I need to retrieve SEI (USER DATA UNREGISTERED) messages from nvcuvid bitstream in the function
handlePictureDecode(CUVIDPICPARAMS *pPicParams)
I have setup a video streaming using a combination of NVENC/NVDEC and live555. This works very well except that I need to add an SEI per frame. The problem is that before giving NALUS to the decoder, I can actually parse them and retrieve my SEI messages (getting nal type by masking with 0x1F). But as soon as I give them to my decoder with cuvidParseVideoData, I am unable to retrieve them in the bitstream (pPicParams->pBitstreamData, pPicParams->nBitstreamDataLen)
Code for feeding nal to NVCUVID is :
void H264Decoder::processNewNalu(const QByteArray& nalu_h264)
CUVIDSOURCEDATAPACKET packet;
memset(&packet, 0, sizeof(CUVIDSOURCEDATAPACKET));
packet.payload = (unsigned char*)nalu_h264.data();
packet.payload_size = nalu_h264.size();
__cucheck(cuCtxPushCurrent(m_cuContext));
__cucheck(cuvidParseVideoData(m_cuVideoParser, &packet));
__cucheck(cuCtxPopCurrent(NULL));
Where m_cuContext is the cuda Context created for my decoder and m_cuVideoParser is the parser created with cuvidCreateVideoParser. Code for creating video parser is :
void H264Decoder::createVideoParser()
CUVIDPARSERPARAMS oVideoParserParameters;
memset(&oVideoParserParameters, 0, sizeof(CUVIDPARSERPARAMS));
oVideoParserParameters.CodecType = cudaVideoCodec_H264;
oVideoParserParameters.ulMaxNumDecodeSurfaces = 1;
oVideoParserParameters.ulMaxDisplayDelay = 0;
oVideoParserParameters.pUserData = this;
oVideoParserParameters.pfnSequenceCallback = handleVideoSequence;
oVideoParserParameters.pfnDecodePicture = handlePictureDecode;
oVideoParserParameters.pfnDisplayPicture = handlePictureDisplay;
__cucheck(cuvidCreateVideoParser(&m_cuVideoParser, &oVideoParserParameters));
return true;
code for parsing bitstream is :
void H264Decoder::parseBitstream(const unsigned char* bitstream, unsigned int size)
unsigned int offset = 0;
while (offset < size - 4)
if (bitstream[offset] == 0x00 && bitstream[offset + 1] == 0x00 && bitstream[offset + 2] == 0x01)
printf("Header 0X00 0X00 0X01 found ! Nal Type : %d\n", bitstream[offset + 3] & 0x1F);
offset += 3;
else if (bitstream[offset] == 0x00 && bitstream[offset + 1] == 0x00 && bitstream[offset + 2] == 0x00 && bitstream[offset + 3] == 0x01)
printf("Header 0X00 0X00 0x00 0X01 found ! Nal Type : %d\n", bitstream[offset + 4] & 0x1F);
offset += 4;
else
offset++;
I only found nalus with type 1 in the bitstream (pPicParams->pBitstreamData, pPicParams->nBitstreamDataLen). I would like to find my SEI (nal type 6) in the bitstream because I actually need to output the correct SEI with the associated frame.
I use Video_Codec_SDK_9.1.23, Geforce GTX 1080, Intel(R) Xeon(R) CPU E5-1650v4 3.60 GHz, Windows 10 professional version 1703.
Current Cuda version 10.1, Nvidia Driver version 436.48
Thank you very much
