1)
GPIO.setup(channel, GPIO.OUT, initial=GPIO.HIGH)
GPIO.setup(channel, GPIO.OUT)
GPIO.output(channel, GPIO.HIGH) #state = GPIO.HIGH
To set initial
is the same as to run directly GPIO.ouput
function with the same state
. Do I understand it right? Or do the state: initial
more?
2)
From github:
7. Clean up
At the end of the program, it is good to clean up the channels so that all pins are set in their default state. To clean up all channels used, call:
GPIO.cleanup()
Here is the talk of “default state”. This means the pinmux default state, not the initial
state from GPIO.setup
function. Do I understand it right?
3)
GPIO.setmode() not working? Why?
# GPIO library
import Jetson.GPIO as GPIO
# define Pins
LED4 = 7
LED8 = 12
LED3 = 13
IN3 = 15
LED7 = 18
IN2 = 19
IN1 = 21
IN7 = 22
LED2 = 23
IN6 = 24
LED1 = 29
IN5 = 32
IN4 = 33
LED5 = 35
LED6 = 38
IN8 = 40
# Pin Definition
LED_IN = [IN1,IN2,IN3,IN4,IN5,IN6,IN7,IN8]
# Warning disable
#GPIO.setwarnings(False)
# Set up the GPIO channel
GPIO.setmode(GPIO.BOARD)
GPIO.setup(LED_IN, GPIO.OUT, initial=GPIO.LOW)
# ON the LEDs
for led_pin in LED_IN:
GPIO.output(led_pin, GPIO.HIGH)
GPIO.cleanup()
print("all LED are ON")
ERROR:
File "/home/nvidia/Desktop/error_ON_gpiodemo_forum.py", line 34, in <module>
File "/home/nvidia/.local/lib/python3.9/site-packages/Jetson/GPIO/gpio.py", line 444, in output
ch_infos = _channels_to_infos(channels, need_gpio=True)
File "/home/nvidia/.local/lib/python3.9/site-packages/Jetson/GPIO/gpio.py", line 119, in _channels_to_infos
_validate_mode_set()
File "/home/nvidia/.local/lib/python3.9/site-packages/Jetson/GPIO/gpio.py", line 83, in _validate_mode_set
raise RuntimeError("Please set pin numbering mode using "
RuntimeError: Please set pin numbering mode using GPIO.setmode(GPIO.BOARD), GPIO.setmode(GPIO.BCM), GPIO.setmode(GPIO.TEGRA_SOC) or GPIO.setmode(GPIO.CVM)
Why does this code give the following error?
