**• Hardware Platform **
x86/64 RTX3060
• DeepStream Version
deepstream6.0
• TensorRT Version
8.0.1
**• NVIDIA GPU Driver Version **
470.86
questions
xhost +
docker run --gpus all -it -p 8889:8888 -v /tmp/.X11-unix:/tmp/.X11-unix -v /home/bigmao/Downloads:/opt/nvidia/deepstream/deepstream-6.0/Downloads -e DISPLAY=$DISPLAY -w /opt/nvidia/deepstream/deepstream-6.0 nvcr.io/nvidia/deepstream:6.0-devel
python3 -m pip install jupyterlab
cd sources/apps/sample_apps/deepstream-test1
export CUDA_VER=11.4
make
./deepstream-test1-app /opt/nvidia/deepstream/deepstream-6.0/samples/streams/sample_720p.h264
The following errors are reported:
Now playing: /opt/nvidia/deepstream/deepstream-6.0/samples/streams/sample_720p.h264
libEGL warning: DRI2: failed to authenticate
0:00:02.011994838 42 0x557dd9d82b90 INFO nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1900> [UID = 1]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-6.0/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine
INFO: …/nvdsinfer/nvdsinfer_model_builder.cpp:610 [Implicit Engine Info]: layers num: 3
0 INPUT kFLOAT input_1 3x368x640
1 OUTPUT kFLOAT conv2d_bbox 16x23x40
2 OUTPUT kFLOAT conv2d_cov/Sigmoid 4x23x40
0:00:02.012058140 42 0x557dd9d82b90 INFO nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2004> [UID = 1]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-6.0/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine
0:00:02.012836196 42 0x557dd9d82b90 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus: [UID 1]: Load new model:dstest1_pgie_config.txt sucessfully
Running…
cuGraphicsGLRegisterBuffer failed with error(219) gst_eglglessink_cuda_init texture = 1
Frame Number = 0 Number of objects = 13 Vehicle Count = 9 Person Count = 4
0:00:02.250050189 42 0x557dd877f140 WARN nvinfer gstnvinfer.cpp:2288:gst_nvinfer_output_loop: error: Internal data stream error.
0:00:02.250083745 42 0x557dd877f140 WARN nvinfer gstnvinfer.cpp:2288:gst_nvinfer_output_loop: error: streaming stopped, reason not-negotiated (-4)
ERROR from element primary-nvinference-engine: Internal data stream error.
Error details: gstnvinfer.cpp(2288): gst_nvinfer_output_loop (): /GstPipeline:dstest1-pipeline/GstNvInfer:primary-nvinference-engine:
Returned, stopping playback
Frame Number = 1 Number of objects = 11 Vehicle Count = 8 Person Count = 3
Frame Number = 2 Number of objects = 11 Vehicle Count = 7 Person Count = 4
Frame Number = 3 Number of objects = 11 Vehicle Count = 7 Person Count = 4
Frame Number = 4 Number of objects = 11 Vehicle Count = 8 Person Count = 3
Frame Number = 5 Number of objects = 12 Vehicle Count = 8 Person Count = 4
Frame Number = 6 Number of objects = 11 Vehicle Count = 7 Person Count = 4
Deleting pipeline
