Understanding #include in Nsight
I have a project with many source files (examples: main.cu, a.cu, b.cu, c.cu, d.cu). Each with functions and kernel calls (global and device).
In a header (cpu.h) all the structures to be used in the host side.
Another header (gpu.h) all the structures to be used in the device side.
  1. If I call kernel functions from main.cu, declared in a.cu. How do I #include those kernel functions declared in a.cu to use in main.cu, without doing the not recommended #include “a.cu”?
  2. Do I create a header a.h with forward declaration of the kernel function in a.cu? Example:
    extern “C” void functionA(type);
Where can I find some examples?
I mention Nsight Eclipse because I am having lots of trouble with it and multiple sources.
mrei, I replied on Stackoverflow (I saw your question there first and copying my reply here would require me redoing the formatting).
Link: linux - How to include several source files in Nsight Eclipse? - Stack Overflow
Does this answer your question?
I commented on Stackoverflow the parts I don’t get. Thanks a lot!
