I’m trying to follow this guide Chapter 21. Configuring Power Management Support to enable saving the GPU video memory during suspend. It suggests to enable NVreg_PreserveVideoMemoryAllocations=1.
So, I have created /etc/modprobe.d/nvidia-power-management.conf with the following contents:
options nvidia NVreg_PreserveVideoMemoryAllocations=1 NVreg_TemporaryFilePath=/mnt/vault/nvidia-tmp.
I have also added FILES=(/etc/modprobe.d/nvidia-power-management.conf) to mkinitcpio.conf, and have enabled all the modules for KMS: MODULES=(nvidia nvidia_modeset nvidia_uvm nvidia_drm) along with the proper kernel parameter.
However, when I check sudo systool -vm nvidia, I only see
Parameters:
nv_cap_enable_devfs = “1”
What can I do to make sure that these parameters are set properly? I have attached a nvidia-bug-report.sh output if it can be helpful. Thanks.
For the bug report I ran sudo systemctl suspend in a TTY, then resumed and switched back to X and ran the bug report. nvidia-bug-report.log.gz (505.4 KB)
