I tried to describe my problem in topic title/topic description. Let me be more descriptive:
My project is divided to several files, where main.cu and hyper.cu are the ones that currently are cuda modified, the rest are plain c files.
Here is my problem:
15:24:58 , pattakosn #_ for i in `ls *.cu`;do nvcc -c $i;done
main.cu(59): warning: variable "filename" was declared but never referenced
15:25:17 , pattakosn #_ for i in `ls *.c`;do nvcc -c $i;done
15:25:43 , pattakosn #_ nvcc *.o -lm
main.o: In function `main':
tmpxft_000078fa_00000000-1_main.cudafe1.cpp:(.text+0x29a): undefined reference to `read_bin(double*, char*, int, int)'
main.o:(.data+0x0): undefined reference to `hyperbolic(double*, float*)'
main.o:(.data+0x8): undefined reference to `inverse_hyperbolic(double*, float*)'
main.o:(.data+0x10): undefined reference to `inverse_sigmoid(double*, float*)'
main.o:(.data+0x18): undefined reference to `sigmoid(double*, float*)'
main.o:(.data+0x20): undefined reference to `tanmichelsen(double*, float*)'
main.o:(.data+0x28): undefined reference to `michelsen(double*, float*)'
main.o:(.data+0x30): undefined reference to `leib_neo(double*, float*)'
main.o:(.data+0x38): undefined reference to `johns(double*, float*)'
collect2: ld returned 1 exit status
I also tried linking using g++ or explicitely using absolute paths but the result was the same:
15:38:08 , pattakosn #_ for i in `ls *.cu`;do nvcc -c $i --machine 64 --ptxas-options=-v -O3 -I. -I/opt/cuda/common/inc -DUNIX ;done
15:38:27 , pattakosn@iraklis,cuda #_ g++ -m64 -O3 *.o -o test1 -lm -L/opt/cuda/lib64 -lcudart
tmpxft_00007a5f_00000000-1_main.cudafe1.cpp:(.text+0xc0b): undefined reference to `read_bin(double*, char*, int, int)'
tmpxft_00007a5f_00000000-1_main.cudafe1.cpp:(.text+0xca2): undefined reference to `hyperbolic(double*, float*)'
main.o: In function `__deviceText_$sm_10$':
tmpxft_00007a5f_00000000-1_main.cudafe1.cpp:(.rodata+0xb00): undefined reference to `hyperbolic(double*, float*)'
tmpxft_00007a5f_00000000-1_main.cudafe1.cpp:(.rodata+0xb08): undefined reference to `inverse_hyperbolic(double*, float*)'
tmpxft_00007a5f_00000000-1_main.cudafe1.cpp:(.rodata+0xb10): undefined reference to `inverse_sigmoid(double*, float*)'
tmpxft_00007a5f_00000000-1_main.cudafe1.cpp:(.rodata+0xb18): undefined reference to `sigmoid(double*, float*)'
tmpxft_00007a5f_00000000-1_main.cudafe1.cpp:(.rodata+0xb20): undefined reference to `tanmichelsen(double*, float*)'
tmpxft_00007a5f_00000000-1_main.cudafe1.cpp:(.rodata+0xb28): undefined reference to `michelsen(double*, float*)'
tmpxft_00007a5f_00000000-1_main.cudafe1.cpp:(.rodata+0xb30): undefined reference to `leib_neo(double*, float*)'
tmpxft_00007a5f_00000000-1_main.cudafe1.cpp:(.rodata+0xb38): undefined reference to `johns(double*, float*)'
If I rename all files to .cu then everything works.
Specs:
ubuntu 10.04 x86_64 server, CUDA Driver Version = 3.20, CUDA Runtime Version = 3.20, driver 260.19.26
cuda sdk and everything else I have tried compiles/runs smoothly.
I have already read cuda compiler driver, searched the forum and googled about it but I still can not get it.
Can someone please explain these to me ?
