I use NV_ENC_SEI_PAYLOAD as a param of NV_ENC_PIC_PARAMS to set up the HEVC HDR sei message. The decoded result is different from the data I set.
The GPU is Quadro P2000,and the driver is 390.77.
The input data is from ffmpeg decoder, and I copy the memory block to the payload.
rypark
#2
Hi bitliangxiang,
Could you provide us which operating system you are using, and provide a sample code that can repro the issue you are encountering?
You can send the sample code to this email address:
video-sdk-feedback@nvidia.com
Thanks,
Ryan Park
Hi rypark,
Thanks for your reply. The sample code has mailed to video-sdk-feedback@nvidia.com.
Hi all,
I’ve sloved the problem. The ffmpeg decoded data is Little-Endian, I transfer it to Big-Endian then I can get the correct sei message.
