I used TLT3.0 Faster-RCNN to train the custom data set and the following error occurred:
File “/home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/faster_rcnn/scripts/train.py”, line 74, in
File “/home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/faster_rcnn/scripts/train.py”, line 66, in main
File “/home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/faster_rcnn/models/utils.py”, line 407, in build_or_resume_model
File “/home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/faster_rcnn/data_loader/inputs_loader.py”, line 78, in init
File “/home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/dataloader/drivenet_dataloader.py”, line 653, in get_dataset_tensors
File “/home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/core/build_wheel.runfiles/ai_infra/moduluspy/modulus/blocks/trainers/multi_task_trainer/data_loader_interface.py”, line 77, in call
File “/home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/core/build_wheel.runfiles/ai_infra/moduluspy/modulus/blocks/data_loaders/multi_source_loader/data_loader.py”, line 396, in call
File “/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/data/ops/dataset_ops.py”, line 2081, in apply
return DatasetV1Adapter(super(DatasetV1, self).apply(transformation_func))
File “/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/data/ops/dataset_ops.py”, line 1422, in apply
dataset = transformation_func(self)
File “/home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/dataloader/drivenet_dataloader.py”, line 371, in
File “/opt/nvidia/third_party/keras/tensorflow_backend.py”, line 356, in new_map
self, _map_func_set_random_wrapper, num_parallel_calls=num_parallel_calls
File “/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/data/ops/dataset_ops.py”, line 2000, in map
MapDataset(self, map_func, preserve_cardinality=False))
File “/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/data/ops/dataset_ops.py”, line 3531, in init
use_legacy_function=use_legacy_function)
File “/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/data/ops/dataset_ops.py”, line 2810, in init
self._function = wrapper_fn._get_concrete_function_internal()
File “/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/eager/function.py”, line 1853, in _get_concrete_function_internal
*args, **kwargs)
File “/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/eager/function.py”, line 1847, in _get_concrete_function_internal_garbage_collected
graph_function, _, _ = self._maybe_define_function(args, kwargs)
File “/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/eager/function.py”, line 2147, in _maybe_define_function
graph_function = self._create_graph_function(args, kwargs)
File “/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/eager/function.py”, line 2038, in _create_graph_function
capture_by_value=self._capture_by_value),
File “/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/framework/func_graph.py”, line 915, in func_graph_from_py_func
func_outputs = python_func(*func_args, **func_kwargs)
File “/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/data/ops/dataset_ops.py”, line 2804, in wrapper_fn
ret = _wrapper_helper(*args)
File “/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/data/ops/dataset_ops.py”, line 2749, in _wrapper_helper
ret = autograph.tf_convert(func, ag_ctx)(*nested_args)
File “/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/autograph/impl/api.py”, line 237, in wrapper
raise e.ag_error_metadata.to_exception(e)
StopIteration: in converted code:
/opt/nvidia/third_party/keras/tensorflow_backend.py:353 _map_func_set_random_wrapper *
return map_func(*args, **kwargs)
/home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/dataloader/drivenet_dataloader.py:136 __call__
/home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/dataloader/drivenet_dataloader.py:104 _get_parse_example
/home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/dataloader/utilities.py:217 extract_tfrecords_features
StopIteration:
File “/usr/local/bin/faster_rcnn”, line 8, in
sys.exit(main())
File “/home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/faster_rcnn/entrypoint/faster_rcnn.py”, line 12, in main
File “/home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/common/entrypoint/entrypoint.py”, line 296, in launch_job
AssertionError: Process run failed.
any idea?thanks
