiz-gnome deja-dup eog evince
evolution-data-server file-roller gcr gdm3 gedit ghostscript ghostscript-x
gir1.2-appindicator3-0.1 gir1.2-gcr-3 gir1.2-gdkpixbuf-2.0
gir1.2-gnomebluetooth-1.0 gir1.2-gnomedesktop-3.0 gir1.2-gtk-3.0
gir1.2-gtksource-3.0 gir1.2-gweather-3.0 gir1.2-mutter-2 gir1.2-nma-1.0
gir1.2-notify-0.7 gir1.2-peas-1.0 gir1.2-rb-3.0 gir1.2-rsvg-2.0
gir1.2-totem-1.0 gir1.2-vte-2.91 gir1.2-webkit2-4.0 gir1.2-wnck-3.0 gjs
gkbd-capplet gnome-bluetooth gnome-calculator gnome-calendar
gnome-control-center gnome-disk-utility gnome-font-viewer
gnome-getting-started-docs gnome-initial-setup gnome-keyring gnome-mahjongg
gnome-mines gnome-online-accounts gnome-power-manager gnome-screensaver
gnome-screenshot gnome-session-bin gnome-session-canberra
gnome-settings-daemon gnome-shell gnome-software gnome-software-plugin-snap
gnome-startup-applications gnome-sudoku gnome-system-monitor gnome-terminal
gnome-themes-extra gnome-todo gnome-user-docs gnome-user-guide
gnome-video-effects gnupg gpg-agent gpg-wks-client gpg-wks-server
gpsd-clients grilo-plugins-0.3-base gstreamer1.0-clutter-3.0 gstreamer1.0-gl
gstreamer1.0-libav gstreamer1.0-plugins-bad gstreamer1.0-plugins-good
gtk-update-icon-cache gtk2-engines-murrine gtk2-engines-pixbuf gvfs-backends
humanity-icon-theme ibus ibus-gtk3 ibus-table imagemagick imagemagick-6.q16
indicator-applet indicator-application indicator-appmenu indicator-bluetooth
indicator-datetime indicator-keyboard indicator-power indicator-sound
language-selector-gnome libappindicator3-1 libappstream-glib8
libavahi-ui-gtk3-0 libavcodec57 libavfilter6 libavformat57
libblockdev-crypto2 libcanberra-gtk3-0 libcanberra-gtk3-module
libcheese-gtk25 libcheese8 libchromaprint1 libclutter-1.0-0
libclutter-gst-3.0-0 libclutter-gtk-1.0-0 libcogl-pango20 libcogl-path20
libcogl20 libcolord-gtk1 libcupsfilters1 libdazzle-1.0-0 libdbusmenu-gtk3-4
libdbusmenu-qt2 libdbusmenu-qt5-2 libdjvulibre21 libdmapsharing-3.0-2
libedataserverui-1.2-2 libevdocument3-4 libevview3-3 libfreeimage-dev
libfreeimage3 libfreerdp-client2-2 libfreerdp2-2 libgail-3-0 libgail-common
libgail18 libgcr-ui-3-1 libgd3 libgdal20 libgdk-pixbuf2.0-0
libgdk-pixbuf2.0-bin libgeotiff2 libgjs0g libgnome-bluetooth13
libgnome-desktop-3-17 libgnome-games-support-1-3 libgnomekbd8
libgoa-backend-1.0-1 libgphoto2-6 libgpod-common libgpod4 libgs9
libgspell-1-1 libgtk-3-0 libgtk-3-bin libgtk2.0-0 libgtk2.0-bin libgtk3-perl
libgtkmm-3.0-1v5 libgtksourceview-3.0-1 libgweather-3-15 libgxps2
libhdf4-0-alt libido3-0.1-0 libindicator3-7 libjpeg-dev libjpeg8
libjpeg8-dev libkf5auth5 libkf5configgui5 libkf5configwidgets5 libkf5crash5
libkf5dbusaddons5 libkf5guiaddons5 libkf5iconthemes5 libkf5itemviews5
libkf5notifications5 libkf5service-bin libkf5service5 libkf5wallet-bin
libkf5wallet5 libkf5widgetsaddons5 libkf5windowsystem5 libkwalletbackend5-5
liblcms2-utils libmagickcore-6.q16-3 libmagickcore-6.q16-3-extra
libmagickwand-6.q16-3 libmediaart-2.0-0 libmetacity1 libmng2 libmutter-2-0
libnautilus-extension1a libnm-gtk0 libnma0 libnotify-bin libnotify4
libnux-4.0-0 libopencv libopencv-dev libopencv-imgcodecs3.2 libopencv-python
libopencv-samples libopencv-videoio3.2 libpanel-applet3 libpeas-1.0-0
libphonon4qt5-4 libpolkit-qt5-1-1 libpoppler-glib8 libpoppler73
libqt4-declarative libqt5gui5 libqt5opengl5 libqt5opengl5-dev
libqt5printsupport5 libqt5svg5 libqt5widgets5 libqt5x11extras5 libqtgui4
libraw16 librhythmbox-core10 librsvg2-2 librsvg2-common libsane1
libsdl-image1.2 libspandsp2 libspectre1 libtiff5 libtimezonemap1 libtotem0
libunity-control-center1 libunity-core-6.0-9 libunity-gtk2-parser0
libunity-gtk3-parser0 libunity-misc4 libunity-settings-daemon1 libv4l-0
libv4lconvert0 libvisionworks-samples libvisionworks-sfm-dev
libvisionworks-tracking-dev libvncclient1 libvolume-key1 libvte-2.91-0
libwebkit2gtk-4.0-37 libwmf0.2-7 libwmf0.2-7-gtk libwnck-3-0
libwxgtk3.0-gtk3-0v5 libyelp0 libzbar0 light-themes mousetweaks mutter
nautilus nautilus-extension-gnome-terminal nautilus-share netpbm
network-manager-gnome network-manager-pptp-gnome notification-daemon
notify-osd nvidia-jetpack opencv-licenses openjdk-8-jdk
openjdk-8-jdk-headless openjdk-8-jre openjdk-8-jre-headless orca phonon4qt5
phonon4qt5-backend-vlc pinentry-gnome3 policykit-1-gnome poppler-utils
printer-driver-c2esp printer-driver-pnm2ppa printer-driver-ptouch
printer-driver-sag-gdi python-gnupg python-gtk2 python-pil python-wxgtk3.0
python-wxtools python3-aptdaemon.gtk3widgets python3-pil qt-at-spi
qt5-gtk-platformtheme qtbase5-dev remmina remmina-plugin-rdp
remmina-plugin-secret remmina-plugin-vnc rhythmbox
rhythmbox-plugin-alternative-toolbar rhythmbox-plugin-zeitgeist
rhythmbox-plugins ros-melodic-actionlib ros-melodic-cv-bridge
ros-melodic-dynamic-reconfigure ros-melodic-image-publisher
ros-melodic-nodelet-core ros-melodic-nodelet-topic-tools
ros-melodic-ros-base ros-melodic-ros-comm ros-melodic-ros-core
ros-melodic-rosbag ros-melodic-rosmsg ros-melodic-rosnode
ros-melodic-rosservice ros-melodic-rostopic ros-melodic-roswtf sane-utils
seahorse session-shortcuts shotwell simple-scan software-properties-gtk
system-config-printer system-config-printer-common totem totem-plugins
transmission-gtk ubuntu-artwork ubuntu-desktop ubuntu-docs ubuntu-mono
ubuntu-release-upgrader-gtk ubuntu-session ubuntu-software unity
unity-asset-pool unity-control-center unity-greeter unity-gtk2-module
unity-gtk3-module unity-scope-calculator unity-scope-manpages unity-services
unity-session unity-settings-daemon update-manager update-notifier vino
vlc-plugin-base vlc-plugin-video-output vpi-samples xdg-user-dirs-gtk
xloadimage yelp zeitgeist-datahub zenity
0 upgraded, 0 newly installed, 356 to remove and 0 not upgraded.
After this operation, 1,169 MB disk space will be freed.
Do you want to continue? [Y/n] y
dpkg: error: info database format (2) is bogus or too new; try getting a newer dpkg
E: Sub-process dpkg --set-selections returned an error code (2)
E: Couldn’t record the approved state changes as dpkg selection states
jetbot@jetson:~$ sudo ln -s /usr/include/locale.h /usr/include/xlocale.h
jetbot@jetson:~$ sudo pip3 install numpy grpcio absl-py py-cpuinfo psutil portpicker six mock requests gast h5py astor termcolor protobuf keras-applications keras-preprocessing wrapt google-pasta
WARNING: The directory ‘/home/jetbot/.cache/pip’ or its parent directory is not owned or is not writable by the current user. The cache has been disabled. Check the permissions and owner of that directory. If executing pip with sudo, you may want sudo’s -H flag.
Requirement already satisfied: numpy in /usr/local/lib/python3.6/dist-packages (1.19.4)
Requirement already satisfied: grpcio in /usr/local/lib/python3.6/dist-packages (1.38.0)
Requirement already satisfied: absl-py in /usr/local/lib/python3.6/dist-packages (0.12.0)
Requirement already satisfied: py-cpuinfo in /usr/local/lib/python3.6/dist-packages (8.0.0)
Requirement already satisfied: psutil in /usr/local/lib/python3.6/dist-packages (5.8.0)
Requirement already satisfied: portpicker in /usr/local/lib/python3.6/dist-packages (1.3.9)
Requirement already satisfied: six in /usr/local/lib/python3.6/dist-packages (1.16.0)
Requirement already satisfied: mock in /usr/local/lib/python3.6/dist-packages (3.0.5)
Requirement already satisfied: requests in /usr/local/lib/python3.6/dist-packages (2.25.1)
Requirement already satisfied: gast in /usr/local/lib/python3.6/dist-packages (0.2.2)
Requirement already satisfied: h5py in /usr/local/lib/python3.6/dist-packages (2.10.0)
Requirement already satisfied: protobuf in /usr/local/lib/python3.6/dist-packages (3.17.0)
Requirement already satisfied: keras-preprocessing in /usr/local/lib/python3.6/dist-packages (1.1.1)
WARNING: You are using pip version 20.2.4; however, version 21.1.2 is available.
You should consider upgrading via the ‘/usr/bin/python3 -m pip install --upgrade pip’ command.
jetbot@jetson:~$ sudo pip3 install --pre --extra-index-url https://developer.download.nvidia.com/compute/redist/jp/v43 tensorflow
Looking in indexes: Simple index, https://developer.download.nvidia.com/compute/redist/jp/v43
Requirement already satisfied: tensorflow in ./.local/lib/python3.6/site-packages (1.8.0)
Requirement already satisfied: gast>=0.2.0 in /usr/local/lib/python3.6/dist-packages (from tensorflow) (0.2.2)
Requirement already satisfied: absl-py>=0.1.6 in /usr/local/lib/python3.6/dist-packages (from tensorflow) (0.12.0)
Requirement already satisfied: protobuf>=3.4.0 in /usr/local/lib/python3.6/dist-packages (from tensorflow) (3.17.0)
Requirement already satisfied: astor>=0.6.0 in /usr/local/lib/python3.6/dist-packages (from tensorflow) (0.8.1)
Requirement already satisfied: termcolor>=1.1.0 in /usr/local/lib/python3.6/dist-packages (from tensorflow) (1.1.0)
Collecting tensorboard<1.9.0,>=1.8.0
Downloading tensorboard-1.8.0-py3-none-any.whl (3.1 MB)
|████████████████████████████████| 3.1 MB 5.4 MB/s
Requirement already satisfied: grpcio>=1.8.6 in /usr/local/lib/python3.6/dist-packages (from tensorflow) (1.38.0)
Requirement already satisfied: six>=1.10.0 in /usr/local/lib/python3.6/dist-packages (from tensorflow) (1.16.0)
Requirement already satisfied: numpy>=1.13.3 in /usr/local/lib/python3.6/dist-packages (from tensorflow) (1.19.4)
Requirement already satisfied: wheel>=0.26 in /usr/lib/python3/dist-packages (from tensorflow) (0.30.0)
Requirement already satisfied: werkzeug>=0.11.10 in /usr/local/lib/python3.6/dist-packages (from tensorboard<1.9.0,>=1.8.0->tensorflow) (1.0.1)
Requirement already satisfied: markdown>=2.6.8 in /usr/local/lib/python3.6/dist-packages (from tensorboard<1.9.0,>=1.8.0->tensorflow) (3.2.1)
Requirement already satisfied: html5lib==0.9999999 in ./.local/lib/python3.6/site-packages (from tensorboard<1.9.0,>=1.8.0->tensorflow) (0.9999999)
Requirement already satisfied: bleach==1.5.0 in ./.local/lib/python3.6/site-packages (from tensorboard<1.9.0,>=1.8.0->tensorflow) (1.5.0)
Requirement already satisfied: setuptools>=36 in /usr/local/lib/python3.6/dist-packages (from markdown>=2.6.8->tensorboard<1.9.0,>=1.8.0->tensorflow) (49.6.0)
Installing collected packages: tensorboard
Attempting uninstall: tensorboard
Found existing installation: tensorboard 1.14.0
Uninstalling tensorboard-1.14.0:
Successfully uninstalled tensorboard-1.14.0
ERROR: After October 2020 you may experience errors when installing or updating packages. This is because pip will change the way that it resolves dependency conflicts.
We recommend you use --use-feature=2020-resolver to test your packages with the new resolver before it becomes the default.
tensorflow-gpu 1.14.0+nv19.10 requires tensorboard<1.15.0,>=1.14.0, but you’ll have tensorboard 1.8.0 which is incompatible.
Successfully installed tensorboard-1.8.0
Based on your error, could you manually install tensorboard-1.14.0 first.
Then install the TensorFlow package without checking dependency to see it it works?
$ sudo pip3 install --no-dependencies ...
