Unable to use nvvideoconvert to crop frames in create_rtsp_src_bin()
• Hardware Platform (GPU): dGPU
• DeepStream Version : 6.0
• Issue Type( questions, new requirements, bugs) : I am trying to use nvvideoconvert in create_rtsp_src_bin() in deepstream_source_bin.c to crop a portion of incoming frame and pass that ahead in the pipeline.I have tried flipping the frame using flip-method property of nvvideoconvert and that works fine but when I use src-crop and dest-crop to crop the frame, it doesn’t works and same original frame is flowing in the pipeline . I also tried making changes to size of caps_filter but it gives 0 fps. Attached my code below.
• Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description): To use nvvideoconvert plugin in create_rtsp_src_bin() to crop incoming to frames to a particular ROI.
**This is the code I am using: **
static gboolean
create_rtsp_src_bin (NvDsSourceConfig * config, NvDsSrcBin * bin)
  NvDsSRContext *ctx = NULL;
  gboolean ret = FALSE;
  gchar elem_name[50];
  bin->config = config;
  GstCaps *caps = NULL;
  GstCapsFeatures *feature = NULL;
  bin->latency = config->latency;
  bin->rtsp_reconnect_interval_sec = config->rtsp_reconnect_interval_sec;
  bin->rtsp_reconnect_attempts = config->rtsp_reconnect_attempts;
  bin->num_rtsp_reconnects = 0;
  g_snprintf (elem_name, sizeof (elem_name), "src_elem%d", bin->bin_id);
  bin->src_elem = gst_element_factory_make ("rtspsrc", elem_name);
  if (!bin->src_elem) {
    NVGSTDS_ERR_MSG_V ("Failed to create '%s'", elem_name);
    goto done;
  g_signal_connect (G_OBJECT(bin->src_elem), "select-stream",
                    G_CALLBACK(cb_rtspsrc_select_stream),
                    bin);
  g_object_set (G_OBJECT (bin->src_elem), "location", config->uri, NULL);
  g_object_set (G_OBJECT (bin->src_elem), "latency", config->latency, NULL);
  g_object_set (G_OBJECT (bin->src_elem), "drop-on-latency", TRUE, NULL);
  configure_source_for_ntp_sync (bin->src_elem);
  // 0x4 for TCP and 0x7 for All (UDP/UDP-MCAST/TCP)
  if ((config->select_rtp_protocol == GST_RTSP_LOWER_TRANS_TCP)
      || (config->select_rtp_protocol == (GST_RTSP_LOWER_TRANS_UDP |
              GST_RTSP_LOWER_TRANS_UDP_MCAST | GST_RTSP_LOWER_TRANS_TCP))) {
    g_object_set (G_OBJECT (bin->src_elem), "protocols",
        config->select_rtp_protocol, NULL);
    GST_DEBUG_OBJECT (bin->src_elem,
        "RTP Protocol=0x%x (0x4=TCP and 0x7=UDP,TCP,UDPMCAST)----\n",
        config->select_rtp_protocol);
  g_signal_connect (G_OBJECT (bin->src_elem), "pad-added",
      G_CALLBACK (cb_newpad3), bin);
  g_snprintf (elem_name, sizeof (elem_name), "tee_rtsp_elem%d", bin->bin_id);
  bin->tee_rtsp_pre_decode = gst_element_factory_make ("tee", elem_name);
  if (!bin->tee_rtsp_pre_decode) {
    goto done;
  g_snprintf (elem_name, sizeof (elem_name), "tee_rtsp_post_decode_elem%d", bin->bin_id);
  bin->tee_rtsp_post_decode = gst_element_factory_make ("tee", elem_name);
  if (!bin->tee_rtsp_post_decode) {
    goto done;
  if (config->smart_record) {
    NvDsSRInitParams params = {0};
    params.containerType = (NvDsSRContainerType) config->smart_rec_container;
    if (config->file_prefix)
      params.fileNamePrefix = g_strdup_printf ("%s_%d", config->file_prefix, config->camera_id);
    params.dirpath = config->dir_path;
    params.cacheSize = config->smart_rec_cache_size;
    params.defaultDuration = config->smart_rec_def_duration;
    params.callback = smart_record_callback;
    if (NvDsSRCreate (&ctx, &params) != NVDSSR_STATUS_OK) {
      NVGSTDS_ERR_MSG_V ("Failed to create smart record bin");
      g_free (params.fileNamePrefix);
      goto done;
    gst_bin_add (GST_BIN(bin->bin), ctx->recordbin);
    bin->recordCtx = (gpointer) ctx;
  g_snprintf (elem_name, sizeof (elem_name), "dec_que%d", bin->bin_id);
  bin->dec_que = gst_element_factory_make ("queue", elem_name);
  if (!bin->dec_que) {
    goto done;
  if (bin->rtsp_reconnect_interval_sec > 0) {
    NVGSTDS_ELEM_ADD_PROBE (bin->rtspsrc_monitor_probe, bin->dec_que,
        "sink", rtspsrc_monitor_probe_func,
        GST_PAD_PROBE_TYPE_BUFFER,
        bin);
    install_mux_eosmonitor_probe = TRUE;
  } else {
        GST_PAD_PROBE_TYPE_EVENT_DOWNSTREAM,
        bin);
  g_snprintf (elem_name, sizeof (elem_name), "decodebin_elem%d", bin->bin_id);
  bin->decodebin = gst_element_factory_make ("decodebin", elem_name);
  if (!bin->decodebin) {
    goto done;
  g_signal_connect (G_OBJECT (bin->decodebin), "pad-added",
      G_CALLBACK (cb_newpad2), bin);
  g_signal_connect (G_OBJECT (bin->decodebin), "child-added",
      G_CALLBACK (decodebin_child_added), bin);
  g_snprintf (elem_name, sizeof (elem_name), "src_que%d", bin->bin_id);
  bin->cap_filter = gst_element_factory_make (NVDS_ELEM_QUEUE, elem_name);
  if (!bin->cap_filter) {
    goto done;
  g_mutex_init (&bin->bin_lock);
  if (config->dewarper_config.enable) {
    if (!create_dewarper_bin (&config->dewarper_config, &bin->dewarper_bin)) {
      g_print ("Failed to create dewarper bin \n");
      goto done;
    gst_bin_add_many (GST_BIN (bin->bin), bin->src_elem,
        bin->tee_rtsp_pre_decode,
        bin->dec_que,
        bin->decodebin,
        bin->cap_filter,
        bin->tee_rtsp_post_decode,
        bin->dewarper_bin.bin,
        NULL);
  }else{
    g_snprintf(elem_name, sizeof(elem_name), "nvvidconv_elem%d", bin->bin_id);
    bin->nvvidconv = gst_element_factory_make(NVDS_ELEM_VIDEO_CONV, elem_name);
    if (!bin->nvvidconv)
      NVGSTDS_ERR_MSG_V("Could not create element 'nvvidconv_elem'");
      goto done;
    //g_object_set (G_OBJECT (bin->nvvidconv), "flip-method", videoConvCtx.flipMethod, NULL);
    g_object_set (G_OBJECT (bin->nvvidconv), "src-crop", "500:400:504:504", NULL);
    g_object_set (G_OBJECT (bin->nvvidconv), "dest-crop", "0:0:504:504", NULL);
    caps = gst_caps_new_simple ("video/x-raw",
      "width", G_TYPE_INT, 504,
       "height", G_TYPE_INT, 504, NULL);
    feature = gst_caps_features_new("memory:NVMM", NULL);
    bin->cap_filter1 =
        gst_element_factory_make(NVDS_ELEM_CAPS_FILTER, "src_cap_filter_nvvidconv");
    if (!bin->cap_filter1)
      NVGSTDS_ERR_MSG_V("Could not create 'queue'");
      goto done;
    g_object_set(G_OBJECT(bin->cap_filter1), "caps", caps, NULL);
    gst_caps_unref(caps);
    gst_bin_add_many(GST_BIN(bin->bin), bin->src_elem,
        bin->dec_que,
        bin->decodebin,
        bin->cap_filter,
        bin->nvvidconv, bin->cap_filter1,
        NULL);
  link_element_to_tee_src_pad(bin->tee_rtsp_pre_decode, bin->dec_que);
  NVGSTDS_LINK_ELEMENT (bin->dec_que, bin->decodebin);
  if (ctx)
    link_element_to_tee_src_pad(bin->tee_rtsp_pre_decode, ctx->recordbin);
  NVGSTDS_LINK_ELEMENT (bin->cap_filter, bin->tee_rtsp_post_decode);
    link_element_to_tee_src_pad (bin->tee_rtsp_post_decode, bin->dewarper_bin.bin);
    NVGSTDS_BIN_ADD_GHOST_PAD (bin->bin, bin->dewarper_bin.bin, "src");
  } else{
    link_element_to_tee_src_pad(bin->tee_rtsp_post_decode, bin->nvvidconv);
    NVGSTDS_LINK_ELEMENT (bin->nvvidconv, bin->cap_filter1);
    NVGSTDS_BIN_ADD_GHOST_PAD (bin->bin, bin->cap_filter1, "src");
  ret = TRUE;
  g_timeout_add (1000, watch_source_status, bin);
  // Enable local start / stop events in addition to the one
  // received from the server.
  #if 0
  if (config->smart_record == 2) {
    if (bin->config->smart_rec_interval)
      g_timeout_add (bin->config->smart_rec_interval * 1000, smart_record_event_generator, bin);
    else
      g_timeout_add (10000, smart_record_event_generator, bin);
  #endif
  GST_CAT_DEBUG (NVDS_APP,
      "Decode bin created. Waiting for a new pad from decodebin to link");
done:
  if (!ret) {
    NVGSTDS_ERR_MSG_V ("%s failed", __func__);
  return ret;
As I am new to gstreamer, please guide if there’s something wrong with my code.
Please upgrade to the latest DeepStream 6.2 first.
