Originally published at: Understanding Memory Management on Hardware-Coherent Platforms | NVIDIA Technical Blog
If you’re an application developer or a cluster administrator, you’ve likely seen how non-uniform memory access (NUMA) can impact system performance. When an application is not fully NUMA-aware, performance can be inconsistent and unpredictable. Because of these challenges, NVIDIA released the Coherent Driver-based Memory Management (CDMM) mode for the NVIDIA driver for platforms that are…
Hi, it looks like the white paper link (https://nvda.ws/4nDHMTt) resolves to https://nvdam.widen.net/s/hqrttsq266/cuda-whitepaper--cdmm-pdf?ncid=ref-qr-326236-vt33, where the page says “PREVIEW NOT AVAILABLE.” Could you please verify the link or share an updated URL? Thank you!
Update (Oct 21): I can access the file now.
