I followed by TLT documentation link for installation of TLT Launcher, every things is good, but I get this error when I want to install nvidia-tlt package:
Looking in indexes: https://pypi.org/simple, https://pypi.ngc.nvidia.com
Collecting nvidia-tlt
Downloading nvidia-tlt-0.0.1.dev4.tar.gz (4.0 kB)
ERROR: Command errored out with exit status 1:
command: /home/mm/.virtualenvs/cv/bin/python -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-hjx6d6e6/nvidia-tlt_e2fdd17088df42b9af89a2ac24b675f9/setup.py'"'"'; __file__='"'"'/tmp/pip-install-hjx6d6e6/nvidia-tlt_e2fdd17088df42b9af89a2ac24b675f9/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' egg_info --egg-base /tmp/pip-pip-egg-info-q1gdb2st
cwd: /tmp/pip-install-hjx6d6e6/nvidia-tlt_e2fdd17088df42b9af89a2ac24b675f9/
Complete output (15 lines):
File "<string>", line 1, in <module>
File "/tmp/pip-install-hjx6d6e6/nvidia-tlt_e2fdd17088df42b9af89a2ac24b675f9/setup.py", line 150, in <module>
raise RuntimeError(open("ERROR.txt", "r").read())
RuntimeError:
The package you are trying to install is only a placeholder project on PyPI.org repository.
This package is hosted on NVIDIA Python Package Index.
This package can be installed as:
$ pip install nvidia-pyindex
$ pip install nvidia-tlt
WARNING: Discarding https://files.pythonhosted.org/packages/c2/f8/dd59d97e0ccf45333631d267f5490412ca0478c04663f47fa0fb6b085c05/nvidia-tlt-0.0.1.dev4.tar.gz#sha256=ed1e7fd797ba4421a1786ddcbc5f40606e93c1d07a24340ae40b5c71d14028fe (from https://pypi.org/simple/nvidia-tlt/). Command errored out with exit status 1: python setup.py egg_info Check the logs for full command output.
ERROR: Could not find a version that satisfies the requirement nvidia-tlt
ERROR: No matching distribution found for nvidia-tlt
