TensorFlow for Jetson TX2!
Our official release of TensorFlow for Jetson TX2!
Python 3.6+JetPack4.6.3
$ sudo apt-get update
$ sudo apt-get install libhdf5-serial-dev hdf5-tools libhdf5-dev zlib1g-dev zip libjpeg8-dev liblapack-dev libblas-dev gfortran
$ sudo apt-get install python3-pip
$ sudo pip3 install -U pip testresources setuptools
$ sudo ln -s /usr/include/locale.h /usr/include/xlocale.h
$ sudo pip3 install -U numpy==1.19.4 future mock keras_preprocessing keras_applications gast==0.2.1 protobuf pybind11 cython pkgconfig packaging
$ sudo pip3 install --extra-index-url https://developer.download.nvidia.com/compute/redist/jp/v461 tensorflow
Python 3.6+JetPack4.5
sudo pip3 install -U pip testresources setuptools==49.6.0
sudo pip3 install -U numpy==1.16.1 future==0.18.2 mock==3.0.5 h5py==2.10.0 keras_preprocessing==1.1.1 keras_applications==1.0.8 gast==0.2.2 futures protobuf pybind11
# TF-2.x
$ sudo pip3 install --pre --extra-index-url https://developer.download.nvidia.com/compute/redist/jp/v45 tensorflow
# TF-1.15
$ sudo pip3 install --pre --extra-index-url https://developer.download.nvidia.com/compute/redist/jp/v45 ‘tensorflow<2’
Python 3.6+JetPack4.4
sudo pip3 install -U pip testresources setuptools numpy==1.16.1 future==0.17.1 mock==3.0.5 h5py==2.9.0 keras_preprocessing==1.0.5 keras_applications==1.0.8 gast==0.2.2 futures protobuf pybind11
# TF-2.x
$ sudo pip3 install --pre --extra-index-url https://developer.download.nvidia.com/compute/redist/jp/v44 tensorflow==2.3.1+nv20.12
# TF-1.15
$ sudo pip3 install --pre --extra-index-url https://developer.download.nvidia.com/compute/redist/jp/v44 ‘tensorflow<2’
Python 3.6+JetPack4.3
sudo pip3 install -U numpy grpcio absl-py py-cpuinfo psutil portpicker six mock requests gast h5py astor termcolor protobuf keras-applications keras-preprocessing wrapt google-pasta
# TF-2.x
$ sudo pip3 install --pre --extra-index-url https://developer.download.nvidia.com/compute/redist/jp/v43 tensorflow==2.1.0+nv20.3
# TF-1.15
$ sudo pip3 install --pre --extra-index-url https://developer.download.nvidia.com/compute/redist/jp/v43 tensorflow==1.15.2+nv20.3
Python 3.6+JetPack4.2.1
sudo pip3 install --pre --extra-index-url https://developer.download.nvidia.com/compute/redist/jp/v42 tensorflow-gpu==1.14.0+nv19.10
Python 3.5+JetPack3.3
sudo pip3 install --pre --extra-index-url https://developer.download.nvidia.com/compute/redist/jp/v33 tensorflow-gpu==1.14.0+nv19.7
Python 2.7+JetPack3.3
sudo pip install --pre --extra-index-url https://developer.download.nvidia.com/compute/redist/jp/v33 tensorflow-gpu==1.14.0+nv19.7
If you meet error when installing h5py, please run this command to solve the dependency:
DL frameworks - https://developer.nvidia.com/deep-learning-frameworks
Download - https://developer.nvidia.com/embedded/downloads
Document - NVIDIA Deep Learning Frameworks Documentation
Thank you for this.
Can it be installed inside a virtualenv ?
which version of tensorflow is it?
I have installed the version 1.10 with whl should i uninstall before install that one?
Thank you
Awesome!
This is TF 1.9.0 for TX2.
Good news !!!
And for Jetson TX1 ?
Thank you
We only have TX2 package currently.
Sorry for the inconvenience.
Are we able to call the python conversion for tensorrt to make a plan from the jetson now?
TensorRT python API for Jetson is still not available.
But you can use the TF-TRT instead.
wrong comment please ignore
i try to install in python 3, in clear deploy.
after install pip in Tx2 using this:
https://askubuntu.com/questions/412178/how-to-install-pip-for-python-3-in-ubuntu-12-04-lts
but to install i want add --user in parameters
pip3 install --user --extra-index-url=https://developer.download.nvidia.com/compute/redist/jp33 tensorflow-gpu
if i don’t add this parameters receive any erros in permission to install numpy using this command.
I have installed tf for python 2.7 and i did had to use --user parameter to install it. So you should use --user parameter
PS: if you are planning to do training on tx2 i wouldn’t recommend it since Ram is a huge bottleneck and usually your training gets killed after a while
Good luck
@kilichzf
Thanks so much, i didn’t no about this problem with the Ram, i will work with the cloud.
I am getting a File does not exist error.
Fresh install of jetpack 3.3 and pip. Python 2.7
Any thoughts, please?
Problem solved. Typo in command string copied from elsewhere.
[b]Invalid requirement: ‘–extra-index-url=https://developer.download.nvidia.com/compute/redist/jp33
It looks like a path. File ‘–extra-index-url=https://developer.download.nvidia.com/compute/redist/jp33’ does not exist.[/b]
The path link is https://developer.download.nvidia.com/compute/redist/jp33/tensorflow-gpu/.
Please make sure you use the entire command in the comment#1.
pip install --extra-index-url=https://developer.download.nvidia.com/compute/redist/jp33 <b>tensorflow-gpu</b>
Hi, I received error message “TypeError: unsupported operand type(s) for -=: ‘Retry’ and ‘int’”, when running above command. Is it something related to the package?
Thank you in advance.
Hi, mk.ikhwan88
Type error is caused by the pip and proxy on your environment.
You can check this topic for more information:
[url]Python PIP Install throws TypeError: unsupported operand type(s) for -=: 'Retry' and 'int' - Stack Overflow
You can solve it by simply up-grating the pip version or unsetting the proxy.
yeah thanks a lot. But after install it how to I use tensorflow. In command tool, where I must director to use it.
