I am trying to install TensorFlow and so far have not had any success. My current setup is: Jetson TX2 dev kit, L4T R32.3.1 (Jetpack 43), python 3.6.9.
Confirmed that this issue can also be reproduced in our environment.
We are checking this with our internal team.
Will update more information with you later.
Hello - the installation got further than it has in the past, but ran into an error at the scipy wheel requirements. Is this also related to the pip tool? Were you able to get a complete and successful install? Error is copied below
sudo pip3 install --pre --extra-index-url https://developer.download.nvidia.com/compute/redist/jp/v43 tensorflow
^TWARNING: The directory ‘/home/jetson1/.cache/pip’ or its parent directory is not owned or is not writable by the current user. The cache has been disabled. Check the permissions and owner of that directory. If executing pip with sudo, you may want sudo’s -H flag.
Looking in indexes: Simple index, https://developer.download.nvidia.com/compute/redist/jp/v43
Collecting tensorflow
Downloading https://developer.download.nvidia.com/compute/redist/jp/v43/tensorflow/tensorflow-2.1.0%2Bnv20.3-cp36-cp36m-linux_aarch64.whl (236.9 MB)
|████████████████████████████████| 236.9 MB 22.0 MB/s
Requirement already satisfied: numpy<2.0,>=1.16.0 in /usr/local/lib/python3.6/dist-packages (from tensorflow) (1.19.5)
Requirement already satisfied: astor>=0.6.0 in /usr/local/lib/python3.6/dist-packages (from tensorflow) (0.8.1)
Collecting tensorboard<2.2.0,>=2.1.0
Downloading tensorboard-2.1.1-py3-none-any.whl (3.8 MB)
|████████████████████████████████| 3.8 MB 3.4 MB/s
Requirement already satisfied: termcolor>=1.1.0 in /usr/local/lib/python3.6/dist-packages (from tensorflow) (1.1.0)
Requirement already satisfied: wrapt>=1.11.1 in /usr/local/lib/python3.6/dist-packages (from tensorflow) (1.12.1)
Requirement already satisfied: wheel>=0.26; python_version >= “3” in /usr/local/lib/python3.6/dist-packages (from tensorflow) (0.36.2)
Requirement already satisfied: six>=1.12.0 in ./.local/lib/python3.6/site-packages (from tensorflow) (1.15.0)
Requirement already satisfied: absl-py>=0.7.0 in /usr/local/lib/python3.6/dist-packages (from tensorflow) (0.12.0)
Requirement already satisfied: google-pasta>=0.1.6 in /usr/local/lib/python3.6/dist-packages (from tensorflow) (0.2.0)
Requirement already satisfied: gast==0.2.2 in /usr/local/lib/python3.6/dist-packages (from tensorflow) (0.2.2)
Requirement already satisfied: opt-einsum>=2.3.2 in /usr/local/lib/python3.6/dist-packages (from tensorflow) (3.3.0)
Requirement already satisfied: keras-preprocessing>=1.1.0 in /usr/local/lib/python3.6/dist-packages (from tensorflow) (1.1.2)
Collecting scipy==1.4.1; python_version >= “3”
Downloading scipy-1.4.1.tar.gz (24.6 MB)
|████████████████████████████████| 24.6 MB 26.2 MB/s
Installing build dependencies … done
Getting requirements to build wheel … error
ERROR: Command errored out with exit status -4:
command: /usr/bin/python3 /usr/local/lib/python3.6/dist-packages/pip/_vendor/pep517/_in_process.py get_requires_for_build_wheel /tmp/tmpeav0h6l3
cwd: /tmp/pip-install-9eo0htxo/scipy
Complete output (0 lines):
ERROR: Command errored out with exit status -4: /usr/bin/python3 /usr/local/lib/python3.6/dist-packages/pip/_vendor/pep517/_in_process.py get_requires_for_build_wheel /tmp/tmpeav0h6l3 Check the logs for full command output.
WARNING: You are using pip version 20.2.4; however, version 21.0.1 is available.
You should consider upgrading via the ‘/usr/bin/python3 -m pip install --upgrade pip’ command.
Hi - I did try installing scipy 1.4.1 before tensorflow using “pip3…” and “sudo pip3…” to see if that would work and got the error pasted below. What is interesting is I was able to easily install scipy1.5.4 using “pip3 install --user scipy”. I was also able to install python 3.5.9 and could successfully install scipy 1.4.1 using “python3.5 -m pip install --user scipy==1.4.1”. However when I went to install tensorflow using your previous instruction after scipy1.4.1(python3.5) installed, I got the same error I posted on April 1 - tensorflow install error at scipy. I should mention that python 3.6.9 is my default and is what it looks like the tensorflow install is trying to use to install scipy1.4.1 as well. Thank you!
Using cached scipy-1.4.1.tar.gz (24.6 MB)
command: /usr/bin/python3 /usr/local/lib/python3.6/dist-packages/pip/_vendor/pep517/_in_process.py get_requires_for_build_wheel /tmp/tmpgykdotch
cwd: /tmp/pip-install-y_sxlgyz/scipy_6a3a6c930f4b40a28d6868b91bd741dc
Hi There,
I’m having a similar issue, also on TX2, JP43 and same version of python. I want to install tensorflow 2 and am getting a slightly different metadata error:
