I’m working with DeepStream 6.4 on my Jetson Orin NX and using the sample configuration file source30_1080p_dec_infer-resnet_tiled_display_int8.txt. I’ve enabled the RTSP sink and disabled the other sinks as per the configuration. However, I’m facing an issue:
When I try to connect to the RTSP stream using the IP address shown in the terminal (via VLC or ffplay), the connection loads indefinitely and never displays any output.
I’m accessing the Jetson device via SSH.
Jetson Orin NX • DeepStream Version
6.4 • JetPack Version (valid for Jetson only)
6.0 • TensorRT Version
8.6 • NVIDIA GPU Driver Version (valid for GPU only)
540.3.0
Here’s the output of GST_DEBUG=4 deepstream-app -c source30_1080p_dec_infer-resnet_tiled_display_int8.txt:
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=5
#gie-kitti-output-dir=streamscl
[tiled-display]
enable=1
rows=5
columns=6
width=1280
height=720
gpu-id=0
#(0): nvbuf-mem-default - Default memory allocated, specific to particular platform
#(1): nvbuf-mem-cuda-pinned - Allocate Pinned/Host cuda memory, applicable for Tesla
#(2): nvbuf-mem-cuda-device - Allocate Device cuda memory, applicable for Tesla
#(3): nvbuf-mem-cuda-unified - Allocate Unified cuda memory, applicable for Tesla
#(4): nvbuf-mem-surface-array - Allocate Surface Array memory, applicable for Jetson
nvbuf-memory-type=0
[source0]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI 4=RTSP
type=3
uri=file://../../streams/sample_1080p_h264.mp4
num-sources=15
#drop-frame-interval=2
gpu-id=0
# (0): memtype_device - Memory type Device
# (1): memtype_pinned - Memory type Host Pinned
# (2): memtype_unified - Memory type Unified
cudadec-memtype=0
[source1]
enable=1
type=3
num-sources=15
gpu-id=0
cudadec-memtype=0
[sink0]
enable=0
#Type - 1=FakeSink 2=EglSink/nv3dsink (Jetson only) 3=File
type=2
sync=1
source-id=0
gpu-id=0
nvbuf-memory-type=0
[sink1]
enable=0
type=3
#1=mp4 2=mkv
container=1
#1=h264 2=h265
codec=1
#encoder type 0=Hardware 1=Software
enc-type=0
sync=0
#iframeinterval=10
bitrate=2000000
#H264 Profile - 0=Baseline 2=Main 4=High
#H265 Profile - 0=Main 1=Main10
# set profile only for hw encoder, sw encoder selects profile based on sw-preset
profile=0
output-file=out.mp4
source-id=0
[sink2]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File 4=RTSPStreaming
type=4
#1=h264 2=h265
codec=1
enc-type=0
#sw-preset=1 #for SW enc=(0)None (1)ultrafast (2)superfast (3)veryfast (4)faster
#(5)fast (6)medium (7)slow (8)slower (9)veryslow (10)placebo
sync=0
bitrate=4000000
profile=0
# set below properties in case of RTSPStreaming
rtsp-port=8554
udp-port=5400
[osd]
enable=1
gpu-id=0
border-width=1
text-size=15
text-color=1;1;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Serif
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
nvbuf-memory-type=0
[streammux]
gpu-id=0
##Boolean property to inform muxer that sources are live
live-source=0
batch-size=30
##time out in usec, to wait after the first buffer is available
##to push the batch even if the complete batch is not formed
batched-push-timeout=40000
## Set muxer output width and height
width=1920
height=1080
##Enable to maintain aspect ratio wrt source, and allow black borders, works
##along with width, height properties
enable-padding=0
nvbuf-memory-type=0
## If set to TRUE, system timestamp will be attached as ntp timestamp
## If set to FALSE, ntp timestamp from rtspsrc, if available, will be attached
# attach-sys-ts-as-ntp=1
# config-file property is mandatory for any gie section.
# Other properties are optional and if set will override the properties set in
# the infer config file.
[primary-gie]
enable=1
gpu-id=0
model-engine-file=../../models/Primary_Detector/resnet18_trafficcamnet.etlt_b30_gpu0_int8.engine
#Required to display the PGIE labels, should be added even when using config-file
#property
batch-size=30
bbox-border-color0=1;0;0;1
bbox-border-color1=0;1;1;1
bbox-border-color2=0;0;1;1
bbox-border-color3=0;1;0;1
interval=0
#Required by the app for SGIE, when used along with config-file property
gie-unique-id=1
nvbuf-memory-type=0
config-file=config_infer_primary.txt
[tests]
file-loop=0
