the Programming Guide 1.0 mentions on page 42 that double types will be demoted to float by default, if there is no native double support.
I have tried this in my kernel using a typedef, but it didn’t work as expected.
The typedef is declared in the header “config.h”
typedef double ColorType;
typedef unsigned char ImgType;
The kernel gets a ColorType passed by parameter
#include "config.h"
__global__ void simpleKernel(ImgType* image, int width,ColorType a)
unsigned int x = blockIdx.x*blockDim.x + threadIdx.x;
unsigned int y = blockIdx.y*blockDim.y + threadIdx.y;
image[(x+y*width)*3] = (ImgType)((a+a)*x);
image[(x+y*width)*3+1] = (ImgType)((a*2.0)*y);
image[(x+y*width)*3+2] = 0;
and will be called like this:
ColorType a = 0.1;
dim3 block(8, 8, 1);
dim3 grid(ImageWidth/8, ImageHeight/8, 1);
simpleKernel<<<grid,block>>>(imageDevice,ImageWidth,a);
I get different results when switching the ColorType typedef from double to float. Is this a bug?
I’m using CUDA 1.0 on Ubuntu Linux 7.04 with a 8600GT 256MB card.
I’ve attached my code, it would be nice if anybody could test it.
doubleTest.tar.gz (2.16 KB)
