Here is the error that was thrown from the training command
Using TensorFlow backend.
2019-11-06 12:16:29.791151: I tensorflow/core/platform/cpu_feature_guard.cc:141] Your CPU supports instructions that this TensorFlow binary was not compiled to use: AVX2 FMA
2019-11-06 12:16:29.936043: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:998] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2019-11-06 12:16:29.937212: I tensorflow/compiler/xla/service/service.cc:150] XLA service 0x62df5a0 executing computations on platform CUDA. Devices:
2019-11-06 12:16:29.937235: I tensorflow/compiler/xla/service/service.cc:158] StreamExecutor device (0): GeForce GTX 1660 Ti, Compute Capability 7.5
2019-11-06 12:16:29.950235: I tensorflow/core/platform/profile_utils/cpu_utils.cc:94] CPU Frequency: 2904000000 Hz
2019-11-06 12:16:29.950636: I tensorflow/compiler/xla/service/service.cc:150] XLA service 0x6347be0 executing computations on platform Host. Devices:
2019-11-06 12:16:29.950653: I tensorflow/compiler/xla/service/service.cc:158] StreamExecutor device (0): ,
2019-11-06 12:16:29.950739: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1433] Found device 0 with properties:
name: GeForce GTX 1660 Ti major: 7 minor: 5 memoryClockRate(GHz): 1.77
pciBusID: 0000:01:00.0
totalMemory: 5.80GiB freeMemory: 5.36GiB
2019-11-06 12:16:29.950754: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1512] Adding visible gpu devices: 0
2019-11-06 12:16:29.952006: I tensorflow/core/common_runtime/gpu/gpu_device.cc:984] Device interconnect StreamExecutor with strength 1 edge matrix:
2019-11-06 12:16:29.952019: I tensorflow/core/common_runtime/gpu/gpu_device.cc:990] 0
2019-11-06 12:16:29.952025: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1003] 0: N
2019-11-06 12:16:29.952073: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1115] Created TensorFlow device (/job:localhost/replica:0/task:0/device:GPU:0 with 5189 MB memory) -> physical GPU (device: 0, name: GeForce GTX 1660 Ti, pci bus id: 0000:01:00.0, compute capability: 7.5)
2019-11-06 12:16:29,953 [INFO] iva.ssd.scripts.train: Loading experiment spec at /workspace/examples/ssd/specs/ssd_train_resnet18_kitti.txt.
2019-11-06 12:16:29,954 [INFO] /usr/local/lib/python2.7/dist-packages/iva/ssd/utils/spec_loader.pyc: Merging specification from /workspace/examples/ssd/specs/ssd_train_resnet18_kitti.txt
WARNING:tensorflow:From ./detectnet_v2/dataloader/utilities.py:114: tf_record_iterator (from tensorflow.python.lib.io.tf_record) is deprecated and will be removed in a future version.
Instructions for updating:
Use eager execution and: tf.data.TFRecordDataset(path)
2019-11-06 12:16:29,957 [WARNING] tensorflow: From ./detectnet_v2/dataloader/utilities.py:114: tf_record_iterator (from tensorflow.python.lib.io.tf_record) is deprecated and will be removed in a future version.
WARNING:tensorflow:From /usr/local/lib/python2.7/dist-packages/tensorflow/python/data/ops/iterator_ops.py:358: colocate_with (from tensorflow.python.framework.ops) is deprecated and will be removed in a future version.
Colocations handled automatically by placer.
2019-11-06 12:16:29,999 [WARNING] tensorflow: From /usr/local/lib/python2.7/dist-packages/tensorflow/python/data/ops/iterator_ops.py:358: colocate_with (from tensorflow.python.framework.ops) is deprecated and will be removed in a future version.
File “/usr/local/bin/tlt-train-g1”, line 10, in
sys.exit(main())
File “./common/magnet_train.py”, line 33, in main
File “./ssd/scripts/train.py”, line 301, in main
File “./ssd/scripts/train.py”, line 167, in run_experiment
File “./ssd/builders/model_builder.py”, line 75, in build
File “./ssd/builders/inputs_builder.py”, line 51, in init
File “./detectnet_v2/dataloader/default_dataloader.py”, line 198, in get_dataset_tensors
File “./detectnet_v2/dataloader/utilities.py”, line 181, in extract_tfrecords_features
StopIteration
Here is the spec file used for training
Spec File:
Next, for SSD, the tlt-train tool does not support training on images of multiple resolutions, or resizing images during training. All of the images must be resized offline to the final training size and the corresponding bounding boxes must be scaled accordingly.
See tlt doc https://docs.nvidia.com/metropolis/TLT/tlt-getting-started-guide/index.html#requirements
The size should match your setting in the training spec.
I generated the tf records for a small sample of my own data identified few files where the fields are more than 15 and separated using a python script. I’m working on the other half of the data which is clean and in right format I hope.
Here is the python logic I used for verifying
file_list=
for fname in files:
with open(fname) as f:
lines = [line.rstrip(’\n’) for line in f]
flag = True
for line in lines:
if(len(line.split())==15):
flag=True
else:
flag = False
break
print(fname)
if(flag==True):
file_list.append(fname)
Speaking of SSD in tlt-train all images are 1920x1080p the bounding boxes generated are of same resolution.
Here is the spec file for training I have commented the places where changes are necessary please confirm them and let me know if I had to change them in any other places
If you set 1920x1080 in your spec, please resize all your training images to 1920x1080.
And the corresponding bounding boxes must be scaled accordingly. That means your KITTI format label file’s xmin/ymin/xmax/ymax should exactly match the bbox of a 1920x1080 image.
Your modification is reverse.
output_image_width should change to 1920
output_image_height should change to 1080
crop_right should change value to 1920
crop_bottom should change to 1080
I go through the issue you mentioned originally, and think there is something problem in your tfrecords.
Could you run “tlt-dataset-convert” again to generate the tfrecord files?
Please share me the log.
2019-11-07 09:47:21,053 - iva.detectnet_v2.dataio.build_converter - INFO - Instantiating a kitti converter
2019-11-07 09:47:21,053 - iva.detectnet_v2.dataio.kitti_converter_lib - INFO - Num images in
Train: 5 Val: 0
2019-11-07 09:47:21,053 - iva.detectnet_v2.dataio.kitti_converter_lib - INFO - Validation data in partition 0. Hence, while choosing the validationset during training choose validation_fold 0.
2019-11-07 09:47:21,053 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Writing partition 0, shard 0
2019-11-07 09:47:21,053 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Writing partition 0, shard 1
2019-11-07 09:47:21,054 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Writing partition 0, shard 2
2019-11-07 09:47:21,054 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Writing partition 0, shard 3
2019-11-07 09:47:21,054 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Writing partition 0, shard 4
2019-11-07 09:47:21,054 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Writing partition 0, shard 5
2019-11-07 09:47:21,054 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Writing partition 0, shard 6
2019-11-07 09:47:21,054 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Writing partition 0, shard 7
2019-11-07 09:47:21,054 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Writing partition 0, shard 8
2019-11-07 09:47:21,054 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Writing partition 0, shard 9
Wrote the following numbers of objects:
2019-11-07 09:47:21,054 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Writing partition 1, shard 0
2019-11-07 09:47:21,054 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Writing partition 1, shard 1
2019-11-07 09:47:21,054 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Writing partition 1, shard 2
2019-11-07 09:47:21,054 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Writing partition 1, shard 3
2019-11-07 09:47:21,055 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Writing partition 1, shard 4
2019-11-07 09:47:21,055 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Writing partition 1, shard 5
2019-11-07 09:47:21,055 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Writing partition 1, shard 6
2019-11-07 09:47:21,055 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Writing partition 1, shard 7
2019-11-07 09:47:21,055 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Writing partition 1, shard 8
2019-11-07 09:47:21,055 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Writing partition 1, shard 9
/usr/local/lib/python2.7/dist-packages/iva/detectnet_v2/dataio/kitti_converter_lib.py:266: VisibleDeprecationWarning: Reading unicode strings without specifying the encoding argument is deprecated. Set the encoding, use None for the system default.
2019-11-07 09:47:21,061 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO -
Class-1: 7
Class-2: 1
Class-3: 2
2019-11-07 09:47:21,061 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Cumulative object statistics
Class-1: 7
Class-2: 1
Class-3: 2
2019-11-07 09:47:21,061 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Class map.
Label in GT: Label in tfrecords file
Class-1: Class-1
Class-2: Class-2
Class-3: Class-3
For the dataset_config in the experiment_spec, please use labels in the tfrecords file, while writing the classmap.
2019-11-07 09:47:21,061 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Tfrecords generation complete.
Here is the output of the script
WARNING:tensorflow:From inspect_tfrecords.py:40: tf_record_iterator (from tensorflow.python.lib.io.tf_record) is deprecated and will be removed in a future version.
All images found in tlt-experiments/tfrecords/kitti_trainval-fold-001-of-002-shard-00006-of-00010 have expected dimensions
All images found in tlt-experiments/tfrecords/kitti_trainval-fold-001-of-002-shard-00004-of-00010 have expected dimensions
All images found in tlt-experiments/tfrecords/kitti_trainval-fold-000-of-002-shard-00009-of-00010 have expected dimensions
All images found in tlt-experiments/tfrecords/kitti_trainval-fold-000-of-002-shard-00000-of-00010 have expected dimensions
All images found in tlt-experiments/tfrecords/kitti_trainval-fold-000-of-002-shard-00008-of-00010 have expected dimensions
All images found in tlt-experiments/tfrecords/kitti_trainval-fold-001-of-002-shard-00008-of-00010 have expected dimensions
All images found in tlt-experiments/tfrecords/kitti_trainval-fold-000-of-002-shard-00002-of-00010 have expected dimensions
All images found in tlt-experiments/tfrecords/kitti_trainval-fold-001-of-002-shard-00000-of-00010 have expected dimensions
All images found in tlt-experiments/tfrecords/kitti_trainval-fold-001-of-002-shard-00002-of-00010 have expected dimensions
All images found in tlt-experiments/tfrecords/kitti_trainval-fold-000-of-002-shard-00005-of-00010 have expected dimensions
All images found in tlt-experiments/tfrecords/kitti_trainval-fold-000-of-002-shard-00001-of-00010 have expected dimensions
All images found in tlt-experiments/tfrecords/kitti_trainval-fold-001-of-002-shard-00003-of-00010 have expected dimensions
All images found in tlt-experiments/tfrecords/kitti_trainval-fold-000-of-002-shard-00004-of-00010 have expected dimensions
All images found in tlt-experiments/tfrecords/kitti_trainval-fold-001-of-002-shard-00009-of-00010 have expected dimensions
All images found in tlt-experiments/tfrecords/kitti_trainval-fold-000-of-002-shard-00006-of-00010 have expected dimensions
All images found in tlt-experiments/tfrecords/kitti_trainval-fold-001-of-002-shard-00001-of-00010 have expected dimensions
All images found in tlt-experiments/tfrecords/kitti_trainval-fold-001-of-002-shard-00007-of-00010 have expected dimensions
All images found in tlt-experiments/tfrecords/kitti_trainval-fold-001-of-002-shard-00005-of-00010 have expected dimensions
All images found in tlt-experiments/tfrecords/kitti_trainval-fold-000-of-002-shard-00003-of-00010 have expected dimensions
All images found in tlt-experiments/tfrecords/kitti_trainval-fold-000-of-002-shard-00007-of-00010 have expected dimensions
I fixed all my annotations(with 16 feilds) with a python script and generated my tfrfecords with all my annotations( unlike the above scenario just few ).
I ran my inspect_tfrecords.py script for cross verifying them
Now that I have everything in right place I hope tried to my training using the below command
This is the log of the script generated after executing the above command which gave a cudnn error
2019-11-07 16:47:50.392205: I tensorflow/core/platform/cpu_feature_guard.cc:141] Your CPU supports instructions that this TensorFlow binary was not compiled to use: AVX2 FMA
2019-11-07 16:47:50.488351: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:998] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2019-11-07 16:47:50.488729: I tensorflow/compiler/xla/service/service.cc:150] XLA service 0x6035670 executing computations on platform CUDA. Devices:
2019-11-07 16:47:50.488748: I tensorflow/compiler/xla/service/service.cc:158] StreamExecutor device (0): GeForce GTX 1660 Ti, Compute Capability 7.5
2019-11-07 16:47:50.490405: I tensorflow/core/platform/profile_utils/cpu_utils.cc:94] CPU Frequency: 2904000000 Hz
2019-11-07 16:47:50.490778: I tensorflow/compiler/xla/service/service.cc:150] XLA service 0x609dcb0 executing computations on platform Host. Devices:
2019-11-07 16:47:50.490795: I tensorflow/compiler/xla/service/service.cc:158] StreamExecutor device (0): ,
2019-11-07 16:47:50.491003: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1433] Found device 0 with properties:
totalMemory: 5.80GiB freeMemory: 5.34GiB
2019-11-07 16:47:50.491022: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1512] Adding visible gpu devices: 0
2019-11-07 16:47:50.491446: I tensorflow/core/common_runtime/gpu/gpu_device.cc:984] Device interconnect StreamExecutor with strength 1 edge matrix:
2019-11-07 16:47:50.491459: I tensorflow/core/common_runtime/gpu/gpu_device.cc:990] 0
2019-11-07 16:47:50.491482: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1003] 0: N
2019-11-07 16:47:50.491529: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1115] Created TensorFlow device (/job:localhost/replica:0/task:0/device:GPU:0 with 5169 MB memory) -> physical GPU (device: 0, name: GeForce GTX 1660 Ti, pci bus id: 0000:01:00.0, compute capability: 7.5)
2019-11-07 16:47:50,493 [INFO] iva.ssd.scripts.train: Loading experiment spec at /workspace/examples/ssd/specs/ssd_train_resnet18_kitti.txt.
2019-11-07 16:47:50,493 [INFO] /usr/local/lib/python2.7/dist-packages/iva/ssd/utils/spec_loader.pyc: Merging specification from /workspace/examples/ssd/specs/ssd_train_resnet18_kitti.txt
2019-11-07 16:47:50,496 [WARNING] tensorflow: From ./detectnet_v2/dataloader/utilities.py:114: tf_record_iterator (from tensorflow.python.lib.io.tf_record) is deprecated and will be removed in a future version.
2019-11-07 16:47:50,552 [WARNING] tensorflow: From /usr/local/lib/python2.7/dist-packages/tensorflow/python/data/ops/iterator_ops.py:358: colocate_with (from tensorflow.python.framework.ops) is deprecated and will be removed in a future version.
target/truncation is not updated to match the crop areaif the dataset contains target/truncation.
WARNING:tensorflow:From ./ssd/utils/tensor_utils.py:31: setdiff1d (from tensorflow.python.ops.array_ops) is deprecated and will be removed after 2018-11-30.
This op will be removed after the deprecation date. Please switch to tf.sets.difference().
2019-11-07 16:47:59,303 [WARNING] tensorflow: From ./ssd/utils/tensor_utils.py:31: setdiff1d (from tensorflow.python.ops.array_ops) is deprecated and will be removed after 2018-11-30.
2019-11-07 16:48:12,731 [INFO] iva.ssd.scripts.train: Loading pretrained weights. This may take a while…
WARNING:tensorflow:From /usr/local/lib/python2.7/dist-packages/tensorflow/python/ops/math_ops.py:3066: to_int32 (from tensorflow.python.ops.math_ops) is deprecated and will be removed in a future version.
Use tf.cast instead.
2019-11-07 16:48:22,904 [WARNING] tensorflow: From /usr/local/lib/python2.7/dist-packages/tensorflow/python/ops/math_ops.py:3066: to_int32 (from tensorflow.python.ops.math_ops) is deprecated and will be removed in a future version.
Total params: 20,503,036
Trainable params: 20,481,916
Non-trainable params: 21,120
2019-11-07 16:50:57,605 [INFO] iva.ssd.scripts.train: Number of images in the training dataset: 2566
2019-11-07 16:50:57,605 [INFO] iva.ssd.scripts.train: Number of images in the validation dataset: 417
2019-11-07 16:51:04.345438: W tensorflow/core/framework/allocator.cc:124] Allocation of 18874368 exceeds 10% of system memory.
2019-11-07 16:51:04.363103: W tensorflow/core/framework/allocator.cc:124] Allocation of 18874368 exceeds 10% of system memory.
2019-11-07 16:51:04.375936: W tensorflow/core/framework/allocator.cc:124] Allocation of 18874368 exceeds 10% of system memory.
2019-11-07 16:51:04.456606: W tensorflow/core/framework/allocator.cc:124] Allocation of 18874368 exceeds 10% of system memory.
2019-11-07 16:51:04.485102: W tensorflow/core/framework/allocator.cc:124] Allocation of 18874368 exceeds 10% of system memory.
Epoch 1/180
2019-11-07 16:51:14.587732: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_16/strided_slice_5. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:14.587783: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_16/CornerCoordToCentroids/StridedReplace/strided_slice. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?,1]
2019-11-07 16:51:14.587804: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_16/CornerCoordToCentroids/strided_slice_4. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:14.587823: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_16/CornerCoordToCentroids/strided_slice_5. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:14.587841: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_16/CornerCoordToCentroids/strided_slice_6. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:14.587859: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_16/CornerCoordToCentroids/strided_slice_7. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:14.587877: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_16/CornerCoordToCentroids/StridedReplace/strided_slice_1. Error: ValidateStridedSliceOp returned partial shapes [?,0] and [?,0]
2019-11-07 16:51:14.587895: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_16/strided_slice_6. Error: ValidateStridedSliceOp returned partial shapes [?,4] and [?,4]
2019-11-07 16:51:14.587943: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_17/strided_slice_5. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:14.587963: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_17/CornerCoordToCentroids/StridedReplace/strided_slice. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?,1]
2019-11-07 16:51:14.587981: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_17/CornerCoordToCentroids/strided_slice_4. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:14.587999: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_17/CornerCoordToCentroids/strided_slice_5. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:14.588017: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_17/CornerCoordToCentroids/strided_slice_6. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:14.588037: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_17/CornerCoordToCentroids/strided_slice_7. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:14.588055: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_17/CornerCoordToCentroids/StridedReplace/strided_slice_1. Error: ValidateStridedSliceOp returned partial shapes [?,0] and [?,0]
2019-11-07 16:51:14.588073: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_17/strided_slice_6. Error: ValidateStridedSliceOp returned partial shapes [?,4] and [?,4]
2019-11-07 16:51:14.588097: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_18/strided_slice_5. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:14.588116: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_18/CornerCoordToCentroids/StridedReplace/strided_slice. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?,1]
2019-11-07 16:51:14.588135: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_18/CornerCoordToCentroids/strided_slice_4. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:14.588153: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_18/CornerCoordToCentroids/strided_slice_5. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:14.588171: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_18/CornerCoordToCentroids/strided_slice_6. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:14.588189: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_18/CornerCoordToCentroids/strided_slice_7. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:14.588207: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_18/CornerCoordToCentroids/StridedReplace/strided_slice_1. Error: ValidateStridedSliceOp returned partial shapes [?,0] and [?,0]
2019-11-07 16:51:14.588225: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_18/strided_slice_6. Error: ValidateStridedSliceOp returned partial shapes [?,4] and [?,4]
2019-11-07 16:51:14.588249: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_19/strided_slice_5. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:14.588267: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_19/CornerCoordToCentroids/StridedReplace/strided_slice. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?,1]
2019-11-07 16:51:14.588286: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_19/CornerCoordToCentroids/strided_slice_4. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:14.588304: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_19/CornerCoordToCentroids/strided_slice_5. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:14.588322: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_19/CornerCoordToCentroids/strided_slice_6. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:14.588340: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_19/CornerCoordToCentroids/strided_slice_7. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:14.588362: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_19/CornerCoordToCentroids/StridedReplace/strided_slice_1. Error: ValidateStridedSliceOp returned partial shapes [?,0] and [?,0]
2019-11-07 16:51:14.588381: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_19/strided_slice_6. Error: ValidateStridedSliceOp returned partial shapes [?,4] and [?,4]
2019-11-07 16:51:14.588404: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_20/strided_slice_5. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:14.588423: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_20/CornerCoordToCentroids/StridedReplace/strided_slice. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?,1]
2019-11-07 16:51:14.588442: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_20/CornerCoordToCentroids/strided_slice_4. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:14.588461: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_20/CornerCoordToCentroids/strided_slice_5. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:14.588479: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_20/CornerCoordToCentroids/strided_slice_6. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:14.588497: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_20/CornerCoordToCentroids/strided_slice_7. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:14.588515: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_20/CornerCoordToCentroids/StridedReplace/strided_slice_1. Error: ValidateStridedSliceOp returned partial shapes [?,0] and [?,0]
2019-11-07 16:51:14.588533: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_20/strided_slice_6. Error: ValidateStridedSliceOp returned partial shapes [?,4] and [?,4]
2019-11-07 16:51:14.588557: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_21/strided_slice_5. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:14.588575: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_21/CornerCoordToCentroids/StridedReplace/strided_slice. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?,1]
2019-11-07 16:51:14.588594: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_21/CornerCoordToCentroids/strided_slice_4. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:14.588611: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_21/CornerCoordToCentroids/strided_slice_5. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:14.588629: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_21/CornerCoordToCentroids/strided_slice_6. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:14.588647: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_21/CornerCoordToCentroids/strided_slice_7. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:14.588664: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_21/CornerCoordToCentroids/StridedReplace/strided_slice_1. Error: ValidateStridedSliceOp returned partial shapes [?,0] and [?,0]
2019-11-07 16:51:14.588681: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_21/strided_slice_6. Error: ValidateStridedSliceOp returned partial shapes [?,4] and [?,4]
2019-11-07 16:51:14.588704: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_22/strided_slice_5. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:14.588723: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_22/CornerCoordToCentroids/StridedReplace/strided_slice. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?,1]
2019-11-07 16:51:14.588742: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_22/CornerCoordToCentroids/strided_slice_4. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:14.588760: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_22/CornerCoordToCentroids/strided_slice_5. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:14.588777: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_22/CornerCoordToCentroids/strided_slice_6. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:14.588794: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_22/CornerCoordToCentroids/strided_slice_7. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:14.588813: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_22/CornerCoordToCentroids/StridedReplace/strided_slice_1. Error: ValidateStridedSliceOp returned partial shapes [?,0] and [?,0]
2019-11-07 16:51:14.588831: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_22/strided_slice_6. Error: ValidateStridedSliceOp returned partial shapes [?,4] and [?,4]
2019-11-07 16:51:14.588854: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_23/strided_slice_5. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:14.588873: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_23/CornerCoordToCentroids/StridedReplace/strided_slice. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?,1]
2019-11-07 16:51:14.588892: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_23/CornerCoordToCentroids/strided_slice_4. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:14.588911: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_23/CornerCoordToCentroids/strided_slice_5. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:14.588929: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_23/CornerCoordToCentroids/strided_slice_6. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:5
Hi psgr,
Have you finished the first epoch training? If not, please ignore the error and keep patient to run several epoches.
BTW, it is better for you to paste the log by adding “code block”.
I there is a character limitation in the forum which has actually chopped my log here is the continuation for the same
2019-11-07 16:51:14.588947: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_23/CornerCoordToCentroids/strided_slice_7. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:14.588965: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_23/CornerCoordToCentroids/StridedReplace/strided_slice_1. Error: ValidateStridedSliceOp returned partial shapes [?,0] and [?,0]
2019-11-07 16:51:14.588983: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_23/strided_slice_6. Error: ValidateStridedSliceOp returned partial shapes [?,4] and [?,4]
2019-11-07 16:51:14.589006: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_24/strided_slice_5. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:14.589025: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_24/CornerCoordToCentroids/StridedReplace/strided_slice. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?,1]
2019-11-07 16:51:14.589044: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_24/CornerCoordToCentroids/strided_slice_4. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:14.589062: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_24/CornerCoordToCentroids/strided_slice_5. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:14.589081: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_24/CornerCoordToCentroids/strided_slice_6. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:14.589099: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_24/CornerCoordToCentroids/strided_slice_7. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:14.589117: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_24/CornerCoordToCentroids/StridedReplace/strided_slice_1. Error: ValidateStridedSliceOp returned partial shapes [?,0] and [?,0]
2019-11-07 16:51:14.589135: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_24/strided_slice_6. Error: ValidateStridedSliceOp returned partial shapes [?,4] and [?,4]
2019-11-07 16:51:14.589158: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_25/strided_slice_5. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:14.589177: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_25/CornerCoordToCentroids/StridedReplace/strided_slice. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?,1]
2019-11-07 16:51:14.589196: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_25/CornerCoordToCentroids/strided_slice_4. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:14.589214: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_25/CornerCoordToCentroids/strided_slice_5. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:14.589233: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_25/CornerCoordToCentroids/strided_slice_6. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:14.589251: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_25/CornerCoordToCentroids/strided_slice_7. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:14.589269: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_25/CornerCoordToCentroids/StridedReplace/strided_slice_1. Error: ValidateStridedSliceOp returned partial shapes [?,0] and [?,0]
2019-11-07 16:51:14.589288: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_25/strided_slice_6. Error: ValidateStridedSliceOp returned partial shapes [?,4] and [?,4]
2019-11-07 16:51:14.589311: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_26/strided_slice_5. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:14.589330: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_26/CornerCoordToCentroids/StridedReplace/strided_slice. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?,1]
2019-11-07 16:51:14.589349: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_26/CornerCoordToCentroids/strided_slice_4. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:14.589367: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_26/CornerCoordToCentroids/strided_slice_5. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:14.589385: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_26/CornerCoordToCentroids/strided_slice_6. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:14.589403: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_26/CornerCoordToCentroids/strided_slice_7. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:14.589421: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_26/CornerCoordToCentroids/StridedReplace/strided_slice_1. Error: ValidateStridedSliceOp returned partial shapes [?,0] and [?,0]
2019-11-07 16:51:14.589439: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_26/strided_slice_6. Error: ValidateStridedSliceOp returned partial shapes [?,4] and [?,4]
2019-11-07 16:51:14.589462: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_27/strided_slice_5. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:14.589480: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_27/CornerCoordToCentroids/StridedReplace/strided_slice. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?,1]
2019-11-07 16:51:14.589500: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_27/CornerCoordToCentroids/strided_slice_4. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:14.589518: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_27/CornerCoordToCentroids/strided_slice_5. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:14.589536: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_27/CornerCoordToCentroids/strided_slice_6. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:14.589554: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_27/CornerCoordToCentroids/strided_slice_7. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:14.589572: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_27/CornerCoordToCentroids/StridedReplace/strided_slice_1. Error: ValidateStridedSliceOp returned partial shapes [?,0] and [?,0]
2019-11-07 16:51:14.589591: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_27/strided_slice_6. Error: ValidateStridedSliceOp returned partial shapes [?,4] and [?,4]
2019-11-07 16:51:14.589614: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_28/strided_slice_5. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:14.589632: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_28/CornerCoordToCentroids/StridedReplace/strided_slice. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?,1]
2019-11-07 16:51:14.589651: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_28/CornerCoordToCentroids/strided_slice_4. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:14.589669: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_28/CornerCoordToCentroids/strided_slice_5. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:14.589688: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_28/CornerCoordToCentroids/strided_slice_6. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:14.589705: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_28/CornerCoordToCentroids/strided_slice_7. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:14.589724: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_28/CornerCoordToCentroids/StridedReplace/strided_slice_1. Error: ValidateStridedSliceOp returned partial shapes [?,0] and [?,0]
2019-11-07 16:51:14.589742: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_28/strided_slice_6. Error: ValidateStridedSliceOp returned partial shapes [?,4] and [?,4]
2019-11-07 16:51:14.589765: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_29/strided_slice_5. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:14.589783: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_29/CornerCoordToCentroids/StridedReplace/strided_slice. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?,1]
2019-11-07 16:51:14.589801: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_29/CornerCoordToCentroids/strided_slice_4. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:14.589820: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_29/CornerCoordToCentroids/strided_slice_5. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:14.589838: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_29/CornerCoordToCentroids/strided_slice_6. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:14.589857: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_29/CornerCoordToCentroids/strided_slice_7. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:14.589875: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_29/CornerCoordToCentroids/StridedReplace/strided_slice_1. Error: ValidateStridedSliceOp returned partial shapes [?,0] and [?,0]
2019-11-07 16:51:14.589893: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_29/strided_slice_6. Error: ValidateStridedSliceOp returned partial shapes [?,4] and [?,4]
2019-11-07 16:51:14.589915: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_30/strided_slice_5. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:14.589934: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_30/CornerCoordToCentroids/StridedReplace/strided_slice. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?,1]
2019-11-07 16:51:14.589953: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_30/CornerCoordToCentroids/strided_slice_4. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:14.589971: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_30/CornerCoordToCentroids/strided_slice_5. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:14.589990: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_30/CornerCoordToCentroids/strided_slice_6. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:14.590008: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_30/CornerCoordToCentroids/strided_slice_7. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:14.590026: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_30/CornerCoordToCentroids/StridedReplace/strided_slice_1. Error: ValidateStridedSliceOp returned partial shapes [?,0] and [?,0]
2019-11-07 16:51:14.590044: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_30/strided_slice_6. Error: ValidateStridedSliceOp returned partial shapes [?,4] and [?,4]
2019-11-07 16:51:14.590067: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_31/strided_slice_5. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:14.590085: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_31/CornerCoordToCentroids/StridedReplace/strided_slice. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?,1]
2019-11-07 16:51:14.590104: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_31/CornerCoordToCentroids/strided_slice_4. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:14.590122: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_31/CornerCoordToCentroids/strided_slice_5. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:14.590140: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_31/CornerCoordToCentroids/strided_slice_6. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:14.590158: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_31/CornerCoordToCentroids/strided_slice_7. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:14.590177: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_31/CornerCoordToCentroids/StridedReplace/strided_slice_1. Error: ValidateStridedSliceOp returned partial shapes [?,0] and [?,0]
2019-11-07 16:51:14.590194: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_31/strided_slice_6. Error: ValidateStridedSliceOp returned partial shapes [?,4] and [?,4]
2019-11-07 16:51:27.741870: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_16/strided_slice_5. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:27.741924: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_16/CornerCoordToCentroids/StridedReplace/strided_slice. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?,1]
2019-11-07 16:51:27.741946: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_16/CornerCoordToCentroids/strided_slice_4. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:27.741966: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_16/CornerCoordToCentroids/strided_slice_5. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:27.741984: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_16/CornerCoordToCentroids/strided_slice_6. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:27.742002: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_16/CornerCoordToCentroids/strided_slice_7. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:27.742021: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_16/CornerCoordToCentroids/StridedReplace/strided_slice_1. Error: ValidateStridedSliceOp returned partial shapes [?,0] and [?,0]
2019-11-07 16:51:27.742040: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_16/strided_slice_6. Error: ValidateStridedSliceOp returned partial shapes [?,4] and [?,4]
2019-11-07 16:51:27.742067: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_17/strided_slice_5. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:27.742087: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_17/CornerCoordToCentroids/StridedReplace/strided_slice. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?,1]
2019-11-07 16:51:27.742106: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_17/CornerCoordToCentroids/strided_slice_4. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:27.742125: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_17/CornerCoordToCentroids/strided_slice_5. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:27.742143: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_17/CornerCoordToCentroids/strided_slice_6. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:27.742162: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_17/CornerCoordToCentroids/strided_slice_7. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:27.742183: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_17/CornerCoordToCentroids/StridedReplace/strided_slice_1. Error: ValidateStridedSliceOp returned partial shapes [?,0] and [?,0]
2019-11-07 16:51:27.742203: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_17/strided_slice_6. Error: ValidateStridedSliceOp returned partial shapes [?,4] and [?,4]
2019-11-07 16:51:27.742227: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_18/strided_slice_5. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:27.742247: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_18/CornerCoordToCentroids/StridedReplace/strided_slice. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?,1]
2019-11-07 16:51:27.742267: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_18/CornerCoordToCentroids/strided_slice_4. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:27.742285: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_18/CornerCoordToCentroids/strided_slice_5. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:27.742305: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_18/CornerCoordToCentroids/strided_slice_6. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:27.742323: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_18/CornerCoordToCentroids/strided_slice_7. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:27.742342: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_18/CornerCoordToCentroids/StridedReplace/strided_slice_1. Error: ValidateStridedSliceOp returned partial shapes [?,0] and [?,0]
2019-11-07 16:51:27.742361: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_18/strided_slice_6. Error: ValidateStridedSliceOp returned partial shapes [?,4] and [?,4]
2019-11-07 16:51:27.742386: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_19/strided_slice_5. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:27.742406: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_19/CornerCoordToCentroids/StridedReplace/strided_slice. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?,1]
2019-11-07 16:51:27.742426: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_19/CornerCoordToCentroids/strided_slice_4. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:27.742445: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_19/CornerCoordToCentroids/strided_slice_5. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:27.742465: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_19/CornerCoordToCentroids/strided_slice_6. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:27.742484: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_19/CornerCoordToCentroids/strided_slice_7. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:27.742503: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_19/CornerCoordToCentroids/StridedReplace/strided_slice_1. Error: ValidateStridedSliceOp returned partial shapes [?,0] and [?,0]
2019-11-07 16:51:27.742522: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_19/strided_slice_6. Error: ValidateStridedSliceOp returned partial shapes [?,4] and [?,4]
2019-11-07 16:51:27.742546: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_20/strided_slice_5. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:27.742566: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_20/CornerCoordToCentroids/StridedReplace/strided_slice. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?,1]
2019-11-07 16:51:27.742587: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_20/CornerCoordToCentroids/strided_slice_4. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:27.742606: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_20/CornerCoordToCentroids/strided_slice_5. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:27.742625: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_20/CornerCoordToCentroids/strided_slice_6. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:27.742644: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_20/CornerCoordToCentroids/strided_slice_7. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:27.742663: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_20/CornerCoordToCentroids/StridedReplace/strided_slice_1. Error: ValidateStridedSliceOp returned partial shapes [?,0] and [?,0]
2019-11-07 16:51:27.742681: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_20/strided_slice_6. Error: ValidateStridedSliceOp returned partial shapes [?,4] and [?,4]
2019-11-07 16:51:27.742705: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_21/strided_slice_5. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:27.742725: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_21/CornerCoordToCentroids/StridedReplace/strided_slice. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?,1]
2019-11-07 16:51:27.742745: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_21/CornerCoordToCentroids/strided_slice_4. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:27.742764: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_21/CornerCoordToCentroids/strided_slice_5. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:27.742783: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_21/CornerCoordToCentroids/strided_slice_6. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:27.742803: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_21/CornerCoordToCentroids/strided_slice_7. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:27.742821: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_21/CornerCoordToCentroids/StridedReplace/strided_slice_1. Error: ValidateStridedSliceOp returned partial shapes [?,0] and [?,0]
2019-11-07 16:51:27.742840: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_21/strided_slice_6. Error: ValidateStridedSliceOp returned partial shapes [?,4] and [?,4]
2019-11-07 16:51:27.742865: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_22/strided_slice_5. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:27.742885: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_22/CornerCoordToCentroids/StridedReplace/strided_slice. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?,1]
2019-11-07 16:51:27.742904: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_22/CornerCoordToCentroids/strided_slice_4. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:27.742924: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_22/CornerCoordToCentroids/strided_slice_5. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:27.742943: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_22/CornerCoordToCentroids/strided_slice_6. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:27.742961: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_22/CornerCoordToCentroids/strided_slice_7. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:27.742981: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_22/CornerCoordToCentroids/StridedReplace/strided_slice_1. Error: ValidateStridedSliceOp returned partial shapes [?,0] and [?,0]
2019-11-07 16:51:27.742999: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_22/strided_slice_6. Error: ValidateStridedSliceOp returned partial shapes [?,4] and [?,4]
2019-11-07 16:51:27.743023: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_23/strided_slice_5. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:27.743043: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_23/CornerCoordToCentroids/StridedReplace/strided_slice. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?,1]
2019-11-07 16:51:27.743063: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_23/CornerCoordToCentroids/strided_slice_4. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:27.743082: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_23/CornerCoordToCentroids/strided_slice_5. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:27.743101: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_23/CornerCoordToCentroids/strided_slice_6. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:27.743119: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_23/CornerCoordToCentroids/strided_slice_7. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:27.743137: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_23/CornerCoordToCentroids/StridedReplace/strided_slice_1. Error: ValidateStridedSliceOp returned partial shapes [?,0] and [?,0]
2019-11-07 16:51:27.743156: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_23/strided_slice_6. Error: ValidateStridedSliceOp returned partial shapes [?,4] and [?,4]
2019-11-07 16:51:27.743180: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_24/strided_slice_5. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:27.743198: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_24/CornerCoordToCentroids/StridedReplace/strided_slice. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?,1]
2019-11-07 16:51:27.743219: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_24/CornerCoordToCentroids/strided_slice_4. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:27.743238: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_24/CornerCoordToCentroids/strided_slice_5. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:27.743256: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_24/CornerCoordToCentroids/strided_slice_6. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:27.743275: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_24/CornerCoordToCentroids/strided_slice_7. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:27.743294: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_24/CornerCoordToCentroids/StridedReplace/strided_slice_1. Error: ValidateStridedSliceOp returned partial shapes [?,0] and [?,0]
2019-11-07 16:51:27.743312: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_24/strided_slice_6. Error: ValidateStridedSliceOp returned partial shapes [?,4] and [?,4]
2019-11-07 16:51:27.743336: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_25/strided_slice_5. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:27.743354: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_25/CornerCoordToCentroids/StridedReplace/strided_slice. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?,1]
2019-11-07 16:51:27.743374: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_25/CornerCoordToCentroids/strided_slice_4. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:27.743394: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_25/CornerCoordToCentroids/strided_slice_5. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:27.743412: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_25/CornerCoordToCentroids/strided_slice_6. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:27.743431: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_25/CornerCoordToCentroids/strided_slice_7. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:27.743450: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_25/CornerCoordToCentroids/StridedReplace/strided_slice_1. Error: ValidateStridedSliceOp returned partial shapes [?,0] and [?,0]
2019-11-07 16:51:27.743469: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_25/strided_slice_6. Error: ValidateStridedSliceOp returned partial shapes [?,4] and [?,4]
2019-11-07 16:51:27.743493: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_26/strided_slice_5. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:27.743513: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_26/CornerCoordToCentroids/StridedReplace/strided_slice. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?,1]
2019-11-07 16:51:27.743532: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_26/CornerCoordToCentroids/strided_slice_4. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:27.743551: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_26/CornerCoordToCentroids/strided_slice_5. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:27.743571: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_26/CornerCoordToCentroids/strided_slice_6. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:27.743588: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_26/CornerCoordToCentroids/strided_slice_7. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:27.743608: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_26/CornerCoordToCentroids/StridedReplace/strided_slice_1. Error: ValidateStridedSliceOp returned partial shapes [?,0] and [?,0]
2019-11-07 16:51:27.743627: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_26/strided_slice_6. Error: ValidateStridedSliceOp returned partial shapes [?,4] and [?,4]
2019-11-07 16:51:27.743650: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_27/strided_slice_5. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:27.743670: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_27/CornerCoordToCentroids/StridedReplace/strided_slice. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?,1]
2019-11-07 16:51:27.743689: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_27/CornerCoordToCentroids/strided_slice_4. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:27.743708: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_27/CornerCoordToCentroids/strided_slice_5. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:27.743744: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_27/CornerCoordToCentroids/strided_slice_6. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:27.743763: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_27/CornerCoordToCentroids/strided_slice_7. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:27.743797: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_27/CornerCoordToCentroids/StridedReplace/strided_slice_1. Error: ValidateStridedSliceOp returned partial shapes [?,0] and [?,0]
2019-11-07 16:51:27.743816: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_27/strided_slice_6. Error: ValidateStridedSliceOp returned partial shapes [?,4] and [?,4]
2019-11-07 16:51:27.743840: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_28/strided_slice_5. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:27.743859: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_28/CornerCoordToCentroids/StridedReplace/strided_slice. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?,1]
2019-11-07 16:51:27.743879: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_28/CornerCoordToCentroids/strided_slice_4. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:27.743899: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_28/CornerCoordToCentroids/strided_slice_5. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:27.743918: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_28/CornerCoordToCentroids/strided_slice_6. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:27.743937: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_28/CornerCoordToCentroids/strided_slice_7. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:27.743955: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_28/CornerCoordToCentroids/StridedReplace/strided_slice_1. Error: ValidateStridedSliceOp returned partial shapes [?,0] and [?,0]
2019-11-07 16:51:27.743975: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_28/strided_slice_6. Error: ValidateStridedSliceOp returned partial shapes [?,4] and [?,4]
2019-11-07 16:51:27.743999: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_29/strided_slice_5. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:27.744018: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_29/CornerCoordToCentroids/StridedReplace/strided_slice. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?,1]
2019-11-07 16:51:27.744038: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_29/CornerCoordToCentroids/strided_slice_4. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:27.744057: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_29/CornerCoordToCentroids/strided_slice_5. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:27.744077: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_29/CornerCoordToCentroids/strided_slice_6. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:27.744095: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_29/CornerCoordToCentroids/strided_slice_7. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:27.744115: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_29/CornerCoordToCentroids/StridedReplace/strided_slice_1. Error: ValidateStridedSliceOp returned partial shapes [?,0] and [?,0]
2019-11-07 16:51:27.744133: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_29/strided_slice_6. Error: ValidateStridedSliceOp returned partial shapes [?,4] and [?,4]
2019-11-07 16:51:27.744157: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_30/strided_slice_5. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:27.744177: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_30/CornerCoordToCentroids/StridedReplace/strided_slice. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?,1]
2019-11-07 16:51:27.744196: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_30/CornerCoordToCentroids/strided_slice_4. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:27.744216: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_30/CornerCoordToCentroids/strided_slice_5. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:27.744235: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_30/CornerCoordToCentroids/strided_slice_6. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:27.744254: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_30/CornerCoordToCentroids/strided_slice_7. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:27.744272: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_30/CornerCoordToCentroids/StridedReplace/strided_slice_1. Error: ValidateStridedSliceOp returned partial shapes [?,0] and [?,0]
2019-11-07 16:51:27.744291: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_30/strided_slice_6. Error: ValidateStridedSliceOp returned partial shapes [?,4] and [?,4]
2019-11-07 16:51:27.744315: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_31/strided_slice_5. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:27.744334: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_31/CornerCoordToCentroids/StridedReplace/strided_slice. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?,1]
2019-11-07 16:51:27.744373: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_31/CornerCoordToCentroids/strided_slice_4. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:27.744395: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_31/CornerCoordToCentroids/strided_slice_5. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:27.744427: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_31/CornerCoordToCentroids/strided_slice_6. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:27.744446: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_31/CornerCoordToCentroids/strided_slice_7. Error: ValidateStridedSliceOp returned partial shapes [?,1] and [?]
2019-11-07 16:51:27.744465: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_31/CornerCoordToCentroids/StridedReplace/strided_slice_1. Error: ValidateStridedSliceOp returned partial shapes [?,0] and [?,0]
2019-11-07 16:51:27.744484: W ./tensorflow/core/grappler/optimizers/graph_optimizer_stage.h:241] Failed to run optimizer ArithmeticOptimizer, stage RemoveStackStridedSliceSameAxis node cond_31/strided_slice_6. Error: ValidateStridedSliceOp returned partial shapes [?,4] and [?,4]
2019-11-07 16:51:29.170924: I tensorflow/stream_executor/dso_loader.cc:152] successfully opened CUDA library libcublas.so.10.0 locally
2019-11-07 16:51:29.786102: I tensorflow/core/kernels/cuda_solvers.cc:159] Creating CudaSolver handles for stream 0x60d74b0
2019-11-07 16:51:31.398825: E tensorflow/stream_executor/cuda/cuda_dnn.cc:334] Could not create cudnn handle: CUDNN_STATUS_INTERNAL_ERROR
2019-11-07 16:51:31.405099: E tensorflow/stream_executor/cuda/cuda_dnn.cc:334] Could not create cudnn handle: CUDNN_STATUS_INTERNAL_ERROR
File “/usr/local/bin/tlt-train-g1”, line 10, in
sys.exit(main())
File “./common/magnet_train.py”, line 33, in main
File “./ssd/scripts/train.py”, line 301, in main
File “./ssd/scripts/train.py”, line 245, in run_experiment
File “/usr/local/lib/python2.7/dist-packages/keras/engine/training.py”, line 1039, in fit
validation_steps=validation_steps)
File “/usr/local/lib/python2.7/dist-packages/keras/engine/training_arrays.py”, line 154, in fit_loop
outs = f(ins)
File “/usr/local/lib/python2.7/dist-packages/keras/backend/tensorflow_backend.py”, line 2715, in call
return self._call(inputs)
File “/usr/local/lib/python2.7/dist-packages/keras/backend/tensorflow_backend.py”, line 2675, in _call
fetched = self._callable_fn(*array_vals)
File “/usr/local/lib/python2.7/dist-packages/tensorflow/python/client/session.py”, line 1439, in call
run_metadata_ptr)
File “/usr/local/lib/python2.7/dist-packages/tensorflow/python/framework/errors_impl.py”, line 528, in exit
c_api.TF_GetCode(self.status.status))
tensorflow.python.framework.errors_impl.UnknownError: Failed to get convolution algorithm. This is probably because cuDNN failed to initialize, so try looking to see if a warning log message was printed above.
[[{{node conv1_1/convolution}}]]
[[{{node loss_1/add_46}}]]
So it ended with an CUDNN error. Can you please help with this?
