**• Hardware Platform : Jetson AGX Xavier
**• DeepStream Version : 5.0
**• JetPack Version : 4.4[L4T 32.4.3]
**• TensorRT Version : 7.1.3.0
**• NVIDIA GPU Driver Version : R32 (release), REVISION: 4.3, GCID: 21589087, BOARD: t186ref, EABI: aarch64
• Unable to install pyindex and nvidia-tlt in AGX Xavier
*• I have tried to install the following packages in AGX Xavier machine
pip3 install nvidia-pyindex
pip3 install nvidia-tlt
( also tried with sudo permission also)
It showed error as :
Complete output from command /usr/bin/python3 -u -c “import setuptools, tokenize;file=’/tmp/pip-build-s5h9uasg/nvidia-pyindex/setup.py’;f=getattr(tokenize, ‘open’, open)(file);code=f.read().replace(’\r\n’, ‘\n’);f.close();exec(compile(code, file, ‘exec’))” install --record /tmp/pip-utkxqsgm-record/install-record.txt --single-version-externally-managed --compile:
running install
COMMAND: InstallCommand
/bin/sh: 1: nvidia_pyindex: not found
File “/tmp/pip-build-s5h9uasg/nvidia-pyindex/nvidia_pyindex/utils.py”, line 17, in get_configuration_files
output = subprocess.check_output(command, stderr=subprocess.STDOUT)
File “/usr/lib/python3.6/subprocess.py”, line 356, in check_output
**kwargs).stdout
File “/usr/lib/python3.6/subprocess.py”, line 438, in run
output=stdout, stderr=stderr)
subprocess.CalledProcessError: Command ‘[’/usr/bin/python3’, ‘-c’, ‘from pip._internal.configuration import get_configuration_files; print(get_configuration_files())’]’ returned non-zero exit status 1.
The above exception was the direct cause of the following exception:
File "<string>", line 1, in <module>
File "/tmp/pip-build-s5h9uasg/nvidia-pyindex/setup.py", line 269, in <module>
packages=find_packages(),
File "/usr/lib/python3/dist-packages/setuptools/__init__.py", line 129, in setup
return distutils.core.setup(**attrs)
File "/usr/lib/python3.6/distutils/core.py", line 148, in setup
dist.run_commands()
File "/usr/lib/python3.6/distutils/dist.py", line 955, in run_commands
self.run_command(cmd)
File "/usr/lib/python3.6/distutils/dist.py", line 974, in run_command
cmd_obj.run()
File "/tmp/pip-build-s5h9uasg/nvidia-pyindex/setup.py", line 160, in run
_install_nvidia_pypi_index()
File "/tmp/pip-build-s5h9uasg/nvidia-pyindex/setup.py", line 59, in _install_nvidia_pypi_index
config_filedict = get_configuration_files()
File "/tmp/pip-build-s5h9uasg/nvidia-pyindex/nvidia_pyindex/utils.py", line 21, in get_configuration_files
raise RuntimeError(output) from e
RuntimeError: Traceback (most recent call last):
ModuleNotFoundError: No module named 'pip._internal'
Command “/usr/bin/python3 -u -c “import setuptools, tokenize;file=’/tmp/pip-build-s5h9uasg/nvidia-pyindex/setup.py’;f=getattr(tokenize, ‘open’, open)(file);code=f.read().replace(’\r\n’, ‘\n’);f.close();exec(compile(code, file, ‘exec’))” install --record /tmp/pip-utkxqsgm-record/install-record.txt --single-version-externally-managed --compile” failed with error code 1 in /tmp/pip-build-s5h9uasg/nvidia-pyindex/
The following error is for nvidia-tlt:
Complete output from command python setup.py egg_info:
File "/tmp/pip-build-NPXyLQ/nvidia-tlt/setup.py", line 129
print(new_line, end='')
SyntaxError: invalid syntax
Command “python setup.py egg_info” failed with error code 1 in /tmp/pip-build-NPXyLQ/nvidia-tlt/
Both the above packages are tried in pip and pip3
Can you please help me out this.
